| EdgeAutosport.com EdgeAutosport.com is committed to being the best at what we do. High performance aftermarket parts is what we do but not who we are. We operate at the highest level of integrity and honesty, all while bringing you superior products and unmatched customer service and support. We hold ourselves to the highest standards, just like we do for our cars! Let us know how we can help! |
![]() Join Date: Nov 2010 Location: Moore, Oklahoma
Rep Power: 234 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 339
__________________ MS3 traded in after VVT eruption 2013 WRX - no mods and slower |
![]() Join Date: Dec 2009 Location: Eden Prairie, MN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19
| Not Ranked : 0 score Did you replace your endlinks yet? |
| The Following 2 Users Say Thank You to claudio For This Useful Post: | kabobulate (11-23-2012), Raider (11-24-2012) |
| Not Ranked : 0 score ^this swaybar clunk is the endlinks not the sway bar itself
![]() Join Date: Dec 2011 Location: howard, pa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,479
Groans: 46
| Not Ranked : 0 score tighten them down as tight as you can, then another 1/4 turn. mine started clunking about 200 miles after i put it on, and i retightened it and have not had any issues since.
__________________ |
![]() Join Date: Nov 2010 Location: northwest arkansas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,067
Groans: 103
| Not Ranked : 0 score sometimes not so much. i still had the clunk after replacing bushings and endlinks.. then i bought a JBR RSB and my clunk is gone. however, since the OP already replaced the RSB and bushings, @Easter Bunny; is spot on. did anyone else laugh at this sentence?
__________________ 2008 ms3 mit: hypertech tune, pg sri, corksport tip, jbr(80 tmm, 88 rmm, 80 pmm), jbarone bushings + heavy shift knob, diy sts, sure ssp, sensen shocks, jbr rsb, ford transfluid, aura 5 channel amp, jbl gt speakers, 6" bazooka sub, diy mudflaps, DDM 3000k HID fog kit, 6000k lows [SIGPIC][/SIGPIC] Last edited by tddvrrn; 11-23-2012 at 03:24 PM. Reason: MSF Database - Automerged Doublepost |
Groans: 46
__________________ | |
(Thread Starter) | Not Ranked : 0 score Thanks for the input. I was just going by the dealership's diagnosis after a ride in it.
| The Following User Says Thank You to phahengpro For This Useful Post: | tddvrrn (11-23-2012) |
Groans: 103
| Not Ranked : 0 score i just thought it was funny that you said to tighten it down as much as you can, implying that there is no way you'll be able to tighten it any more. then tighten it 1/4 turn more. even though you've tightened it as much as you can.. i know, it's stupid when it is explained, but the original sentence made me chuckle. thanks!
__________________ 2008 ms3 mit: hypertech tune, pg sri, corksport tip, jbr(80 tmm, 88 rmm, 80 pmm), jbarone bushings + heavy shift knob, diy sts, sure ssp, sensen shocks, jbr rsb, ford transfluid, aura 5 channel amp, jbl gt speakers, 6" bazooka sub, diy mudflaps, DDM 3000k HID fog kit, 6000k lows [SIGPIC][/SIGPIC] |
| The Following User Says Thank You to tddvrrn For This Useful Post: | GunGuru727 (11-23-2012) |
Groans: 46
(Thread Starter) | Not Ranked : 0 score I am going to pull the shocks today to see how they look. They don't bounce, but they seem to be bottoming out. Oklahoma roads are really shitty. I will give everything a twist for good measure.
| Banned ![]() Join Date: Jun 2012 Location: Oxford Michigan
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 93
| Not Ranked : 0 score Had the same issue with JBR RSB clunking .Replaced Endlinks same issue after few days clunking back again. My permanent fix was by coincidence when I installed GTSPEC Rear Subframe Reinforcement Panel Part #: GTS-SUS-1429 that took care of it I have been running for a year now with no issues. |
| The Following User Says Thank You to speeda For This Useful Post: | mroclimbr (01-14-2013) |
(Thread Starter) | Not Ranked : 0 score Thanks, I will keep that in mind.
Groans: 63
| Not Ranked : 0 score I've had the JBR rsb on for 6 months or so now, no clunks. I had some squeaks that were taken care of by greasing the bushings, but never a clunk. you really do have to tighten the shit out of the end links.
(Thread Starter) | Not Ranked : 0 score I got down there and cranked them up as tight as I could. I didn't get to the shocks cause I opened up my thumb when I slipped a socket on the bottom nut. I am pretty sure they need to be changed. The ass seems to bottom quite a bit. I think I will go with the endlinks first as that is what many of you are saying, and they are cheaper to replace. I appreciate the advice!!!
(Thread Starter) | Not Ranked : 0 score Front and rear endlink change=no more clunk. Put in some Moogs and fsb bushings and all is well. Thanks for the info!
