> 2010 MS3 - Big Turbo Builds
Like Tree17Likes
 Old 12-19-2016, 03:10 AM   #41
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Originally Posted by knocturnal View Post
i had my car tuned in that weather and never had issues. i went to meth after just for better numbers
Big power stock block - what you should know
Now you know, so be prepared.
Ringlands crack because of excess of heat, tuned or not, with meth or not (meth helps, but when people use it also up the boost and timing).
Originally Posted by PearlySpeed View Post
Yep, 88mm Manley pistons. Luckily, the bores were fine.
If the bores are fine and you can use 87.5mm pistons I'd return the 88mm pistons and get 87.5 instead.
If something happens again (and on tuned cars chances are that it will) you at least have what to bore into. If you have any bore issue with a block already bored to 88mm the options are limited, basically you need to get some custom pistons (probably Arias, and have them machined). Also, you'll also save some money on machining the block. I also had cracked ringlands on #2 and #3 and the block was absolutely and totally mint in factory specs, but I already had the 88mm pistons and in my case it's less easy to return a part from the other side of the planet and get a replacement.
Also make sure you add a meth kit to your build. If you don't plan to up the power with meth then just tune it to the max with pump gas and spray water+meth through a DO3 nozzle or something. However, with stringer internals and the CS turbo you can use some Do12 (or equivalent) nozzle and shot well above 400bhp.
Vitamin M likes this.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 02-02-2017, 10:54 PM   #42
PearlySpeed's Avatar
Posts: 122   (View Stats)
PearlySpeed has much to be proud ofPearlySpeed has much to be proud ofPearlySpeed has much to be proud ofPearlySpeed has much to be proud ofPearlySpeed has much to be proud ofPearlySpeed has much to be proud ofPearlySpeed has much to be proud ofPearlySpeed has much to be proud ofPearlySpeed has much to be proud ofPearlySpeed has much to be proud of
Progress pics finally, had to get a new block from Mazda so I went with stock bore manleys, I'll keep the 88mm Pistons when rebuild time comes around again.
1 slow speed
PearlySpeed is offline   Reply With Quote
The Following User Says Thank You to PearlySpeed For This Useful Post:
mituc (02-03-2017)
 Old 02-02-2017, 11:30 PM   #43
rocknrolla47's Avatar
Posts: 77   (View Stats)
rocknrolla47 is just really nicerocknrolla47 is just really nicerocknrolla47 is just really nicerocknrolla47 is just really nice
Groaned at 14 Times in 6 Posts
Default BNR S4 Build in Florida
Originally Posted by rocknrolla47 View Post
Awesome , I had to bore mine , cyclinder #3 was fucked lol. Got 88mm wiseco pistons with Manley h beam rods and oem bearings , apt head studs and main. What bearing did you go with ? I was tempted to go with the clevite h series but opted for the oems for a semi daily Speed3 , also got balance shaft delete and jbr oil pan baffle , act hd clutch with streetlite flywheel , Damond motorsports vented oil catch can , Matt Damond pcv plate , and corksport injector bushings. Plan on getting 5th and 6th port later. All this on the bnrs4.
Corksport hpfp- Corksport long catted downpipe-Ultimate racing catback- tr6 front mount intercooler w/ cx racing piping- Jbr 3.5 tru wide path aluminum intake- Jbr 3port bcs- Jbr rear and passenger mount-Bosch 3 BAR MAP sensor- Jbr shifter bushings- Matt Damond shift plate-
Last edited by rocknrolla47; 02-02-2017 at 11:33 PM. Reason: MSF Database - Automerged Doublepost
rocknrolla47 is offline   Reply With Quote
 Old 02-03-2017, 12:07 AM   #44
I went with oem bearings as well. Future fueling plans for me are going with the Damond ST port injection adapter.
1 slow speed
 Old 02-03-2017, 03:00 PM   #45
Couple mock up pics
JFSpeed3 and Jonb82 like this.
1 slow speed
 Old 03-10-2017, 09:46 PM   #46
It's finally alive! First start, everything went smooth. No codes, no leaks, no smoke, runs smooth and feels strong.
Jonb82 and rocknrolla47 like this.
1 slow speed
 Old 03-11-2017, 10:35 AM   #47
Jonb82's Avatar
Posts: 416   (View Stats)
Hell yeah. How long has it been down for?
Sent while probably pooping
 Old 03-11-2017, 11:53 AM   #48
Damn near 4 months. I started pulling the engine 2 weeks before my son was born, so I've been lucky to get 10 min a day to finish it until recently. Do you work at ultra tech?
1 slow speed
 Old 03-11-2017, 11:55 AM   #49
tmillner's Avatar
Posts: 621   (View Stats)
Did you get all you ic piping powder coated? Looks good
Sent from my SM-G935P using Tapatalk
 Old 03-11-2017, 12:41 PM   #50
Jonb82's Avatar
Nope I manage a restaurant
 Old 03-11-2017, 03:38 PM   #51
I just painted it with spray cans
1 slow speed
 Old 08-30-2017, 08:43 PM   #52
BYE BYE S4 hello BorgWarner. Changing some things up with the setup. Running a FJ Performance T3 manifold and this BorgWarner with the JMF intake manifold and 6th port. Should be able to hit 500whp comfortably with good response
JFSpeed3, Jonb82 and Tifosi42 like this.
1 slow speed
 Old 08-31-2017, 09:35 AM   #53
JFSpeed3's Avatar
Posts: 5   (View Stats)
JFSpeed3 will become famous soon enough
Why the change from the BNR S4? Did it just not meet your power goals or where you ready to go for more power now? Just curious since I was looking into the BNR S4 for my future upgrade path. Thanks
Sent from my SAMSUNG-SM-N920A using Tapatalk
JFSpeed3 is offline   Reply With Quote
No AC in Florida Leila Mazdaspeed3/6 General Discussion 2 06-11-2014 04:54 PM
Page generated in 0.34341 seconds with 26 queries
