Like Tree26Likes
 Old 08-22-2013, 05:39 PM   #81
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
Originally Posted by SFWD 1934 View Post
Honestly it all depends on you. Only suggestion I might make to you is to go to a vinyl shop and just use black vinyl to cover the rear Wilwood logo. That way if you ever go to resell them you can just peel the vinyl off. Can't just peel spray paint off.
Jason
Good idea!
 Old 08-22-2013, 09:14 PM   #82
lup15's Avatar
Posts: 8   (View Stats)
lup15 is an unknown quantity at this point
Here is a pic from when I did the install last year of the front with stock style rotors. As you can see because the stock hat is so small it looks different compared to when you have a 2 piece rotor design with a larger hat. There is still a minimum of 2" brake annulus.
Jason
Jason, when you used the Dynapro and the stock rotors, did you need spacers for the wheels you had on? Specs on wheels if you didnt? Also are you able to comment on the pedal feel and braking bias, particularly with the stock rotor caliper options. Cheers
lup15 is offline   Reply With Quote
 Old 08-22-2013, 09:34 PM   #83
Fatpig78's Avatar
Posts: 127   (View Stats)
Fatpig78 has a reputation beyond reputeFatpig78 has a reputation beyond reputeFatpig78 has a reputation beyond reputeFatpig78 has a reputation beyond reputeFatpig78 has a reputation beyond reputeFatpig78 has a reputation beyond reputeFatpig78 has a reputation beyond reputeFatpig78 has a reputation beyond reputeFatpig78 has a reputation beyond reputeFatpig78 has a reputation beyond reputeFatpig78 has a reputation beyond repute
You will need 5mm spacers in order for the stock 08 wheels to clear the wilwood calipers.
does this apply to all first gen? 07-09? ive got the 07 stock wheels
07 Cosmic Blue Mica MS3 GT:
Cobb AP, Torq R3 Street; Sure CounterWeight; Corksport CAI/TIP; Cobb Shift Knob on Stratified extension w/ TWM shortshifter; Corksport Internals; Custom straight 3 inch catback exhaust by RPM
Fatpig78 is offline   Reply With Quote
 Old 08-23-2013, 01:10 AM   #84
SFWD 1934's Avatar
Posts: 973   (View Stats)
SFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the world
lup,
I did not need spacers. My Advans are 18x8 +38MM. The brake pedal feel was great. Car stops very very nice. No fade.
Jason
JRL Tuning 510-459-7229
www.full-race.com
SFWD 1934 is offline   Reply With Quote
The Following User Says Thank You to SFWD 1934 For This Useful Post:
jm211 (08-25-2013)
 Old 08-23-2013, 02:21 PM   #85
speeding3's Avatar
Posts: 118   (View Stats)
speeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond repute
Groaned at 17 Times in 8 Posts
You will need 5mm spacers for 07-09 stock wheels to fit.
speeding3 is offline   Reply With Quote
 Old 08-23-2013, 04:09 PM   #86
Reedy's Avatar
Posts: 391   (View Stats)
Reedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the world
Am I blind or has nobody commented on whether Gen II wheels will fit without spacers???
Reedy is offline   Reply With Quote
 Old 08-25-2013, 10:43 PM   #87
hnda etr's Avatar
Groans: 90
Hmmmm.... Sneak Peak perhaps... Will post write up after discussing couple issues with JP...
The Following 5 Users Say Thank You to hnda etr For This Useful Post:
bodyboardingbum (08-26-2013), El_Diablo (08-26-2013), Lex (08-25-2013), mrmonk7663 (08-26-2013), super_pablo_ (09-09-2013)
 Old 08-26-2013, 09:22 AM   #88
Yes, we installed them on an 09 and tried to fit the stock wheels without spacers. they just barely do not clear the front face of the caliper. They fit perfect with a 5mm spacer though.
Not sure yet as we haven't got any second gen wheels laying around. Since they are a half inch wider with the same offset, it is more likely they will fit without spacers than the first gen.
Last edited by EdgeAutosport.com; 08-26-2013 at 09:22 AM. Reason: MSF Database - Automerged Doublepost
 Old 08-26-2013, 09:29 AM   #89
bodyboardingbum's Avatar
Posts: 24   (View Stats)
bodyboardingbum is a splendid one to beholdbodyboardingbum is a splendid one to beholdbodyboardingbum is a splendid one to beholdbodyboardingbum is a splendid one to beholdbodyboardingbum is a splendid one to beholdbodyboardingbum is a splendid one to beholdbodyboardingbum is a splendid one to behold
Thanks for sharing! Any chance you could post a few more snaps, showing how they sit behind the wheel in full? - thanks!
BK MPS3 Sports - Work Meister S1R
CP-e Catalogue.JDM Goodies.
bodyboardingbum is offline   Reply With Quote
 Old 08-26-2013, 11:18 AM   #90
hnda etr's Avatar
Groans: 90
I don't have the stock wheels installed, so clearance wouldn't apply.. btw, these are the rears...
 Old 08-26-2013, 05:04 PM   #91
Understood, not wanting to see stock wheel clearance (also not running stock wheels).
Hoping to see how the caliper mounts and potential obviously visible size differences between stock calipers - haven't seen any comparisons done yet?
Aware these are rears too, but all good Sure when you're ready some more pictures will appear.
 Old 08-29-2013, 10:23 PM   #92
Lancer-AM's Avatar
Posts: 306   (View Stats)
Lancer-AM is the leader of the worldLancer-AM is the leader of the worldLancer-AM is the leader of the worldLancer-AM is the leader of the worldLancer-AM is the leader of the worldLancer-AM is the leader of the worldLancer-AM is the leader of the worldLancer-AM is the leader of the worldLancer-AM is the leader of the worldLancer-AM is the leader of the worldLancer-AM is the leader of the world
I just ordered a set to go on my PU with stock rims. I'll post up my findings.
2010 Mazdaspeed 3 Tech
Stocking out
If a person says they 'work smart, not hard,' odds are they are lazy and stupid.
Lancer-AM is offline   Reply With Quote
The Following 3 Users Say Thank You to Lancer-AM For This Useful Post:
bodyboardingbum (08-29-2013), daafisch (08-30-2013), EdgeAutosport.com (08-30-2013)
 Old 09-01-2013, 06:43 AM   #93
Reedy's Avatar
Awesome, which set did you get?
 Old 09-01-2013, 07:14 AM   #94
Lancer-AM's Avatar
I got the 4 pot set. I mainly Autox and only for fun, so I figured these would suit me perfectly. They said it will be at least a week before they ship though.
Stocking out
 Old 09-01-2013, 01:16 PM   #95
hnda etr's Avatar
Groans: 90
Fronts or rear? I'm still working with JP to perfect the rear BBK and make it THE easiest and best rear brake upgrade option.
The Following 2 Users Say Thank You to hnda etr For This Useful Post:
EdgeAutosport.com (09-03-2013), El_Diablo (09-01-2013)
 Old 09-01-2013, 02:58 PM   #96
Lancer-AM's Avatar
Just the front for now. I may do the rear eventually. We will just have to see how these work out.
Stocking out
The Following User Says Thank You to Lancer-AM For This Useful Post:
 Old 09-06-2013, 03:53 PM   #97
Lancer-AM's Avatar
Figured while I am waiting for my calipers I would grab some DBA slotted rotors to go on when I get them. Thanks again Edge for the awesome hook up.
Stocking out
EdgeAutosport.com (09-06-2013)
 Old 09-09-2013, 02:02 PM   #98
julienjj's Avatar
Posts: 292   (View Stats)
julienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the world
This thread need more MS6 love.
Current money pits:
2006 MS6 Black mica
CP-E RMM|COBB AP|Test pipe|RX-8 oem wheels|Corksport SRI+TIP|Autotech CDFP|Michelin Pilot Super Sports 235/40ZR18|
|HKS SSQV|COBB Sift weight|Corksport mudflaps (Because rallycar)| JBR 70A Sidemounts|
2008 BMW 135i 6MT
M package|JB4 tune|255/35r18 Michelin PSS|BMW Performance exhaust|
julienjj is offline   Reply With Quote
The Following User Says Thank You to julienjj For This Useful Post:
EdgeAutosport.com (09-09-2013)
 Old 09-09-2013, 04:36 PM   #99
MS6 kits will be coming soon
cletusb likes this.
Jh8909 (09-15-2013), MarineMazda (09-11-2013), Poohster (09-09-2013), robertof (09-13-2013)
 Old 09-09-2013, 04:47 PM   #100
cletusb's Avatar
Posts: 488   (View Stats)
Great news!
Will they be full kits with rotors etc or calliper only kits... or both?
Also interested if the will use the stock lines or equivalent (Australian design rules compliance)
 Old 09-09-2013, 05:45 PM   #101
julienjj's Avatar
Great news!
I'm sure they will simply offer the same kits with a ms6 specific bracket and rotor.
Current money pits:
2006 MS6 Black mica
2008 BMW 135i 6MT
EdgeAutosport.com (09-10-2013)
 Old 09-09-2013, 10:07 PM   #102
Lancer-AM's Avatar
No it needs 100% more pictures of the calipers on my car. Any day now........
Stocking out
 Old 09-09-2013, 10:28 PM   #103
super_pablo_'s Avatar
Posts: 1,648   (View Stats)
kinda late to the thread but glad to see these. been looking for more rear bias, these are gonna be nice without having to go super aggressive on the rear pads.
 Old 09-10-2013, 12:15 AM   #104
hnda etr's Avatar
Groans: 90
Like these rears?
EdgeAutosport.com (09-10-2013), Micha (09-10-2013)
 Old 09-10-2013, 11:52 AM   #105
Great news!
Both and they will be compliant.
 Old 09-10-2013, 04:38 PM   #106
cletusb's Avatar
Awesome. I was searching google and from what I could find they lacked dust covers which made them non compliant but good to hear they are.
Cash ready :-)
The Following User Says Thank You to cletusb For This Useful Post:
Micha (09-10-2013)
 Old 09-10-2013, 06:57 PM   #107
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Yeah, there are very few Wilwood offerings that I know of which use dust boots...
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
The Following 3 Users Say Thank You to Nliiitend1 For This Useful Post:
breakfstincluded (09-13-2013), EdgeAutosport.com (09-11-2013), MarineMazda (09-11-2013)
 Old 09-12-2013, 07:33 AM   #108
Lancer-AM's Avatar
Woot, I have been so busy with work I haven't had time to check on the fun stuff. My brakes shipped yesterday and will be here tomorrow!!!! I am meeting up with some of the Austin and SA NATOR guys this weekend, as long as they are delivered to my cube before I leave work tomorrow then I should be able to have some test fit pics of them on my PU with stock wheels this weekend. Going to wait for my new DBA's before fully installing them.
Stocking out
The Following 2 Users Say Thank You to Lancer-AM For This Useful Post:
EdgeAutosport.com (09-12-2013), Reedy (09-13-2013)
 Old 09-12-2013, 08:54 AM   #109
lk250f's Avatar
Posts: 253   (View Stats)
lk250f is the leader of the worldlk250f is the leader of the worldlk250f is the leader of the worldlk250f is the leader of the worldlk250f is the leader of the worldlk250f is the leader of the worldlk250f is the leader of the worldlk250f is the leader of the worldlk250f is the leader of the worldlk250f is the leader of the worldlk250f is the leader of the world
I need this... All I can hope is that I will win the raffle. Sponsored by the wonderful Edge Autosport!!
2013 CWP Mazdaspeed3
lk250f is offline   Reply With Quote
The Following User Says Thank You to lk250f For This Useful Post:
 Old 09-12-2013, 02:50 PM   #110
maddocx240's Avatar
Posts: 823   (View Stats)
Glad to hear ms6 options coming out. Will they be priced the same as the ms3? I would think the only thing changing is the mounting bracket. Are we looking this year or next year release? As far as pads go, are willwood pads the only option, or are there comparable options.
The Following User Says NO Thank You to maddocx240 For This Un-useful Post:
Lancer-AM (09-14-2013)
 Old 09-13-2013, 06:10 AM   #111
daafisch's Avatar
Posts: 3,553   (View Stats)
Groans: 58
Other manufactures make pads that will fit these calipers.
 Old 09-14-2013, 11:21 AM   #112
Lancer-AM's Avatar
Don't know if the pictures will post from my phone but the 4pot fronts fit perfect behind PU stock rims.
EdgeAutosport.com likes this.
Stocking out
The Following 10 Users Say Thank You to Lancer-AM For This Useful Post:
Code Monkey (09-14-2013), EdgeAutosport.com (09-16-2013), hnda etr (09-16-2013), KCi (09-15-2013), magicka (09-14-2013), Mauro_Penguin (09-22-2013), Reedy (09-14-2013), RobT2009 (10-10-2013), silvapain (09-16-2013), slikr (09-15-2013)
 Old 09-14-2013, 12:05 PM   #113
Reedy's Avatar
No Spacers needed at all? This is excellent news. How much clearance is there exactly? is it a couple of mm or is it a fairly large gap?
 Old 09-14-2013, 12:17 PM   #114
breakfasteatre's Avatar
Posts: 308   (View Stats)
breakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the world
hmmmm. they dont use much of the disk surface. Is this common?
I know that the farther the caliper is out, the more torque the calipers can put on the rotors, but what about surface area of the pad?
here is the stock caliper for reference:
breakfasteatre is offline   Reply With Quote
 Old 09-14-2013, 12:38 PM   #115
Are these fully mounted in the picture. The outer edge of the pad seems to extend beyond the outer edge of the rotor. Seems like the caliper should be pushed closer to the centre of the hub.
breakfasteatre (09-14-2013), hnda etr (09-16-2013)
 Old 09-14-2013, 01:15 PM   #116
Lancer-AM's Avatar
I'll have to look again, there looked to be no issues when I mounted them and no one from nator noted an issue. I will post up again when I have my rotors in. This time I was only testing to see if they fit behind the wheels.
Stocking out
 Old 09-14-2013, 02:05 PM   #117
Reedy's Avatar
Either its not fully mounted, or the pistons are retracted a long way and you're getting all kinds of parralax bullshit that is making the image look out of wack.
If the rotor and pad doesn't align properly then that's a total lollercaust.
The Following User Says Thank You to Reedy For This Useful Post:
Tokay444 (10-12-2013)
 Old 09-14-2013, 02:37 PM   #118
Lancer-AM's Avatar
That is one thing to note, the brake lines were not connected and the pistons are fully retracted.
Stocking out
 Old 09-14-2013, 03:37 PM   #119
Nliiitend1's Avatar
The bridge is missing in that pic too, so that obviously isn't an "all buttoned up" pic...
2008 MS3 GT
2016 MX-5 Club
 Old 09-14-2013, 04:11 PM   #120
Lancer-AM's Avatar
The part you are taking about is an optional piece for the wilwoods and not stock. The pictures are pretty much fully bolted but not bedded or bled.
Stocking out
Nliiitend1 (09-14-2013)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f539/wilwood-brake-kits-edgeautosport-152848/
Bullsh*t thread - Page 792 - 2010-13 Mazda 3/Mazdaspeed 3 Forums This thread Pingback 08-14-2013 03:32 PM
4 Piston Brake Kits for a 2010 MS3 (and what happens when you push the stock brakes as far as they will go) Reedy 2010 MS3 - Suspension & Brakes 264 01-03-2020 03:07 AM
New big brake possibilities? We share front brake calipers with audis/vws breakfasteatre MazdaSpeed 3/6 - Suspension & Brakes 15 11-03-2012 09:18 PM
Hawk HPS brake pads & Goodridge brake lines in stock for the 07-11 MS3. Chris@Xtreme Mazdaspeed3/6 General Discussion 3 08-06-2011 08:56 PM
Page generated in 0.58284 seconds with 38 queries
