Like Tree26Likes
 Old 08-14-2013, 10:08 AM   #1
Default Wilwood Brake Kits at EdgeAutosport!
Well guys, they are finally here. Many of our customers over the last couple years have been asking about more brake kit options. There are a few good ones out there but it leaves most people with incomplete, mismatched, or impractical braking setups. Starting today, that changes.
Several Wilwood combinations and kits customized for the Mazdaspeed 3 are now exclusively available through Edge Autosport.
Here's a run down of what options are available and some general info about the kits. More information can be found by clicking the links to each kit here.
-Wilwood Narrow Superlite 6 Piston Calipers
-Wilwood 2 Piece Slotted Rotors
-Wilwood BP-10 Brake Pads
-Custom Stainless Steel Brake Lines
-Custom Billet Caliper Mounting Brackets
Wilwood 6 Piston Caliper Kit FRONT
$950.00
-Wilwood Dynapro 6 Piston Calipers
-Designed for use with STOCK or upgraded factory size rotors
Wilwood 4 Piston Caliper Kit FRONT
$525.00
-Wilwood Dynapro 4 Piston Calipers
Wilwood 4 Piston Caliper Kit REAR
$795.00
-Wilwood Powerlite 4 Piston Calipers
-Retains Factory Parking/Emergency Brake
-New Parking/Emergency Brake Lines
We also have a few other options available including:
-Wilwood 13 inch 4 Piston Front Big Brake Kit for Mazdaspeed 3 and Mazdaspeed 6
PLEASE let us know if you have any questions about the kits! We'd be glad to help with anything we can! We have a few kits in stock and ready to ship!
NOTE: It is normal for the pads in the caliper kit to not cover the entire factory rotor.
The Following 85 Users Say Thank You to EdgeAutosport.com For This Useful Post:
4RGED (08-14-2013), adamizme (04-06-2015), Alpha (08-20-2013), amggilly305 (08-21-2013), anavrinIV (08-21-2013), Bolted6 (08-15-2013), Boosted Beluga (08-16-2013), Boost_creep (08-17-2013), breakfasteatre (08-19-2013), breakfstincluded (08-15-2013), Celestspeed3 (08-23-2013), Code Monkey (08-14-2013), cshunter (08-15-2013), daafisch (08-14-2013), dale_gribble (08-15-2013), darkcherry (08-16-2013), darkstar5440 (08-16-2013), derek0609 (11-27-2013), derek13p (09-14-2013), diego_uru (08-17-2013), DISIindahead (08-17-2013), djuosnteisn (08-19-2013), Domino81 (08-18-2013), dot584 (08-14-2013), DuoofDeath1 (08-19-2013), Easter Bunny (09-22-2013), El_Diablo (08-14-2013), fishin53 (08-18-2013), galens47 (08-22-2013), Grumpyjap (10-22-2013), helmetface (08-14-2013), Hush (08-15-2013), IamJamen (08-14-2013), IanMacKenzie (08-16-2013), ItsNox (09-19-2013), jared. (11-10-2013), JBR (08-15-2013), Jh8909 (08-14-2013), jracer (08-16-2013), JTMS3 (09-01-2013), jtms6 (08-18-2013), kdoughty00 (09-01-2013), Kellerspeed3 (09-15-2013), KILLER_VIZ (08-17-2013), kpuser1 (08-14-2013), Lancer-AM (08-21-2013), Lex (08-14-2013), MarineMazda (08-18-2013), Mauro_Penguin (08-15-2013), MazdaBoy2.3 (08-16-2013), Micha (08-16-2013), MS3G35 (08-15-2013), mWindu (08-14-2013), nighthawk358 (08-14-2013), Nliiitend1 (08-15-2013), psychophyr (08-17-2013), qtrmile beast (08-15-2013), Raider (08-15-2013), RE-ACTIONENGSPEED3 (08-17-2013), RhoadBlock (08-19-2013), RobT2009 (10-10-2013), Ryguy (08-15-2013), silvapain (08-19-2013), Sinerspeed (08-21-2013), SLOWHATCH (08-14-2013), snailD (08-22-2013), SparkySparks (08-19-2013), speed3sailor (08-14-2013), speeding3 (08-15-2013), Speed_j23 (08-15-2013), StayGold_562 (09-25-2013), Sterling (10-21-2013), superskaterxes (08-15-2013), super_pablo_ (09-09-2013), Tabasco69 (08-18-2013), taf0422 (08-16-2013), TexasSpeed3 (08-18-2013), The Nut (08-20-2013), Tokay444 (08-16-2013), Tomas (08-14-2013), triplejumper18 (08-16-2013), Vader (08-14-2013), warlord (08-14-2013), YABBAMZR (08-15-2013), [R]usty (08-14-2013)
 Old 08-14-2013, 12:26 PM   #2
mWindu's Avatar
Posts: 244   (View Stats)
mWindu is the leader of the worldmWindu is the leader of the worldmWindu is the leader of the worldmWindu is the leader of the worldmWindu is the leader of the worldmWindu is the leader of the worldmWindu is the leader of the worldmWindu is the leader of the worldmWindu is the leader of the worldmWindu is the leader of the worldmWindu is the leader of the world
Already ordered!
So excited to start using them in the name of love, for hammer time, and before I collaborate and listen.
\\2008.5 MGM Speed3//
POWER
\\Autotech HPFP//HTP 3.5" Intake\\CNT Catback//Corksport TP\\TR1035 FMIC//P&P Intake Mani\\JBR TIGS//EGR Delete\\
HANDLING
\\JBR 88 Duro Trilogy Mounts//H&R Coilovers\\JBR RSB//Whiteline Adjustable Rear Endlinks\\Corksport Camber Plates//JBR Camber Arms\\SS Brake Lines//
\\Stoptech Drilled Rotors\\
\\STRATIFIED TUNED//
mWindu is offline   Reply With Quote
The Following 9 Users Say Thank You to mWindu For This Useful Post:
4G63 (09-14-2013), chomorro (08-17-2013), EdgeAutosport.com (08-14-2013), Ferdball (08-14-2013), Micha (08-16-2013), msantana101 (08-14-2013), SLOWHATCH (08-14-2013), Vader (08-14-2013), xI Leveler Ix (08-15-2013)
 Old 08-14-2013, 12:59 PM   #3
Oalmon's Avatar
Posts: 999   (View Stats)
Oalmon is the leader of the worldOalmon is the leader of the worldOalmon is the leader of the worldOalmon is the leader of the worldOalmon is the leader of the worldOalmon is the leader of the worldOalmon is the leader of the worldOalmon is the leader of the worldOalmon is the leader of the worldOalmon is the leader of the worldOalmon is the leader of the world
Groans: 32
Groaned at 37 Times in 28 Posts
Originally Posted by mWindu View Post
Already ordered!
U forgot the ruff ryder's anthem...... Stop drop shut em down open up shop
Oalmon is offline   Reply With Quote
The Following User Says Thank You to Oalmon For This Useful Post:
Micha (08-16-2013)
 Old 08-14-2013, 01:12 PM   #4
[R]usty's Avatar
Posts: 2,204   (View Stats)
Damn. This is amazing. All the choices! I like the 4 pistons for fronts for 525.
2010 Mazdaspeed3 w/tech
The Following 6 Users Say Thank You to [R]usty For This Useful Post:
brandonlee (08-15-2013), EdgeAutosport.com (08-15-2013), Micha (08-16-2013), Quigs (08-14-2013), SLOWHATCH (08-14-2013), SneakySin (08-15-2013)
 Old 08-14-2013, 01:28 PM   #5
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
Holy shit! A rear BBK for the MS3? oh sweet baby jesus.. what to do now...
EDIT: what kind of brake pads does the rear kit used? Off the shelf or proprietary Wilwood?
Hmmm... Stoptech front BBK and Wilwood rear BBK.... not sure about that lol...
EDIT 2: Any info on how the various kits affect Brake Bias?
The Following 5 Users Say Thank You to hnda etr For This Useful Post:
Code Monkey (08-14-2013), EdgeAutosport.com (08-15-2013), Micha (08-16-2013), SLOWHATCH (08-14-2013), super_pablo_ (09-09-2013)
 Old 08-14-2013, 01:44 PM   #6
kladuscan's Avatar
Posts: 70   (View Stats)
kladuscan has a brilliant futurekladuscan has a brilliant futurekladuscan has a brilliant futurekladuscan has a brilliant futurekladuscan has a brilliant futurekladuscan has a brilliant futurekladuscan has a brilliant futurekladuscan has a brilliant futurekladuscan has a brilliant futurekladuscan has a brilliant futurekladuscan has a brilliant future
Price on the front 4 piston caliper kit for the Speed6??
BCM MS6 #5338
Mods: a few things here and there...
kladuscan is offline   Reply With Quote
The Following 8 Users Say Thank You to kladuscan For This Useful Post:
Code Monkey (08-14-2013), Downmented (08-15-2013), EdgeAutosport.com (08-15-2013), IanMacKenzie (08-16-2013), Jh8909 (08-14-2013), mdd5148 (08-14-2013), Micha (08-16-2013), Poohster (08-14-2013)
 Old 08-14-2013, 01:51 PM   #7
Can you guys list *all* the options/kits available for the MS6?
Rayd likes this.
The Following 14 Users Say Thank You to Code Monkey For This Useful Post:
dot584 (08-14-2013), Downmented (08-15-2013), EdgeAutosport.com (08-15-2013), IanMacKenzie (08-16-2013), Jh8909 (08-14-2013), kladuscan (08-14-2013), Lakespeed6 (08-14-2013), mdd5148 (08-14-2013), Micha (08-16-2013), PapaShultz (08-14-2013), qtrmile beast (08-15-2013), RichieRichness (08-15-2013), speeding3 (08-15-2013), superskaterxes (08-15-2013)
 Old 08-14-2013, 02:01 PM   #8
Jh8909's Avatar
Posts: 1,457   (View Stats)
Groans: 130
Groaned at 8 Times in 7 Posts
THIS THIS THIS THIS THIS SOO MUCH.
The Following 3 Users Say Thank You to Jh8909 For This Useful Post:
Code Monkey (08-14-2013), EdgeAutosport.com (08-15-2013), kladuscan (08-14-2013)
 Old 08-14-2013, 02:40 PM   #9
Manny's Avatar
Posts: 1,185   (View Stats)
Groans: 320
OMG ORDERING NOW!!!!
when was the last time your speed reeled in this many bitches?
The Following User Says Thank You to Manny For This Useful Post:
 Old 08-15-2013, 11:03 AM   #10
All the kits use BP-10 Wilwood specific pads except for the 13" big brake kit. That has Hawk pads at the moment but will soon be able to accept Wilwood pads with a little changing around that's being done as we speak. For the bias, I'm not 100% sure on this. Obviously, it's going to be closer to being more even with grab, heat, fade, etc but there's no measurable data up to this point.
There is a 13" big brake kit with 4 pistons for MS6 priced at $1650. At this point, this is the only option for the MS6 but a caliper kit should be available soon. I'll keep you guys in the loop on this. I think I may have said wrong in the OP about MS6 kits available, I apologize if I did and I will modify the OP.
A couple other things we've come across that will help with decisions...
We have test fit the 13" MS3 Front BBK to a stock wheel and all you need is 5mm spacers to clear the caliper which is actually better than what I expected. This was done on a Gen1 so we'd have to check Gen2 for clearance, also.
The 2 piece rotor assembly is actually 5.8 pounds LESS than the factory rotor PER ROTOR. That's a huge rotational mass weight savings. We haven't done a ton of brake comparisons so maybe I shouldn't be as surprised but I'll say I was definitely pleased with this.
Let us know if you have any other questions.
Thank you!
Looks like I did say the correct kits but that is what it's limited to for MS6 currently. We'll let you know on the caliper kits soon.
Last edited by EdgeAutosport.com; 08-15-2013 at 11:03 AM. Reason: MSF Database - Automerged Doublepost
The Following 11 Users Say Thank You to EdgeAutosport.com For This Useful Post:
breakfstincluded (08-15-2013), Code Monkey (08-15-2013), cshunter (08-15-2013), El_Diablo (08-15-2013), hnda etr (08-15-2013), Jh8909 (08-15-2013), kladuscan (08-15-2013), Mauro_Penguin (08-15-2013), Micha (08-16-2013), The Nut (08-20-2013), Vader (08-15-2013)
 Old 08-15-2013, 11:08 AM   #11
Yatta's Avatar
Posts: 1,862   (View Stats)
While dreaming, how about two piece rotors for the front and rear in stock form factor?
I've seen these kits by themselves on other sites but never all together, thanks for making me notice the hole burning in my pocket....
The Following 3 Users Say Thank You to Yatta For This Useful Post:
EdgeAutosport.com (08-15-2013), Micha (08-16-2013), mrmonk7663 (08-15-2013)
 Old 08-15-2013, 11:20 AM   #12
Hmm, good question. I'll see what kind of info we can get on this possibility.
 Old 08-15-2013, 11:37 AM   #13
[R]usty's Avatar
So the front 4 pistons for the PU. Do I need to modify anything to get these to fit?
I was planning on stainless steal lines and some new pads but fuck that 4 piston calipers with everything included is 10x better.
The Following 2 Users Say Thank You to [R]usty For This Useful Post:
EdgeAutosport.com (08-15-2013), galens47 (08-22-2013)
 Old 08-15-2013, 11:49 AM   #14
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
Yes, I too would be interested in 2 piece lightweight rotor setups, for use with stock calipers. I have been looking forever for this, and the only option was a custom setup with a minimum of 10 orders
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
The Following User Says Thank You to mrmonk7663 For This Useful Post:
 Old 08-15-2013, 12:08 PM   #15
tubeman's Avatar
Posts: 11   (View Stats)
tubeman has a spectacular aura abouttubeman has a spectacular aura about
Do the kits include Motul 600 brake fluid?
tubeman is offline   Reply With Quote
The Following User Says Thank You to tubeman For This Useful Post:
 Old 08-15-2013, 12:18 PM   #16
BruhhWill's Avatar
Posts: 104   (View Stats)
BruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond repute
YES!!!!!!
2008.5 MGM Mazdaspeed3
Engine
Cobb Accessport // Autotech HPFP Internals // Stratified Auto 3 Port Boost Control Solenoid (2-Port Mode) // Injen Cold Air Intake // CorkSport TIP // NGK Spark Plugs // Ultimate Racing Resonated Test Pipe // Stratified Auto S-OTS Stage 2+ Tune //
Transmission
JBR V2 Rear Motor Mount 80a // JBR Heavy Shift Knob // Corksport Shifter Bushings // Corksport Short Shift Plate //
Suspension
Koni Yellow Struts and Shocks with H&R Sport Springs // JBR Rear Sway Bar // 18x8 +45 Enkei Raijins in Black wrapped in Kumho Ecsta 4X All Seasons 235/40/18
Aesthetics
JDM Axela Window Visors // Corksport LED Fog Lights // Corksport LED Interior Lights //
Past:
1999 Crystal Blue Honda Prelude SH
2006 Titanium Grey Mazda 3 Hatchback (R.I.P.)
1995 Hyundai Elantra
BruhhWill is offline   Reply With Quote
The Following User Says Thank You to BruhhWill For This Useful Post:
 Old 08-15-2013, 12:23 PM   #17
daafisch's Avatar
Posts: 3,553   (View Stats)
Groans: 58
Is there a template for fitment?
The Following User Says Thank You to daafisch For This Useful Post:
 Old 08-15-2013, 12:34 PM   #18
can we get some of these for the MS6 as well?
lol@5.8lb weight savings compared to these haha
The Following 3 Users Say Thank You to superskaterxes For This Useful Post:
Alpha (08-20-2013), EdgeAutosport.com (08-15-2013), El_Diablo (08-15-2013)
 Old 08-15-2013, 12:51 PM   #19
hnda etr's Avatar
Groans: 90
So the REAR kit uses these same pads?
 Old 08-15-2013, 03:45 PM   #20
Reedy's Avatar
Posts: 391   (View Stats)
Reedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the world
Questions to ask:
Which of these kits will fit the stock Gen 1/Gen 2 rims WITHOUT spacers? Be it one, two or all?
Is a wheel fitment template for them available?
Is there an equivalent DBA5000 2 piece Rotor that will fit with the 13" Kit?
Rayd likes this.
Reedy is offline   Reply With Quote
 Old 08-15-2013, 04:01 PM   #21
Rayd's Avatar
Posts: 171   (View Stats)
Rayd has a reputation beyond reputeRayd has a reputation beyond reputeRayd has a reputation beyond reputeRayd has a reputation beyond reputeRayd has a reputation beyond reputeRayd has a reputation beyond reputeRayd has a reputation beyond reputeRayd has a reputation beyond reputeRayd has a reputation beyond reputeRayd has a reputation beyond reputeRayd has a reputation beyond repute
In for good news about 4 pot - gen 2 wheel clearance!
05 MPS 6 - Self Tuned
Borg Warner EFR T4 Twin Scrolled, Forged Block, Snow Performance S3 WMI, 5th/6th Port Injection, CPe: Ex Mani, Custom intake 3.75" MAF, CPe HPFP, Injector Seals, REM, SURE: Rear Diff Front mount & Brace, TIG's; Tial EWG, HDI FMIC, Custom 3" TBE, 3.5-Bar MAP sensor, AWR SEM, SouthBend S4 Clutch, Custom Head Unit, Car-LED Tails, 6000K HIDs, Auto Head-light Kit, Mugen Visors, LED conv., BC Coilovers, SPC Ball Joints, Brembo BBK
Rayd is offline   Reply With Quote
 Old 08-15-2013, 04:05 PM   #22
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
AAH IM CUMMING
Package deal with front and rear?
I could of sworn I had heard something about how rear aftermarket calipers wouldn't be able to retain E-brake so this is a very nice suprise (:
 Old 08-15-2013, 04:10 PM   #23
qtrmile beast's Avatar
Posts: 2,423   (View Stats)
Well i have the brembo set up in the front and i would love to have the rears especially if im not going to have as much of a problem with finding wheels as i do with the brembos.
track weight 3220
street weight 3370
 Old 08-15-2013, 05:44 PM   #24
The only thing we needed to do for the big brake kit was to slightly shave the 2 front facing ends of the steering knuckle a little bit so that the caliper bracket could mount flush with the bolt holes which was part of the instructions, so it was expected.
No, but it's free shipping if you order together!
There is not a template right now.
Yes, the rear uses the same pad compound, if that's what you're asking.
[R]usty (08-16-2013)
 Old 08-15-2013, 06:10 PM   #25
Jhornbrook's Avatar
Posts: 708   (View Stats)
Jhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the world
Groaned at 6 Times in 4 Posts
Does the replacement calipers come with instructions for the rear?
Ultimate Racing // testpipe, catback // TWM // Full Replacement Shifter, Short Shift Boot // Cobb// AP // Sure aeros, sidewinder, shortcut, ags SS knob, return, chargetubes, countershift // Corksport // License Plate Relocate, Fog Light LED's, Interior LED's, Poly Exhaust Hangers, Oil Catch Can // PTP// HPFP Upgrade, 2150 rail valve // H&R // SS Coilovers // SPC// Adjustable Camber Arms // Hawk// HPS Brake Pads // Ebay Chargespeed Lip 06-07 STI Lip // DDM 8K 55W HIDs // JBR// Rear Sway Bar, 88D RMM, AP Mount //WHITELINE// Front End Links // ETS// TMIC//
Jhornbrook is offline   Reply With Quote
 Old 08-15-2013, 06:13 PM   #26
speeding3's Avatar
Posts: 118   (View Stats)
speeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond repute
Groaned at 17 Times in 8 Posts
Sick... willwood 4 pistons for the front that dont cost an arm and a leg. was on the fence about CS 4 piston brakes but i think this will be the way i go.
just wondering why dont the other kits show up on ur website when you do a search for them. it just shows the willwood 6 piston kit and ksport ETC but no 4 piston kit.
Can you post a pic of the 13" 4 piston kit and the cost
speeding3 is offline   Reply With Quote
The Following 2 Users Say Thank You to speeding3 For This Useful Post:
EdgeAutosport.com (08-16-2013), Speed_j23 (08-15-2013)
 Old 08-16-2013, 09:30 AM   #27
Wilwood 4 Piston Front Brake Caliper Kit for Stock Rotors Mazdaspeed 3
This is the 4 piston kit comparable to the CS kit that was recently released. Do you want the 13" kit with the 2 piece rotors? That will be on the site soon.
breakfstincluded (08-16-2013)
 Old 08-16-2013, 11:45 AM   #28
Thank you!
If this is the case the gen2 wheel might clear without spacers as it has more clearance than a gen1.
 Old 08-16-2013, 01:24 PM   #29
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
Maybe I missed it but what are rear options, if any, for the 6?
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
 Old 08-16-2013, 01:44 PM   #30
robertof's Avatar
Posts: 405   (View Stats)
robertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the world
none yet.
robertof is offline   Reply With Quote
 Old 08-16-2013, 03:59 PM   #31
hnda etr's Avatar
Groans: 90
can i cancel my v3 order and change over to the rear bbk?
EDIT: DONE! Thanks JP!
Boosted Beluga (08-16-2013), breakfstincluded (08-16-2013), EdgeAutosport.com (08-16-2013), kritz (08-18-2013), Micha (08-16-2013)
 Old 08-16-2013, 05:58 PM   #32
Yes!
This is fixed. You should be able to see all kits on the search by car, manufacturer, or part functions. We'll post pics of the 4 piston 13" kit when we get it in.
Thank you Roy!
hnda etr (08-16-2013)
 Old 08-16-2013, 06:04 PM   #33
m4tic's Avatar
Posts: 4,928   (View Stats)
MS6 4pot kit... cack in hand
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
Jh8909 (08-16-2013)
 Old 08-16-2013, 10:04 PM   #34
darkstar5440's Avatar
Posts: 477   (View Stats)
darkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the world
Dope!!! These kits are all in stock ready to ship?
darkstar5440 is offline   Reply With Quote
 Old 08-16-2013, 10:25 PM   #35
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Did you guys help develop these kits?
I'm wondering if there were design limitations to using Wilwood's Radial Mount options vs. their Lug Mount calipers, or if the choice was more price/cost-driven...
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
Tokay444 (10-12-2013)
 Old 08-16-2013, 10:51 PM   #36
therapist510's Avatar
Posts: 83   (View Stats)
therapist510 has a reputation beyond reputetherapist510 has a reputation beyond reputetherapist510 has a reputation beyond reputetherapist510 has a reputation beyond reputetherapist510 has a reputation beyond reputetherapist510 has a reputation beyond reputetherapist510 has a reputation beyond reputetherapist510 has a reputation beyond reputetherapist510 has a reputation beyond reputetherapist510 has a reputation beyond reputetherapist510 has a reputation beyond repute
Frigging cheap. Ordering the 4 piston
Corksport SRI/TIH, Treadstone TR8/CXracing kit, Corksport Testpipe, Autotech HPFP, CPE Safe seals, Cobb Ap. Freektuned.
ISC N1 Street Sport coilovers. Enkei RPF1 17x9 35/45 front and rear offsets. Bridgestone Potenza RE-71R 235 45 17.
therapist510 is offline   Reply With Quote
 Old 08-16-2013, 11:39 PM   #37
Ferdball's Avatar
Posts: 1,340   (View Stats)
Ferdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the world
I have no idea what you just said.
Ferdball is offline   Reply With Quote
The Following User Says Thank You to Ferdball For This Useful Post:
Code Monkey (08-19-2013)
 Old 08-16-2013, 11:51 PM   #38
Nliiitend1's Avatar
Q: What advantage is there in having a radial mount Caliper over a lug mount caliper?
A: Radial mount calipers and brackets offer a much more rigid mounting system than a lug mount design. The radial design also accommodates rotor diameter changes with a simple spacer rather than a whole new bracket. A customer with a 13” rotor kit that wants to upgrade to a 14” rotor would only require longer studs and spacers rather than a completely new taller bracket.
Wilwood High Performance Disc Brakes
2008 MS3 GT
2016 MX-5 Club
The Following 2 Users Say Thank You to Nliiitend1 For This Useful Post:
Ferdball (08-17-2013), Tokay444 (10-12-2013)
 Old 08-17-2013, 03:02 AM   #39
hnda etr's Avatar
Groans: 90
Yes. lol
I'm guessing space constraints foremost as well as price.
Also, as much as we like to kid ourselves, Speeds Racecars
What do you guys think:
I already have the StopTech BBK (in black) up front and will be installing these Wilwood rear BBK.
Is it gonna look lame having the StopTech logo on the front and the Wilwood logo on the rear?
I'm debating on spraying over the Wilwood logo so the calipers are all black.
Last edited by hnda etr; 08-17-2013 at 03:02 AM. Reason: MSF Database - Automerged Doublepost
 Old 08-17-2013, 08:16 PM   #40
dereeek's Avatar
Posts: 2,053   (View Stats)
Groans: 386
yeahhhhhhhhh, These are what I'm going to buy as soon as I'm situated in my new living quarters.
BNR3-FREEK-PU-398HP
The Following User Says Thank You to dereeek For This Useful Post:
aforst (06-11-2014)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f539/wilwood-brake-kits-edgeautosport-152848/
Bullsh*t thread - Page 792 - 2010-13 Mazda 3/Mazdaspeed 3 Forums This thread Pingback 08-14-2013 03:32 PM
4 Piston Brake Kits for a 2010 MS3 (and what happens when you push the stock brakes as far as they will go) Reedy 2010 MS3 - Suspension & Brakes 264 01-03-2020 03:07 AM
New big brake possibilities? We share front brake calipers with audis/vws breakfasteatre MazdaSpeed 3/6 - Suspension & Brakes 15 11-03-2012 09:18 PM
Hawk HPS brake pads & Goodridge brake lines in stock for the 07-11 MS3. Chris@Xtreme Mazdaspeed3/6 General Discussion 3 08-06-2011 08:56 PM
Page generated in 0.77991 seconds with 50 queries
