Like Tree42Likes
 Old 06-16-2011, 09:16 PM   #41
Soto's Avatar
Posts: 525   (View Stats)
Soto is the leader of the worldSoto is the leader of the worldSoto is the leader of the worldSoto is the leader of the worldSoto is the leader of the worldSoto is the leader of the worldSoto is the leader of the worldSoto is the leader of the worldSoto is the leader of the worldSoto is the leader of the worldSoto is the leader of the world
thats a shit load of parts
make genpu crowd proud.
11' Speed 3
Mods: Stock for now.
Soto is offline   Reply With Quote
The Following User Says Thank You to Soto For This Useful Post:
rfinkle2 (06-17-2011)
 Old 06-16-2011, 09:18 PM   #42
Speed3eak's Avatar
Posts: 2,290   (View Stats)
Groans: 82
Originally Posted by cpolly69 View Post
in for fail
1. cpe core is too small for that turbo
2. even the best port jobs still wind up with creep on that turbo w/ iwg on this car
3. where's the rest of what u need to push more cyl pressure? injector seals? rv upgrade?
oh well guess all that will be covered in the 6k labor.... how much was spent on the brianstorming for the name? 1k?
Damn, you could cut the hate with a knife in here.
1.) New cp-e core is massive - dimensions are 24” x 9.5” by 3.25”, what size would you say someone would need for a stock-flange 3071 (out of curiosity)?
2.) What about driver311? 801ms3 (or something similar)? They're both running IWG 3071 bolt-on turbos and seem to be having success with them - do you have links to the guys with port jobs with uncontrollable boost creep? Not meant to be an attack or anything, I just was interested in the proposition of a 3071 with IWG and would like to read as much as I can on it.
3.) This is true about the injector seals, wasn't aware about the inadequacy of the rail valve. Are you speaking of the high pressure rail valve that silverdemon, jumpingjackson and others are running? I wasn't aware that you needed an upgraded rail valve if you're only going to be requesting stock pressure (~1650-1800 psi) - do you have to request higher pressure for big turbos (1900 psi +)?
If $6k includes a PnP job for the IM and Head, I partially understand it. Then again, that is a ton of $$$ just to have anything installed. Idk, I'd say go for it if you have the money to spend.
I hope this guy does hit 400whp but I doubt it'll happen on the stock ex-mani and without some PnP work, and without WMI. But if you have 32k to spend on a car and you don't want to wrench it yourself, I don't see why a BT ms3 like this is a bad proposition. I'm sure he'll have some kinks to work out, but that's true of any big turbo build.
08.5MS3 likes this.
The Following 8 Users Say Thank You to Speed3eak For This Useful Post:
08.5MS3 (06-16-2011), 16-driver (06-17-2011), Ckmazdaspeed3 (06-17-2011), dizzydtrain (06-16-2011), rfinkle2 (06-17-2011), ScarMS3 (06-17-2011), SLOWHATCH (06-17-2011), Special--k (06-17-2011)
 Old 06-16-2011, 09:20 PM   #43
Fatguy729's Avatar
Posts: 1,685   (View Stats)
Groans: 82
I can't believe this. Of all the crazy shit I've seen on Msf, including sfw.... I made a simple, mildly funny comment about how decals suck and no one here cares about your stickers... Please just talk about more power!... And my post gets deleted? WOW!
Fatguy729 is offline   Reply With Quote
The Following 3 Users Say Thank You to Fatguy729 For This Useful Post:
jwilkins88 (06-17-2011), smitty5788 (06-22-2011), Speed3eak (06-16-2011)
 Old 06-16-2011, 09:24 PM   #44
dizzydtrain's Avatar
Posts: 2,476   (View Stats)
Groans: 64
@Speed3eak
You make some great points and I won't even get involved in the technical aspect of all his parts. I guess I am viewing this 10k upgrade from my own perspective instead of Op's. 32k for a speed3 that probably won't hit 400whp and still needs a few parts to run safely and hit that number just does not seem like a reasonable way to spend that money (yes, I know it's his money and as long as op is happy..yada yada).
I am just curious why he chose to pursue this route rather than some other options that are clearly within that 32k and probably will be less of a pain to deal with and work on.
dizzydtrain is offline   Reply With Quote
The Following User Says Thank You to dizzydtrain For This Useful Post:
 Old 06-16-2011, 09:25 PM   #45
cpolly69's Avatar
Posts: 2,116   (View Stats)
Groans: 27
i didn't know the new cpe core was bigger - guess they took notes from cobb and changed it
driver311 still creeps - he just lives with it - same for rodrigo - as long as exhaust flow is good - that turbo is gonna creep - ewg is the light
increased pressure does nothing - it's the ability to sustain the max pressure (around 1800) that's needed - w/ a better pump the stock relief valve just keep cycling the more you crank the power - w/ out a mod fp will not stay steady -
i've seen the results to turning a car over to folks w/ little experience w/ the platform, so yeah i'm a bit skeptical of anyone doing it...
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
The Following 3 Users Say Thank You to cpolly69 For This Useful Post:
08.5MS3 (06-16-2011), ScarMS3 (06-17-2011), Speed3eak (06-16-2011)
 Old 06-16-2011, 09:28 PM   #46
dsmluck's Avatar
Posts: 1,193   (View Stats)
dsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the world
Groans: 60
I think 400whp is unrealistic on a 3071 at this altitude (Denver area). I would think you need at least a 3076 and be FULLY bolted on WMI to have a shot at 400whp. Many of the dynos around here give way over inflated numbers on power output for turbo cars. Technically you COULD put down 400whp on a dyno here on a 3071 but it wouldn't be close to reality.
2003 Lancer Evolution VIII - FIC 1120cc/Walbro 255/E85/Pure Drive Performance Tune
1990 Talon TSI AWD: Evo III 16g/E85/Exhaust/PTE 1000cc's/2g Maf/ECMLink *Wrecked*
2012 WRX: TD05 20g/E85/FIC 900cc's/Walbro 255 *SOLD* 12.8@110mph
2009 MS3: GT3076r/(75/25) E85/Bolt-ons *SOLD* 13.6@112mph
dsmluck is offline   Reply With Quote
The Following User Says Thank You to dsmluck For This Useful Post:
 Old 06-16-2011, 09:34 PM   #47
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
This will not hit 400 hp and I'm disappointed this thread exists only for false-joy.
The Following User Says NO Thank You to Mizzle For This Un-useful Post:
 Old 06-16-2011, 09:35 PM   #48
Speed3eak's Avatar
Groans: 82
Oh gotcha - I hadn't looked at any of their datalogs. I knew rodrigo used a MBC with his, didn't know what driver 311 was using. I agree that ewg is the light for that particular turbo, but different companies make better/worse IWGs - holset and borg warner both have great IWGs that flow enough to prevent boost creep even at the power levels this guy is looking to achieve.
If I were spending $10k, I'd definitely wait and get one of the EFR setups from full race.
As for the relief valve, I know phate pressure tested his in the thread he made about e85 - IIRC, it held pressure all the way to 1900 psi. The people that have blown the OEM out that I know of (dougefresh and bmorrisj) have done so because their pressure was way too high, even at part throttle conditions.
I seem to remember reading about a tuning technique where you overwhelm the rail valve enough at WOT that the lowest pressure you see is the point at which it opens. But, for part throttle conditions, you keep it low enough that the rail valve stays closed all the time.
In ATR I've raised up my pressure targets for all loads above 1.2 and RPM above 2.5k to ~1850. Hopefully my rail valve holds, but if it doesn't at least I'll know what caused it and it'll be good info to have at any rate.
Thanks for clarifying on all that stuff.
Didn't socks make his 392 whp at the cp-e dyno on a 3071? I know it won't be the same at your altitude, but here on the east coast (aka near sea level), I think the 3071 is perfectly capable of an honest-to-god 400 whp if you have the supporting mods. That includes an exhaust mani, t3 flange and a 3" v-band exit for the turbo from what I can tell.
I was thinking about how tits a twin-scroll 3071 setup would be - kissing 400 whp with spool time like a 2871. Actually, you could have better spool than that and more power with the new GTX turbos from garret, and a divided housing with t3/v-band connections.
And yes, I've lost a significant portion of my life fantasizing about a twin-scroll GTX3071R setup.
The Following 2 Users Say Thank You to Speed3eak For This Useful Post:
Ckmazdaspeed3 (06-17-2011), rfinkle2 (06-17-2011)
 Old 06-16-2011, 09:35 PM   #49
bertrand_CX_7's Avatar
Posts: 1,455   (View Stats)
bertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the world
Sounds already like a $1000 for 1 HP thing so 10 HP total.... fail
2010 MazdaSpeed3 Velocity Red: Forge BPV V2, CP-e [HPFP, TMIC, Driver + passenger Mount, 75-A], CorkSport [RSB, Coilover, camber plate], SPC rear camber arm, JBR SSP stg2 + heavy knob, Cobb [ SRI, AP ], HTP 3.5" TIP, - STG2 PERM tuned by DJ, Ultimate Racing TBE (Metal core DP). Aeroforce dual guages, Hankook R-S3 on stock wheels, Sparco Evo2 race seat. ARP long wheel studs -- 17x9 ET 45+ Kosei K1 TS on 255/40/17 on Dunlop Direzza ZII.
Pending install: JB EGR block plate
Next mod:CorkSport[ Front + Rear swaybar endlinks ], OCC, brake upgrade (CorkSport or BBK), 6 point Harness.
2007 CX-7 GT AWD: CPE CAI, ETS 3" TMIC, JB EGR block plate ,Matt's OCC, AutoExec Strut tower bar, AutoExec lower arm bar, Nittos 420 tires, 12" JBL subwoofer with Bose system.
bertrand_CX_7 is offline   Reply With Quote
The Following User Says NO Thank You to bertrand_CX_7 For This Un-useful Post:
 Old 06-16-2011, 09:41 PM   #50
Originally Posted by MS33SM View Post
This is how i imagine it.....
A 10k build should have 9k in parts and 1k in pizza,beer & hookers for your local Nator group during install.
Oh dang, I didn't read this one. This forum is really funny. Muss visit the forum each day before going to bed....
 Old 06-16-2011, 09:51 PM   #51
dsmluck's Avatar
Groans: 60
Parts installed & on the dyno tuning
Only achieving 350hp
Continues to up boost
Uncontrollable boost creep
An Injector seal pops
WGDC is maxed out
Crazy boost spike
Lean condition
#3 rod is ejected out the bottom of the block
Brownie donates to make a part out thread
Dibs on your FP &.....well thats the only part in your build that's worth a damn
I don't think our local Nator is very organized. JP@edgeautosport.com was trying to get it going. I would help install shit for free. No pizza or hookers needed. Although i wouldn't turn down a HJ/BJ from said hookers.
I_Heart_Haters and rfinkle2 like this.
The Following 2 Users Say Thank You to dsmluck For This Useful Post:
rfinkle2 (06-17-2011), Special--k (06-17-2011)
 Old 06-16-2011, 09:52 PM   #52
memoriesmazda's Avatar
Posts: 157   (View Stats)
memoriesmazda has a reputation beyond reputememoriesmazda has a reputation beyond reputememoriesmazda has a reputation beyond reputememoriesmazda has a reputation beyond reputememoriesmazda has a reputation beyond reputememoriesmazda has a reputation beyond reputememoriesmazda has a reputation beyond reputememoriesmazda has a reputation beyond reputememoriesmazda has a reputation beyond reputememoriesmazda has a reputation beyond reputememoriesmazda has a reputation beyond repute
You got to admit, all them parts look sexy tho
Cobb SRI ll Jbarone SSP ll CP-e 60 RRM ll UR Test Pipe ll Cobb Knob ll Cobb AP Running Stage 2 + SF ll Auto tech Internals
Coming Soon: ll UR Cat-back ll
memoriesmazda is offline   Reply With Quote
The Following 2 Users Say Thank You to memoriesmazda For This Useful Post:
 Old 06-16-2011, 09:55 PM   #53
JP@edgeautosport.com's Avatar
Posts: 887   (View Stats)
No posts were deleted because of their content. We didn't want this to be yet another blow up of you can't do this or this isn't going to work. I love this forum for what it is and I appreciate all of you donating to have a platform like this. However, this is unacceptable in our forum. Our section is not meant for bashing. It is educational, helpful, and a place where you can get excellent customer service on the parts that make your cars go faster. That's it.
We appreciate all of the input and there is nothing personal about this post. All future posts that are not helpful to our section will be deleted.
Thank you.
The Following 5 Users Say Thank You to JP@edgeautosport.com For This Useful Post:
08.5MS3 (06-16-2011), K7addict (06-19-2011), rfinkle2 (06-17-2011), ScarMS3 (06-17-2011), SLOWHATCH (06-17-2011)
 Old 06-16-2011, 09:59 PM   #54
Groans: 64
was really confused for a second here. Almost thought this was cp-e vendor section.
The Following 7 Users Say Thank You to dizzydtrain For This Useful Post:
Chriscote (06-17-2011), doubleflusher (06-17-2011), jwilkins88 (06-17-2011), manelscout4life (06-16-2011), Mizzle (06-17-2011), sellers (06-17-2011), smitty5788 (06-22-2011)
 Old 06-16-2011, 10:14 PM   #55
^^^^^ dizzy, you gotta be killing
@jp-edgeautosport-com: don't take it so personal... It's been quiet around lately beside: "Hey I blow up please check my logs" or "can I do Cobb DP with SLK AMG CBE" :bighlaugh: Let it pass men after the excitement you should see some nice post on this thread.
Hope you guys didn't forgot the AP.
 Old 06-16-2011, 10:48 PM   #56
dsmluck's Avatar
Groans: 60
I am not gonna lie. I fantasize about anything that starts with GT and doesn't spell K04.
 Old 06-17-2011, 05:41 AM   #57
MS33SM's Avatar
Posts: 1,821   (View Stats)
MS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the world
Groans: 132
Groaned at 166 Times in 92 Posts
I'm bashing falcon, not edge autosports. Falcon's mindset and mod path are fail. GTFO with mach 3. Your car isn't made by gillette. That also means a few guys on here are at mach 20.
I haven't bought anything from edge but you guys seem like a quality vendor. I've got nothing but love & leg humping for quality vendors.
MS33SM is offline   Reply With Quote
 Old 06-17-2011, 06:40 AM   #58
First I have to write that I know JP has excellent pricing, so if the owner of the MS3 spent $10k, there is NO DOUBT in my mind, that he is getting his $'s worth.
JP has given me nothing short of EXCELLENT service and pricing on anything that I've bought from him, and I've done a few $'s worth of business through him also.
LET ME SAY.... AS A FAN OF EDGE, and JP... Thanks for helping the OP with his build, making a solid attempt @ being a quality vendor, and best of luck with the build, power levels, and everything in general.
I Love Brownies (06-20-2011), JP@edgeautosport.com (06-18-2011), kmac (06-17-2011)
 Old 06-17-2011, 07:40 AM   #59
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
We appreciate your efforts in big terboh genpu
But it is not us who need to understand anything.
You sir, need to understand that this is MSF. This is not some watered down <insert name of some bullshit mazda forum here>. There are things on MSF that you will HAVE to deal with if you choose to do business here. Take it or leave it. But I assure you that deleting posts, WILL leave a bad taste in peoples mouth.
CP-E couldnt take it. Now they no longer post here and i assure you they have lost a lot of business because of it.
But its entirely up to you.
The Following 4 Users Say Thank You to Monotonous ONE For This Useful Post:
Ckmazdaspeed3 (06-17-2011), Fatguy729 (06-17-2011), rfinkle2 (06-17-2011), smitty5788 (06-22-2011)
 Old 06-17-2011, 07:47 AM   #60
08.5MS3's Avatar
Posts: 3,840   (View Stats)
Groans: 89
We are big and tough. We are the hardcore of Mazda performance.
Man, people need to get off their high horse.
This build is headed in the right direction. Keep it up.
Tapawhat?
 Old 06-17-2011, 07:47 AM   #61
I just ask everyone to try and remember that JP is trying to strike a balance in this thread between a customer's personal parts preference / selection, and running a successful business.
kmac (06-17-2011)
 Old 06-17-2011, 08:00 AM   #62
MS33SM's Avatar
Groans: 132
Yeah, it's headed towards fail.
The Following User Says Thank You to MS33SM For This Useful Post:
The Following 2 Users Say NO Thank You to MS33SM For This Un-useful Post:
rfinkle2 (06-17-2011), SLOWHATCH (06-17-2011)
 Old 06-17-2011, 08:02 AM   #63
alien_sporez's Avatar
Posts: 1,199   (View Stats)
alien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the world
subbed for fappage... or part out
2011 Jaguar XFR Full Resonator Delete Mina Cat-Back Exhaust Staggered Giovanna Portofinos
2010 Mazdaspeed 3 - GONE
alien_sporez is offline   Reply With Quote
The Following User Says NO Thank You to alien_sporez For This Un-useful Post:
 Old 06-17-2011, 08:18 AM   #64
First of all, there are MANY internally wastegated turbos that are good for well in excess of 400 hp.
Second, the customer has $, and we don't know of all of the parts going on the car.
Third... as long as the tune is sound, there is no reason to expect any fail.
Would some of us choose a different upgrade path, maybe, but why shit on this guys build?
08.5MS3 (06-17-2011), kmac (06-17-2011), sheldonross (06-21-2011), SLOWHATCH (06-17-2011)
The Following User Says NO Thank You to rfinkle2 For This Un-useful Post:
MS33SM (06-17-2011)
 Old 06-17-2011, 08:20 AM   #65
Abu Zib's Avatar
Posts: 958   (View Stats)
Abu Zib is the leader of the worldAbu Zib is the leader of the worldAbu Zib is the leader of the worldAbu Zib is the leader of the worldAbu Zib is the leader of the worldAbu Zib is the leader of the worldAbu Zib is the leader of the worldAbu Zib is the leader of the worldAbu Zib is the leader of the worldAbu Zib is the leader of the worldAbu Zib is the leader of the world
Groans: 48
X2 good luck with build!! Can't wait to see the outcome!
2011 MS3 Celestial Blue Mica
Exterior: 15% tint all around (except windshield), Evil 'M' logo blacked out badges in the back, plasti-dipped lower rear valence
Interior: Ambient Blue LED lighting
Engine: eBay Downpipe, Autotech Fuel Pump Internals, Accessport, JBR 88Duro RMM, Cobb SRI, HKS BOV
Abu Zib is offline   Reply With Quote
The Following 3 Users Say Thank You to Abu Zib For This Useful Post:
08.5MS3 (06-17-2011), kmac (06-17-2011), rfinkle2 (06-17-2011)
 Old 06-17-2011, 08:31 AM   #66
MS33SM's Avatar
Groans: 132
Looks like the fun police have shown up. Can't we bash a brownie and not get interrupted by the brownie messiah?
The Following 3 Users Say Thank You to MS33SM For This Useful Post:
jwilkins88 (06-17-2011), sellers (06-17-2011), Special--k (06-17-2011)
The Following 4 Users Say NO Thank You to MS33SM For This Un-useful Post:
Chriscote (06-17-2011), manelscout4life (06-17-2011), rfinkle2 (06-17-2011), SLOWHATCH (06-17-2011)
 Old 06-17-2011, 08:35 AM   #67
Groans: 819
i think he should put in an order for a Steedspeed bro
The Following 6 Users Say Thank You to Monotonous ONE For This Useful Post:
08.5MS3 (06-17-2011), Chriscote (06-17-2011), kmac (06-17-2011), MS33SM (06-17-2011), rfinkle2 (06-17-2011), Special--k (06-17-2011)
 Old 06-17-2011, 09:43 AM   #68
Put yourself in JP's position and see how a thread like this is "fun" to you.
Besides that, will you show up and eat your words if this car puts down decent #'s on a dyno?
 Old 06-17-2011, 10:00 AM   #69
MS33SM's Avatar
Groans: 132
I am trying to help him not have an unsatisfied customer. Now is his chance to make changes.
He's gonna have a pissed off customer who spent 10k for <400hp. What is this brownie gonna do when his mach 3 build only hits mach 2?
This is brownie bashing, not vendor bashing.
08.5MS3 likes this.
The Following 5 Users Say Thank You to MS33SM For This Useful Post:
alien_sporez (06-18-2011), jwilkins88 (06-17-2011), kmac (06-17-2011), rfinkle2 (06-17-2011), thehead (06-17-2011)
 Old 06-17-2011, 10:05 AM   #70
I'm sure JP would appreciate any suggestions you might have toward the build.
Again, we don't know all of the parts on the list, who is tuning the car etc.
I find most of the "suggestions" so far (not all) misdirected jealousy toward the owner of the car to have a lump sum of $10k for a build.
 Old 06-17-2011, 10:10 AM   #71
dsmluck's Avatar
Groans: 60
I am sure the car will be fast. But the numbers at altitude uncorrected will not hit 400whp. You are looking at a 40-50 horsepower drop for this elevation. I bet it will get in the upper 300's uncorrected with a good tune. I am interested to see what it can do because I want to go 3071 myself.
 Old 06-17-2011, 10:15 AM   #72
Very true.
I don't know that JP promised the owner 400 hp, although I see the owner is expecting it.
Regardless, it puts JP in a tough position.
I'd bet both JP and the owner will be happy after the build is finished and the car is tuned and dyno'd.
 Old 06-17-2011, 10:20 AM   #73
16-driver's Avatar
Posts: 374   (View Stats)
16-driver is the leader of the world16-driver is the leader of the world16-driver is the leader of the world16-driver is the leader of the world16-driver is the leader of the world16-driver is the leader of the world16-driver is the leader of the world16-driver is the leader of the world16-driver is the leader of the world16-driver is the leader of the world16-driver is the leader of the world
I'm confident that this build will be successful, but I'm basing this only on faith and the OP's deep pocket. I'm sure he'll do whatever he can to hit his plan and target. Plus, I'm an optimist.
Good luck!
Car Mods: Walmart SRI, Home Depot TIP, Dollar General Racepipe, Local Hardware Store Shifter Bushings, Junkyard Rear Motor Mounts, Short Shifter Plate Kit coming from Fingerhut.
Driver mod: Asian quickness!
16-driver is offline   Reply With Quote
The Following 2 Users Say Thank You to 16-driver For This Useful Post:
08.5MS3 (06-17-2011), rfinkle2 (06-17-2011)
 Old 06-17-2011, 10:24 AM   #74
MS33SM's Avatar
Groans: 132
No jealousy. My 10k lump sump didn't go towards my car.
Anytime I spend 10k I do a lot of research regardless of the purchase. It would have been wise for this brownie to join MSF and pick the brains of our current BT members. Do you really think any of them would have suggested those mods? For 10k I would like to see a exhaust mani, V Band down pipe, 3076 or 35r Turddddbo and for fucks sake at least a EWG.
A fool and his money are soon parted.
If he hits 400hp on a dyno I'll be glad to eat my words. Car won't last very long but I will eat my words.
The Following 7 Users Say Thank You to MS33SM For This Useful Post:
08.5MS3 (06-17-2011), Big_Burd (06-21-2011), Ckmazdaspeed3 (06-17-2011), i8urgti (06-22-2011), jwilkins88 (06-17-2011), kmac (06-17-2011), rfinkle2 (06-17-2011)
 Old 06-17-2011, 10:37 AM   #75
Your build ideas are limited to suggestions on msf.
There are some very high hp cars running internal wastegates.
As a matter of fact, most turbo upgrades for other platforms are internally wastegated.
 Old 06-17-2011, 10:45 AM   #76
MS33SM's Avatar
Groans: 132
We aren't talking about other platforms. We're talking about the MZR motor and known issues with his part selection.
Excuse the crappy webcam pic and work plate & utensils. He will not hit 400HP.
Post the dyno #s
The Following 8 Users Say Thank You to MS33SM For This Useful Post:
08.5MS3 (06-17-2011), i8urgti (06-22-2011), jwilkins88 (06-17-2011), kmac (06-17-2011), manelscout4life (06-17-2011), sellers (06-17-2011), Special--k (06-17-2011), wankular (06-17-2011)
 Old 06-17-2011, 10:49 AM   #77
Post the dyno #s
Turbocharging is turbocharging. The general rules and principals apply to all platforms.
Every time I read that the MZR is some sort of anomaly in some way, I wonder where people get that idea.
All platforms have their quirks.
Running an ewg on the street is in most cases, not only illegal, but impracticle for a DD.
Suggesting that missing the 400whp mark is what was meant by "fail" earlier in the thread is dishonest.
08.5MS3 (06-17-2011), kmac (06-17-2011), SLOWHATCH (06-17-2011)
 Old 06-17-2011, 10:57 AM   #78
MS33SM's Avatar
Groans: 132
You're an idiot.
doubleflusher (06-17-2011), i8urgti (06-22-2011), jwilkins88 (06-17-2011), Mizzle (06-17-2011), sellers (06-17-2011)
 Old 06-17-2011, 11:02 AM   #79
You're an idiot.
I see the above as a last resort.
 Old 06-17-2011, 11:05 AM   #80
16-driver's Avatar
Post the dyno #s
You're left handed?
Just curious because of the placing of the knife and fork.
Ducati officially rolls out Monster 796, Monster Art customization program Haltech Automotive News 0 04-19-2010 03:50 PM
Those Monsters: Monster Cable sues Monster Transmission Haltech Automotive News 0 04-12-2009 11:20 AM
Page generated in 0.67014 seconds with 37 queries
