Like Tree32Likes
 Old 05-08-2014, 10:35 AM   #1
Default MZR DISI Remanufactured Long Blocks now Available at EdgeAutosport
Well since we all drive Mazdaspeeds here, we are all familiar with the term "Zoom Zoom Boom". Proper tuning, modding, and driving can save you but it can still happen to anyone. Some will use it as an excuse to go built motor, but some don't need a built motor and just want to stay stock. That is where this comes in.
This engine is 100% remanufactured using factory OEM parts and is machined and built according to factory specifications to ensure a long lasting, high quality replacement engine. All seals and gaskets get replaced with brand new hardware and the long block is fully assembled, ready to be put into your vehicle and start up quickly. There is no need to get any extra machine work or assembly with this long block.
This remanufactured long block comes with a 3-year, unlimited mileage warranty against engine defects. Each engine goes through a 9 step process to make sure you are getting the quality and performance that would come with a brand new engine.
The nine steps include the following:
Engine Identification
Proper Disassembly
Thorough Cleaning
Initial Testing
Machining
Secondary Testing
Full Assembly
Final Testing
Delivery
Upon receiving your engine, you will be provided with a shipping label that you can send your old engine back with and inside the same crate the new motor came in. The shipping of the new engine is free as well as the shipping of the old engine in return. Just schedule your pickup with us and you're good to go.
The price of the MZR DISI Remanufactured Long Block for MS3/MS6 2006-2013 is $3940.00 shipped to the continental US. There is a core charge of $460 that is included in the price of the engine. Upon a successful return of your engine core in it's crate, you will be reimbursed $460. If you choose not to return an engine, this core charge will not be refunded and you don't have to worry about any returns.
Click on any of the pictures to be redirected to our site for purchase.
The Following 49 Users Say Thank You to EdgeAutosport.com For This Useful Post:
adamizme (05-21-2015), Agent_Orange (05-08-2014), alaskazero (05-09-2014), Bleupit80 (05-09-2014), Bolted6 (05-08-2014), Boost_creep (05-08-2014), Cevaes_64 (05-09-2014), Cyclops (06-04-2014), darkstar5440 (06-04-2014), doctavus (07-27-2014), Domino81 (05-18-2014), Easter Bunny (05-09-2014), faeker (05-09-2014), goHAMM (10-02-2014), Hammology (06-04-2014), Hush (06-22-2014), Ingle (05-09-2014), ItsNox (05-09-2014), jakk (05-09-2014), KCi (05-08-2014), kgb (05-08-2014), King Scumbag (06-12-2014), krimsonviper (05-21-2018), Little John (06-04-2014), littleloogy (09-26-2014), Mauro_Penguin (05-09-2014), mituc (05-08-2014), ms6ms6 (05-09-2014), mxlplx71 (05-08-2014), NCspecV81 (05-08-2014), Ottousmc0341 (05-08-2014), predapio (05-09-2014), r3d (06-05-2014), Raider (05-09-2014), RobT2009 (05-21-2014), sadak (01-15-2015), SamiChicago (08-22-2014), sidekick (05-09-2014), simply_pandora (07-30-2014), snailD (05-08-2014), SofaKingAwesome (05-09-2014), speed23 (05-09-2014), SpeedRebirth (05-09-2014), SpeedThrizzle (06-04-2014), SpencerC (05-09-2014), taf0422 (05-09-2014), Tokay444 (05-08-2014), trancehead (05-08-2014), YABBAMZR (05-09-2014)
 Old 05-08-2014, 10:37 AM   #2
Dimenus's Avatar
Posts: 2,825   (View Stats)
Groans: 33
Pu pistons?
2012 Velocity Red Mica
 Old 05-08-2014, 10:55 AM   #3
NCspecV81's Avatar
Posts: 2,867   (View Stats)
Wished you guys offered remanf. heads with valve train packages.
EdgeAutosport.com (05-08-2014), JSmith (05-08-2014)
 Old 05-08-2014, 11:43 AM   #4
Originally Posted by Dimenus View Post
Pu pistons?
I'm not sure. I have one here that I'm about to put in my personal MS6. I'll check with scope before I install and post up what I find.
GunGuru727 likes this.
The Following 6 Users Say Thank You to EdgeAutosport.com For This Useful Post:
jrotaryb (05-08-2014), Mauro_Penguin (05-09-2014), SamiChicago (08-22-2014), SofaKingAwesome (05-09-2014), speed23 (05-09-2014), trancehead (05-08-2014)
 Old 05-08-2014, 11:49 AM   #5
snailD's Avatar
Posts: 3,039   (View Stats)
nice option to have
 Old 05-08-2014, 03:00 PM   #6
sleeperstang1994's Avatar
Posts: 569   (View Stats)
Groaned at 7 Times in 5 Posts
looks like they used a cast iron block for the rebuild. all black? I jest.
 Old 05-08-2014, 03:04 PM   #7
Matrix311's Avatar
Posts: 2,133   (View Stats)
well priced option for sure.
 Old 05-08-2014, 03:35 PM   #8
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Can you tell us a little about the rebuilder you partnered with, i.e. their specialty, time in business, reputation, etc.? Also, can you talk more about Machining, Secondary Testing, Full Assembly, Final Testing stages? What do they machine? Does the owner get the test sheet with compression/leak down info? Does it ship with a valve cover and oil pan?
I'm not in the market, and $3,500 for a full rebuild shipped (- core) from a reputable shop seems reasonable. The more info for this crowd, the better.
MINI H1 6.0 - CAR LED TAILS
The Following 8 Users Say Thank You to dale_gribble For This Useful Post:
Agent_Orange (05-08-2014), CosmicArkie (06-04-2014), Easter Bunny (05-09-2014), EdgeAutosport.com (05-08-2014), Fatpig78 (05-25-2014), ItsNox (05-09-2014), memin (05-09-2014), SamiChicago (08-22-2014)
 Old 05-08-2014, 05:06 PM   #9
Its actually cast unobtainium to prevent future zzb
We get them from HERE.
They are remanufactured engines so they have necessary machine work done such as honing and possible over-boring if necessary. Brand new Mazda OEM parts are used for the rebuilds (pistons/bearings/head bolts/main bolts etc).
As for testing, clearances are tested then machining occurs to bring things back into spec. It is then tested again to make sure all the parts are good. The motor is then assembled and checked that timing and all clearances are good. Final testing includes compression results as well as a test to make sure it builds adequate oil pressure.
Here is what it comes with.
Arrives in Crate that you can also use to ship your long block back as a core.
It also comes with the gaskets and stuff listed here.
And the test results as well.
For mine in particular, the only thing I have to get that it didn't come with is an oil pickup tube. Due to the nature of the failure of my engine, I don't trust the one thats currently on it.
This motor does not come with a valve cover or oil pan, but there is an option to get those with it for a few hundred more.
Also, something I forgot to mention originally, I was able to purchase a $50 extra warranty that includes a no fault clause for this motor. In other words if this motor pops on me within 3 years, they don't ask questions and just send me a new motor.
The Following 23 Users Say Thank You to EdgeAutosport.com For This Useful Post:
Agent_Orange (05-08-2014), dale_gribble (05-08-2014), Darth_Nuruodo (07-30-2014), djern (02-05-2015), doctavus (07-27-2014), Easter Bunny (05-09-2014), Fatpig78 (05-25-2014), Ingle (05-09-2014), ItsNox (05-09-2014), kgb (07-30-2014), Little John (06-04-2014), Mattcinnc1 (11-18-2014), Mauro_Penguin (05-09-2014), predapio (05-09-2014), Raider (05-09-2014), SamiChicago (08-22-2014), sidekick (05-09-2014), sleeperstang1994 (05-19-2014), SLOWHATCH (05-10-2014), speed23 (05-09-2014), SpeedThrizzle (06-04-2014), Tokay444 (05-08-2014), Zdraveca (05-09-2014)
 Old 05-08-2014, 05:22 PM   #10
[R]usty's Avatar
Posts: 2,204   (View Stats)
Any chance they could reman with aftermarket internals for some extra $$$?
Yousuf likes this.
2010 Mazdaspeed3 w/tech
The Following 8 Users Say Thank You to [R]usty For This Useful Post:
bstover17 (05-08-2014), Chicagospeed6 (05-08-2014), Dumbguy (05-09-2014), impossible (01-09-2017), JSmith (05-09-2014), Mauro_Penguin (05-09-2014), mituc (05-08-2014), Yousuf (10-07-2014)
 Old 05-09-2014, 08:05 AM   #11
Unfortunately, that will not be possible.
 Old 05-09-2014, 10:36 AM   #12
trf5000's Avatar
Posts: 2,290   (View Stats)
This is a sweet fucking deal. Especially if you need to get back on the road in a hurry.
2010 MS3 - Sold
2015 CX-5 GT AWD - Current
The Following 2 Users Say Thank You to trf5000 For This Useful Post:
EdgeAutosport.com (05-09-2014), faeker (05-09-2014)
 Old 05-09-2014, 01:37 PM   #13
dan7225's Avatar
Posts: 511   (View Stats)
bsd delete void warranty?
stock head bolts & friction washers or arp or other?
 Old 05-09-2014, 02:47 PM   #14
BSD delete will possibly void the warranty. And is Mazda OEM parts for everything.
 Old 05-09-2014, 02:59 PM   #15
JgamB's Avatar
Posts: 2,566   (View Stats)
3 years unlimited boost - hrmmm, might need one of these.
EdgeAutosport.com (05-12-2014), kgb (07-30-2014)
 Old 05-09-2014, 03:22 PM   #16
speed23's Avatar
Posts: 1,480   (View Stats)
Thats awesome! Thanks Edge!
The Following User Says Thank You to speed23 For This Useful Post:
 Old 05-09-2014, 03:40 PM   #17
Ingle's Avatar
Posts: 421   (View Stats)
WHERE WAS THIS 8 MONTHS AGO?!?!
...Oh well, forced me to become built with the excuse "There are no other cheap/reliable options." The wife believed me
Ingle is offline   Reply With Quote
The Following 3 Users Say Thank You to Ingle For This Useful Post:
Bleupit80 (05-09-2014), EdgeAutosport.com (05-12-2014), kgb (07-30-2014)
 Old 05-09-2014, 04:25 PM   #18
blackms3_71's Avatar
Posts: 2,250   (View Stats)
Wow 4k for a full long block. The fear of blown up isnt as scary anymore. Thanks guys.
Side note : you guys really do great work and continue to take care of your customers and the msf community. Thanks again
The Following 8 Users Say Thank You to blackms3_71 For This Useful Post:
EdgeAutosport.com (05-12-2014), ericrapp0507@gmail.com (07-26-2016), Mauro_Penguin (06-04-2014), Raider (05-09-2014), SamiChicago (08-22-2014), sidekick (05-09-2014), speed23 (05-09-2014), SpeedThrizzle (06-04-2014)
 Old 05-09-2014, 04:40 PM   #19
PhillyCheese's Avatar
Posts: 226   (View Stats)
awesome. My Speed6 is at 87k currently. Going strong but I have thought about a rebuild or buying a reman.
MOD LIST
UNDER CONSTRUCTION
The Following 2 Users Say Thank You to PhillyCheese For This Useful Post:
EdgeAutosport.com (05-12-2014), sidekick (05-09-2014)
 Old 05-09-2014, 05:39 PM   #20
predapio's Avatar
Posts: 8,939   (View Stats)
Groans: 309
Very. interesting.
What a lovable bunch we are!!
The Following 2 Users Say Thank You to predapio For This Useful Post:
 Old 05-12-2014, 01:02 PM   #21
Since I'm putting this Long Block in my personal car, I figured I would start a thread to document it. If anyone is interested, you can follow that here.
Project Six Flip
So far, the bad engine has been removed and now I need to swap all the accessories over to the new engine.
blackms3_71 (05-12-2014), ericrapp0507@gmail.com (07-26-2016), faeker (05-14-2014)
 Old 06-04-2014, 09:29 AM   #22
Update on this. I finally got to check and it looks like the pistons used in this engine are the gen 1 style pistons. That being said, I did order it for a 2006 speed 6 and since they use OEM parts, that may be why. I don't know though if you were to order one for a Gen 2 speed 3 if it would come with the updated pistons...
This is how everything is sitting right now. Had to clean up the Oil Pan real good and now that the sludge is out I have to make sure and get all the little chunks of rod bearing out.
jeopardy98 (10-01-2014), JgamB (06-12-2014), predapio (06-04-2014)
 Old 06-04-2014, 06:40 PM   #23
alextheguineapig's Avatar
Posts: 827   (View Stats)
Awesome project! Wish I had the toys and time to get to work on something like this.
Current
SOLD!
2008 Sunlight Silver MS3:
BNR: S3 V2
Cobb: V3 AccessPort
Damond Motorsports: RMM
Eibach: Prokit
JBR: Rear Sway Bar
Koni: Yellows
MAC: 3-Port EBCS
 Old 06-04-2014, 09:00 PM   #24
maddocx240's Avatar
Posts: 823   (View Stats)
@EdgeAutosport.com; so they just use the Oem mazdaspeed rods too. I figured you could at least get stronger rods than Oem? That would be a great selling point you could run by them.
The Following User Says Thank You to maddocx240 For This Useful Post:
Mistersix (09-27-2014)
 Old 06-04-2014, 09:24 PM   #25
FSUMazdaSpeed's Avatar
Posts: 350   (View Stats)
@chasewiese;
The Following User Says Thank You to FSUMazdaSpeed For This Useful Post:
4RGED (06-16-2014)
 Old 06-04-2014, 09:58 PM   #26
Hargarbl's Avatar
Posts: 642   (View Stats)
Groans: 51
I agree completely, maybe just have it as an option where it would just be a difference in price between the 2. Although going by your website, and correct me if I'm wrong on this, but a set of Manley H beams are $360, where a single Oem rod is $136, so wouldn't it actually be cheaper using the aftermarket stronger rods? Now I do realize the rebuilder gets the parts at a fairly well discounted price then what we the consumer would pay, but I would think with the price difference it would almost break even.
 Old 06-04-2014, 10:10 PM   #27
SpeedThrizzle's Avatar
Posts: 427   (View Stats)
SpeedThrizzle is the leader of the worldSpeedThrizzle is the leader of the worldSpeedThrizzle is the leader of the worldSpeedThrizzle is the leader of the worldSpeedThrizzle is the leader of the worldSpeedThrizzle is the leader of the worldSpeedThrizzle is the leader of the worldSpeedThrizzle is the leader of the worldSpeedThrizzle is the leader of the worldSpeedThrizzle is the leader of the worldSpeedThrizzle is the leader of the world
Now I will never have to get rid of my gen1 for a PU! Edge FTMFW!!!!
08.5 MGM MS3
Tampa Nators "Fake Bot"
SpeedThrizzle is offline   Reply With Quote
The Following 2 Users Say Thank You to SpeedThrizzle For This Useful Post:
Big_Burd (06-12-2014), EdgeAutosport.com (06-05-2014)
 Old 06-04-2014, 11:33 PM   #28
ArmanRus's Avatar
Posts: 1,566   (View Stats)
Groans: 42
I read that if you want to use aftermarket rods with OEM pistons, the rods have to be machined to fit. Or vice versa. That will add cost, and they may not be able to warranty the engine. @Tokay444;
The Following User Says Thank You to ArmanRus For This Useful Post:
 Old 06-05-2014, 05:28 AM   #29
magicka's Avatar
Posts: 520   (View Stats)
Edge carries Eagle and Carrillo rods that will work with OE pistons (22.5 mm wrist pin). I think that Molnar does as well.
2009 CWP MS3 GT
 Old 06-05-2014, 06:40 AM   #30
kvg823's Avatar
Posts: 58   (View Stats)
kvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant future
@EdgeAutosport.com; Can you get a deal on these?
2006 Mazda 6 cylinder heads 2FGFR
I pull the head off this weekend to determine the extent of the damage and if it is just in the valvetrain I will be in the market. Otherwise I will be facing the @Ingle;
Dilemma with the wife.
2006 "GTMO Green" Speed 6
{ Corksport TBE w/ resonator }{ COBB AP }{ Corksport Max-Flow internals }
{ TWM STS Stg 2 w/ bushings }{ Primary/Secondary EGR Deletes }{ JBR Motor Mount Trilogy}
{TurboSmart BPV }{ COBB TIP }{ SS Brake/Clutch Lines }{ ARP Head Studs }
HTP 4" intake w/ 51R }{ FMIC }{ Enkei PF01 Rims }{ Stoptech Slotted rotors }{ AEM Wide-band AFR gauge }
AEM TRU-Boost Controller }{ Gauge pod (Block8head) }{ Bnoon Bolt }
{ Turbo-timer (yeah...) }{ PERM Plate }{ JBR Intake/TB TIGs }
{ Coming Soon: install GT3071r EWG setup, CPE Seals, tune, and re-paint }
kvg823 is offline   Reply With Quote
 Old 06-05-2014, 06:52 AM   #31
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
It's not the wrist pin that needs to be modified to fit oe pistons.
Manley has rods with 22.5mm pins as well. It's the small end that need to be tapered to fit the piston.
"Exclusivity" - CP-enis
Demodded.
The Seals
The Following 5 Users Say Thank You to Tokay444 For This Useful Post:
ArmanRus (06-05-2014), Easter Bunny (06-05-2014), EdgeAutosport.com (06-05-2014), magicka (06-05-2014), Mauro_Penguin (06-05-2014)
 Old 06-05-2014, 10:21 AM   #32
magicka's Avatar
I would have sworn that at one point @Dano; ran Carrillos and Gen Pu pistons without machining. His Trail of Fail™ is too long to page through on my phone, through.
Edit:
The first post in "Dano's build part duex" has the outline of the build. No mention of machining early on, although the thread runs to 57 pages on Forum Runner. It could still be buried in there.
2009 CWP MS3 GT
 Old 06-05-2014, 02:54 PM   #33
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
Yes you can order the Carrillos with the OE taper, Edge did not have them in stock but drop shipped them from Carrillo...they are the only rods you can do that with AFAIK.
 Old 06-05-2014, 03:47 PM   #34
Unfortunately there will be not semi built motor options with these engines. They are just remanufactured to OEM spec and the company that does it doesn't have any interest in doing custom builds. If you need a built block, I suggest a cp-e shortblock or Freekbuilt engine.
And like Dano said, the carrillos are the only ones that fit with stock pistons and those are quite a bit more expensive than OEM.
 Old 06-05-2014, 04:01 PM   #35
JSmith's Avatar
Posts: 707   (View Stats)
Groans: 106
Will they rework just the head? They never returned my email inquiring.
 Old 06-05-2014, 04:22 PM   #36
yeah it appears they have a head only option. I'm waiting on a response.
theurgy (06-05-2014)
 Old 06-12-2014, 02:57 PM   #37
JSmith's Avatar
Groans: 106
@EdgeAutosport.com;
Ever hear back on this?
 Old 06-12-2014, 05:26 PM   #38
Trail of Fail
Dano's Avatar
@EdgeAutosport.com;
yes and does the head only option come w happy ending...guessing so but inquiring minds....
Easter Bunny (06-12-2014), EdgeAutosport.com (06-13-2014), theurgy (06-12-2014)
 Old 06-13-2014, 11:03 AM   #39
We will be adding the Head to our site shortly. It will be $984 for the reman head plus a $175 core charge. As of right now, there is a 2 to 3 week lead time on them.
Coaststarlight (06-24-2014)
 Old 07-16-2014, 08:28 AM   #40
Well the install in my MS6 went well. After sorting out the oil return line issue for the EWG GTX3071 which was the only real snag I ran into during the install, I was able to get the car up and running and got some break in miles on it before delivering it to Texas on Friday to meet up with its new owner.
The final install went smoothly as well as the 14hr drive from Denver to East Texas. For anyone considering getting this engine for themselves, it is about as easy as it gets for coming back from a zzb or similar failure.
If you have any questions, feel free to let me know and I'll be happy to help!
SamiChicago likes this.
Hush (07-16-2014), JgamB (07-30-2014), Mattcinnc1 (11-18-2014)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f539/mzr-disi-remanufactured-long-blocks-now-available-170110/
BLOWN L3!!!! 07 bk mps rod through block HELP - Page 2 This thread Refback 07-27-2014 09:44 PM
NAPA remanufactured block Axel907 MazdaSpeed 6 - Engine, Transmission & Driveline 57 11-21-2014 09:55 PM
Vacuum Blocks 3P EdgeAutosport.com EdgeAutosport.com 28 12-13-2012 08:17 AM
HP Remanufactured Photosmart C5280 Color Flatbed All-in-One $64.98 Haltech Hot Deals Section 0 04-03-2008 09:20 AM
Page generated in 0.60470 seconds with 47 queries
