Like Tree9Likes
 Old 08-18-2014, 10:05 AM   #41
Nel Mazdaspeed's Avatar
Posts: 407   (View Stats)
Nel Mazdaspeed is the leader of the worldNel Mazdaspeed is the leader of the worldNel Mazdaspeed is the leader of the worldNel Mazdaspeed is the leader of the worldNel Mazdaspeed is the leader of the worldNel Mazdaspeed is the leader of the worldNel Mazdaspeed is the leader of the worldNel Mazdaspeed is the leader of the worldNel Mazdaspeed is the leader of the worldNel Mazdaspeed is the leader of the worldNel Mazdaspeed is the leader of the world
By chance did you happen to get a inconsistent clicking sound while the clutch pedal is out? And clicking when revving the engine at low blip rpms?
Nel Mazdaspeed is offline   Reply With Quote
 Old 08-18-2014, 10:25 AM   #42
Mylifeiseasy's Avatar
Posts: 74   (View Stats)
Mylifeiseasy has much to be proud ofMylifeiseasy has much to be proud ofMylifeiseasy has much to be proud ofMylifeiseasy has much to be proud ofMylifeiseasy has much to be proud ofMylifeiseasy has much to be proud ofMylifeiseasy has much to be proud ofMylifeiseasy has much to be proud ofMylifeiseasy has much to be proud of
Groaned at 6 Times in 3 Posts
No clicking a tiny bit of clutch chatter a light rattling sound. when idle with clutch out and rpms are low. Turning on the ac makes it a bit louder. But I am thinking this Is normal for a stage 3.
2008.5 gtx fmic dm pd Manley
Mylifeiseasy is offline   Reply With Quote
 Old 08-18-2014, 10:51 AM   #43
Chatter is pretty normal anytime you go with a lighter flywheel.
 Old 08-18-2014, 11:14 AM   #44
For those who just put there clutch in. It was super stiff the first few times I pushed it in I thought something must be wrong. But it just keeps getting better and easier everyday. It was hard to bleed all the air out of the slave. I did not disconnect the original slave just bolted it on and it blew its seal before I got out of the drive way. Got a new oem slave started to bleed it and ran the res dry. Took twenty mins of pumping clutch pedal to get pressure and blew the second slave. Got the oem slave warrented and got a motive power bleeder . Bleeding all the air out by myself no help no pumping . Worked perfect. No problems since. That incident. I have been working on cars for 25yrs. Never had a bleeding issues befor. The only comment I got on my problem that made any sence was that the slave I got was just a bad part and I didn't need a power bleeder. And I agree. But I like the motive power bleeder and I am ver happy I bought it.
The Following 2 Users Say Thank You to Mylifeiseasy For This Useful Post:
EdgeAutosport.com (08-18-2014), JTMS3 (08-18-2014)
 Old 08-18-2014, 11:20 AM   #45
They didnt bleed my slave.. he said he didnt have to because he didnt disconect it.. ?
 Old 08-18-2014, 11:22 AM   #46
That's normal. If it's working it will be fine. They seem a bit fussy they either work or blow lol.
 Old 08-28-2014, 02:02 AM   #47
shaneski's Avatar
Posts: 505   (View Stats)
Is there a defective batch of machined flywheels @Papasmuf flywheel stage 4 extreme)? doesn't fit onto the end of the crank as the inner diameter is too small and the same thing with mine when it was to be installed today. Mine is stage 3 enduro was shipped August 2nd.
 Old 08-28-2014, 11:40 AM   #48
We think there was a defective batch. We are trying to get with South Bend to correct the problem. Haven't been able to get a response yet though. We will not be selling anymore SB clutches until the issue is resolved though as this has happened a few times now.
Micha (09-16-2014), PapaSmurf (08-30-2014)
 Old 08-29-2014, 09:06 AM   #49
JTMS3's Avatar
Posts: 2,306   (View Stats)
My FW fit without issue. I will say there guide pin is not very accurate (cheap). I had to hold it while someone else tightened the PP.
 Old 08-29-2014, 09:12 AM   #50
No problems with mine. The paint on the pressure plate made it a bit hard to get in place. A little sand paper fixed that. I had my buddy hold everything in place wile I tightened everything up.
 Old 08-31-2014, 07:48 AM   #51
cletusb's Avatar
Posts: 488   (View Stats)
Will those affected be contacted? My order number is 18800 and the plan was to install in the next couple of weeks. Would be best to know before hand if something needs to be corrected
 Old 09-02-2014, 12:35 PM   #52
Can someone here tell me how your clutch felt after breakin...
My stage3 pedal engagement is happening at about half way out, the only time I remember feeling it that way was when I needed to replace it.
Any help would be appreciated.
 Old 09-02-2014, 04:30 PM   #53
Can you measure the center bore on the flywheel? I need to find out what it needs to be because I don't know off hand but that will be the best way to tell if its correct or not.
Engagement and pedal feel will definitely change, but you may want to check and make sure you are not leaking between the clutch master or slave cylinders.
Nel Mazdaspeed (09-02-2014)
 Old 09-03-2014, 02:48 AM   #54
shaneski's Avatar
The Southbend flywheel i received was 27mm and the crank end is 30mm ,I ended up getting mine machined to fit which cost me an extra $245 out of my pocket to have it machined and freighted to and back from the machine shop.
Being overseas i had my car in the shop to get fitted when it was discovered, my only other option was getting them to put the oem clutch back in that came out and paying $800 labour for nothing.
Not happy how this is being handled, i emailed you guys a week ago when the car was on the lift asking if anything can be express shipped and received no response,other than reading on here no response from Southbend as yet..Wouldn't you guys pick up the phone and get a response straight away from them considering the premuim price we paid as well as us guys from overseas who also paid a few hundred in shipping.
 Old 09-03-2014, 07:28 AM   #55
Hmm die grinder bit about 20 bucks and 5 mins of grinding. For 245 bucks. That's a lot of butt hurt there.
IMO... Anyone considering spending 1k to have someone else put a clutch In should consider doing it them selves. 1k buys you a lot of cool tools and 1k in tools will save you thousands more over the years to come.
Last edited by Mylifeiseasy; 09-03-2014 at 07:28 AM. Reason: MSF Database - Automerged Doublepost
 Old 09-03-2014, 04:45 PM   #56
Hey Shane,
I just found your email from last Thursday about the clutch. I am very sorry you have not gotten a response from us. We have actively been trying to work with South Bend on this and we have gotten nowhere with emails or phone calls. When we call them we get transferred around through different departments until we end up at an answering machine. We have not forgot about you and we will take care of you. Again, I am sorry for the lack of response from us but we will handle this with South Bend one way or another.
shaneski (09-04-2014)
 Old 09-03-2014, 06:47 PM   #57
This is sad to hear. From all the talk on there web sites and face book about how great they rate themselves. You think this wouldn't be a problem. I called them to ask a tech questions and they were on the ball. I got someone on the phone rite away. I hope they get there shit together. Fast!! Or they will lose a lot of business.
 Old 09-05-2014, 06:37 PM   #58
cletusb's Avatar
Sorry I'm not real sure what we are measuring but the hole at the bottom of the assembly on mine seems to be about 32mm.
Does that seem right?
 Old 09-05-2014, 10:44 PM   #59
My oem is 31.5mm so you got a good one.
The Following User Says Thank You to Mylifeiseasy For This Useful Post:
EdgeAutosport.com (09-08-2014)
 Old 09-09-2014, 11:07 AM   #60
IMASA's Avatar
Posts: 209   (View Stats)
Any updates on the issue with SBC clutches? I need one NOW!
 Old 09-09-2014, 12:32 PM   #61
South Bend has finally gotten back in touch with us and are investigating the issue.
cletusb (09-09-2014), IMASA (09-09-2014)
 Old 09-09-2014, 03:28 PM   #62
cletusb's Avatar
Thanks for the update. Mine goes in next week so would be good to hear results from the investigation before then ☺
 Old 09-09-2014, 04:37 PM   #63
If sb know about the problem they probably won't ship anymore out that are undersized. So if your worried about just ordering one. Call them directly and ask them personly before you order. All you have to do is measure the hole when you get it.
 Old 09-09-2014, 06:52 PM   #64
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
Well my CM twin disc got here and it fit perfect. Def a problem on SB end
860whp/677wtq
2.7 V6 Ecoboost
Bob-o (09-10-2014)
 Old 09-10-2014, 02:57 AM   #65
shaneski's Avatar
I would personally like to thank Edge especially Alan for his assistance and offering to reimburse me the machining fees i paid to get the flywheel to fit, the offer to do that is priceless as Edge weren't to know some of the flywheels were shit.
The clutch itself feels smoother to engage than OEM, the pedal is a tad heavier. There is chatter noise on any acceleration..the noise could be amplified more as i have the JBR tranny mount.
I am interested what the weight difference is between the stock and Southbend flywheel i didn't think to weigh either of them and i passed on the OEM flywheel already.
The Following 3 Users Say Thank You to shaneski For This Useful Post:
EdgeAutosport.com (09-16-2014), IMASA (09-10-2014), SarcasticOne (09-10-2014)
 Old 09-16-2014, 01:17 PM   #66
Just wanted to give you guys an update. SouthBend is addressing the flywheel issue.
Micha (09-16-2014), PapaSmurf (09-16-2014), TJ446 (09-16-2014)
 Old 09-18-2014, 08:48 AM   #67
JTMS3's Avatar
This clutch is awesome. .. That is all.
The Following User Says Thank You to JTMS3 For This Useful Post:
Brendanb (06-13-2015)
 Old 09-18-2014, 09:08 AM   #68
Matrix311's Avatar
Posts: 2,133   (View Stats)
I have the south bend stage 3 clutch in my car and I installed it 13 months ago. I've put a very hard 14,000 miles on this clutch with my Gtx3071r and it's holding up perfectly fine. It's never slipped once. I never had any issues with my flywheel it worked the day I installed it. I would highly recommend this clutch to anyone. I'm running stage 3.
The Following 5 Users Say Thank You to Matrix311 For This Useful Post:
Bob-o (09-30-2014), EdgeAutosport.com (09-18-2014), JTMS3 (09-18-2014), Nel Mazdaspeed (09-21-2014), TJ446 (09-20-2014)
 Old 09-30-2014, 03:17 AM   #69
Bob-o's Avatar
Posts: 1,312   (View Stats)
@EdgeAutosport.com;
Any updates with the status of the flywheels?
EWG GTX3071 | PERM 3.5" intake | COBB FMIC | CP-e injector seals | UR downpipe | CS testpipe | HKS catback | KW V1's | Blahblahblah
 Old 09-30-2014, 03:35 AM   #70
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
@Zdraveca;
 Old 09-30-2014, 11:32 AM   #71
South Bend is working on it. We have three clutches we have to send back to them with the Flywheel being off a little.
 Old 09-30-2014, 02:18 PM   #72
Zdraveca's Avatar
Posts: 3,888   (View Stats)
Groans: 145
NO! mine is still good
2011 MS3"Princess GRU"
GT2876r
E85 FREEKTUNE
 Old 10-18-2014, 09:15 PM   #73
England15j's Avatar
Posts: 1,910   (View Stats)
Any updates on this?
 Old 10-19-2014, 02:15 AM   #74
Bob-o's Avatar
I think edge is aware and will check of the issues (if any) that their kits may have, and only ship out the good ones to those who buy through them
 Old 10-20-2014, 02:45 PM   #75
Southbend is pulling all their inventory to have it fixed. They are sending us a few kits that have already been fixed so we should have them back in stock soon.
 Old 10-23-2014, 01:13 PM   #76
We've got the fixed south bend clutches back in stock.
Bob-o (10-23-2014), SpeedRebirth (10-23-2014)
 Old 10-23-2014, 01:15 PM   #77
biggman026's Avatar
Posts: 453   (View Stats)
biggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the world
Groaned at 49 Times in 12 Posts
Any reason they're not listed in the MS6 section of your site?
2007 Mazdaspeed 6 - Black Mica - ZZB RIP 2016!
BNR S3, JBR 3" wp intake, JBR rmm, JBR heavy shift knob, JBR shifter bushings, JBR SSP, South Bend Stage 3 Endurance clutch, Juggernaught/Dreadnaught, Autotech HPFP, 3 bar map sensor, Stratified Boost Dial, Streetunit TMIC, Forge V2 BPV, ebay DP/TP, 3 inch custom single exit cat-back, magnaflow muffler, H&R springs, Cobb AP, JL Audio 12" W3 w/ 500w Alpine amp, 6000k HIDs, LED fogs, dipped and tinted - Stratified 369awhp/383awtq vdyno on 4 gallons of corn
biggman026 is offline   Reply With Quote
 Old 10-23-2014, 02:59 PM   #78
They come up when I search for the MS6.
MS6/Transmission/Clutch
We have been doing some site maintenance that could have messed up your search...
 Old 10-23-2014, 03:44 PM   #79
SpeedRebirth's Avatar
Posts: 685   (View Stats)
Groans: 33
They dont show for me either. Your link works great but filtering on "2006/07 > Mazda > Mazdaspeed 6 > Transmission" only shows SPEC, Thechna-fit, DDS ect:
Mazdaspeed, Subaru, Mitsubishi, Honda, Nissan, VW, BMW, Hyundai, and more Performance and Aftermarket Parts | Sport Compact and Tuner Aftermarket Performance Car Parts
Mazdaspeed6 -06
Tuned with by Alex@Stratified
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
 Old 10-23-2014, 03:47 PM   #80
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
your kidding me,
do you guys offer south bend clutches for the 1zz/2zz mr2spyder/celica gts platform?
ACT Clutches In Stock at EdgeAutosport. EdgeAutosport.com EdgeAutosport.com 7 09-30-2013 03:42 PM
3" crush bend vs 2 1/2" mandrel bend exaust chuckdaiceman MazdaSpeed 6 - Engine, Transmission & Driveline 7 05-04-2009 11:18 PM
Page generated in 0.56427 seconds with 36 queries
