> 2010 MS3 - Big Turbo Builds
 Old 10-17-2016, 03:08 PM   #81
iwabo's Avatar
Posts: 51   (View Stats)
iwabo will become famous soon enoughiwabo will become famous soon enough
Groaned at 9 Times in 4 Posts
Originally Posted by RalliartRsX View Post
..........Should have bought an EFR
i wish lol
iwabo is offline   Reply With Quote
 Old 10-17-2016, 03:13 PM   #82
iwabo's Avatar
i think i'll be happy with the 2867, now i just need to find the time to install it and get all the supporting mods. Probably going to buy a Guardian Angel as well, and use that as the map sensor.
 Old 10-17-2016, 08:44 PM   #83
sheston's Avatar
Posts: 1,847   (View Stats)
That's my dream turbo right now. Why did the person sell it?
I guess I need to start bad mouthing the GTX2867Rs so more people will sell them used? By the way, these turbos suck. Very laggy response. Only produce max 20 psi. Flow 10% more than a K04.... :-)
 Old 10-17-2016, 09:09 PM   #84
iwabo's Avatar
lol, he sold it because he's putting his pu back to stock, he parted out everything that wasn't oem
 Old 10-17-2016, 09:15 PM   #85
iwabo's Avatar
Sell that intake and get a 3 inch.
is this not 3"?
 Old 10-18-2016, 01:55 AM   #86
shaneski's Avatar
Posts: 506   (View Stats)
Originally Posted by iwabo View Post
is this not 3"?
The link you posted looks to be their stage III CAI kit which is OEM size MAF etc to suit a K04
 Old 10-18-2016, 12:24 PM   #87
iwabo's Avatar
yeah it is, but with a coupler it should work fine
 Old 10-18-2016, 01:59 PM   #88
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Since you're getting a new intake, why go with an OEM size instead of a larger one better suited for a larger turbo? That question was to wake you up.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 10-18-2016, 10:54 PM   #89
iwabo's Avatar
i know, i just didn't want to spend more money, being stubborn i suppose. The jbr doesn't look bad but it says it won't fit in the oem spot, cp-e paired with there tip looks good but it's also 100$+ more than the jbr... decisions
 Old 10-19-2016, 01:04 AM   #90
shaneski's Avatar
If you want to run e85 or get the best out of the 2867 you will need at least a 3 inch, the OEM size one will max out easy.
What do you mean by the JBR won't fit in the OEM spot. I had the silicone one when i had 2867 and it fits with the stock battery box even though it was slightly against it, but being silicone it wasn't doing any damage compared to what a metal one would do.
Actually have the 3.5 Silicone JBR on my current set up, i use the corksport battery box now and it has an inch clearance from touching that.
 Old 10-19-2016, 01:24 AM   #91
mituc's Avatar
Groans: 111
The JBR Tru 3" silicone version will fit in the factory location. This is what I keep telling you...
First Romanian BT MS3
 Old 10-19-2016, 12:33 PM   #92
iwabo's Avatar
Uses stock mounting location for OEM Turbo. (May not use OEM mounting location with all GT Turbos)
it's right here on edgemotorsports, it's not that i dont believe you it just says it lol
JBR Tru-3.0 Wide Path Full Aluminum Intake System BLUE Mazdaspeed 3 2007-2013 / Mazdaspeed 6 2006-2007 - EdgeAutosport.com
 Old 10-19-2016, 03:19 PM   #93
mituc's Avatar
Groans: 111
I have this intake on my car, I fitted it with my own hands. You're not paying attention at all, I'm saying silicone, you keep giving me links to the aluminium version. I keep saying it fits without relocating the ECU or battery, you keep wondering if it's really true. Man...
shaneski (10-20-2016)
 Old 10-20-2016, 01:21 AM   #94
shaneski's Avatar
Like mituc said..i clearly said mine was silicone as well....you may wan't spend the next month or so reading through pages and pages of this site for some proper research before fitting that turbo.
 Old 10-20-2016, 12:32 PM   #95
iwabo's Avatar
Yes i am still learning, no i didn't notice you also said silicone and i research every night. Not trying to justify myself for no noticing that but i emailed jbr and they did the same thing i did lol.
GTX2867r meicalnissyen MazdaSpeed 3/6 - Turbo Induction 59 04-18-2015 05:06 PM
alexryan's GTX2867r Build alexryan 2010 MS3 - Big Turbo Builds 95 11-07-2014 06:14 PM
EdgeAutosport.com's Focus ST Build w/ GTX2867R EdgeAutosport.com Ford Focus ST Ecoboost - General Discussion 42 08-08-2014 02:09 PM
GTX2867R Build mainelyperformance 2010 MS3 - Big Turbo Builds 5 06-17-2014 04:43 AM
Page generated in 0.43157 seconds with 24 queries
