 Old 03-27-2014, 10:25 AM   #1
Default SPC Rear Camber Arms at EdgeAutosport
Hey guys, a lot of you are starting to add lowering springs and coilovers to your cars to get that nice drop all around. Whether you are going for form or function with your drop, you may want to consider addressing rear camber. When you lower a car, it will naturally develop more negative camber and this can cause excessive wear on your tires or less than desirable handling characteristics. It is important to get your rear camber in check for the best results from a lowered car. Some of you may need more negative camber to keep your tires from rubbing on the fender while others may need less negative camber to allow better rotation of the car around corners and help minimize understeer. Either way, you will need the SPC Rear Camber Arms.
The SPC Rear Camber Arms are adjustable without having to unbolt them from the car which makes adjustments for alignments much easier.
They are $176 shipped for the pair in the continental US and are definitely worth including with your order for lowering springs or coilovers.
Click any of the pictures to purchase from our site. And be sure to let us know if you have any questions!
white'swhiteMPS (03-27-2014)
 Old 03-27-2014, 11:32 AM   #2
white'swhiteMPS's Avatar
Posts: 639   (View Stats)
ill be picking these up soon
Freektuned- E85 4/8gal mix
white'swhiteMPS is offline   Reply With Quote
The Following User Says Thank You to white'swhiteMPS For This Useful Post:
EdgeAutosport.com (03-27-2014)
 Old 03-27-2014, 10:24 PM   #3
Sinister_Speed3's Avatar
Posts: 180   (View Stats)
Sinister_Speed3 has a reputation beyond reputeSinister_Speed3 has a reputation beyond reputeSinister_Speed3 has a reputation beyond reputeSinister_Speed3 has a reputation beyond reputeSinister_Speed3 has a reputation beyond reputeSinister_Speed3 has a reputation beyond reputeSinister_Speed3 has a reputation beyond reputeSinister_Speed3 has a reputation beyond reputeSinister_Speed3 has a reputation beyond reputeSinister_Speed3 has a reputation beyond reputeSinister_Speed3 has a reputation beyond repute
I should have gotten a set of these, my JBRs are loud and cost more to align.
Sinister_Speed3 is offline   Reply With Quote
 Old 03-28-2014, 07:50 AM   #4
Yeah these make alignments much easier since you don't have to disconnect them to adjust them. Just make sure that you line them up with your factory camber arms before you install them so that you or whoever is aligning your car has a good base point to start from.
Corksport Struts, JBR Rear Sway Bar, JBR Rear Camber Arms Install/Initial Feedback Sinister_Speed3 MazdaSpeed 3/6 - Suspension & Brakes 15 11-25-2015 09:03 AM
Page generated in 0.25390 seconds with 22 queries
