| 2010 MS3 - Big Turbo Builds Genpu - Big Turbo Builds. All discussions about big turbos, hybrids and builds belong here. |
![]() Join Date: Jul 2017 Location: Houston
Rep Power: 0 ![]() ![]() ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Question is where do I splice this 12V ground output to? My car is a 2013. And before someone says ‘search’ the only threads I’ve found say to get a Guardian Angel, and I’m not even running a BPV so that’s not an option for me since the Guardian Angle controls the BPV as a failsafe. |
![]() Join Date: Mar 2018 Location: Orange County CA
Rep Power: 0 ![]() ![]() Thanks: 4
| Not Ranked : 0 score Soooo, Mazda made the 2013 Speed without a BPV? Or you removed it?
__________________ 06 Speed6 AP V3| CS TIP/SRI |CS 50/50 BPV |CS Test Pipe |CS FP internals|CS high pressure SS fuel line |CPE EGR delete |CPE TMIC |JBR Boost Tubes |JBR Trilogy race mounts |JBR short shift kit |Grimmspeed EBCS |GA V3|Custom FREEK tune |
Can we get back on topic please? I’m not spending $250 on a GA when it already has a failsafe built in. | |
| Not Ranked : 0 score be carefull not to mix different things. Your meth output isn't made for the same purpose of a GA. Unless you have the full AEM failsafe system with the flow gage and extra stuff, the standard unit only trigger On when you are low in fluid or when the pump is dead. This isn't a fail safe but more a fault output. IT won't see a broken pipe or a plugged jet.... The most common way of using this kind of output is to wire it to a relay and have the relay wired to cut your EBCS signal. Since the output give negative, you connect the other side of the relay coil to any fused 12v+ and then you wire both side of the NC contact of it to one of the wire going to the EBCS. This way, when AEM give grounds, the relay get activated and it's NC contact open and remove any wastegate duty to your EBCS to drop boost (return to mecanic wastegate spring boost) The GA protection is made to protect against an overboost condition and use the BPV to make a good leak to drop boost. The Ga has an input to connect your meth fault output into it instead of playing with the EBCS wires but you need a BPV installed... I won't argue with you for the benefit of a BPV but if you don't get this, you may still read a bit more before buying a 6466.
| Not Ranked : 0 score Are you planning fuel port injection or meth ? IMO The best and probably mandatory with a huge drag racing turbo is to inject gas and maybe from a secondary tank filled with race fuel. I didn't see anyone with a split second driving methanol injection but maybe.... IMO the best methanol kit available : Aquamist HSF4. ---- 806-065 ----- HFS4-v3.1 system for DI engines The most advanced system to date. - aquamist-direct.com There is other advanced methanol controller like the one i use: https://torqbyte.com/products/torqbyte-cm5-lt Or similar from snow https://www.snowperformance.net/product-p/sno-70000.htm There is no limitations about how much fuel you can use from methanol but it would be hard to come close to the reliability and control of gas port injection.
| Not Ranked : 0 score Ok i bet you mean gaz injectors when saying it, not 4x meth nozzles (Both are port injection) And the best cooling effect is when meth is mixed with water.
![]() Join Date: Feb 2012 Location: Li ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,290
Groans: 74
Sorry but i stopped reading the thread after this part. LMFAO maby you should not go near wot until this is solved...... Maby you should "search"... There is a way to make a fail safe with a relay, EBCS and a 12$ boost switch......
__________________ MECP 2012 BM PTE 5858 Vband .82ar // Tial EWG // CPE Mani // 3" Turboback // JBR Under route hot pipe // MD ST mani+spacer with PI // Siemens 60lb Injectors // Splitsecond inj controller // JBR 88 duro RMM/TMM // MD PMM // TWM Full replacement shifter // JBR CC // Autotech FP Internals // SP63 SB/Manley rods SP63 pro pistons // Treadstone FMIC TR824 // FoMoCo Tranny Jizz // South Bend Clutch Stage 3 enduro// GFB Respons // FJ 4" intake // WMI 100% VPM1 // Air Lift 1000 in rear // N2MB WOT BOX Rfinkle tune in progress The Brooklyn beater: 2005 1.8 Auto Sentra | |||
![]() Join Date: Jun 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 242
__________________ Gen 2 2012 - Precision 6062 Turbo - CPE Exhaust Mani - PTE 46mm EWG - 2NV Industries built Forged bottom end - PNP Head - JMF V2 Intake Mani- Custom DP UR Cat Back - HTP 4 inch intake - TR8 FMIC - Custom FREEKTUNE METH Port Injection - Cobb 3 port EBC- Autotech internals - FREEKTUNED. | |
| The Following User Says Thank You to shaneski For This Useful Post: | 5doorsoffury (11-02-2018) |
Are you using fuel injectors to control meth ? Similar to a gas setup but the tank is filled with meth ? Is it hard to find stuffs with seals that handle full methanol content ? I bet you no longer use quick connect pipe? I really like that route!
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... | |
Groans: 74
5doorsoffury the tank will be coated black as well, it's just dummy fitted at the moment to get all the fittings etc right. The under bonnet tank running meth via the JMF rail and injectors are an individual system with a return line and inline pump (no surge set up needed)..The standard fuel tank uses stock fuel system and pump gas.
__________________ Gen 2 2012 - Precision 6062 Turbo - CPE Exhaust Mani - PTE 46mm EWG - 2NV Industries built Forged bottom end - PNP Head - JMF V2 Intake Mani- Custom DP UR Cat Back - HTP 4 inch intake - TR8 FMIC - Custom FREEKTUNE METH Port Injection - Cobb 3 port EBC- Autotech internals - FREEKTUNED. Last edited by shaneski; 11-03-2018 at 02:13 AM. | |
| Not Ranked : 0 score Perfect it is what i tough. The precise injectors and pulsing controller is hard to be compared to a cheap traditional meth system. One start and stop a pump to spill methanol in the intake path while trying to adjust pump speed based to an incoming signal...Precision is inexistant, it lag at start and keep feeding for a second when it should stop...Not to mention the risks of leaks from the plastic lines and quick connect. Yours is more like a reliable oem injection system from the 90s that remain in open loop I really like it.
| AEM failsafe configuration | Justin@Freektune | FREEKTUNE | 27 | 04-07-2015 05:58 PM |
