Like Tree25Likes
 Old 08-21-2014, 01:13 PM   #41
dale_gribble's Avatar
Posts: 4,720   (View Stats)
For everyone wondering, Edge did a great job on this kit. I priced the equivalent Stage 3 out initially part for part from Jim Ellis Mazda Parts online which usually has decent pricing. It wasn't to double check Edge, it was more of a sanity check for me that it has all of the parts I need.
Edge's Stage 3 kit with VVT comes in at least $200 cheaper than individual pricing and I know they have a running MSF discount code, so the are even better than that.
@EdgeAutosport.com;, can you confirm that you provide the latest VVT actuator as the VVT option (L3K9124X0C9U)?
Great job adding the cap/head bolt options.
Honestly, some good pistons & rods and this stage 3 kit with bolts + good machine work = well built motor for <3k. An entire engine build only takes 1 simple order with 3 items through Edge!
EdgeAutosport.com likes this.
MINI H1 6.0 - CAR LED TAILS
ItsNox (08-22-2014), jdmage_mx5 (08-21-2014), Mauro_Penguin (07-22-2015)
 Old 08-22-2014, 11:30 AM   #42
We do offer the latest VVT actuator with our kits. Its the only one available as it superseded the original.
 Old 05-06-2015, 02:48 PM   #43
Hey guys, just wanted to let you know that we made some updates to this.
All motor build kits now come with the OEM Oil Pickup as this is likely more important to replace than the oil pump. We also added the option to add the massive speed timing tools to the motor build kits and the VVT Kit. And the VVT Kit now comes with the cam bolt as well.
We keep all of this stuff in stock so most of the time you will only have to wait for the 3 to 4 business days it takes to ship (unless you choose a faster option)
Let me know if you have any questions!
JgamB (05-06-2015), Micha (05-19-2015)
 Old 05-06-2015, 02:59 PM   #44
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
I love edge.
Nicely done guys
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
EdgeAutosport.com (05-07-2015)
 Old 05-15-2015, 11:58 AM   #45
Make sure you read the descriptions before purchasing so you know exactly what you are getting! Everything in these kits is either necessary or highly recommended for when you are building a motor!
 Old 05-17-2015, 04:38 PM   #46
Zoom66's Avatar
Posts: 281   (View Stats)
Great job on the kits, I am currently using the stage 3 to rebuild my motor and it has everything you might need and more.
Let me suggest that for these kits you add one camshaft friction washer part number L3K9-12-429. The reason I say this is that regardless if you replace the VVT actuator or not, you have to loosen the exhaust camshaft sprocket when you are timing your engine. For peace of mind is recommended to replace this one after it is used. Thanks guys.
The Following 2 Users Say Thank You to Zoom66 For This Useful Post:
EdgeAutosport.com (05-18-2015), shaneski (05-18-2015)
 Old 05-18-2015, 01:48 AM   #47
shaneski's Avatar
Posts: 505   (View Stats)
Beat me to it about the cam friction washers. Buying the stage 2 kit from Edge saved me hundreds of dollars to what i would of paid getting it off Mazda here in Aus
The Following 2 Users Say Thank You to shaneski For This Useful Post:
EdgeAutosport.com (05-18-2015), Zoom66 (05-18-2015)
 Old 05-19-2015, 10:12 PM   #48
King Scumbag's Avatar
Posts: 2,384   (View Stats)
Stage 2 kit is a must IMO. Re-Used my VVT system on the new motor because it was replaced only 10k Miles prior to the build and presented no problems. Just replaced the friction washers and Crank bolt. Till I started getting some crazy timing codes. (One rare one that people have been chasing (P0012). After endless amounts of trouble shooting with no grounds gained. I ended up replacing everything in the VVT including the actuator <--Probably didn't have to do that it was a "Rev C", but I did.
My speculation came down to the Tensioner being reused. Had just a cunt hair of less tension on it causing an over retard on the intake camshaft.
07 BLACK MICA MS3
PATTY/JEFF BUILT MOTOR
STOCK BLOCK
BOSTON STRONG
The Following 2 Users Say Thank You to King Scumbag For This Useful Post:
EdgeAutosport.com (05-20-2015), Zoom66 (05-20-2015)
 Old 05-20-2015, 11:11 AM   #49
Yeah its one of those things where its just insurance against a more costly fix later on down the road...
 Old 05-29-2015, 04:14 PM   #50
If you plan on building a motor, this will help ensure you are not left waiting on parts that you didn't know you needed.
 Old 06-04-2015, 03:15 PM   #51
We keep this stuff in stock so you don't have to wait for your local mazda dealer to get everything in!
 Old 07-17-2015, 01:49 PM   #52
No need to make it difficult on yourself!
 Old 07-21-2015, 02:29 PM   #53
We keep the stuff for these kits in stock so you don't have to wait while parts are sourced from all over.
dan7225 (07-21-2015)
 Old 09-03-2015, 02:39 PM   #54
Building your motor? This will help...
zjnspeed3 likes this.
 Old 09-17-2015, 01:17 PM   #55
Do you know what you need for your built motor?
 Old 09-17-2015, 01:32 PM   #56
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
This kit made my life easier.
 Old 09-29-2017, 09:06 AM   #57
jstnpke's Avatar
Posts: 6   (View Stats)
jstnpke is an unknown quantity at this point
So one of these kits + rods + pistons and it should be everything needed for a fresh motor rebuild? correct?
How do you know which size bearings to order?
Last edited by jstnpke; 09-29-2017 at 09:06 AM. Reason: MSF Database - Automerged Doublepost
jstnpke is offline   Reply With Quote
 Old 09-29-2017, 01:47 PM   #58
KiwiFlavor likes this.
The Following 4 Users Say Thank You to Code Monkey For This Useful Post:
KiwiFlavor (10-06-2017), monkey.bones.007 (09-30-2017), MS3Shadow (09-29-2017), shaneski (09-29-2017)
What You Need to Know to Build a Motor TWOptSL0W Mazda MZR DISI Engine Builds (2006-2013) 73 07-26-2019 03:57 PM
What You Need to Know to Build a Motor TWOptSL0W MSF KB - Mazdaspeed 3/6 - Engine/Turbo Builds 14 09-26-2012 03:33 PM
HOW TO build an mzr motor!! qtrmile beast MazdaSpeed 6 - Engine, Transmission & Driveline 4 09-12-2012 05:07 AM
everything neded to build motor? ms3boost MazdaSpeed 3 - Engine, Transmission & Driveline 15 05-04-2009 11:14 PM
Build A 9v Battery Connector, Turn Signals Won't Work, Shop Safety, Diesel Engines, HHO Kits: Mike Allen's Weekly Online Haltech Automotive News 0 10-10-2008 03:10 PM
Page generated in 0.38787 seconds with 28 queries
