 Old 04-03-2014, 03:17 PM   #1
Default Supertech Valvetrain at EdgeAutosport
As more and more big power builds are beginning to surface, we see the need continue to grow for valvetrain upgrades. Supertech has been offering these upgraded valvetrain components for some time now and I figured some of you guys getting ready to build may be interested in knowing that they are available.
The following is some of the Supertech components we keep in stock here at EdgeAutosport.
Supertech Exhaust Valves:
Available in Iconel or Nitride and in standard size, +1mm over size, and +2mm oversize.
Iconel Exhaust Valves - $238 for a set of 8
Nitride Exhaust Valves - $159.60 for a set of 8
Supertech Intake Valves:
Click HERE to view all Valve options
Iconel Intake Valves - $159.60 for a set of 8
Supertech Valve Springs and Retainers: $336.73 for the set
•Type: Single Spring
•Press.Seat: 55 @ 35
•Press.Open: 150 @ 10
•Max Lift: 14.3mm
•Coil Bind: 20.7mm
•Rate: 9.6mm
•Retainer: RET-TS5.5/T1+Fact Seat + SEAT-DUR1
•OutSpr.OD: 27.5mm
•OutSpr.ID: 20mm
Supertech Valve Guides: - $88.64 for the set of 16
These are necessary if you plan on running the upgraded valves.
Supertech Valve Seals: - $11.20 for a set of 16
These are designed to work with the Supertech valves and valve guides.
These upgrades may not be for everyone but if you are planning to run big boost, rev higher, or do some port/polish work on your head to open up flow, then they will definitely be a benefit to you.
06Speed6 (04-03-2014), Domino81 (04-04-2014), Easter Bunny (04-24-2014), Nitr0EngiE (04-03-2014), speed3 britz (04-25-2014)
 Old 04-03-2014, 04:09 PM   #2
skiptowncat's Avatar
Posts: 1,592   (View Stats)
Damn you, I have more stuff to buy!!!
Tuned with by
The Following User Says Thank You to skiptowncat For This Useful Post:
EdgeAutosport.com (04-03-2014)
 Old 04-03-2014, 05:13 PM   #3
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
Bravo !
 Old 04-24-2014, 10:46 AM   #4
Rev higher or push more boost. Whatever you want to do with this valvetrain
 Old 05-09-2014, 09:02 AM   #5
How many of you guys know that the MZR DISI has a 3 angle valve job from the factory?
dagrimey1 (05-09-2014), Mauro_Penguin (05-09-2014)
 Old 05-28-2014, 05:12 PM   #6
We have these valvetrain components in stock!
Supertech Valvetrain Info holeinmypocket MazdaSpeed 3 - Engine, Transmission & Driveline 27 03-06-2015 11:29 AM
E30 UOA results with SuperTech 5w-30 Synthetic cld12pk2go MazdaSpeed 3/6 - E85 Fueling 6 08-27-2014 10:31 AM
Supertech valve into jracer Mazdaspeed3/6 General Discussion 28 09-25-2012 03:20 PM
Supertech wants our head zx2man MazdaSpeed 3 - Engine, Transmission & Driveline 38 07-17-2011 07:03 PM
Knock in valvetrain? meeker13 MazdaSpeed 6 - Engine, Transmission & Driveline 33 04-18-2010 08:50 PM
Page generated in 0.27376 seconds with 22 queries
