Like Tree66Likes
 Old 04-19-2012, 01:26 AM   #81
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Really interested in dyno and overlay results.
k.
PS, terrible with the Gimp.
Scoobs and rfinkle2 like this.
The Following 6 Users Say Thank You to Enki For This Useful Post:
BigRedSpecial (04-19-2012), Monotonous ONE (04-27-2012), mzr0818 (04-19-2012), rfinkle2 (04-19-2012), Scoobs (04-19-2012), Ziggo (04-19-2012)
 Old 04-19-2012, 07:47 AM   #82
Ziggo's Avatar
Posts: 3,843   (View Stats)
It was my understanding that the maps cover the full rated RPM window the turbo was designed for to use in continuous operation.
Under this definition the 2871 is not intended to rev over the 127k RPM limit on the compressor map and the 2867 is rated to go to 150k RPM due to the forged wheel coupled with smaller diameter or perhaps due to other rotating assembly limits (bearing loading limits and etc).
Of course, one can always overspin either to squeeze some more flow out at the risk of longevity.
Please let me know if you have different information.
For whatever reason all the gtx maps go to 150k rpm. I have heard it a couple ways, Some have it mapped out to the longevity limits, other just map to reasonable efficiency limits under the assumption that, yes the compressor may survive higher rpms, but the efficiency is so low, why bother. Because all the gtx maps are spun out this high, I suspect it is just an efficiency thing.
The critical factors probably have less to do with the smaller diameter and forged wheel, and more to do with the bearings and how precisely the wheels are balanced. Also I bet the gtx wheel is simply more efficient at higher so it makes sense to map it out further.
IMO, a gtx and a gt2871R (ball bearing) should be mechanically able to spin to the same rpms. However when talking about the gt2871 journal bearing unit in my BNR, I bet 127k vs 150k is more reasonable. In the journal bearing, when you exceed the rated rpms, you can push past the shear strength of the oil bearing and get contact between the shaft and the guide, eventually you will wear it down, get shaft play, and oil leaking past it (sound familiar?) ball bearings are much less sensitive to axial loads, probably the leading reliability factor for the ball bearings is temperature.
Ask Me About My:
The Following 9 Users Say Thank You to Ziggo For This Useful Post:
atvfreek (04-30-2012), BigjohnB20 (04-19-2012), cld12pk2go (04-19-2012), Easter Bunny (06-26-2012), FistPump20fo7 (06-26-2012), Lex (04-25-2012), Monotonous ONE (04-28-2012), rfinkle2 (04-25-2012), Scoobs (04-19-2012)
 Old 04-25-2012, 09:05 AM   #83
Cataphract_40's Avatar
Posts: 1,730   (View Stats)
Groans: 30
Still nothing on your website about this kit...
2008 GT MS3 - 307 WHP/338 WTQ
1995 Miata
The Following 2 Users Say Thank You to Cataphract_40 For This Useful Post:
EdgeAutosport.com (04-25-2012), leon78 (04-25-2012)
 Old 04-25-2012, 09:19 AM   #84
We have a list on what needs to be added to the site. Sorry about the delay we will work on that today
atvfreek (04-30-2012), blkspeed307 (04-25-2012), breakfstincluded (04-25-2012), Cataphract_40 (04-25-2012), rfinkle2 (04-25-2012)
 Old 04-26-2012, 08:50 PM   #85
Groans: 30
Dunno if anyone has mentioned this yet. It's an alternative to the ATP turbo inlet. 3" and very nice quality.
HTP 3" Mazdaspeed Turbo Inlet (Polished) - Hi-Tuned Performance Products
1995 Miata
 Old 04-27-2012, 08:59 AM   #86
Just recieved my gtx2867 yesterday. I'm looking forward to being able to run @ least 20 psi to redline.
Thank you JP and Eric for excellent customer service.
The Following 17 Users Say Thank You to rfinkle2 For This Useful Post:
08.5MS3 (04-27-2012), atvfreek (04-29-2012), AZSPEED3 (05-01-2012), BigjohnB20 (04-27-2012), breakfstincluded (01-06-2014), Broxer (04-27-2012), bstover17 (01-05-2014), charlesfist (04-27-2012), cld12pk2go (04-29-2012), EdgeAutosport.com (04-27-2012), Fobio (04-27-2012), JasonMzdSpd3 (04-27-2012), Monotonous ONE (04-27-2012), Scoobs (04-30-2012), skeurton (04-27-2012), wolly6973 (04-28-2012), Ziggo (04-27-2012)
 Old 04-27-2012, 09:14 AM   #87
skeurton's Avatar
Posts: 745   (View Stats)
skeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the world
Nice! Let's see some pics of that bad boy!
You get an exhaust mani, Rob?
2011 MAZDASPEED 3
BNR: 352 hp / 342 ft-lbs
K04: 296 hp / 343 ft-lbs
BNR Supercars Stage 3 Turbo Aquamist HFS-4 Alcohol Injection Cobb Tuning AccesPORT • AccessTUNER Race KMD Tuning HPFP Internals v2.2 NGK 6510 Spark Plugs Bosch 3-Bar MAP Sensor Saikou Michi Oil Catch Can Grimmspeed 3-Port EBCS JBR TIGs • EGR Delete • Rear Sway Bar • RMM • PSMM • TMM HTP 3" TIP • Battery Tray SURE Motorsports 3" MAF • Shortcut • CounterShift • Anchors • AGS 621g Shift Knob Ultimate Racing Catted Downpipe • Test Pipe • Cat-Back Exhaust CP-e FMIC • SAFEseals Turbosmart Dual Port BOV PTP Injector Seal Studs EBC RedStuff Brake Pads • UPR Rotors Swift Spec R Springs Bilstein B8 Shocks SPC Performance Rear Camber Arms Tanabe Sustec Strut Tower Brace TWM Performance Full Replacement Shifter 5zïgen ZR+ 18x7.5 (Ceramic Bronze) Nitto NeoGen Tires Rally Armor Mud Flaps Morimoto 6000K HID Replacement Bulbs DDM Tuning 3000K HID Fog Lights Headlight Armor Yellow Fog Overlays Qualir QL-MZD723 Headunit Glowshift Mechanical Boost Gauge • A-Pillar Gauge Pod Aeroforce Dual Interceptor Gauges
skeurton is offline   Reply With Quote
The Following 2 Users Say Thank You to skeurton For This Useful Post:
rfinkle2 (04-27-2012), Scoobs (04-30-2012)
 Old 04-27-2012, 09:17 AM   #88
I am not a big picture guy (either me or my camera sucks. HAHA), but will snap a couple for you guys.
I know I should get an exhaust manifold, but it wasn't on my list right now.
If I was going to buy one, I think I would go Full race though.
 Old 04-27-2012, 09:25 AM   #89
08.5MS3's Avatar
Posts: 3,840   (View Stats)
Groans: 89
May 5, I better see it!
 Old 04-27-2012, 09:27 AM   #90
It'll be there, maybe not installed, but it'll be there. LOL
 Old 04-27-2012, 09:29 AM   #91
08.5MS3's Avatar
Groans: 89
I'd rather see it not installed!
 Old 04-27-2012, 11:38 AM   #92
JasonMzdSpd3's Avatar
Posts: 253   (View Stats)
JasonMzdSpd3 is the leader of the worldJasonMzdSpd3 is the leader of the worldJasonMzdSpd3 is the leader of the worldJasonMzdSpd3 is the leader of the worldJasonMzdSpd3 is the leader of the worldJasonMzdSpd3 is the leader of the worldJasonMzdSpd3 is the leader of the worldJasonMzdSpd3 is the leader of the worldJasonMzdSpd3 is the leader of the worldJasonMzdSpd3 is the leader of the worldJasonMzdSpd3 is the leader of the world
Groaned at 10 Times in 9 Posts
Nice bruddah. I get my GTX2867r on Monday! I can't wait! I agree both JP and Eric are the shiz for sure.
Thanks EdgeAutosport for the deal.
Sent from Epic 4G via tap & touch 2.
2012 Speed3 Tech~ Liquid Silver~
Mods - AP, CP-E Xcel 3.25 Maf Intake, ATP Catless DP, CP-E Triton 3" SS CBE, AT Internals, NGK 1 step colder plugs, TurboSmart BPV, GTX 2867r, 3 bar map, GS EBCS, HTP 3" TIP, JBR stage 2 OCC, CP-E Delta core FMIC, JBR Trilogy, JBR Solid Shifter Bushings
Ordered Mods -
Planned mods -safe seals. SSP oil return, CObb V3, Denso step colder plugs. My car hates NGK for some reason.
Mods here but not installed-
Purple Drank tuned!
Tinted 15% all the way around, 5% hatch.
I think the internet needs more Cowbell!
JasonMzdSpd3 is offline   Reply With Quote
The Following User Says Thank You to JasonMzdSpd3 For This Useful Post:
 Old 04-27-2012, 11:45 AM   #93
Someone post pics of this bad boy! @rfinkle2
 Old 04-27-2012, 11:47 AM   #94
I will when I get home, although it is relatively small compared to the pics posted of the 30 framed turbos.
 Old 04-27-2012, 12:01 PM   #95
But it has the same punch as the big boys. 11's are going to be very achievable with that kind of power band and spool time.
Scoobs, rfinkle2 and BigRedSpecial like this.
atvfreek (04-29-2012), AZSPEED3 (05-01-2012), Broxer (04-27-2012), Scoobs (04-30-2012)
 Old 04-27-2012, 12:11 PM   #96
I totally agree. I have a plan and it doesn't exceed 350 whp, but all in usuable form.
I'm pretty excited, although I do need to piece things together.
I posted in the Full Race thread.
Skeurton has me looking @ exhaust manis now. LOL.
skeurton likes this.
Monotonous ONE (04-28-2012), skeurton (04-27-2012)
 Old 04-27-2012, 12:13 PM   #97
BigRedSpecial's Avatar
Posts: 1,436   (View Stats)
Groans: 56
Does anyone know what the spool time is on these yet? Is it the same ~300 later than the K04 as the 2871?
Needed: Driver mod
 Old 04-27-2012, 12:19 PM   #98
m4tic's Avatar
Posts: 4,928   (View Stats)
No you're gonna buy mine.
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
 Old 04-27-2012, 12:26 PM   #99
No EWG for me, but I appreciate your offer, as well as your help with Windows yesterday.
 Old 04-27-2012, 12:54 PM   #100
Ziggo's Avatar
Nobody knows for sure yet, but it should be quicker than the 2871 with an equivalent hotside.
Zigatapatalka
Ask Me About My:
BigRedSpecial (04-27-2012)
 Old 04-27-2012, 01:01 PM   #101
Groans: 56
Nice! I also realize that the ~300 later number I quoted would depend on A/R, that's just the number I've always heard quoted.
Needed: Driver mod
 Old 04-27-2012, 01:08 PM   #102
Broxer's Avatar
Posts: 875   (View Stats)
Broxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the world
Groans: 90
Hells ya man! You must do a build thread! I want impressions and data ASAP! Wish you lived closer, I'd love to help you out with the install.
2012 Triumph Street Triple
SOLD -- 2010 Velocity Mica Red MS3
ATP GTX3071r - Cobb AP(Freek Permed) - CNT Catted DP - UR CBE - DO Stage 2 WMI(80/20) - cp-e TMIC - cp-e xcelXL - cp-e invicid inlet - Grimmspeed MBC - KMD v2.2 hpfp internals - Bosch 3bar MAP - H&R Springs - DDM 6k Raptor Kit - ITV22's - Forge v2 BPV - 225/40/18 Nitto Neogens - SURE RMM
Broxer is offline   Reply With Quote
The Following 3 Users Say Thank You to Broxer For This Useful Post:
atvfreek (04-29-2012), EdgeAutosport.com (04-27-2012), rfinkle2 (04-27-2012)
 Old 04-27-2012, 02:18 PM   #103
I wish you lived closer too! (no homo). I will definitely give my impessions of the turbo and take some pictures.
I have been trolling your thread, as well as cld12pk2go, ziggo, and skeurton's thread for helpful tips.
I think I may as well get a manifold while everything is going to be apart.
Broxer (04-27-2012), EdgeAutosport.com (04-27-2012), skeurton (04-27-2012)
 Old 04-27-2012, 02:36 PM   #104
skeurton's Avatar
Glad to hear you've put logical and budgetary thinking aside. When it comes to modding, it's best to not think at all.
2011 MAZDASPEED 3
 Old 04-27-2012, 02:36 PM   #105
BigjohnB20's Avatar
Posts: 779   (View Stats)
Will definitely be looking forward to your Pics/install thread/impressions. How long do you think it will be before you get this on the car? Sounds like you might still be collecting some parts (Mani, 3in MAF) so probably not tomorrow, lol.
I am curious as to why you ended up with this turbo vs. the BNR or 3071? All 3 of these so far seem to be a pretty good fit for our motors, each with their own pros and cons. (I realize no one has probably ran the gtx2867 yet, but sounds like it should be comparable to the 2871 only better.) Personally I think the BNR S3 beats this turbo FOR ME based almost solely on the price comparison. Seems like either one shoudl give you an easy 350+ with the BNR allowing use of stock/aftermarket parts I already have and costs a little less to begin with.
Either way, I think you should see really good results and can't wait to see what you are able to do with this.
2006 BCM MS6 GT
CS SRI/TIP
Jbarone SSP/bushings
cp-e RMM, TMIC, Stiff Diff
AP
KMD V2.whatever
Ebay Catless DP
Grom Ipod
 Old 04-27-2012, 02:47 PM   #106
Broxer's Avatar
Groans: 90
Dual ball bearing and billet compressor wheel. Faster spool and more flow for future power needs. Not to mention journal bearings wear faster, but they can be rebuilt so I guess its a matter of preference.
The Following 2 Users Say Thank You to Broxer For This Useful Post:
BigjohnB20 (04-27-2012), EdgeAutosport.com (04-27-2012)
 Old 04-27-2012, 02:58 PM   #107
@BigjohnB20 Remember you are going to be really hard pressed to make 350awhp on a bnr3 in an ms6. You are really going to have to run that turbo hard to make that power imo
 Old 04-27-2012, 03:19 PM   #108
BigjohnB20's Avatar
yea, I always forget we are at a disadvantage power wise with the AWD. Of course there are some benefits that come with it as well, lol.
I'm so used to seeing all these 3's putting up great numbers lately and have to remember I can't directly compare to them. I was making the same mistake pouring over the VD thread and wondering why the hell my car wasn't putting up the same numbers as a lot of people in there.
I do have easy access to E85 though and like to think I could squeeze 350ish out of a BNR without gettign too crazy. Either way, I don't even have my DP installed that I bought 6 months ago so its not like I have to worry about a turbo upgrade yet. I just like to live vicariously though all you guys and think one day I will do it.
EdgeAutosport.com likes this.
2006 BCM MS6 GT
CS SRI/TIP
AP
KMD V2.whatever
Ebay Catless DP
Grom Ipod
The Following User Says Thank You to BigjohnB20 For This Useful Post:
 Old 04-27-2012, 03:35 PM   #109
Ziggo's Avatar
350 with a touch of e85 is be very do-able. Yes you have to run the turbo to near its limits to do it, but its not like stressing the k04 running 18psi. The operating point at 22psi at redline is still on the compressor map.
Ask Me About My:
 Old 04-27-2012, 03:45 PM   #110
Groans: 30
Less talk moar turbo pron
1995 Miata
The Following 5 Users Say Thank You to Cataphract_40 For This Useful Post:
BigjohnB20 (04-27-2012), Broxer (04-27-2012), Deldran (04-28-2012), Easter Bunny (05-02-2012), Eighty8 (04-29-2012)
 Old 04-28-2012, 09:06 AM   #111
7mileshome's Avatar
Posts: 350   (View Stats)
7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world
I had 383/397 on my GT28(@24 psi, that was maxed out), based on what are you saying the GTX2867 will be maxed out at 350 hp? I take into account different set-up, of course, but I would like to Understand what you mean by this.
Just by reading the compressor map, it is still a 0.6 a/r, and with the aluminum blade it should be
Good for 43-44 lbs/min. Anyways, I plan on pushing this turbo to the limit, so we shall see.
2012 Mazdaspeed3 LSM
Should have gotten a speed6
2008 Mazdaspeed3 GT Black Mica [sold]
Built motor, Etc.
383 hp 401 tq GTX2867R @ 25 psi
7mileshome is offline   Reply With Quote
 Old 04-28-2012, 09:59 AM   #112
Ziggo's Avatar
I was referring to the BNR.
Ask Me About My:
7mileshome (04-28-2012), breakfstincluded (01-06-2014)
 Old 04-28-2012, 09:59 AM   #113
7mileshome's Avatar
Not sure if it was just me, but the coupler ATP sent was a 45 Deg, 2" to 2"
Most intercooler kits have 2.25" piping so I needed this..
45 (or 90 deg) 2" to 2.25" coupler (Blue is from ATP)
Not to mention the compressor outlet is farther down since the compressor housing is
smaller than the GT2871. It seems like ATP wielded the same outlet as the GT2871. So a longer coupler is generally required anyways.
Built motor, Etc.
The Following User Says Thank You to 7mileshome For This Useful Post:
Cataphract_40 (04-28-2012)
 Old 04-28-2012, 06:17 PM   #114
@rfinkle2 I will post of up some pics as well on Monday when mine finally arrives.. I am very curious to see how this spools as well. I went the simple cheap route... Not sure there is a way with these cars though lol.. But I might put it in this week if the weather is good enough for me to ride..
Ordered Mods -
Purple Drank tuned!
 Old 04-29-2012, 05:04 AM   #115
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
While not absolutely required, it is highly recommended to get the mani when doing the turbo swap.
Saves mucho work later and helps balance the backpressure/EGT between the cylinders.
atvfreek (04-29-2012), rfinkle2 (04-29-2012)
 Old 04-29-2012, 07:48 AM   #116
Thanks, as always. Looking @ the Full race now, but in the air per coating. I like the black coating, but expect egt's >1600.
Looks as if function>form on this one.
 Old 04-29-2012, 08:13 AM   #117
Eth/Meth Junkie
cld12pk2go's Avatar
Are you going to be measuring EGT's?
During the turbo swap is the perfect time to tap the Ex mani...
I would be very interested in seeing how much more choked up the smaller hot side is as indicated by the EGT...
 Old 04-30-2012, 07:07 AM   #118
I was contemplating it. I'm going to talk to Eric about having Full Race weld a bung in for me.
cld12pk2go (04-30-2012), EdgeAutosport.com (04-30-2012), skeurton (04-30-2012)
 Old 04-30-2012, 07:26 AM   #119
skeurton's Avatar
Don't forget a good EGT gauge and gauge pod....
2011 MAZDASPEED 3
The Following 9 Users Say Thank You to skeurton For This Useful Post:
08.5MS3 (04-30-2012), atvfreek (04-30-2012), AZSPEED3 (05-01-2012), BigRedSpecial (04-30-2012), cld12pk2go (04-30-2012), EdgeAutosport.com (04-30-2012), JacksonMS30 (04-30-2012), JasonMzdSpd3 (04-30-2012), TriO (04-30-2012)
 Old 04-30-2012, 09:16 AM   #120
This can be done no problem Just let me know what runner and where
rfinkle2 (04-30-2012)
Page generated in 0.63174 seconds with 33 queries
