Like Tree21Likes
 Old 02-12-2015, 08:55 PM   #1
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
I received mine today. Quick question; what P2W clearance is everyone running with these? Manley recommends .0035" but I've seen people mention .0028" in other threads in regards to other Pistons.
Mauro_Penguin (02-13-2015)
 Old 02-12-2015, 09:00 PM   #2
LumberJack's Avatar
Groans: 57
Do not go below the minimum recommendation, it's there for a reason. You go any less you risk running piston and cyl wall scoring from the gap being too tight. P2W is generally chosen based on power goals and boost levels, but 99% of forged Piston minimum p2w is .0035
10.36@148 Fastest Gen 2
The Following 4 Users Say Thank You to LumberJack For This Useful Post:
jdmage_mx5 (02-12-2015), Justin@Freektune (03-10-2015), Mauro_Penguin (02-13-2015), The Nut (02-12-2015)
 Old 02-12-2015, 08:56 PM   #3
jdmage_mx5's Avatar
Ps picture of the goods.
The Following 3 Users Say Thank You to jdmage_mx5 For This Useful Post:
LumberJack (02-12-2015), Mauro_Penguin (02-13-2015), nojjy (02-12-2015)
 Old 02-27-2015, 12:08 PM   #4
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
Are these made of 2618 or 4032?
Edit: Never mind it's in the first sentence of the add....
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
EdgeAutosport.com (02-27-2015)
 Old 02-27-2015, 12:40 PM   #5
Mikey's Avatar
Posts: 2,049   (View Stats)
Mikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the world
Groans: 104
Groaned at 45 Times in 36 Posts
I bought I set of these with the rods from Edge and will hopefully have my car up and running next week for the break end period. So hopefully all good.
2007 Cosmic Blue
Built HTA 3076 Corn Fed with shot of Meth and Freektuned
Mikey is offline   Reply With Quote
The Following 3 Users Say Thank You to Mikey For This Useful Post:
EdgeAutosport.com (02-27-2015), JgamB (02-27-2015), Micha (02-28-2015)
 Old 03-02-2015, 09:29 AM   #6
Lakespeed6's Avatar
Posts: 2,403   (View Stats)
800 miles on my set
have yet to check compressions but car is feeling strong @18psi
JgamB likes this.
1990 Nissan Skyline GTR
1991 White BMW 325ic
The Following 4 Users Say Thank You to Lakespeed6 For This Useful Post:
EdgeAutosport.com (03-02-2015), JgamB (03-10-2015), Justin@Freektune (03-10-2015), Mikey (03-02-2015)
 Old 03-02-2015, 10:39 AM   #7
Originally Posted by Lakespeed6 View Post
800 miles on my set
Good to hear! Let us know if anything does develop!
Lakespeed6 likes this.
 Old 03-02-2015, 10:47 AM   #8
The Nut's Avatar
Posts: 1,571   (View Stats)
800 miles on my set
That pretty common to break in forged internal at higher (even slightly) than stock boost levels?
2012 BLACK MICA w/TECH
91 & Corn diagnostics by:
 Old 03-02-2015, 10:54 AM   #9
Lakespeed6's Avatar
I'm quite sure every person here will give you different instructions on how to break in an engine.
I am following the instructions from Freek.
Worked my way up to spring pressure/maxing out the stock injectors after 500 miles.
Hopefully I will get my meth running again, do a compression check, and start turning up the boost soon.
The Following 5 Users Say Thank You to Lakespeed6 For This Useful Post:
EdgeAutosport.com (03-02-2015), JgamB (03-02-2015), Justin@Freektune (03-10-2015), shaneski (03-02-2015), The Nut (03-02-2015)
 Old 03-02-2015, 01:24 PM   #10
Best bet for engine break in is to do what your builder tells you too.
The Following 6 Users Say Thank You to EdgeAutosport.com For This Useful Post:
ASHMS3 (03-02-2015), Hammology (03-11-2015), Justin@Freektune (03-10-2015), LumberJack (03-04-2015), The Nut (03-02-2015), Tokay444 (03-02-2015)
 Old 03-10-2015, 10:36 AM   #11
Jtaylor's Avatar
Posts: 656   (View Stats)
Any update with oil squirter clearance issues with these? I am about to click purchase on @EdgeAutosport.com;
Was going to go with the Wiseco's but was unsure if their clearance issues have been resolved. Also like the Gen2 design of these better
08 MazdaSpeed3
 Old 03-10-2015, 10:38 AM   #12
LumberJack's Avatar
Groans: 57
Click away. They are badass Pistons and yes they clear!
The Following 6 Users Say Thank You to LumberJack For This Useful Post:
EdgeAutosport.com (03-11-2015), Frottage75 (11-22-2015), JgamB (03-10-2015), Jtaylor (03-10-2015), Mauro_Penguin (03-10-2015), The Nut (03-10-2015)
 Old 03-10-2015, 12:14 PM   #13
acemanz's Avatar
Posts: 224   (View Stats)
acemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the world
Oil Squirter Confirm Clear?! HUZZAWH
i will be picking up these in a few months
acemanz is offline   Reply With Quote
 Old 03-10-2015, 07:45 PM   #14
SilverMS307's Avatar
Posts: 298   (View Stats)
SilverMS307 has a reputation beyond reputeSilverMS307 has a reputation beyond reputeSilverMS307 has a reputation beyond reputeSilverMS307 has a reputation beyond reputeSilverMS307 has a reputation beyond reputeSilverMS307 has a reputation beyond reputeSilverMS307 has a reputation beyond reputeSilverMS307 has a reputation beyond reputeSilverMS307 has a reputation beyond reputeSilverMS307 has a reputation beyond reputeSilverMS307 has a reputation beyond repute
Mine should be here tomorrow and hopefully going in this weekend. Just have to hone the cylinders, clean it out, and reassembling starts.
07 Sunlight Silver MS3 GT: JBR 3.5", CS Race Pipe, M2 DP, CNT Racing CBE, SURE Shortcut, Autotech Internals, Forge V1, Cobb AP, FREEK tuned, JBR 88a RMM, CXRacing FMIC w/ TR8 core, BNR S3, PG V2 Exhaust Manifold, and Devil's Own DVC-30 Stage 2 w/ 100% meth.
Best 1/4 mile: 12.18 @ 115.48
06 Speed 6 GT, rescued from a vented block. Pu motor, Fujita CAI, Autotech Internals, RMM, ATP Catted DP, GHL Catback, AP, FREEK OTS+ in progress
SilverMS307 is offline   Reply With Quote
The Following 2 Users Say Thank You to SilverMS307 For This Useful Post:
EdgeAutosport.com (03-11-2015), JgamB (03-11-2015)
 Old 03-10-2015, 08:36 PM   #15
The Nut's Avatar
I think these bad boys will eventually become the fav for builders and buildees alike. On every other platform that has had these pistons for a long while now, these are the elite. They cost way less than CP-E's and they're def going into my car when I can afford to build.
The Following 3 Users Say Thank You to The Nut For This Useful Post:
EdgeAutosport.com (03-11-2015), JgamB (03-11-2015), LumberJack (03-11-2015)
 Old 03-10-2015, 08:42 PM   #16
jdmage_mx5's Avatar
I'm in the middle of filing/gapping the rings for mine right now.
JgamB (03-11-2015)
 Old 03-11-2015, 02:10 PM   #17
Jtaylor's Avatar
What specs are you going with? I just ordered mine
08 MazdaSpeed3
 Old 03-11-2015, 04:15 PM   #18
LumberJack's Avatar
Groans: 57
Ring gaps will depend on your power goals or the recommendation of your builder or machine shop same with your p2w clearance.
The Following 3 Users Say Thank You to LumberJack For This Useful Post:
jdmage_mx5 (03-11-2015), Jtaylor (03-11-2015), The Nut (03-11-2015)
 Old 03-11-2015, 12:03 AM   #19
JgamB's Avatar
Posts: 2,566   (View Stats)
They might've arrived with little fanfare, but it looks like they are making their way to the head of the line. My build sheet has these penciled in as well.
The Following 3 Users Say Thank You to JgamB For This Useful Post:
BLKSTIG (03-23-2015), LumberJack (03-11-2015), The Nut (03-11-2015)
 Old 03-11-2015, 04:04 AM   #20
shaneski's Avatar
Posts: 505   (View Stats)
Mine arrived as well, i like the extra length/metal of the skirts, the cylinder walls will enjoy not getting slapped.
The Following 2 Users Say Thank You to shaneski For This Useful Post:
 Old 03-11-2015, 06:55 PM   #21
The Nut's Avatar
Does anyone have like 5 G's I can borrow?
 Old 03-11-2015, 08:20 PM   #22
jdmage_mx5's Avatar
G G G G G
You can have mine ^^^.
taf0422 likes this.
 Old 03-11-2015, 08:56 PM   #23
The Nut's Avatar
G G G G G
Thanks brother! Somebody start my build!
 Old 03-11-2015, 10:33 PM   #24
Mikey's Avatar
Groans: 104
I should be driving mine next week for the break in period. Would of been this week but damn Kozmic oil feed line started leaking. need to call Edge tomorrow and get here and get on the road... It started like a champ on first turn though.
2007 Cosmic Blue
The Following 4 Users Say Thank You to Mikey For This Useful Post:
BLKSTIG (03-13-2015), jack_hammer (03-12-2015), JgamB (03-11-2015), The Nut (03-11-2015)
 Old 03-18-2015, 05:17 AM   #25
shaneski's Avatar
Engine builder that has hold of mine is concerned the top ring land on Manleys has no gas pockets compared to CPE ones he has used previously.
 Old 03-18-2015, 10:39 AM   #26
This is the first I've heard of this being an issue.
shaneski (03-19-2015), The Nut (03-18-2015)
 Old 03-18-2015, 10:30 PM   #27
LumberJack's Avatar
Groans: 57
Default Manley Pistons, arrived with not much fanfare
Same. These are being used in many builds with mild horsepower to lots of damn power. They're going in my build and I'll be back over 800+ and Justin has no concerns about these Pistons or there design.
EdgeAutosport.com (03-19-2015), shaneski (03-19-2015), The Nut (03-18-2015)
 Old 03-18-2015, 11:14 PM   #28
The Nut's Avatar
Getting some ductile sleeving done sir?
 Old 03-18-2015, 11:15 PM   #29
LumberJack's Avatar
Groans: 57
Wayyyyy ahead you broski.
EdgeAutosport.com likes this.
BLKSTIG (03-19-2015), The Nut (03-18-2015)
 Old 03-21-2015, 05:18 PM   #30
Lakespeed6's Avatar
Little update on my Manley pistons.
Engine has ~1500 miles and is currently @24psi with a D12 meth. ~400HP
Compression check is 190 +/-1psi
Can't wait to get this turbo actually spinning.
smoogs12 and Justin@Freektune like this.
The Following 10 Users Say Thank You to Lakespeed6 For This Useful Post:
BLKSTIG (03-23-2015), Easter Bunny (03-22-2015), EdgeAutosport.com (03-23-2015), JgamB (03-22-2015), Justin@Freektune (03-22-2015), Mauro_Penguin (03-22-2015), shaneski (03-21-2015), smoogs12 (03-22-2015), The Nut (03-21-2015), Tokay444 (03-21-2015)
 Old 03-21-2015, 07:15 PM   #31
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
That Freek build.
"Exclusivity" - CP-enis
Demodded.
The Seals
The Following 6 Users Say Thank You to Tokay444 For This Useful Post:
Easter Bunny (03-22-2015), EdgeAutosport.com (03-23-2015), JgamB (03-22-2015), Justin@Freektune (03-22-2015), smoogs12 (03-22-2015), The Nut (03-21-2015)
 Old 03-21-2015, 10:22 PM   #32
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
Will anyone ever make 4032 pistons for us?
The Following 4 Users Say Thank You to Tomas For This Useful Post:
Easter Bunny (03-22-2015), EdgeAutosport.com (03-23-2015), Justin@Freektune (03-22-2015), Mauro_Penguin (03-22-2015)
 Old 03-21-2015, 10:39 PM   #33
The Nut's Avatar
Is there a need? I was under the impression we were running out of fuel before hitting the limits of these beautiful fuckers? Please, someone more learned chime in on this.
 Old 03-22-2015, 03:28 PM   #34
Justin@Freektune's Avatar
Posts: 954   (View Stats)
With 4032 you can run tighter PWC clearance as it doesn't expand as much. This would last much longer, especially in a street driven car.
Realistically 2618 should only be used in legit race engines that have frequent overhaul intervals. But that's all we have. So it's what we use.
What I really like about these manley Pistons is the longer skirts they use which is very similar to the length of an Oem piston. And then the top ring thickness is much thicker than what wiseco offers.
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
Last edited by Justin@Freektune; 03-22-2015 at 03:28 PM. Reason: MSF Database - Automerged Doublepost
The Following 7 Users Say Thank You to Justin@Freektune For This Useful Post:
802MS3 (03-22-2015), Easter Bunny (03-22-2015), EdgeAutosport.com (03-23-2015), Mauro_Penguin (03-22-2015), Micha (03-22-2015), SpeedRebirth (03-22-2015), The Nut (03-22-2015)
 Old 03-22-2015, 04:09 PM   #35
jdmage_mx5's Avatar
With 4032 you can run tighter PWC clearance as it doesn't expand as much. This would last much longer, especially in a street driven car. Realistically 2618 should only be used in legit race engines that have frequent overhaul intervals. But that's all we have. So it's what we use. What I really like about these manley Pistons is the longer skirts they use which is very similar to the length of an Oem piston. And then the top ring thickness is much thicker than what wiseco offers.
Would you mind sharing your thoughts on PWC and ring gap with these Pistons? I know you have installed a few sets. I'm just curious as to what the more knowledgeable are running spec wise with these.
 Old 03-22-2015, 04:40 PM   #36
acemanz's Avatar
So given that we are using what you consider to be a product that should really only be used in an engine with regular overhaul intervals, what is your thoughts about the realistic longevity of these in a Daily Driver car.
how long do we got doc?.. give it to me straight..
 Old 03-23-2015, 07:19 AM   #37
Always use their recommendations as a guidleline and adjust each spec per customers engine use/goals.. Each engine is built to spec, so there is no one size fits all.
I have guys that have 40k+ miles on their engines, and as lex mentioned, short of louder piston slap, haven't had any ill effects. But things that do occur is more blowby and oil consumption. The key with keeping her healthy starts with a proper break in, maintenance, and definitely a good PCV system. I like big ports to let that CC vapor escape whether 10an fittings to a vented can, or breather cap.
I think Manley really hit it on the head by using the thicker top ring as opposed to the other pistons that are available right now. Each motor that I have used them in, is running, and all were pulling crazy manifold vacuum within just as few miles. I gave one of the engines a little boost (1-2psi) about 5 miles into my road test and that thing just wanted to pull. Made me all giddy inside. lol
PTE 6062
633HP/523TQ
Easter Bunny (03-23-2015), EdgeAutosport.com (03-23-2015), Mauro_Penguin (03-23-2015), Micha (03-23-2015), shaneski (03-24-2015), SpeedRebirth (03-23-2015), The Nut (03-23-2015)
 Old 03-22-2015, 09:09 AM   #38
Micha's Avatar
Posts: 3,436   (View Stats)
We have fueling options now. So running out of fuel is in the past. It just costs a bunch of moolah.
I am slow again.
I modded it a little.
The Following 2 Users Say Thank You to Micha For This Useful Post:
 Old 03-22-2015, 05:06 PM   #39
This all depends on how tolerant you are to blow by and piston slap . I don't see 60k miles as a problem and probably more. They won't break, they will just have more blowby, consume more oil and may become noisier.
Easter Bunny (03-22-2015), Justin@Freektune (03-22-2015), phate (03-22-2015)
 Old 03-22-2015, 05:38 PM   #40
Tokay444's Avatar
Groans: 793
Manley also recommends stacking the ring gap in reverse, with the larger gap on the top ring. This explains the lack of expansion groove.
Demodded.
The Seals
Wiseco pistons question pistons squirters clearance JDMCRX MazdaSpeed 3 - Engine, Transmission & Driveline 6 11-27-2013 05:23 PM
Official: Mercedes-Petronas AMG W04 launched to little fanfare, lot of pressure [w/video] Haltech Automotive News 0 02-05-2013 12:50 PM
LA 2009: 2011 Ford Mustang V6 on show floor with little fanfare Haltech Automotive News 0 12-02-2009 05:10 PM
Page generated in 0.62385 seconds with 37 queries
