| 2010 MS3 - Big Turbo Builds Genpu - Big Turbo Builds. All discussions about big turbos, hybrids and builds belong here. |
![]() Join Date: Mar 2015
Groaned at 9 Times in 4 Posts
(Thread Starter) | Not Ranked : 0 score ![]() My hopes are to keep my internals stock and not detonate. Last edited by iwabo; 09-24-2016 at 04:57 PM. |
![]() Join Date: Oct 2013 Location: FL -IN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 43
| Not Ranked : 0 score I have a very similar setup. I'm running a gtx2867r paired with the cp-e exhaust mani. Tial External west gate and cp-e downscream DP and dump tube. It sounds incredible with their exhaust mani and the EWG dumping straight to atmosphere. If you plan on pushing the tune a bit id upgrade the MAP sensor. The CorkSport 3.5 bar map sensor is plug and play which makes life really easy for installation. And if you really wanna go the next step then consider a Water/methanol kit too. I'm currently tuning mine and hoping to get to 400whp on stock block. |
| Not Ranked : 0 score Pic of exhaust mani and ewg |
. I'm interested in the ewg but really don't know to much about buying/installing one on this turbo (or any turbo lol) but god damn is it pretty | |
| Not Ranked : 0 score I here ya man, it's definitely a quality piece (not cheap haha) but well worth it down the road if you get to that. Cp-e usually have a pretty nice sale around xmas time. As for the ewg, there are plenty of good reads here on how to go about it and Pros vs cons worth searching thru at some point. |
| The Following User Says Thank You to iwabo For This Useful Post: | GabbyChaves (09-21-2016) |
Groans: 63
| Not Ranked : 0 score you need a bigger map sensor, 3 bar is fine but any will need a tune.
![]() Join Date: Mar 2013 Location: North Brunswick, NJ
Rep Power: 1125 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,645
Groans: 143
| Not Ranked : 0 score Your first priority should be to find a way to get some alcohol involved, either methanol or ethanol (via E85). These are medicinal for these engines, providing both a substantial power and reliability increase.
__________________ 2007 Mazdaspeed3 GT |
| The Following User Says Thank You to MD1032 For This Useful Post: | torquemaniac (09-29-2016) |
(Thread Starter) | Not Ranked : 0 score i do plan on getting meth but i don't know how comfortable i feel installing it properly. it seems tricky. I'm good with bolt on parts but when it comes to drilling holes in my car and running hose from one end to another i get sweaty palms. Last edited by iwabo; 09-22-2016 at 12:00 AM. |
(Thread Starter) | Not Ranked : 0 score Welp, i just ordered an Aem meth inj. kit and throttle body spacer. here goes nothing ! |
| Not Ranked : 0 score Nice, I have the AEM also with their fail safe flow gauge and so far it's been great. |
| Not Ranked : 0 score Yes about 4 inches before the throttle body. With a snow 375 cc/min nozzle. Playing around with mixes to see what the car likes best. |
| COCKSTRONG ![]() ![]() ![]() Join Date: Jul 2011 Location: Your Mom's House
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,809
Groans: 890
| Not Ranked : 0 score OP picked a good username!
__________________ Searching for something? Try MS3Shadow's Custom Search EVERY "I DON'T USE MSF" FACEBOOK RETARD EVER |
![]() lol thanks man seen them live 3 or 4 times, good show Last edited by iwabo; 09-23-2016 at 12:30 PM. Reason: MSF Database - Automerged Doublepost | |
| The Following User Says Thank You to iwabo For This Useful Post: | SofaKingAwesome (09-23-2016) |
Groans: 438
I'll see if I can dig up the link, it's definitely on here though. Here you go - Dale's meth injection fun - pre vs. post TB and dual vs. single nozzle
__________________ All good things must come to an end... | |
| The Following User Says Thank You to g00s3y For This Useful Post: | torquemaniac (09-29-2016) |
| Not Ranked : 0 score Interested in seeing the difference with the tb spacer as far as temps go. With my set up I see about 10-20 degrees below ambient when WOT |
Groans: 438
| Not Ranked : 0 score Check out that link in my post above yours. BAT data is in there too.
| The Following User Says Thank You to g00s3y For This Useful Post: | GabbyChaves (09-23-2016) |
![]() Join Date: Mar 2012 Location: Oroville, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
Groaned at 13 Times in 2 Posts
| Not Ranked : 0 score You will need a larger maf housing for 400whp. |
![]() Join Date: Mar 2011 Location: Dallas, Texas
| Not Ranked : 0 score My input, I would definitely get the MAP sensor and I'd also go ahead and get the 3.5 bar one. I got the 3 bar and now wish I had the 3.5 If you are staying on stock internals, the turbo should get you there. I agree with @MD1032; Alcohol is medicinal, I think a requirement for these engines. Not only for the added fuel (which is why it's good you went Meth spray) to get to 400 hp, but for the octane and cooling protection it provides. As far as doing it yourself, it's just plumbing. Just make sure you clean up all the shavings when you are done taping. Those wouldn't be good for your engine Edit: I would do it off the engine to make sure you can clean it well
__________________ Max Bolted and Built Stock K04 |
(Thread Starter) | Not Ranked : 0 score Judging by the what i read i may have just wasted 90$ on the JMF throttle body spaced, I'm going to install the meth kit and have justin@freektune do his thing and see if it's a bad idea or not. Once i get the gtx2867 in i will decide where to mount the meth/inj location off of those numbers. I'm kind of salty i didn't i didn't do all my research first |
![]() Join Date: Jun 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 242
| Not Ranked : 0 score I've had the 2867 with meth on mine, you can get 400whp on a 2867, but the timing and boost needed isn't good for stock internals, the ring lands will give out especially on an aged engine. 3076 is a good choice torque comes in just right where you want it with a FWD without the rods flying out the block and doesn't need a shit load of boost or timing to get 400.
__________________ Gen 2 2012 - Precision 6062 Turbo - CPE Exhaust Mani - PTE 46mm EWG - 2NV Industries built Forged bottom end - PNP Head - JMF V2 Intake Mani- Custom DP UR Cat Back - HTP 4 inch intake - TR8 FMIC - Custom FREEKTUNE METH Port Injection - Cobb 3 port EBC- Autotech internals - FREEKTUNED. |
![]() | | #24 | ![]() |
![]() Join Date: Aug 2012 Location: Toronto, Ontario, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 165
Groaned at 7 Times in 4 Posts
I'm running 16* at 6k rpm on the k04 and am intentionally not going any further as I am approaching the lowest e85 mix timing curve posted in the e85 timing database thread started by @phate;
__________________ - 2009 Speed 3 - Clocked BNR S4 v2 - Corksport 3.5" Intake - Cobb 3 Port Bcs - Cobb AP V2 - Guardian Angel V3 - Tr8 Fmic w/ Jbr Under Route Piping - Jbr Raiders Air Damn w/ Custom Radiator Side Ducting - Cpe Catless Dp - Cnt Catback - Cobb Xle Bpv - Corksport IM - Full Race EM - Cobb Shift Knob - Autotech Internals - Corksport HP Fuel Line - Gen 2 VC w/ Sp63 Oil Breather Cap - DM PCV Plate w/ Dual Vented Catch Cans - Jbr 88a Rmm - 88a Tmm - 80a Pmm - Corksport Injector Seals - Ngk 1 Step colder Plugs - Koni Yellow Shocks - Eibach Springs - 94 Octane w/ 3 Gallons of In Tank Methanol - Sp63 6th Port Kit (tune in progress) | |
| The Following User Says Thank You to BuddySpeed3 For This Useful Post: | phate (09-24-2016) |
![]() | | #25 | ![]() |
Rep Power: 1237 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,288
Groans: 111
| Not Ranked : 0 score Timing or boost alone will not damage anything. The combination of the two (which can give you an idea about the cylinder pressure) may. Detonation will for sure, even the slightest if it happens too many times in a row on an already hot engine when the factory pistons crowns are already a bit more brittle than we'd like.
| The Following 2 Users Say Thank You to mituc For This Useful Post: | BuddySpeed3 (09-24-2016), torquemaniac (09-29-2016) |
![]() | | #26 | ![]() |
![]() | | #27 | ![]() |
| Not Ranked : 0 score Doesn't the turbo choice depend on how you want to drive? Sure the 3076 "holds" off until just when you want it, but only if you are doing a pull. If you are cruising and shift and punch it, won't it take much longer to spool up and give you the power you are looking for, say about 4000 rpm. The 2867 would be almost instantaneous.... I would prefer to tune the turbo reaction to save the motor instead of picking a turbo that spools slow and saves the engine :-) Just my opinion
| The Following User Says Thank You to sheston For This Useful Post: | MD1032 (09-26-2016) |
![]() | | #28 | ![]() |
![]() | | #29 | ![]() |
I can only go off experience running both turbos as a daily both on and off meth.
__________________ Gen 2 2012 - Precision 6062 Turbo - CPE Exhaust Mani - PTE 46mm EWG - 2NV Industries built Forged bottom end - PNP Head - JMF V2 Intake Mani- Custom DP UR Cat Back - HTP 4 inch intake - TR8 FMIC - Custom FREEKTUNE METH Port Injection - Cobb 3 port EBC- Autotech internals - FREEKTUNED. Last edited by shaneski; 09-25-2016 at 04:52 AM. | |
| The Following User Says Thank You to shaneski For This Useful Post: | torquemaniac (09-29-2016) |
![]() | | #30 | ![]() |
Groans: 143
I have yet to experience a single GT/GTX30 turbo that could push me back in my seat at 3000 RPM's. My BNR makes 20 psi at 3000 RPM's but it's definitely not pushing anyone back in their seat until a few hundred RPM's later. Make no mistake, the larger you go, you're going to get more lag. And if you autocross your car at all, you're going to hate it. I like the idea of the 2867 and 3067/3076 more than I like the price. At the end of the day you can pay <$1200 for a BNR that can do the same shit. That's the route I chose. There's a reason they're popular.
__________________ 2007 Mazdaspeed3 GT | |
![]() | | #31 | ![]() |
| Not Ranked : 0 score I've got a K04 that hits 31+ psi at 3000 rpm and pushes me back in my seat. I also get 400 whp at some point. Of course I've got a built engine. I was just trying to point out that various people like different feels in a car. I don't think I would like a 3076 with all the cats, and restrictions. I might if I built it like my current car.
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score From all my readings over the passed few weeks i'm seeing more and more people saying with a stock motor it isn't wise to slap a larger turbo onto my car. The car is my DD and an engine build is ultimately out of the question. As sad as it makes me i think i will be stuck with the k04. I have the AEM meth kit and JMF Throttle Body Spacer w/ Meth Bungs otw hopefully with those mods i will be happy with the power. |
![]() | | #33 | ![]() |
![]() Join Date: Apr 2013 Location: Evanston, IL
Rep Power: 1329 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 938
Groans: 57
__________________ "you, sir, are the most knowledge slow guy I know. Stop fucking around and drive faster." -feejay "if anyone else acts a fool, we'll punish them to Roberts oil hut to discuss string alignment technique" -wetzel | |
![]() | | #34 | ![]() |
![]() | | #35 | ![]() |
| Well, time to change the title :p sent from my Nexus 6P
![]() | | #36 | ![]() |
![]() | | #37 | ![]() |
| I got you, bruh.. I changed it.
![]() | | #38 | ![]() |
![]() | | #39 | ![]() |
Groans: 111
| Not Ranked : 0 score For a DD the 3076 may be a bit too laggy. I have the GTX3071 and I feel it's at the limit of usability in therms of response at low RPM (which is required for a DD).
![]() | | #40 | ![]() |
(Thread Starter) | Not Ranked : 0 score All i really want to know is if it's actually a reasonable idea to buy a BT for a stock block, or am i just better off sticking with k04+meth? |
| GTX2867r | meicalnissyen | MazdaSpeed 3/6 - Turbo Induction | 59 | 04-18-2015 05:06 PM |
| alexryan's GTX2867r Build | alexryan | 2010 MS3 - Big Turbo Builds | 95 | 11-07-2014 06:14 PM |
| EdgeAutosport.com's Focus ST Build w/ GTX2867R | EdgeAutosport.com | Ford Focus ST Ecoboost - General Discussion | 42 | 08-08-2014 02:09 PM |
| GTX2867R Build | mainelyperformance | 2010 MS3 - Big Turbo Builds | 5 | 06-17-2014 04:43 AM |
