Like Tree5Likes
 Old 01-24-2014, 04:56 PM   #1
Default HTP Intakes at EdgeAutosport!
With the Mazdaspeed 3 and 6, turbo upgrades are becoming pretty common. And when upgrading your turbo, running a larger intake will help you get the most out of that upgrade. Not only can it help you get the most out of your upgraded turbo but it can also help you get more out of your factory K04.
HTP Intakes are a smooth one piece design that help to improve flow to the turbo with minimal restrictions. The optional air straightener will smooth out the air moving past the MAF sensor to make tuning more consistent and predictable.
There are several sizes available for you to choose from depending on how much power you are looking to go for.
The HTP 3" intake system is a good choice for stock turbo and smaller turbo upgrades like the BNR or the ATPGT/GTX28's and even the GT3071.
It is $260 for a complete intake system from the filter to the turbo and negates the need to buy a separate turbo inlet pipe.
The HTP 3.5" Intake System would be a good choice for anything GTX3071 or bigger.
It is $275 and it too is a complete intake system with no need for a turbo inlet pipe.
These intakes also come with the option to add a smaller 51r battery tray. The 3" intake system will fit with the stock battery tray and ECU with only the need to remove the lower ECU cover for proper fitment. The 3.5" intake system however does require significant modification to the factory battery box as well as ECU relocation. If you get it with the battery tray you would need to purchase a 51r battery but you still have a cleanly mounted battery with a nice ECU mount as well. This is recommended to be included with the 3.5" intake.
The 51r Battery Tray is $145 by itself.
The HTP 3.0" Intake system with 51r Battery Tray is $399
The HTP 3.5" Intake System with 51r Battery Tray is $414
Another thing to think about for you guys that are looking to start modding with an intake. If you know you are going to be wanting to go with a bigger turbo later on, you can install one of these intakes on the stock turbo and then when you upgrade, all you have to get is a different coupler and you are ready to go. Keep in mind that when going with a larger diameter intake, you will need to tune for it to compensate for the extra airflow.
We have these intakes in stock and ready to ship! Let me know if you have any questions and I'll be happy to help!!
The Following 8 Users Say Thank You to EdgeAutosport.com For This Useful Post:
Fail_6 (01-24-2014), mac_dre (01-24-2014), Micha (02-11-2014), PapaSmurf (01-24-2014), Pu Manchu (01-24-2014), smoogs12 (01-24-2014), SpeedRebirth (01-26-2014), timmcc02 (01-24-2014)
 Old 01-24-2014, 05:59 PM   #2
kbz0129's Avatar
Posts: 986   (View Stats)
Niceeee. Looks like every penny of my refund is now going to edge..
2010 Ms3 PD Tuned
2006 Ms6 GT-Stock
EdgeAutosport.com (01-25-2014)
 Old 01-24-2014, 07:06 PM   #3
happykat's Avatar
Posts: 171   (View Stats)
happykat is the leader of the worldhappykat is the leader of the worldhappykat is the leader of the worldhappykat is the leader of the worldhappykat is the leader of the worldhappykat is the leader of the worldhappykat is the leader of the worldhappykat is the leader of the worldhappykat is the leader of the worldhappykat is the leader of the worldhappykat is the leader of the world
dam it, i just bought some stuff from you guys...
JBR Stage II SRI//JBR 88 duro rmm//JBR rear sway bar//AP//ATI//Cobb BPV// Ebay special test pipe// Rally Armor mud flaps
happykat is offline   Reply With Quote
The Following User Says Thank You to happykat For This Useful Post:
 Old 01-24-2014, 08:38 PM   #4
Darthspeed3's Avatar
Posts: 292   (View Stats)
Darthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the world
Just bought a 3.5 from you guys!!!! Cant wait to install it. I was going to wait and try to avoid the battery box but I broke down and bought one direct from HTP both are top notch, cant wait to do the install. note to self....buy new battery.
Gen1 - Built and sleeved block, some headwork, Gen2 6266, FJ turbo kit, JMF with PI.
Darthspeed3 is offline   Reply With Quote
The Following User Says Thank You to Darthspeed3 For This Useful Post:
 Old 01-24-2014, 10:55 PM   #5
alextheguineapig's Avatar
Posts: 827   (View Stats)
Are these going to be on sale when you guys start your tax return sale? I have been eying one of these, but can't quite justify the price just yet. If even a little bit on sale I could sell my corksport kit and upgrade to this kit! You say it fits with the stock battery box, is that gen1/2 specific? Or does it work on both models. I know the boxes have a few differences between them.
Current
SOLD!
2008 Sunlight Silver MS3:
BNR: S3 V2
Cobb: V3 AccessPort
Damond Motorsports: RMM
Eibach: Prokit
JBR: Rear Sway Bar
Koni: Yellows
MAC: 3-Port EBCS
 Old 01-25-2014, 10:50 AM   #6
These will be included in the tax sale and you won't regret switching to it.
I've personally installed one of these on a Gen2 and the 3" fits with the stock battery box and ECU no problem. To prevent it from rubbing you will have to remove the lower cover for the ECU but the upper ECU cover will still fit in place so you can't tell that anything is different from stock.
 Old 01-25-2014, 11:03 AM   #7
Patty-Wack's Avatar
Posts: 885   (View Stats)
Patty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the world
What's these intakes made out of? Doesn't look like silicon? How's the sound from these bad boys? The ricer in me wants to know..
Black 2010 MS3 - Non-Tech 281whp/310tq on 92 (v-dyno w/ 1.01 correction)
Corksport 3" Intake l AP v2 l Stage-2 CP-E RMM l Autotech Internals l DDM 35w 5k Hids (Low Beam) l JBR Stage 2 Short Shift Plate Kit w/ Bushings l JBR big Fing Knob l Corksport TMIC l Forge BPV v2 l Stratified E-Tune l Stratified 3-port (Running 2-port) l NGK 1 step Colder plugs l Corksport Test Pipe l DDM 35w 3k Hids (Fogs)
Waiting to install... Prosport Boost Gauge w/ vent pod
Patty-Wack is offline   Reply With Quote
 Old 01-25-2014, 11:09 AM   #8
MZRSPEED's Avatar
Posts: 550   (View Stats)
They are aluminum, sound great, and they will powder coat different colors if you ask. I've ran the stock size inlet pipe, also the 3" full intake, and I just ordered the 3.5" powder coated white. Top notch product for sure.
The Following User Says Thank You to MZRSPEED For This Useful Post:
EdgeAutosport.com (01-27-2014)
 Old 01-25-2014, 11:11 AM   #9
Patty-Wack's Avatar
Thanks for the info! Sounds like I will be spending the tax check on one..
The Following User Says Thank You to Patty-Wack For This Useful Post:
MZRSPEED (01-25-2014)
 Old 01-26-2014, 09:00 AM   #10
Zoom66's Avatar
Posts: 281   (View Stats)
I got the 3" installed with my GTX2867r and it is a sweet setup. I have the JBR small battery box with a 51r Optima Yellow Battery. The sound of this combo is pure sex at spool time..
The Following User Says Thank You to Zoom66 For This Useful Post:
MZRSPEED (01-26-2014)
 Old 01-26-2014, 02:57 PM   #11
kbz0129's Avatar
What size would you guys suggest running with a gtx3071. Don't wanna jack the thread tho lol
2010 Ms3 PD Tuned
2006 Ms6 GT-Stock
 Old 01-26-2014, 05:34 PM   #12
Zoom66's Avatar
I would probably go 3.5" on the 30 and above..
The Following 2 Users Say Thank You to Zoom66 For This Useful Post:
EdgeAutosport.com (01-27-2014), Micha (02-11-2014)
 Old 01-27-2014, 11:12 AM   #13
Like Zoom66 said, 3.5" would be good for the 3071 and above. You don't necessarily need it on the GT3071 but the GTX3071 is capable of quite a bit more flow and anything bigger than that would definitely be worth putting on the 3.5".
 Old 01-29-2014, 01:23 PM   #14
SparkySparks's Avatar
Posts: 1,314   (View Stats)
@EdgeAutosport.com; are you going to have just the battery box by it self or only in the combo?
On Order:
Coming Soon:
DIY Projects:
 Old 01-29-2014, 04:11 PM   #15
We have them by itself, but haven't got it on the website. I'll make sure that goes up tomorrow.
SparkySparks (01-30-2014)
 Old 01-29-2014, 04:19 PM   #16
Thank you, it's on my list for tax return spendage.
On Order:
Coming Soon:
DIY Projects:
EdgeAutosport.com (01-30-2014)
 Old 01-29-2014, 08:12 PM   #17
alfre127's Avatar
Posts: 291   (View Stats)
alfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond repute
Any plans to sell the 4" ver?
GTX3076 EWG // Tial Waste Gate // Sure 3.25 Big Mouth // // JBR Side Motor Mounts // JBR, SS Kit, Corksport RMM Inserts // Cobb Pipping with TRL8 // CNT DP // CNT Cat back // DNP Mani // Autotech HPFP // Rota G-force 18x8.5 // Eibach Pro Kit Springs // Cobb AP, // Auto meter boost and vacuum gauges // AEM A/F gauge // AEM Meth Stage 2 kit // Hella Horns // PTP injector seals // PNP IM // TIGS // EGR Delete // ACT 6 Puck Sprung/Streetlite // Superskaterex 74MM TB //
alfre127 is offline   Reply With Quote
 Old 01-30-2014, 09:04 AM   #18
We do, I need to get that one up on the site as well.
alfre127 (01-31-2014)
 Old 01-30-2014, 09:02 PM   #19
Patty-Wack's Avatar
Any video/audio of this thing? I'm still debating and picky. Afraid it might be too loud or even worse too quite. Ha
Sent from my iPad using Tapatalk - now Free
 Old 01-31-2014, 06:12 AM   #20
MZRSPEED's Avatar
I'll be installing my 3.5 today or tomorrow, I'll get a sound clip for you.
Patty-Wack (01-31-2014)
 Old 01-31-2014, 06:37 AM   #21
I love the way mine sounds, good balance of sound from the HTP 3.5" intake and CNT Catless long DP with stock resonator and muffler still in place.
On Order:
Coming Soon:
DIY Projects:
The Following 2 Users Say Thank You to SparkySparks For This Useful Post:
MZRSPEED (02-06-2014), Patty-Wack (01-31-2014)
 Old 02-06-2014, 10:45 AM   #22
Patty-Wack's Avatar
Were you able to ever get a sound clip? How do you like it? How is the sound during casual driving? I just am concerned of sounding like a wind tunnel on my DD. Under WOT the thing can and should be loud as shit..
 Old 02-06-2014, 10:50 AM   #23
alaskazero's Avatar
Posts: 195   (View Stats)
alaskazero has a reputation beyond reputealaskazero has a reputation beyond reputealaskazero has a reputation beyond reputealaskazero has a reputation beyond reputealaskazero has a reputation beyond reputealaskazero has a reputation beyond reputealaskazero has a reputation beyond reputealaskazero has a reputation beyond reputealaskazero has a reputation beyond reputealaskazero has a reputation beyond reputealaskazero has a reputation beyond repute
Groans: 34
Groaned at 55 Times in 18 Posts
I have the HTP 4" with the battery tray on my gtx3071 sounds so clean adn amazing as well
alaskazero is offline   Reply With Quote
The Following User Says Thank You to alaskazero For This Useful Post:
 Old 02-06-2014, 11:10 AM   #24
MZRSPEED's Avatar
I had had a clip, it was from the inside going part throttle through 1-3rd, my phone couldn't really pick up the noise, it's not loud at all. Wot it sounds like you think it would, nice spool up and bpv swoosh. My 3" was louder.
 Old 02-06-2014, 11:17 AM   #25
Patty-Wack's Avatar
Good to know. You running 3.5" on stock turbo? If so, do you think it's worth it over 3"?
 Old 02-06-2014, 11:19 AM   #26
I can try and get a sound clip for you tonight if I have time to set up my phone so it can hear the intake. You only hear it under boost and depending on how loud you play your music, you might not hear it much at all. Are you wanting a sound clip of just driving or WOT?
On Order:
Coming Soon:
DIY Projects:
 Old 02-06-2014, 11:19 AM   #27
MZRSPEED's Avatar
I went with the 3.5 cause I plan on BT later this year, if it wasn't for that, I woulda went with the 3" again.
ItsNox likes this.
Patty-Wack (02-06-2014)
 Old 02-06-2014, 11:20 AM   #28
One of the first comments I made about the HTP 3.5" intake after I put it on was that the COBB one was louder.
On Order:
Coming Soon:
DIY Projects:
 Old 02-06-2014, 11:21 AM   #29
MZRSPEED's Avatar
I'm running a full cat less down pipe, mated to the stock cat back with resonator, I can barely hear the intake on part throttle over the exhaust.
 Old 02-06-2014, 11:26 AM   #30
I'm also a on full catless down pipe with the stock exhaust, if you find the sweet spot on the throttle you can get mostly intake sucktion sound and only a little exhaust, you can hear it plenty then. But for the most part, windows up and radio on, you don't really hear it till you go WOT.
On Order:
Coming Soon:
DIY Projects:
MZRSPEED (02-06-2014), Patty-Wack (02-06-2014)
 Old 02-06-2014, 11:52 AM   #31
Patty-Wack's Avatar
.. you don't really hear it till you go WOT.
Let's be honest, which is most the time.
 Old 02-10-2014, 08:49 AM   #32
ItsNox's Avatar
Posts: 3,076   (View Stats)
I just installed my 3" HTP intake and am very impressed with the quality of parts. Paired with Edges great customer service and I couldn't be happier with my purchase. Well worth the price.
You don't hear it at all until you're out of vacuum. Then its pure sex
MZRSPEED likes this.
'06 Mazdaspeed 6 GT
- Miltuned
Georgia Motherfucking Nator
 Old 02-10-2014, 09:02 AM   #33
anodizedeeznutz's Avatar
Posts: 2,796   (View Stats)
anodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the world
Do you find the 3 Inch to be loud?
Tapatalkin'
2013 CWP Mazdaspeed3 - SOLD
2014 Mitsubishi Evo X - time for some fun.
anodizedeeznutz is offline   Reply With Quote
The Following User Says Thank You to anodizedeeznutz For This Useful Post:
ItsNox (02-10-2014)
 Old 02-10-2014, 09:13 AM   #34
ItsNox's Avatar
Tapatalkin'
Loud is a relative term, really. Its definitely not quiet but in no way obnoxious. I went from the stock airbox to the 3" and there is a HUGE audible difference. First a real strong suction, then you hear the turbo spool much more clearly, and then the singing of the BPV is perfect. I have a test pipe and it paired very well with the intake. After my experience I wouldn't go with ANY other intake personally.
'06 Mazdaspeed 6 GT
- Miltuned
 Old 02-10-2014, 09:17 AM   #35
I agree that loud is a relative term.
I have a JBR 3 inch awaiting install and am debating swapping it for the aluminum HTP for the reason of being able to buy a simple coupler for a BT application. In all honesty I also love the spool noise and a loud spool noise is a plus in my book.
Tapatalkin'
ItsNox (02-10-2014)
 Old 02-10-2014, 09:21 AM   #36
ItsNox's Avatar
Tapatalkin'
Agreed. I went with the 3" HTP so in the future it would be a simple coupler change to a BNR S3 or BT. Cant go wrong with it. Top notch quality.
'06 Mazdaspeed 6 GT
- Miltuned
The Following 3 Users Say Thank You to ItsNox For This Useful Post:
anodizedeeznutz (02-10-2014), EdgeAutosport.com (02-10-2014), Patty-Wack (02-10-2014)
 Old 02-10-2014, 11:11 AM   #37
The HTP intake does make switching turbos super easy. All it takes is a < $15 coupler...
ItsNox (02-11-2014), Micha (02-11-2014), Patty-Wack (02-10-2014)
 Old 02-10-2014, 11:20 AM   #38
IIRC the JBR WP for OE inlet will fit on a BNR.
Tapatalkin'
 Old 02-10-2014, 03:20 PM   #39
Tapatalkin'
True, but if you are planning to upgrade to a GT turbo you would need to change intakes completely or just couplers if you have an HTP intake.
 Old 02-10-2014, 03:57 PM   #40
Main reason I went HTP over JBR, since JBR went to all silicone before I upgraded.
On Order:
Coming Soon:
DIY Projects:
Micha (02-11-2014)
Intakes Now Available! HTP HTP (Hi-Tuned Performance) 354 10-14-2014 08:21 AM
Intakes finalems3 CorkSport 38 03-29-2013 11:16 PM
Intakes in stock!!! CorkSport CorkSport 3 02-28-2013 10:05 AM
Why CorkSport Intakes? CorkSport CorkSport 0 01-31-2013 12:31 PM
Out of stock intakes!!!!!! Toymachinespeed 2010 MS3 - Turbo Induction 26 07-30-2011 06:34 AM
Page generated in 0.61194 seconds with 32 queries
