> 2010 MS3 - Big Turbo Builds
Like Tree20Likes
 Old 12-18-2011, 09:49 AM   #241
Ziggo's Avatar
Posts: 3,843   (View Stats)
What kind of boost were you running? Any idea how much torque?
Ask Me About My:
 Old 12-18-2011, 09:59 AM   #242
Ckmazdaspeed3's Avatar
Posts: 2,077   (View Stats)
Groans: 134
it would spike at like 24 and settle 22-23psi. The torque was pretty high from the eth. I'd have to look at VDs, but I bet close to 400. I could occasionally break loose in fourth and third gear was useless.
DJ has a copy of my tune and is reviewing it just to make sure that I didn't make any glaring mistakes, and of course, he is always curious about shit like that anyway.
I think that if my head is ok, I might buy Joel's extra short block and do a mild build. Upgraded rods with stock pistons cuz i may have the hook up on the pistons for cheap... DJ gave me a brief idea of what needs to be done, and I'll talk to him more about it soon. He also has an engine shop book for the motor. I just want a build with more durability than stock, but because I DD and don't plan on running the best tires (cuz with all my miles they wear too quickly) I still don't really want anymore than 400whp.
Shit CK, really sorry to hear that. Best of luck with your beater car, and whatever you decide to do ms3 wise.
Well thanks, but honestly (unless I'm in shock or some shit), I'm really not too bummed at all and although there will be major headaches and dolla dolla bills to be spent, I'm actually looking forward to the learning process.
I'll never be one of the gear heads on here, but I would like to understand as much as possible about how a car works.
Last edited by Ckmazdaspeed3; 12-18-2011 at 09:59 AM. Reason: MSF Database - Automerged Doublepost
Ckmazdaspeed3 is offline   Reply With Quote
The Following 5 Users Say Thank You to Ckmazdaspeed3 For This Useful Post:
atvfreek (12-18-2011), charlesfist (12-18-2011), djuosnteisn (12-28-2011), rfinkle2 (12-18-2011), silvapain (12-19-2011)
 Old 12-18-2011, 10:03 AM   #243
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
Damn Keith, sorry to hear about that. Ya never like to hear about someone blowing an engine like that and it doesn't sound like you did anything wrong just prior to the incident. Its more likely a slow process weakening or bending of the rod over time until bam.
you sure the drain plug is still in there....lol
Seems the speeds tend to let go in cooler weather for some reason and I know load/TQ values are higher but not sure that alone is the cause. In the early days it was thought the combination of higher load values along with the load cap was the cause of blown motors but we have removed one of those variables.
Your LTFT values would indicate you were running richer which would make less power if anything so I don't think they are a factor in themselves.
BTW what PSI and or Load do you typically see i the same conditions as last night?
Edit: see your psi what load values do you see when that "spike" occurs?
phate (12-21-2011), rfinkle2 (12-18-2011)
 Old 12-18-2011, 10:06 AM   #244
Groans: 134
There also MAY be a financial silver lining. APPARENTLY, at least for joel, who totaled his car last month (truck ran him off the road... he was not racing... if you have not heard), because he never used his extended warranty once, he was able to get it refunded... IDK, what the parameters are for that, but I'm gonna look into it, cuz there may be 2kish there.
Seems the speeds tend to let go in cooler weather for some reason and I know load/TQ values are higher but not sure that alone is the cause. In the early days it was thought the combination of higher load values along with the load cap was the cause of blown motors but we are removed one of those variables.
load peaks at 3ish (skewed from eth) and boost sits around 23 w a peak not much higher than 24.
Last edited by Ckmazdaspeed3; 12-18-2011 at 10:06 AM. Reason: MSF Database - Automerged Doublepost
The Following 3 Users Say Thank You to Ckmazdaspeed3 For This Useful Post:
Dano (12-18-2011), dougefresh_ (12-18-2011), rfinkle2 (12-18-2011)
 Old 12-18-2011, 10:07 AM   #245
atvfreek's Avatar
Posts: 7,787   (View Stats)
Shit if you have an extended warranty, you can probably get paid for a block and labor. Who is the warranty through? Even though you have BT, if it's not through mazda and it's an after market extended warranty, they just send an adjuster out and take a pic of the hole in the block.
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 2 Users Say Thank You to atvfreek For This Useful Post:
 Old 12-18-2011, 10:13 AM   #246
Trail of Fail
Dano's Avatar
did you see the new vent hole in the block and was it in the #3 cylinder location?
since you are vested in learning more it would be interesting to keep your hands on during the teardown to see if there are any other signs of wear that might give a clue as to the cause.
it may just be that in the end there will be no smoking gun per se and all you'll find are some bent/broken rods.
Were you running a MAP, Grimspeed IM or stock? I still feel that poor IM design leans out #3 to a dangerous level and why Mazda calibrated their DISI in such a rich condition to compensate.
atvfreek (12-18-2011), rfinkle2 (12-18-2011)
 Old 12-18-2011, 10:29 AM   #247
Ziggo's Avatar
Did you have an upgraded MAP? Or are you just reading boost off of a gauge?
Based on my results 24psi would be much more than 400wtq particularly at low temperatures and on an Eth mixture. I am load targeting about 400wtq am down to 18psi as it has been cooling off.
Ask Me About My:
Ckmazdaspeed3 (12-18-2011), rfinkle2 (12-18-2011)
 Old 12-18-2011, 11:09 AM   #248
bewsted's Avatar
Posts: 2,456   (View Stats)
bewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the world
After seeing what @burn813 car did on 3 gallons of e85 I'm starting r see why on a bt its just not as viable as it is on the k04. 105 idc on 22 Psi @ only 5200 rpms.... That's no Buenos if u Ask me
When your demanded more fuel and the injectors run out of juice bad things happen
EWG K04...GETSUM!
A journey to make people cry like babies when loosing to a wagon.
bewsted is offline   Reply With Quote
 Old 12-18-2011, 11:30 AM   #249
Groans: 134
I do hav an upgraded map, but I don't think I was making as much power as u and dano cuz my 60-100 times were a bit slower than danos anyway... In 4th, 60-100 was at 4.7 recently.
 Old 12-18-2011, 11:53 AM   #250
RyansSpd3's Avatar
Posts: 424   (View Stats)
RyansSpd3 is the leader of the worldRyansSpd3 is the leader of the worldRyansSpd3 is the leader of the worldRyansSpd3 is the leader of the worldRyansSpd3 is the leader of the worldRyansSpd3 is the leader of the worldRyansSpd3 is the leader of the worldRyansSpd3 is the leader of the worldRyansSpd3 is the leader of the worldRyansSpd3 is the leader of the worldRyansSpd3 is the leader of the world
Groaned at 7 Times in 5 Posts
Sorry to be a pain in the ass but i skimmed through everything and couldnt get the gist of everything...You running gt3071 or gt28? I'm local so cut me slack haha
||2008 Metro Grey Ms3|| Cobb Sri|| Cobb TIP|| Cobb AP|| TurboSmart Dual Port BOV|| ATP full downpipe|| Autotech fuel pump internals|| TurboXS FMIC|| Denso ITV22's|| JBR 88a RMM|| BC Coilovers|| Evo X Wheels|| 25% E85 Mix|| Phate Tuned||
RyansSpd3 is offline   Reply With Quote
 Old 12-18-2011, 11:54 AM   #251
atvfreek's Avatar
IIRC He's running GT2871
Tappin
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
 Old 12-18-2011, 12:10 PM   #252
Ziggo's Avatar
Power != torque. Acceleration is based on power, specifically power under the curve. I am making near 400whp, but keeping torque down using my brontosaurus boost curve.
Torque is ultimately what blows motors, not power. I am mostly curious because your tune and hardware was stable. Make sure to save the broken bits. I would like to do some failure analysis to make sure it wasn't a fatigue failure.
A single large event like hyrolock will tend to bend rods, fatigue would cause catastrophic failure.
Ask Me About My:
 Old 12-18-2011, 01:11 PM   #253
Groans: 134
Ok, so dont know much more except that it is one and/or two and there is a hole in the front and a hole in the back of the block
The Following 2 Users Say Thank You to Ckmazdaspeed3 For This Useful Post:
 Old 12-18-2011, 01:22 PM   #254
bewsted's Avatar
Hurmmmm.... Still blows
EWG K04...GETSUM!
 Old 12-18-2011, 01:27 PM   #255
Trail of Fail
Dano's Avatar
Lol
Well at least you didn't do it half way
Tappin
Ckmazdaspeed3 (12-18-2011), djuosnteisn (12-28-2011), rfinkle2 (12-18-2011)
 Old 12-18-2011, 04:58 PM   #256
This sucks man, how many miles did you have with the turbo?
 Old 12-18-2011, 05:06 PM   #257
Groans: 134
Dude it doesn't "shuck" too bad if I can get a beater set up. 15k since the turbo has been on. It's been making really good power for about 5k
 Old 12-18-2011, 07:15 PM   #258
JacksonMS30's Avatar
Posts: 2,242   (View Stats)
/me engages grandma driving mode for the rest of winter
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M Twisted Top Mount -
- P.E.R.M.Tuning -
The Following 6 Users Say Thank You to JacksonMS30 For This Useful Post:
atvfreek (12-18-2011), burn813 (12-18-2011), Ckmazdaspeed3 (12-18-2011), djuosnteisn (12-28-2011), dougefresh_ (12-18-2011), rghispanic88 (12-21-2011)
 Old 12-18-2011, 07:40 PM   #259
bewsted's Avatar
Don't be scared lol
EWG K04...GETSUM!
The Following User Says Thank You to bewsted For This Useful Post:
 Old 12-18-2011, 07:50 PM   #260
lulz @Raider
burn813's Avatar
Posts: 3,171   (View Stats)
I think I said something like that already too..... Hey I got an idea Alan..... You go out and wot and tell me if you are ok!
2008 MS3 gt
470hp/463tq on GT35r at 29psi
burn813 is offline   Reply With Quote
The Following 2 Users Say Thank You to burn813 For This Useful Post:
atvfreek (12-18-2011), JacksonMS30 (12-18-2011)
 Old 12-18-2011, 08:01 PM   #261
bewsted's Avatar
Man u Guys..... I can haz fastest bt in the Lou?
EWG K04...GETSUM!
 Old 12-18-2011, 08:06 PM   #262
Groans: 134
 Old 12-18-2011, 08:14 PM   #263
bewsted's Avatar
If u need help with anything let me know man.....
EWG K04...GETSUM!
 Old 12-18-2011, 08:28 PM   #264
lulz @Raider
burn813's Avatar
Meh
2008 MS3 gt
 Old 12-18-2011, 08:41 PM   #265
We have the exact same mileage. I just rolled over 80k last week. I'm boost creeping to 26psi. I'm gonna unclip the wastegate actuator rod until spring.
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M.Tuning -
 Old 12-18-2011, 09:18 PM   #266
lulz @Raider
burn813's Avatar
Lol..... Friday I am putting on the frankenwastegate
2008 MS3 gt
The Following User Says Thank You to burn813 For This Useful Post:
 Old 12-18-2011, 09:23 PM   #267
bewsted's Avatar
Will you guys quit being pussies already....Keith's car unfortunately was destine for this type of death....lets just hope he doesnt try to use snake oil on his motor build and all should be well......
In all seriousness Kyle your going to come over Friday and do that wastegate right?
If Kieth gets his car back before then would you mind swinging by there and snatching his intake..I haz need for it.
BTW Kieth i still love you and would gladly rub your back at any moment! By back rubs used to cause people to get BJS!
EWG K04...GETSUM!
rfinkle2 (12-21-2011)
 Old 12-18-2011, 09:38 PM   #268
Groans: 134
No, they don't sadly. Anyway, yeah, my car was destined. I can only imagine I screwed something up to cause this, but here is what we have:
Dyno axle fail (axle is still working on universal cv boot btw)
Snake oil fail
Clutch fail
Motor fail
If the built motor fails, I'm done lol!
Oh, wg fail too (remember, new bt, but stuck at 15psi!)
Last edited by Ckmazdaspeed3; 12-18-2011 at 09:38 PM. Reason: MSF Database - Automerged Doublepost
djuosnteisn (12-28-2011), rfinkle2 (12-19-2011)
 Old 12-18-2011, 09:38 PM   #269
lulz @Raider
burn813's Avatar
Plan on it! And if I pick up the intake I expect you to do some in taking
2008 MS3 gt
 Old 12-18-2011, 09:40 PM   #270
lulz @Raider
burn813's Avatar
Snake oil fail
Clutch fail
Motor fail
Lol I am sure there is moar fail that you are not remembering
2008 MS3 gt
 Old 12-18-2011, 09:56 PM   #271
Do the coil packs count as fail?
Cause if so I was personally wittness to two of Keiths fails and I was only in STL for a weekend...
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M.Tuning -
The Following 3 Users Say Thank You to JacksonMS30 For This Useful Post:
burn813 (12-18-2011), djuosnteisn (12-28-2011), silvapain (12-19-2011)
 Old 12-18-2011, 10:26 PM   #272
bewsted's Avatar
Snake oil fail
Clutch fail
Motor fail
That is where it all began....did you by chance keep that old wg?
And did you ever try adjusting the arm on it...Just saying it may have worked afterall.
As long as keith is ok with all of this shenanigan.....@Ckmazdaspeed3 how does this situation make you feel.....
EWG K04...GETSUM!
Last edited by bewsted; 12-18-2011 at 10:26 PM. Reason: MSF Database - Automerged Doublepost
 Old 12-19-2011, 12:02 AM   #273
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
Good luck with build & finding a beater. Sorry about the motor, but at least it had some miles on it.
Ckmazdaspeed3 (12-19-2011)
 Old 12-19-2011, 09:00 AM   #274
Trail of Fail
Dano's Avatar
Careful guys, Keith can and will spread his fail around. Already gave me some back a few months ago with my fueling issues.
My suggestion is for everyone in this thread to take it easy on the car for a week or two.
Jussayin
*mods map for 18 psi boost target*
Tappin
Ckmazdaspeed3 likes this.
bewsted (12-19-2011), Ckmazdaspeed3 (12-19-2011), silvapain (12-22-2011)
 Old 12-21-2011, 09:31 AM   #275
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
It pains me to read about this. Best of luck with the build.
-06 MS6
-Corn fed 07 MS3 - Sold
 Old 12-21-2011, 09:32 AM   #276
bewsted's Avatar
lol....why dont you come down and help dissessmble and reassemble man...
EWG K04...GETSUM!
 Old 12-21-2011, 09:43 AM   #277
Eth Fiend
phate's Avatar
If you guys are doing it next week, I'm down. Christmas vacation FTW!
-06 MS6
 Old 12-21-2011, 09:52 AM   #278
bewsted's Avatar
I have to work all week.... But when Keith calls upon my assistance I will be there
EWG K04...GETSUM!
The Following 2 Users Say Thank You to bewsted For This Useful Post:
Ckmazdaspeed3 (12-21-2011), Dano (12-21-2011)
 Old 12-21-2011, 09:54 AM   #279
Eth Fiend
phate's Avatar
Let me know if you guys need some help or whatever! You guys aren't that far away.
-06 MS6
 Old 12-21-2011, 10:07 AM   #280
Groans: 134
I'm sure that the build won't commence for at least a couple of weeks, if not more because:
1) Dustin is on vaca and has a set of pistons for me, and also helps like everyone else on here, so it may take him a bit of time to send them out
2) I am having my motor built by one of the most talented guys out there (has a shop car which is an old laser with a built motor with 300k+ on it). The only problem with him is that he moves slower than molasses and he has to wait on the pistons from DJ.
At this point, I don't think that my rods have been ordered, but papasmurf raised a point regarding machining the k1 rods which worries me. He says that they have to be machined perfectly (which I would expect), but his doubt makes me curious to know how hard it is to machine them perfectly? Can any compitent machinist do this, or should i look into a different set up?
and when the time comes, I will definitely give a shout out to NATOR IL (NATOR MO's brothas from different mothas) and see who can come down.
The Following 4 Users Say Thank You to Ckmazdaspeed3 For This Useful Post:
Dano (12-21-2011), djuosnteisn (12-28-2011), phate (12-21-2011), rfinkle2 (12-21-2011)
MX-5 EFR Turbo Build Andy@Killshot Miata - Forced Induction 40 12-28-2011 04:01 PM
Turbo Build UKMPS3MK2 2010 MS3 - Turbo Induction 12 05-10-2011 09:53 AM
My big turbo build Speedie6 MazdaSpeed 3/6 - Big Turbo Builds 4 12-09-2010 01:54 AM
Big turbo kit, build one or not? ptperformance Mazdaspeed3/6 General Discussion 33 10-12-2008 02:55 PM
Page generated in 0.59937 seconds with 31 queries
