  • 2 Post By EdgeAutosport.com
 Old 11-14-2013, 12:17 PM   #1
Default Manley I-Beam Rods Now Available at EdgeAutosport
Just wanted to let you guys know that we now carry the line of Manley Turbo Tuff Pro Series I-Beam Rods
The Pro Series I-Beam rods are forged from 4340 aircraft quality vacuum degassed material. They are shot peened after machining and 100% magnafluxed. All Manley Connecting Rods are weight matched to +/- 1.5 grams and big and small end bores are final honed to a tolerance of +/- .0002".
You have a choice between 22 and 22.5 (stock) mm wrist pins as well as ARP 2000 and ARP 625+ rod bolts.
Manley Turbo Tuff Pro Series I-Beam Rods w/ ARP 625+ - $972.60
Manley Turbo Tuff Pro Series I-Beam Rods w/ ARP 2000 - $810
taf0422 and atvfreek like this.
The Following 7 Users Say Thank You to EdgeAutosport.com For This Useful Post:
ABolewski (11-18-2013), atvfreek (11-14-2013), LumberJack (11-17-2013), ms6mil (11-14-2013), Realgib3 (11-14-2013), rymanmazda (11-14-2013), taf0422 (11-14-2013)
 Old 11-17-2013, 10:26 PM   #2
LumberJack's Avatar
Groans: 57
Them are some sexy rods
10.36@148 Fastest Gen 2
EdgeAutosport.com (11-18-2013)
 Old 11-18-2013, 01:01 AM   #3
So what is the difference between the I beam and H beam "economical" rods they sell?
ABolewski (11-18-2013), boostdmazda3 (11-18-2013), CWP_MS3 (11-18-2013), LumberJack (11-18-2013)
 Old 11-18-2013, 06:38 AM   #4
LumberJack's Avatar
Groans: 57
@Lex; this might help. It is just a general "hypothetical" comparison, but helped me a lot.
The Following 4 Users Say Thank You to LumberJack For This Useful Post:
atvfreek (11-18-2013), BigRedSpecial (11-18-2013), EdgeAutosport.com (11-18-2013), Realgib3 (11-18-2013)
 Old 11-18-2013, 09:01 AM   #5
Most companies sell the h beam as the stronger rod and without actual dimensions we can't infer this. The description on the site labels the h beam as economical without giving any specs.
 Old 11-18-2013, 09:13 AM   #6
I believe it has to do with how and where the rods are made. I believe the I-beams are made in America while the H-beams are farmed out to somewhere else. They are likely made along side K1 and eagle rods.
 Old 11-18-2013, 10:42 AM   #7
BigRedSpecial's Avatar
Posts: 1,436   (View Stats)
Groans: 56
Doesn't Carrillo offer an I beam as a stronger alternative to their H beam?
Needed: Driver mod
The Following 2 Users Say Thank You to BigRedSpecial For This Useful Post:
EdgeAutosport.com (11-18-2013), LumberJack (11-18-2013)
 Old 11-18-2013, 10:45 AM   #8
LumberJack's Avatar
Groans: 57
Never seen there I beams. But they make an extremely sexy A beam rod
 Old 11-18-2013, 10:57 AM   #9
LumberJack's Avatar
Groans: 57
Well, I tried calling Manley to get a better explanation on this and I referred him to that picture I posted since he had actually seen that comparison online on the corvette forums where I found it. He said it is a very good example and the representation of difference in design and showing how strength is actually different between the 2
 Old 11-18-2013, 11:17 AM   #10
Groans: 56
You're right, I was thinking of the A beams.
Needed: Driver mod
 Old 11-18-2013, 12:12 PM   #11
Carrillo makes a lower power rating A beam. These rods are also A beams as they flare out near the big end.
 Old 11-18-2013, 02:12 PM   #12
I've always thought they were more like A-Beams, but Manley calls them I-Beams so thats what we sell them as.
ABolewski (11-18-2013), LumberJack (11-18-2013)
 Old 11-18-2013, 02:14 PM   #13
LumberJack's Avatar
Groans: 57
Yeah, I agree. Every company sells them differently there is no "industry" standard name for rods. The turbo Tuffs are I beam, they look like the Carillo A beams. Then the Manley I beams are there highest rated rods, and Carillo rates there H beams higher than there A beams.
 Old 11-18-2013, 07:21 PM   #14
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
@Hammology;
MANLEY H BEAM RODS SPEED6 KILLAH Mazdaspeed3/6 General Discussion 40 04-18-2015 03:26 PM
Manley "turbo tuff" I-Beam connecting rods *oem replacements whoosh@Realtune MazdaSpeed 3 - Engine, Transmission & Driveline 13 02-12-2009 04:40 PM
Page generated in 0.34885 seconds with 25 queries
