| 2010 MS3 - Big Turbo Builds Genpu - Big Turbo Builds. All discussions about big turbos, hybrids and builds belong here. |
13Likes ![]() |
![]() Join Date: Apr 2013 Location: Wilkesboro, North Carolina
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,221
(Thread Starter) | Not Ranked : 0 score Has anyone else noticed this when going BT? I doubt anyone cares, but any little bit helps when trying to justify mods to the fiance'. No corn or e85 just your typical 93 v-power. Also, catted downpipe with stock catback and CS TMIC that is being replaced by a UR FMIC. |
![]() Join Date: Aug 2011 Location: Goffstown,NH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,292
| Not Ranked : 0 score I dont trust that computers estimate so I just do the math at the pump when I fill up and reset my trip. Worst Ive gotten so far is 23mpg on all wot logs multiple maps. So far this last tank I got 31mpg at 60mph I commute 90miles round trip for work. Im that slow asshole in the right hand lane. Edit: I should mention the 31mpg was on and off boost..not much wot besides getting on the highway. Im very pleased with it since it pulls now.
__________________ 2010 black mica ~GTX2867~ Auto tech internals--UR DP--UR res TP--bosch 3 bar map--HTP 3.5" intake--GFB dual port bpv--Cobb fmic--Cobb AP--GS EBCS-- --JBR fully mounted --JBR OCC--JBR TB TIG--JBR 51r battery tray--JBR RSB--JBR rear camber arms --Stratified extended shifter-- Freektuned333hp/354tq @ gsd (without meth) Last edited by YABBAMZR; 09-07-2013 at 11:41 PM. |
![]() Join Date: Jun 2011 Location: australia
Rep Power: 1125 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,310
Groaned at 8 Times in 4 Posts
| Not Ranked : 0 score Slower to get into boost = less fuel ![]() Did notice my highway cruising got better with BT, around town was about the same
__________________ OLD: GT3071 IWG | Autotech HPFP | Cobb AP | tune | Catted DP |HDi FMIC | CPE 4" TIP + 3.25" MAF | Grimmspeed EBCS | RX8 S2 Rims | JBR 80a Trilogy | Forge V2 BPVNEW: HTP full 3" | catted DP | Autotech HPFP | COBB AP |
| The Following User Says Thank You to SarcasticOne For This Useful Post: | rfinkle2 (09-08-2013) |
| Not Ranked : 0 score I hope the freek is ok with me answering a q. concerning one of his tunes, but I'm pretty sure a slightly higher closed loop max load, a little leaner afr in open loop, tighter maf curve and not entering open loop fueling and boost as often (as Sarcastic one mentioned above) should definitely help your fuel economy. |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | Mistersix (09-18-2013) |
![]() Join Date: Sep 2012 Location: Roanoke, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,408
Groans: 39
| Not Ranked : 0 score I suppose it's a good feeling to get more power and also more mpg, but unfortunately that computer is usually off a good amount. If you actually do the math when you fill up you'll get the correct mileage. Although I'd say it's plausible you would still be getting better mpgs if you did it he manual way too.
__________________ 2008 MS3 |
| The Following User Says Thank You to Dralphy For This Useful Post: | rfinkle2 (09-09-2013) |
![]() Join Date: May 2010 Location: Virginia Beach
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 369
Groans: 58
| Not Ranked : 0 score Im haven't been seeing that but I have also been doing quite a few logs and do a lot of stop and go during the week so I have been getting around 20-21. I am sure for a highway run chilling I will get up there.
__________________ [SIGPIC][/SIGPIC] 2013 CWP (DD)COBB AP| JBR HSK| JBR RSB| JBR SSP| JBR Shifter Bushings| AT Internals| Ksport Kontrol Pro Coilovers| 3.5 MAF HOUSING| 3' HTP TIP| UR FMIC| TIGS| GTX2867| EBAY 3' DP TUNE IN PROGRESS (RFINKLE2) 1999 Mazda Miata (PROJECT) (blown motor) BEGI Cast Manifold| BEGI DP| SR20 Turbo (GT2554)| Flying Miata Silicone IC Piping| Cx Racing IC| HKS BOV| TEIN SA| Harddog Rollbar|Sparco Spint V| TRmotorsports C1 15x8 |
Rep Power: 6573 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,956
Groans: 122
| Lol, I can't get my shit to go above 23 anymore. Computer may not be super accurate, but its not 10mpg off either. I'm normally around 21-22mpg and my computer says 23.7 mpg.
__________________ CP-e S2 RMM // TurbineTech FMM // Ghetto SRI // 3" ATP MAF housing // Ultimate Racing CBE // Ebay Downpipe // Cobb AP // Autotechs // PG TIP // HKS V4 BOV // NGK Iridiums // ACT Street Disc // JBR Trans Mount Rich Tuned 330WHP and 363TQ 10-19-13 Moore Automotive ![]() |
![]() Join Date: Jun 2010 Location: Ellicott City, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 57
| Not Ranked : 0 score I made slightly better MPG with my 3071 running 93 octane for the first few months, about 1-2 more mpg than I did on the k04. this is based on my own observations, calculating MPG myself (used the same gas station, same pump even). I'm pretty sure it's almost entirely due to the fact that the bigger snail doesn't spool until much later than the k04, so I could just drive around like a normal person and be lame and never really spool the turbo during my normal commute. simply staying out of boost is probably going to have a more dramatic effect on MPG than the increased efficiency gained from a good tune. it's just that its impossible to stay out of boost with a k04, but much more feasible with a bigger turbo. not that I would actually recommend that anyone intentionally stay out of boost! I wasn't entirely confident in the BT setup at first (install was rushed) so I drove like a bitch. once I got comfortable and started enjoying the turbo more often, my MPG went down but only slightly. once I hopped on the corn wagon, MPG dropped, obviously. I'm now making about 21-22mpg, which is about 5mpg less on average than I did stock. I never saw 30mpg on this car, ever... I don't know if it's my driving style, or the shorter Gen1 gearing or what.
__________________ 09 CWP MS3 Sport - ATP GT3071r on ~E30, ACT 6-puck, TR8 FMIC, Bilsteins, etc... sold Last edited by kimura; 09-08-2013 at 09:22 AM. |
| The Following User Says Thank You to kimura For This Useful Post: | rfinkle2 (09-09-2013) |
![]() Join Date: Jun 2013 Location: Gilbertsville, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 201
| Not Ranked : 0 score |
| Not Ranked : 0 score I see that too... Hmm maybe someone else can chime in then. I saw that it was in order to keep the wideband primary AF sensor calibrated. Too much conflicting information. |
![]() Join Date: Nov 2010 Location: Manchester, NH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,797
| Not Ranked : 0 score @rfinkle2; I'm always ok with you answering questions, so never hesitate to chime in. Lol It is actually very common to get better gas mileage with a bigger than stock turbo when just cruising. The larger turbo does not have the on/off boost which constantly throws it into OL fueling. Everyone needs to also remember that the best way to control gas mileage is with your right foot. Drive like me and be lucky to average 17mpg and 200 miles per tank. Lol. Drive like @PartiAudiMazdarati; and you will see 360+ miles per tank of gas.
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 |
![]() Join Date: Jul 2011 Location: Danvers, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,418
Well just my experience, which is extremely abnormal, on 93 with the k04 I actually had considerably worse fuel econ (?!) for some reason. Usually would see about 275-280 miles, and if I'm really pushing, maaaaaaaaaybe 300. When I went to e85, consistently in the 300-310 mile range. Don't ask me wtf lol, I can't explain that one either. All I know is I started running e85 year round once I saw the difference made in power and fuel econ. Fast forward to the 28r, and the thing is a freak of nature lol, tune is somewhere in the 340-360 awhp area with the e85 and meth setup, yet I consistently see 350-380 per tank, and a best so far of 412 hahaha ![]() I typically fill ~11 gals of 93, and 3.5 gals of E, so I never drain it further than a 14.8 fill up. Calculating it out, puts it somewhere btwn 23-26 combined mpg on average. And for the record, yes, I do open it up every now and then, give her a nice 3rd-4th, run thru the gears every couple days, but I am pretty anal about tire pressure, regular maintenance. Seems the larger snail not only adds power, but allows the car to cruise much more efficiency. Barely have to tap the gas to keep up a good pace around 65-70.
__________________ 2006 Black Mica MS6 GT FreekBuilt Longblock, Manley 9.5:1, Manley H Beams, BW S300SX 6268 1.00 A/R, Dual Tial 38mm MVR EWG, Twinscroll Tubular Top Mount, EGR Delete, Labontes Stage 2 Meth Kit w/ D10, Grimmspeed 3 port EBCS, 3 Bar Map Sensor w/ Matt Jackson Harness, PERM 4" Intake, Cp-E HPFP, CX Racing FMIC, HKS SSQV V3, NGK IX 6510's, Toyota Injector Seals, PERM Catless 3" Turboback w/ dual Magnaflow Magnapaks, PERM Top Mount Valve Cover, PNP Intake Mani, BSD, ACT ZX4-HDG6, Bilstein HD Shocks, H & R Springs, Stoptech Slotted Rotors w/ API Ceramic Pads, JBR Heavy Shift Knob Stock motor w/ GT2871r: 380 awhp, 375 awtq @ 24 psi (e85 only) ![]() - 13.1 @ 110, 2.1 60 ft | |
![]() Join Date: Mar 2013 Location: Huntsville, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,402
| Not Ranked : 0 score I was getting the 34-36mpg (on screen only) on Freek's 93 tune with the K04 ~75mph on flat road. I gained 10% fuel economy from the tune, and then lost it and 10% more with the E85 25% mix. I also commute about 7 miles, so zero fucks given for MPG I'm in the boost all the damn time and avg 21 overall.
__________________ Manley forged long block, secret snail, manifolds, and 2gal E85 tune running like a champ - about to dial in a lot of meth and see what we've got. 13.10@117.1 full weight DD no prep 1/4 (BNR S3 / E85) |
| Hide Yo Kids-No really, Hide them! ![]() Join Date: Oct 2011 Location: PMITA Jail until 12/2015
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,515
Groans: 77
| Not Ranked : 0 score Wtf? How are you people doing this? Fully bolted k04 I was lucky to get 250-280 to a full tank. Bt, I see about 220 if I'm lucky. And I'm murdering tires too. |
![]() Join Date: Feb 2010 Location: SLC, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,720
| Not Ranked : 0 score from my experience messing around and trying to gain fuel economy through tuning, i haven't seen an increase with the gtx2867 vs the ko4. Granted i have optimized my tune for my driving style, so yes if you are a little foot happy its easier to waste fuel with short bursts from the ko4. Last summer i always averaged around 23mpg, and i have been continuing to do so with the gtx.
__________________ GTX 2867/ JBR OG 3.5 WP/ Snail Ported IM/ ITV-22/ DAMOND RMM EBAY DP wCAT/ HKS BPV/ CP-E FP/ COBB EBCS/ PG FMIC W/ TR8 STOPTECH/ EBC YELLOW/ GOODRIDGE LINES/ MOTUL RBF 600 [443/409]SAE CORRECTED -------------245 DZ102 / 245 NT01 |
![]() Join Date: Sep 2011 Location: St. Johns, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,014
Groans: 56
| Not Ranked : 0 score I was a pretty large increase in highway driving when I went to the 3071. Around town took a hit however. Of course now I'm running meth in-tank so it's all shot to hell.
__________________ 2008.5 CWP: GTX 3071//Rapebuilt EM//Relentless pnp IM//JBR 3.5" WP//TurboXS DP/RP//TR8C/Cobb FMIC//GFS bpv//JBR 88/70/70a//Eibach Pro Kit//Koni Yellows//JBR RSB//RX8's Awaiting Install: DO Stage 2//3 Bar MAP//CPe Safeseals Winter Beater: 96 GMC K1500 5 speed 4x4 Needed: Driver mod [SIGPIC][/SIGPIC] |
![]() Join Date: Dec 2009 Location: camas valley
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,720
Groans: 40
| Not Ranked : 0 score mine definitely improved on freeway but on my route home if i drive it sporty it gets better than putting at 55,so 65 70 is the sweet spot with lots of wot's ![]() but mine is perm tuned, but when you go wot mine use to drop into the 10s so leaning it out to 11.5 does make a difference .... and all the big exhaust and intake no cats, it breaths way better..
__________________ BT T3 .5557 @25 psi 10. 6:1 peformance3 pistons, manley rods arp 625+ rod bolts, arp L19 head studs, Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, cobb electronic boost control 1 3/4 screamer p, odyssey batt, cs racepipe, custom 3'' dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth 2000 cc, ATC 6 puck sl fw 472 hp 461tq virtual dyno and ran out of fuel! nishan said theirs a easy 550 in the setup if i had the fuel but meh... 54,000 miles big turbo! stock block at 104000 2 bent rods current miles 113000 and runs perfect! no hiccups! tuned by nishan |
![]() Join Date: Jun 2012 Location: Hickory NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 324
Groans: 106
| Not Ranked : 0 score Just another reason to go BT you get better fuel mileage along with more HP
__________________ go fast- atp gt2871r,3bar map sensor,3port ebcs,freektune 4" wp intake,,jbr trilogy mount, turbosmart bov,cpe tmic,cpe cbe, UR catless DP, UR catless TP, autotech internals cobb ap v2, aem meth controller and pump, custom meth tank,snow solenoid and aquamist nozzle suspension-c/s springs,c/s midbrace,jbr rsb, 235/40/18 nitto nt55 |
| The Following User Says Thank You to motherfnmonsta For This Useful Post: | NCspecV81 (09-11-2013) |
![]() Join Date: Oct 2011 Location: Spring City, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,343
| Not Ranked : 0 score I cant remember the last time I got over 240 miles to a tank. I suck.
__________________ BNR s3 w/ some other stuff. Hypnotic tuned. |
| Not Ranked : 0 score I don't know about your pump gas tune, but e85 takes substantially more fuel to create a requested afr, so when you are running your e85 tune, you are going to take a mpg hit for sure. That and I think people tend to lay into it a little more when they have some corn in the tank. LOL. |
| The Following 3 Users Say Thank You to rfinkle2 For This Useful Post: |
| Not Ranked : 0 score I know its gone down a bit with my e85 tune, but even before it didnt get much better. I remember the only reason I could somewhat smile when my station ran out of e85 was that I could expect slightly better MPGs. And I still dont think I broke 250. buttfuck it. I dont care. If I cared about fuel economy Id be driving skyactive.
| The Following User Says Thank You to ricknm For This Useful Post: | rfinkle2 (09-09-2013) |
![]() | | #24 | ![]() |
Groans: 106
| Not Ranked : 0 score I normally get 320 off a tank of gas, but most my driving is high way but I feel up twice a week to. I would run corn more often it was easier for me to obtain, I really don't care about mileage when I have corn in the tank cause all I care about is the get up and go the car has
![]() | | #25 | ![]() |
Groans: 77
![]() | | #26 | ![]() |
| Tripple OG ![]() Join Date: Dec 2008 Location: North Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,643
Groans: 113
| Not Ranked : 0 score Some want more power some want more money in their pocket. The way of the world through the eyes of a gearhead @Voltron Locos; |
| The Following 5 Users Say Thank You to NJSPEED3 For This Useful Post: | Agent_Orange (09-10-2013), atvfreek (09-10-2013), rfinkle2 (09-09-2013), ricknm (09-09-2013), Voltron (09-09-2013) |
![]() | | #27 | ![]() |
![]() Join Date: Oct 2011 Location: Boca Raton, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,717
Groaned at 50 Times in 17 Posts
| Not Ranked : 0 score I never hit 300miles p/tank on k04. Now with 3071 and freek tuned will get 220/240.... Because race car.....
__________________ 2012 LSM MS3 Some mods, No list, too much "zapos". |
![]() | | #28 | ![]() |
![]() Join Date: Mar 2012 Location: Pittsburgh, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 105
| Not Ranked : 0 score Last highway trip I made on 93 my cars computer said like 28.x but when I did the math, I ended up being around 31mpg. Which I thought was odd but ill take it. Also, I managed to squeeze out over 400miles on that tank just before the fuel light came on. Now last time I took a highway trip on my e85 map, I averaged (after doing the math) about 23. I think the car said 25.x or something. Same highway going the same direction roughly same temps and blah blah blah. Around town my car says around 21 on both maps and I usually get about 250-275 mpt with minimal highway driving on corn...300-325 on just 93.
__________________ Power: BORG WARNER S360 TURBO w/ .70A/R SINGLE SCROLL HOTSIDE HTP 3.5" WHALE PEEN TIAL 44mm EWG (red) FJ PERFORMANCE TUBULAR MANIFOLD w/ VBAND EWG OUTLET/VBAND CATLESS DP/VTA EWG TUBE/FMIC PIPING - HOTSIDE ROUTED UNDER CAR/AN OIL FEED/DRAIN LINES ULTIMATE RACING CBE TREADSTONE TR1035 FMIC CORE AUTOTECH HPFP INTERNALS COBB TUNING ACCESSPORT GO FAST BITS TMS RESPONS BOV NGK LTR7IX-11 Handling: JAMES BARONE RACING RSB/88aRMM/88aTMM/80aPMM SONIC TUNING S3 COILOVERS STOPTECH SPORT STOP CROSS DRILLED ROTORS BRIDGESTONE POTENZA RE-11 235/40/18 SPC REAR CAMBER ARMS Extra Shit:SURE SHORTCUT/COUNTERSHIFT/ANCHORS JAMES BARONE RACING SPHERICAL HEAVY KNOB/51r BATTERY TRAY/STAGE II OCC CORKSPORT LED REAR BUMPER REFLECTORS/LED INTERIOR KIT/URETHANE EXHAUST HANGERS/GAS HOOD PROP STRUTS BOSCH 3-BAR MAP SENSOR BITWISE PnP MAP HARNESS COBB TUNING 3-PORT EBCS DDM TUNING 8000K LOWS/3000K FOGS O.Z. RACING ULTRALEGGERAS 18x8 +48 MUTEKI SR48 OPEN ENDED LUGS NUTS ARP 100-7708 EXTENDED WHEEL STUDS HELLA SUPERTONES RALLY ARMOUR MUDFLAPS (BLACK WTH RED LETTERS) [SIGPIC][/SIGPIC] K04 POWER FIGURES 277HP/325TQ SixTuned On 93 314HP/356TQ Rfinkle2 Tuned With 33% Corn S360 POWER FIGURES 365HP/356TQ Purple Drank Tuned ON 93 421HP/392TQ Purple Drank Tuned w/ 3 GAL E85 MIX NUMBERS LIMITED BY STOCK BLOCK ON STOCK FUELING TILL SPRING |
![]() | | #29 | ![]() |
| Not Ranked : 0 score Not only is the bigger turbo less spool happy but, under vacuum and while cruising it provides LESS restriction and therefore increases volumetric efficiency when the engine is not in boost. Another trick is to run a recirculating BPV that is open during low throttle conditions. Having the BPV open reduces work on the compressor pushing air against the throttle plate and increases mileage.
![]() | | #30 | ![]() |
![]() Join Date: Apr 2008 Location: San Diego, CA
Rep Power: 493 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 666
![]() | | #31 | ![]() |
| Not Ranked : 0 score Most push type valves if you don't preload or use a very stiff spring. OEM.
![]() | | #32 | ![]() |
![]() Join Date: Aug 2011 Location: Miami, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,355
Groans: 279
| Not Ranked : 0 score This is pretty much what I get, hand calculated as always, which nets me around 270-300 p/ tank depending on how right-foot-happy I am on that week. 60% city/40% highway driving.
__________________ 2010 LSM Speed3 Bolted + Corn + Meth + ACT 6-Puck #BakeryTuned |
![]() | | #33 | ![]() |
![]() Join Date: Sep 2012 Location: Elizabeth, NJ
Rep Power: 3180 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,265
Groans: 665
| The Following User Says Thank You to Agent_Orange For This Useful Post: | Voltron (09-10-2013) |
![]() | | #34 | ![]() |
| Not Ranked : 0 score Permanently bookmarking this thread so I can show it to my wife for the inevitable "you're full of shit a new turbo is going to save money".
| The Following 5 Users Say Thank You to JgamB For This Useful Post: | Agent_Orange (09-10-2013), atvfreek (09-10-2013), Dimenus (09-10-2013), NCspecV81 (09-10-2013), Voltron (09-10-2013) |
![]() | | #35 | ![]() |
| Freektune Speed 6 | dawgincustoms | MazdaSpeed 3/6 - ECU Computer Tuning | 7 | 01-19-2016 01:05 AM |
| 91 Oct Freektune VD vs. Stock | Dr. Speed | 2010 MS3 - Dyno Sheets/Discussions | 41 | 08-05-2013 11:20 PM |
| Freektune in progress... | jseams | 2010 MS3 - ECU Computer Tuning | 43 | 04-07-2013 03:04 PM |
| My Freektune | atvfreek | 2010 MS3 - Dyno Sheets/Discussions | 12 | 02-19-2012 08:01 AM |
