> 2010 MS3 - Big Turbo Builds
 Old 07-15-2018, 12:29 PM   #1
achulz's Avatar
Posts: 94   (View Stats)
achulz has a spectacular aura aboutachulz has a spectacular aura aboutachulz has a spectacular aura about
Default Oil Return Leaking CS Turbo
K so I installed my CS turbo, along with a 3” SS catless downpipe. Got it at 0% WGDC so I can drive it while I wait on my tune.
I was checking around for leaks, it appears the oil return line is leaking hella bad, throwing oil everywhere. I’m going to try to tighten it a bit more, but anyone have suggestions on a fix? Is it too hot for some sort of sealant?
And does anyone know the OEM Part# for the turbo side and block side gaskets?
Edit: What’s the lb-ft for these bolts? I tightened them more, they seemed to be kind of loose, maybe I forgot to tighten them.
achulz is offline   Reply With Quote
Oil leaking from turbo Djohns 2010 MS3 - Troubleshoot/Diagnostics 42 03-22-2019 07:39 AM
Stock Turbo Leaking Coolant pastry00 MazdaSpeed 3/6 - Turbo Induction 9 02-22-2017 07:40 AM
Oil return line is leaking Fonsi 2010 MS3 - Turbo Induction 81 12-30-2016 03:28 AM
Leaking, dripping turbo Lex2007 MazdaSpeed 3/6 - Turbo Induction 0 09-25-2016 02:05 PM
KO4 TURBO ON MS6 LEAKING OIL RETURN LINE GAMISTAD Mazdaspeed3/6 General Discussion 9 01-27-2011 01:06 AM
Page generated in 0.31225 seconds with 25 queries
