| EdgeAutosport.com EdgeAutosport.com is committed to being the best at what we do. High performance aftermarket parts is what we do but not who we are. We operate at the highest level of integrity and honesty, all while bringing you superior products and unmatched customer service and support. We hold ourselves to the highest standards, just like we do for our cars! Let us know how we can help! |
| Approved MSF Vendor ![]() Join Date: May 2010 Location: Denver, CO
Rep Power: 1280 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 906
(Thread Starter) | Not Ranked : 0 score Here is a little info on water/meth injection that may help explain what is going on in the motor when you inject the mixture. Injecting water can provide a number of benefits. Most people know that it helps when you are limited to running lower octane fuels, but I want to talk about why it helps. During combustion, the water is converted to steam. This conversion pulls heat out of the combustion process and slows down the rate that pressure in the cylinder rises. The steam particles that are created get in the between the fuel and oxygen molecules which also helps slow down the combustion and pressure rise rate. Meanwhile the piston is moving towards TDC (top dead center), squeezing the gases together. But, since there is less heat in the chamber and slower pressure rise, detonation is far less likely to occur. As the piston starts its descent a controlled burn continues, but the combustion flame now has to dodge around steam molecules plus an increasing number of exhaust molecules to get to fuel and oxygen molecules. Now lets take a look at what meth brings to the table (besides making a lot of money but causing a ton of problems for certain high school chemistry teachers that is) /breaking bad reference Methanol has a very high latent heat of vaporization compared to gasoline, but much lower compared to water. Because it vaporizes at a much lower temperature than water, the meth will pull heat from the intake tract, the piston crown, and the intake and exhaust valves where the temperatures are much cooler than that of the combustion event (where the water comes into play). Because internally, the engine is cooler, less heat will be put into the combustion charge resulting in higher mixture density in the cylinder. Furthermore, less heat means slower burn. So with a cooler combustion chamber and steam molecules resulting in a slower burn, spark advance and boost pressure can be increased resulting in more horsepower and improved throttle response. |
| The Following 19 Users Say Thank You to JP@edgeautosport.com For This Useful Post: | 12blkms3 (09-20-2013), atvfreek (10-29-2012), Grumpyjap (04-02-2013), JacksonMS30 (11-01-2012), JDW1 (10-29-2012), kritz (10-29-2012), Lanegrita11 (03-31-2013), leon78 (01-30-2013), Micha (01-30-2013), Pointless (01-11-2013), SC08Speed3 (01-30-2013), sidekick (01-30-2013), SparkySparks (11-01-2012), SPEEDRAC3R (10-29-2012), speed_freak91 (10-29-2012), stuntz89 (01-30-2013), triphop631 (01-11-2013), turboKart (02-16-2013), Twofer (03-30-2013) |
![]() Join Date: Mar 2011 Location: Birmingham, Al
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 278
| Not Ranked : 0 score Now you can recommend a good kit for me with a fail safe.
__________________ 07 Liquid Plat Silver W/BNR S3 ~325/340 Pump gas AlphaTuned. Parting out. 11 Mustang GT current. |
| The Following User Says Thank You to JDW1 For This Useful Post: | EdgeAutosport.com (10-29-2012) |
| Approved MSF Vendor ![]() Join Date: Sep 2011 Location: Denver Colorado
Rep Power: 5796 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,830
| Not Ranked : 0 score Check out this one They dont have a solenoid with the kit but as long as you mount the tank below the pump you will be fine. We can get you a solenoid for 52.50 also Performance Stage 2 Boost Cooler Methanol/Water Injection System |
| The Following User Says Thank You to EdgeAutosport.com For This Useful Post: | JDW1 (10-29-2012) |
![]() Join Date: Jun 2009 Location: Denver Colorado
Rep Power: 2697 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,601
| Not Ranked : 0 score AEM makes an awesome Failsafe that will work with pretty much any kit. Water/Methanol FAILSAFE Device - 1/4" SAE
__________________ 2008 MGM MS3 GT - HTA3586- - P.E.R.M Twisted Top Mount - - P.E.R.M. Fifth/Sixth Port Injection - - P.E.R.M. Tuning - |
| The Following User Says Thank You to JacksonMS30 For This Useful Post: | JDW1 (11-01-2012) |
| Not Ranked : 0 score Bump! This is a good resource! Educate yourself and your experience with your car will be better! |
| The Following User Says Thank You to EdgeAutosport.com For This Useful Post: | stuntz89 (01-30-2013) |
![]() ![]() ![]() Join Date: Nov 2012 Location: Temecula, CA
Rep Power: 2724 ![]() Thanks: 3,896
Groans: 57
| Nice write up, great info! Will be going with a Meth kit on my BT build!
__________________ 2018.... Doing even more freeky things! 10.36@148 Fastest Gen 2 |
| The Following User Says Thank You to LumberJack For This Useful Post: | EdgeAutosport.com (01-31-2013) |
![]() Join Date: Mar 2011 Location: Greenwood, SC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 207
| Not Ranked : 0 score Great info! Im trying to decide exactly which set-up I wont to go with when i go BT..
__________________ 08 MGM Speed 3=SURE Rmm/ShortCut/Anchors/Return,COBB AP/SF/TIP,TurboSmart B.O.V,BC Coilovers/SWIFT Springs,SPC R.C.A, M2 DP, CNT CBE, Autotech Internals, SSP EGR Delete, DDM 6K |
| The Following User Says Thank You to SC08Speed3 For This Useful Post: | EdgeAutosport.com (01-31-2013) |
![]() Join Date: Jan 2012 Location: Laruel,MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,453
Groaned at 8 Times in 7 Posts
| Not Ranked : 0 score Most kits are going to be good such as Devils own and aem and snow.... what is important is how it is setup such as running of maf voltage.
__________________ 2011 BLACK MS3 ZZB on GT3076 Rebuild in progress |
| The Following 2 Users Say Thank You to The Panda For This Useful Post: | EdgeAutosport.com (01-31-2013), SC08Speed3 (01-31-2013) |
![]() Join Date: May 2012 Location: Ontario
| Not Ranked : 0 score I was about to order the Snow Performance silicone adapter for the Stage 2 MAF kit I ordered already(through a GB)... was just wondering if I should be buying anything else. I was planning on mounting the kit somewhere it's easy to fill. Is there a shopping list of crap I am going to need to do the install? |
-Alan | |
| To the people with meth/water injection | AntiStock | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 20 | 05-20-2010 04:50 PM |
| water/meth injection fillups? | johnac08 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 14 | 01-20-2009 01:09 AM |
| Water-Meth injection | EvilMonkey | MazdaSpeed 3 - Engine, Transmission & Driveline | 2 | 08-06-2008 10:41 AM |
