 Old 04-22-2019, 09:56 AM   #1
5doorsoffury's Avatar
Posts: 1,123   (View Stats)
Groans: 74
I think i got that one then added the vvt and the cam washers and the bolts for cam/crank. You still need injector seals. It worked out to be a better price once you add in the valve seals and injector orings.
You also need the obvious. It dosent come with bearings btw.
MECP
2012 BM
Rfinkle tune in progress
The Following User Says Thank You to 5doorsoffury For This Useful Post:
juantaburger (04-23-2019)
High Mileage Motor Build or not to Build Kentozer MazdaSpeed 3/6 - Build Diaries 3 11-15-2018 05:59 PM
2010Speed3 BNR Stage 3 Build 2010Speed3 2010 MS3 - Big Turbo Builds 43 05-19-2015 06:51 PM
How-to: CP-E Stage 2 Rear Motor Mount RallySportDirect 2010 MS3 - Engine, Transmission & Driveline 11 07-15-2013 03:21 PM
New stage 2 CP-e rear motor mount peter_parker8740 2010 MS3 - Engine, Transmission & Driveline 210 08-09-2012 09:02 PM
CP-E Stage 2 motor mount? breakfstincluded Custom Performance Engineering (cp-e.com) 21 02-04-2012 12:10 PM
Page generated in 0.22545 seconds with 21 queries
