| 2010 MS3 - Big Turbo Builds Genpu - Big Turbo Builds. All discussions about big turbos, hybrids and builds belong here. |
![]() Join Date: Jul 2017 Location: Houston
Rep Power: 0 ![]() ![]() ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Today I got the spare motor torn down, will need some crank polishing and undersized bearings but other than that it’s good for a rebuild. I’ve been reading up a lot on connecting rods, but Im just not sure which is the most proven and cost effective rod. My aim with this motor is 550-600WHP with a Precision 6062. This will be running 93 in the stock fuel tank along with a port injection manifold and separate fuel cell with E85 or 100% methanol (haven’t decided yet but my current meth setup has got me hooked). I’m between K1 H-Beam rods and Manley H-Beam rods, also don’t know if the 625 rod bolts are necessary at this power level. I’m trying to keep the build somewhat economical, otherwise I would just go with Carrillo rods lol I know for a fact I’m using L19 head and main studs, I’ve been told by multiple people to skip the ARP2000 studs. With such a large turbo I should be running considerably less boost but better safe than sorry. Another thing is pistons, I’m not sure how much power the stock pistons can handle, but if I should replace these then I was thinking of Manley Platinum pistons? Or is there something else a lot of people go with? Other than that I think I’m pretty set, I know the turbo is very large for this HP level but I want plenty of overhead, I can’t tell you how many times I’ve blown up these smaller turbos simply because they were working so hard. |
| Choosing coilovers | Steezyms3 | MazdaSpeed 3/6 - Suspension & Brakes | 53 | 04-19-2014 02:44 PM |
| Help with choosing first MODS!?!? | KILLER_VIZ | Gen2 MS3 General Discussion | 36 | 02-13-2012 03:34 AM |
| Need help choosing an OTS map... | flz33 | Cobb Access Port/Maps | 2 | 08-12-2009 07:11 PM |
| need help choosing | 06speed | MazdaSpeed 3/6 - Turbo Induction | 4 | 03-15-2009 09:59 AM |
| Help choosing a new ap map. | tburton101 | MazdaSpeed 3/6 - ECU Computer Tuning | 0 | 12-28-2008 02:40 PM |
