> 2010 MS3 - Big Turbo Builds
Like Tree266Likes
 Old 11-18-2013, 09:13 AM   #1
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
Default Papasmurf Round #2
Some of you may know, some of you may not know but I recently removed my engine yet again.
It started with noticing excessive blow by, so I checked compression, all cylinders were 150 besides cylinder #3 which was 130, keep in mind, 160 is normal at my altitude.
I was also getting an excess amount of blow by, im talking about filling up one of my catch cans in one pull, so I decided to remove the engine and inspect. I also decided to go bigger and better for next season at the same time. see bottom of post for the new set up.
At the moment the engine is on the engine stand with the head removed, I still need to tear down the bottom end to inspect my pistons. As of right now I have come to the conclusion my head was def lifting, not much but it was lifting. The valves looked fine.
Cylinders two and three have slight combustion gas residue under the gasket on the block and head side and there was trace of coolant on the head gasket. I will take detailed pictures when I have time and upload them.
I still need to figure out what was causing my blow by issue, I am not sure if head lifting causes blow by or not. My guess is going to be ringlands and or rings being damaged. Seeing how much I beat on my car with no type of oil cooling besides stock, I would be willing to guess something is fried or warped on my pistons. Again, detail pictures and findings will be posted when I tear down the block some more.
As far as my new build. I will keep as much as I can with the current build in the block, but my guess I will just be able.
I will most likely buying new pistons, still unsure which ones but it will most likely be SP pistons.
Now on to the head, I will be scraping my current head and I recently purchased a fully built/ported head from @doubleflusher; it was originally posted by @aviator79;, I have the spec sheet on my desktop at home that i will eventually attach, the head has since had SP port work. Here are some details.
•1mm oversized valves
•Ferrea Custom Valve train
•CompPlus intake and exhaust valves
•Turbo spring valve
•Titanium retainers
•Spring seat locator
•Billet Valve locks
•Custom Manganese/Bronze valve guides
•Intake and exhaust valve stem seals for custom guides
•CnC porting done to the intake and exhaust side, as well as a fair about of bowl blending and a performance valve job.
The head is complete besides buckets and cams, I am pretty set on staying with stock cams and just have them keyed. Along with keying the crank.
http://i.imgur.com/I4ueAv4.jpg
http://i.imgur.com/ll6KVEA.jpg
http://i.imgur.com/VPrgDVW.jpg
http://i.imgur.com/T86eGIk.jpg
http://i.imgur.com/IyxBnZC.jpg
http://i.imgur.com/YJsFOd2.jpg
http://i.imgur.com/cSbYTyi.jpg
http://i.imgur.com/23OIgkQ.jpg
http://i.imgur.com/N1rUedN.jpg
I will also be going with a bigger turbo. I have decided on:
PTE CEA 6466 Vband Flange, .82 A/R
CPe Exhuast Manifold PTE Vband Flange
44mm EWG
SP H11 Head studs
Target is 40-45psi.
and before anyone asks what about fuel, I am running a full SP PI kit. So go fuck yourself
860whp/677wtq
2.7 V6 Ecoboost
The Following 58 Users Say Thank You to PapaSmurf For This Useful Post:
2 slo pu (07-27-2014), 2eatV8everyday (11-18-2013), ABolewski (11-19-2013), Agent_Orange (11-22-2013), atvfreek (11-18-2013), aviator79 (11-19-2013), bhamitgeek (01-14-2014), Bolted6 (11-22-2013), boostdmazda3 (11-18-2013), Boosted Beluga (12-10-2013), CarlitoSpeed3 (11-22-2013), cbspd3flip (11-22-2013), Cevaes_64 (11-18-2013), Code Monkey (12-08-2013), cshunter (11-19-2013), CWP_MS3 (11-18-2013), DingoDave (01-03-2014), Dmurray06 (11-18-2013), Downmented (02-27-2014), Easter Bunny (11-19-2013), EdgeAutosport.com (07-09-2014), galens47 (01-10-2014), GunGuru727 (11-26-2013), h0ckeyman (11-22-2013), Hammology (11-18-2013), idnthv1 (11-18-2013), impossible (05-21-2014), jracer (11-22-2013), jreiden1 (11-18-2013), Koke382 (11-18-2013), krazycoble (11-18-2013), lilred (11-18-2013), LumberJack (12-13-2013), Mauro_Penguin (11-22-2013), mazdafreak (12-22-2013), Micha (08-28-2014), mr.speedy3 (11-18-2013), ms3blackmica (11-19-2013), mxlplx71 (11-18-2013), MZRSPEED (03-04-2014), NJSPEED3 (11-19-2013), Pointless (11-18-2013), Pu Manchu (11-18-2013), RE-ACTIONENGSPEED3 (11-19-2013), Realgib3 (11-22-2013), Roddiy (11-22-2013), rymanmazda (11-22-2013), smoogs12 (11-19-2013), spd6demon (11-19-2013), SpeedLife (11-22-2013), Status Update (02-28-2014), Sterling (11-19-2013), taf0422 (11-22-2013), trancehead (11-18-2013), trini247 (11-22-2013), Vader (11-18-2013), Voltron (11-19-2013), WetzMS3 (11-18-2013)
 Old 11-18-2013, 09:15 AM   #2
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
First! Heh, suck it bitches...
Good luck son!
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
PapaSmurf (11-18-2013)
 Old 11-18-2013, 06:06 PM   #3
PapaSmurf's Avatar
Block with head gasket still on it, you can notice coolant on the gasket along with some combustion gas on cylinders 2 and 3.
Close up of water on head gasket, this was pretty much the whole head gasket.
Cylinders 3 and 4, notice combustion gas around the top side of cylinder 3( top side meaning top of picture)
Cylinders 1 and 2, again notice the combustion has around cylinder 2, top side of picture again,
This is the block sides of cylinder 2 and 3, combustion gas not as bad, but it's there.
Sent from your girlfriends tapabedroom
860whp/677wtq
2.7 V6 Ecoboost
The Following 9 Users Say Thank You to PapaSmurf For This Useful Post:
Boosted Beluga (12-10-2013), CWP_MS3 (11-18-2013), Easter Bunny (11-19-2013), ItsNox (06-21-2014), jmhinkle (06-05-2014), jracer (11-22-2013), jreiden1 (11-18-2013), Roddiy (11-22-2013), WetzMS3 (11-18-2013)
 Old 11-18-2013, 06:29 PM   #4
PapaSmurf's Avatar
Also forgot to mention, coolant was cloudy with carbon specs in it.
860whp/677wtq
2.7 V6 Ecoboost
Boosted Beluga (12-10-2013), Easter Bunny (11-19-2013), jmhinkle (06-05-2014)
 Old 11-18-2013, 06:45 PM   #5
Koke382's Avatar
Posts: 4,361   (View Stats)
Groans: 32
Zaaaaaamn son. One beast of a build coming
sent from my peepee
2007 Mazdaspeed 3 GT
18x8.75 XXR 527 225/40/18r
New fucken miata build:
1993 Red Na6
Some suspension modz yo
Coilovers// Other shit
 Old 11-18-2013, 09:50 PM   #6
atvfreek's Avatar
Posts: 7,787   (View Stats)
Curious to see what you find with tear down. Hopefully it's just worn rings and not melted ring lands.
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
PapaSmurf (11-19-2013)
 Old 11-18-2013, 10:58 PM   #7
Celestspeed3's Avatar
Posts: 1,136   (View Stats)
I would just run (and I did) the Supertech valvetrain, it will probably be a lot cheaper then going custom and it's already proven to work. Since you are staying with the stock cams I wouldn't bother upgrading the valve springs or any of that. The stock cams run out of steam and the redline shouldn't be raised to more then 7500rpm anyway which makes no sense on the stock cams.
Edit: never mind the head already has all that done, I need to learn to read slower.
Fueled by the haters.
Celestspeed3 is offline   Reply With Quote
The Following 2 Users Say Thank You to Celestspeed3 For This Useful Post:
Boosted Beluga (12-10-2013), Realgib3 (11-22-2013)
 Old 11-19-2013, 01:01 AM   #8
Matrix311's Avatar
Posts: 2,133   (View Stats)
awesome!
 Old 11-19-2013, 01:46 AM   #9
rtabagaboy's Avatar
Posts: 363   (View Stats)
Groaned at 7 Times in 3 Posts
Papasmurf when you built your engine the first time what type of engine break in did you do?
2008.5 BlackMica Mods:
AZ Status!
 Old 11-19-2013, 01:48 AM   #10
speed3sailor's Avatar
Posts: 835   (View Stats)
speed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the world
good luck man. im looking forward to new race videos! blu pu dominating EVERYONE!
07 SILVER Speed3 , BNR S3- Tial 38mm EWG w/ stock mani- COBB AP- Ebay catless Downpipe- HTP 3in intake- Devils Own WMI (D10)- CX Racing FMIC- Autotech internals- Grimmspeed 3P EBCS- Denso ITV22- HKS super SQV- Bosch 3 bar - Damon PMM- JBR RMM- shift weight- EGR delete- TIGs- JBR RSB- Eibach springs- TR Motorsports 17x9- Hankook RS-3 255/40/17
speed3sailor is offline   Reply With Quote
The Following User Says Thank You to speed3sailor For This Useful Post:
 Old 11-19-2013, 01:57 AM   #11
ABolewski's Avatar
Posts: 1,279   (View Stats)
Hell yea, sounds like a legit build. Going to put down some serious numbers.
(sold)
 Old 11-19-2013, 03:25 AM   #12
4G63's Avatar
Posts: 1,479   (View Stats)
Groans: 123
This is a serious question and not to poke fun, why are these blocks so unreliable even when built? Just seems like I see more REBUILDS after someone has gone full bore on a build. Unlike other cars that when built take multiple seasons and tons of track passes and then it's just replacing rings, maybe rod bolts/head studs kinda thing
Build looks good man that 6466 is beast
 Old 11-19-2013, 04:55 AM   #13
Voltron's Avatar
Posts: 4,556   (View Stats)
Groans: 77
Good luck with the new monster build Rob. Between you and Bryce, you guys are taking Pu's to the next next level!
Voltron is offline   Reply With Quote
The Following 4 Users Say Thank You to Voltron For This Useful Post:
atvfreek (11-19-2013), Darthspeed3 (01-10-2015), PapaSmurf (11-19-2013), SpeedLife (11-22-2013)
 Old 11-19-2013, 06:08 AM   #14
spd6demon's Avatar
Posts: 164   (View Stats)
spd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the world
Badass build, looking forward to seeing the numbers your pu makes. 45 psi will be insane
06 MS6 GT // PTE 6266 GEN2 // Kozmic 6th Port Inj. 1200cc // Weisco Pistons (0.020 over) // Manley H+ Rods // JDM Sport EM // Tial 38mm EWG // SP63 Keyed & Polished Crank & Sprockets // 4" WPI // P&P IM // Cobb AP // Custom DP
CP-E Safe Seals // CP-E Rear Diff Mount // Bosch 3.5 BAR // Sure ShortCut // TWM Shift Knob // AutoTech HPFP internals // H&R Springs // DRAG DR-34 +35mm // CS2 Front Lip // CX Racing Air to Water IC // Custom Matt Damond Dual OCC
HTP Small Batt Tray // SP63 EBCS // HKS BOV // Kozmic Oil Feed Line // JBR EGR block off // JBR BSD // JBR Counter-weight // NGK // DW 65c ITFP // JBR PMM // JBR SSB // SU RMM // Corksport TMM Insert // FREEK Tune in progress
305/364 (K04) // 367/387 (2871r)
454/417 (PTE6262 R.I.P)
spd6demon is offline   Reply With Quote
 Old 11-19-2013, 06:17 AM   #15
timjs's Avatar
Posts: 908   (View Stats)
timjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the world
Groaned at 16 Times in 7 Posts
Sorry if I missed it or should know.. but what kind of head fasteners did you use last round?
'06 Mazdaspeed 6
timjs is offline   Reply With Quote
 Old 11-19-2013, 06:47 AM   #16
PapaSmurf's Avatar
I have to do some more research on cams, but i might get a custom grind considering how awesome this head is. i think it might be a waste to use stock cams. I am honestly looking for 650-700 uncorrected at my altitude.
Used unconventional penzoil oil, always was changing rpms, never let the car sit at the same rpm even if it was at idle i would slowly rev up and down.
100 mile oil change
500 mile oil change
850 mile oil change
checked compression and it was 160's across all cylinders.
Boosted
well most built engines that have failed have all been because of the ARP 2000 headstuds, which are only rated to 400-450wtq, they arent even specfically made for our car. They are made for an N/A 3. now that we have a way better option with headstuds I think you will see less issues.
Now my blow by issue im still unsure of, but if it is a ringland/ring problem then I would totally put fault on myself for not running an oil cooler. We put these engines through some serious heat along with the oil and yet hardly anyone runs an aftermarket oil cooler. @djuosnteisn; noticed oil temps sky rocket before installing his oil cooler. I think not having an oil cooler had a direct influence on my blow by.
My blow by could have also been effected from the head lifting and combustion gas getting into the oil ports? Not sure if blow by is something that can happen with head lifting? Anyone chime in on that?
Standard ARP 2000's
860whp/677wtq
2.7 V6 Ecoboost
The Following 13 Users Say Thank You to PapaSmurf For This Useful Post:
4G63 (11-19-2013), atvfreek (11-19-2013), Boosted Beluga (12-10-2013), CWP_MS3 (11-19-2013), Easter Bunny (11-19-2013), JeffroMS3 (11-19-2013), Koke382 (11-19-2013), Lakespeed6 (11-19-2013), magicka (11-19-2013), SpeedLife (11-22-2013), Sterling (11-19-2013), taf0422 (11-22-2013), [R]usty (11-19-2013)
 Old 11-19-2013, 02:25 PM   #17
rtabagaboy's Avatar
100 mile oil change
500 mile oil change
850 mile oil change
Boosted
So In that order? Did you check compression and start boosting after the 850 miles or before that @ like 100miles. Varying the RPMs, yes, but did you load it up much in the first 100-500-850 miles or just after.
Good luck on the new build!
AZ Status!
 Old 11-19-2013, 04:09 PM   #18
PapaSmurf's Avatar
In that order, I did not boost at all until after the compression check and I had synthetic oil in it.
860whp/677wtq
2.7 V6 Ecoboost
 Old 11-19-2013, 04:40 PM   #19
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
Best of luck Rob.
Looking forward to seeing a monster!
www.tunedbynishan.com
 Old 11-22-2013, 11:42 AM   #20
PapaSmurf's Avatar
Ok I am really interested with sleeving my block since its already bored out .020 over.
My question is, has anyone on here done it? If so what was your experience with?
What are the options besides:
ERL
Darton
One of the local guys I know is a benson dealer so he can get me a decent price on getting the block sleeved by them, the only thing is I dont think they have ever sleeved an MZR.
Dan Benson Racing - Aftermarket Performance Sleeve Installation
860whp/677wtq
2.7 V6 Ecoboost
 Old 11-22-2013, 11:53 AM   #21
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
@btstarcher; is sleeved maybe he can chime in.
 Old 11-22-2013, 12:01 PM   #22
Matrix311's Avatar
LA SLEEVE?
 Old 11-22-2013, 12:13 PM   #23
Realgib3's Avatar
Posts: 2,443   (View Stats)
I'll chime in on the blow-by issues.
It is most likely directly related to your head lifting. Your compression numbers are most likely related to the same thing. That's exactly the symptoms (along with other symptoms) that I saw every time I've lifted a head.
On another note... I'm fucking pumped to see someone else run this turbo and can't wait to see what you and Dustin can do with this thing.
PapaSmurf (11-22-2013)
 Old 11-22-2013, 12:16 PM   #24
PapaSmurf's Avatar
So the local guy I talked to who owns CamTuning, mainly subaru based can get me a pretty good price on Sleeves and to Oring the block.
I think the total is around $1400 and that includes return shipping.
They are dry sleeves.
Keep in mind Cam runs the same sleeves on his sti swapped wagon and pushes 800whp.
I guess benson was the first to have hondas running 50+psi too.
Koke382 likes this.
860whp/677wtq
2.7 V6 Ecoboost
Agent_Orange (11-22-2013), atvfreek (11-22-2013), Boosted Beluga (12-10-2013), chaser27 (12-08-2013), helmetface (11-22-2013), Koke382 (11-22-2013), Micha (05-21-2014), Realgib3 (11-22-2013), Roddiy (11-22-2013)
 Old 11-22-2013, 12:43 PM   #25
SpeedLife's Avatar
Posts: 890   (View Stats)
SpeedLife is the leader of the worldSpeedLife is the leader of the worldSpeedLife is the leader of the worldSpeedLife is the leader of the worldSpeedLife is the leader of the worldSpeedLife is the leader of the worldSpeedLife is the leader of the worldSpeedLife is the leader of the worldSpeedLife is the leader of the worldSpeedLife is the leader of the worldSpeedLife is the leader of the world
Subbed ! Good Luck Rob this will be a record breaker !!! ( Even tho it already was ) lol
Mylifeiseasy likes this.
2013 Mazdaspeed3
Mods:Stock as shit, trading in for e92
Add me on instagram: @mario_speed3
SpeedLife is offline   Reply With Quote
 Old 11-22-2013, 12:58 PM   #26
atvfreek's Avatar
I was talking to another member a few months ago about sleeving, and I honestly think that will be the future of high HP builds. My machinist says it's no problem to do them and has done them in a couple duratec engines.
That is a very reasonable price quote that you got too.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
The Following 2 Users Say Thank You to atvfreek For This Useful Post:
PapaSmurf (11-22-2013), SpeedLife (11-22-2013)
 Old 11-22-2013, 01:53 PM   #27
btstarcher's Avatar
Posts: 4,852   (View Stats)
My block was sleeved last time, machinist had a hard time finding sleeves but eventually found some straight ones that fit. Not sure the dimensionsbut I'm .020" over, and the sleeves were very cheap, something like $50 each. I think the total rebuild cost was a hair under $1k.
SnailTune in progress
The Following 2 Users Say Thank You to btstarcher For This Useful Post:
Micha (08-28-2014), PapaSmurf (11-22-2013)
 Old 11-22-2013, 02:51 PM   #28
PapaSmurf's Avatar
Mega/Supa head came in today.
thanks @doubleflusher;
Here is a quick difference between stock and ported
YABBAMZR, Voltron and bhamitgeek like this.
860whp/677wtq
2.7 V6 Ecoboost
The Following 19 Users Say Thank You to PapaSmurf For This Useful Post:
Agent_Orange (11-22-2013), AshFromCan (06-21-2014), atvfreek (11-22-2013), Boosted Beluga (12-10-2013), btstarcher (11-22-2013), chaser27 (12-08-2013), DingoDave (01-03-2014), Easter Bunny (11-22-2013), gsrtype1 (10-27-2014), LatinKraze (12-20-2013), Little John (11-22-2013), Micha (05-21-2014), mxlplx71 (11-22-2013), Realgib3 (11-22-2013), snailD (08-17-2015), socks (12-17-2013), taf0422 (11-22-2013), YABBAMZR (11-22-2013), [R]usty (11-22-2013)
 Old 11-22-2013, 03:06 PM   #29
2012FailWheelDrive's Avatar
Posts: 327   (View Stats)
2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world
"under construction"
2012FailWheelDrive is offline   Reply With Quote
 Old 11-22-2013, 03:09 PM   #30
That bad boy will flow! What's been done to the exhaust side?
atvfreek (11-22-2013), YABBAMZR (11-22-2013)
 Old 11-22-2013, 03:17 PM   #31
PapaSmurf's Avatar
Im pretty sure this is the original SP "supa" head.
It has Intake/bowl/Exhaust side porting. The exhaust side doesn't look as noticeable as the intake side.
860whp/677wtq
2.7 V6 Ecoboost
 Old 11-22-2013, 03:20 PM   #32
msantana101's Avatar
Posts: 1,517   (View Stats)
Posted up to see a monster.
FreekTuned
 Old 11-22-2013, 03:36 PM   #33
Matrix311's Avatar
Wow
 Old 11-22-2013, 03:36 PM   #34
Roddiy's Avatar
Posts: 5,388   (View Stats)
Groans: 279
Damn this build is gonna be insane. Good luck, first of all.
and make sure you come down to sea level and put down 1000whp when you get this thing done
2010 LSM Speed3
#BakeryTuned
The Following 3 Users Say Thank You to Roddiy For This Useful Post:
Easter Bunny (11-22-2013), Mauro_Penguin (11-22-2013), SLOWHATCH (12-08-2013)
 Old 11-22-2013, 06:28 PM   #35
btstarcher's Avatar
Oh I want one!
 Old 11-22-2013, 06:47 PM   #36
Voltron's Avatar
Groans: 77
That head is insane. That is the original supa head. I really wanted it but monies issues said not this time lol.
Im pumped to see your numbers.
The Following 6 Users Say Thank You to Voltron For This Useful Post:
Agent_Orange (11-22-2013), atvfreek (11-22-2013), btstarcher (11-22-2013), Easter Bunny (11-22-2013), Roddiy (11-22-2013), YABBAMZR (11-22-2013)
 Old 11-22-2013, 08:39 PM   #37
I wish you were getting a ported head.
atvfreek (11-23-2013), Voltron (11-23-2013)
 Old 11-23-2013, 11:54 PM   #38
GARRETHEXTREME's Avatar
Posts: 516   (View Stats)
GARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the world
Man! This is sick build to come! Your built engine is already a beast, and now this?
Our next nator nm meet, I have to check up your car when it's finished!
2008.5 Mazdaspeed3 GT
MODS:
ETS TMIC - Forge BPV - JBR Tru 3in Intake - JBR Boost/Bypass Hoses - Koni Yellows - Corksport CBE/Corksport Racepipe - Front Corksport FSB (Thanks Previous Owner) - JBR RSB - JBR STS/Heavy Weight Knob - Corksport Aluminum Skid Plate - JBR 88a RMM - Corksport LED Light Kit - Goodridge Braided SS Brake Lines - COBB AP - Corksport HPFP
Running on Freektune OTS+ Map
Possibly the first deaf MS3 owner here? hmmm...
GARRETHEXTREME is offline   Reply With Quote
The Following User Says Thank You to GARRETHEXTREME For This Useful Post:
PapaSmurf (11-24-2013)
 Old 12-07-2013, 03:11 PM   #39
PapaSmurf's Avatar
well I finally stopped being lazy and broke the block down.
My findings.
Spun rod bearing - cylinder 3
Cracked ring - cylinder 3
Warped ringland - cylinder 3
Bad scratching on the top sides of all pistons (Above rings)
Scratching on all Cylinder walls
All oil squirters were getting slightly hitting my pistons, not much but the tips of the oil squirters had some metal shaved off.
see attached pictures.
Now as far as the scratching on the pistons, has anyone seen this before and what could be the cause or is the cause? Ive never seen it, but then again this is my first motor I have ever built.
Maybe because the pistons where hitting the squirters it caused the scratching?
860whp/677wtq
2.7 V6 Ecoboost
The Following 7 Users Say Thank You to PapaSmurf For This Useful Post:
Agent_Orange (12-07-2013), Boosted Beluga (12-10-2013), chaser27 (12-08-2013), jmhinkle (12-07-2013), Micha (12-13-2013), Realgib3 (12-08-2013), SPEED6 KILLAH (12-07-2013)
 Old 12-07-2013, 03:24 PM   #40
Tough to tell on my phone but it looks like it could be detonation
PapaSmurf (12-07-2013)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f540/papasmurf-round-2-a-159317/
What engine do I have? - Page 3 - Cobalt SS Network This thread Refback 09-17-2014 12:58 PM
What engine do I have? - Page 3 - Cobalt SS Network This thread Pingback 09-17-2014 12:53 PM
Papasmurf's New Numbers PapaSmurf 2010 MS3 - Dyno Sheets/Discussions 18 09-16-2013 11:10 AM
Page generated in 0.62099 seconds with 44 queries
