| 2010 MS3 - Big Turbo Builds Genpu - Big Turbo Builds. All discussions about big turbos, hybrids and builds belong here. |
![]() | | #41 | ![]() |
| Not Ranked : 0 score
![]() | | #42 | ![]() |
![]() Join Date: Dec 2016 Location: DFW, Tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7
__________________ Built motor w/ Manley rods & Mahle 4032 pistons,BNR S4v2, 3.5" JBR tru-wide, XS power V3 exhaust mani, ST intake mani, CNT catless dp, Magnaflow 3" exhaust, autotech hpfp, Coolingmist progressive (lots of methanol), Cobb FMIC, Cobb RMM, DM PMM, JBR shifter w/ Maisonvi knob, 255/35/18 Pilot Super Sports, Bilstein coilovers (f), Bilstein cartridges in (r) with BC linear spring conversion, GFB valve w/ a GA, Versatune so I can be a rebel, just a little north of 500whp. And Yeah, that`s Steve Vai playing my arm in my avatar. |
| The Following User Says Thank You to VoodooJef For This Useful Post: | voodoo2crue (09-02-2017) |
![]() | | #43 | ![]() |
![]() Join Date: Jan 2015 Location: Holden Louisiana
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 182
| Not Ranked : 0 score Back on topic, did you end up going with the 4032 mahles? And where did you get them. The only 4032s I'm seeing are the sp63 and supertechs from edge Sent from my SAMSUNG-SM-G890A using Tapatalk
__________________ 2012 MS3 VRM/w Tech Self Tuned BNR S4/SP63 4032 88mm pistons/Manley Rods/Power XS Manifold/JBR BSD with Baffle Plate/Cobb APv3/Cobb XLE BPV/CMGS Stg2 w/DO14/CPE TMIC/Autotech HPFP internals/JBR Tru-3 Intake/JBR Boost tubes/JBR EGR delete/Custom 1liter OCC/CPE xflex RMM/CPE Injector Seals/Eibach Pro Springs/Ebay Downpipe/Custom 3" TBE with Vibrant Resonator/Magnaflow Muffler/TB Coolant Bypass/Bosch 3 bar map/ACT 6 puck/GS EBCS 3port interrupt/SP63 VC breather Plugs-NGK LTR7IX-11(6510) Oil-RP 10/30 Tires-235 40 18 Federal 595 rsrr Brakes-EBC Yellow pads with ATE 200 fluid Check out my wheelwell page here. If your a member hit me up. https://www.wheelwell.com/profile/558b073762d1852928f23712/garage/ |
![]() | | #44 | ![]() |
| Not Ranked : 0 score According to Post #1 : indeed he did. But I can see it could be read differently the way it was written.
![]() | | #45 | ![]() |
Mahle makes them for sp63. Like they might as well have been drop shipped. They showed up in a mahle box with all of the mahle paperwork, mahle shipping label.
__________________ Built motor w/ Manley rods & Mahle 4032 pistons,BNR S4v2, 3.5" JBR tru-wide, XS power V3 exhaust mani, ST intake mani, CNT catless dp, Magnaflow 3" exhaust, autotech hpfp, Coolingmist progressive (lots of methanol), Cobb FMIC, Cobb RMM, DM PMM, JBR shifter w/ Maisonvi knob, 255/35/18 Pilot Super Sports, Bilstein coilovers (f), Bilstein cartridges in (r) with BC linear spring conversion, GFB valve w/ a GA, Versatune so I can be a rebel, just a little north of 500whp. And Yeah, that`s Steve Vai playing my arm in my avatar. | |
| The Following User Says Thank You to VoodooJef For This Useful Post: | voodoo2crue (09-04-2017) |
![]() | | #46 | ![]() |
__________________ 2012 MS3 VRM/w Tech Self Tuned BNR S4/SP63 4032 88mm pistons/Manley Rods/Power XS Manifold/JBR BSD with Baffle Plate/Cobb APv3/Cobb XLE BPV/CMGS Stg2 w/DO14/CPE TMIC/Autotech HPFP internals/JBR Tru-3 Intake/JBR Boost tubes/JBR EGR delete/Custom 1liter OCC/CPE xflex RMM/CPE Injector Seals/Eibach Pro Springs/Ebay Downpipe/Custom 3" TBE with Vibrant Resonator/Magnaflow Muffler/TB Coolant Bypass/Bosch 3 bar map/ACT 6 puck/GS EBCS 3port interrupt/SP63 VC breather Plugs-NGK LTR7IX-11(6510) Oil-RP 10/30 Tires-235 40 18 Federal 595 rsrr Brakes-EBC Yellow pads with ATE 200 fluid Check out my wheelwell page here. If your a member hit me up. https://www.wheelwell.com/profile/558b073762d1852928f23712/garage/ | |
![]() | | #47 | ![]() |
(Thread Starter) | Not Ranked : 0 score Like I have said all along, it`s not so much that either alloy is "better" than the other, they just have their own strengths and the 4032s are what I was looking for. If the engine is healthy they`ll both handle pretty well the same power numbers. 2816s have a higher resistance to detonation, which is good if you run shit gas or freakish amounts of boost and insufficient means of cooling the combustion charge. I run E85 and methanol on top of it so detonation really isn`t even in the equation so the drastically increased lifespan of 4032 was a high priority.
![]() | | #48 | ![]() |
![]() Join Date: Jun 2014 Location: Savannah , GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
| Not Ranked : 0 score I would get the rings Pistons wrist pins and bearings epc treated when you do the Pistons Sent from my SM-N930P using Tapatalk
__________________ UR TBE/JBR RMM/UNKNOWN HPFP INTERNALS/COBB V2 AP/CS SRI + TIH/CXRACING FMIC |
![]() | | #49 | ![]() |
(Thread Starter) | Not Ranked : 0 score picked up my car today. Jesus that was a treat. I'm restricted to mobile posting so I'll save the details. The short version: hooray!
![]() | | #50 | ![]() |
| Not Ranked : 0 score I meant WPC treated... Congrats btw Sent from my SM-N950U using Tapatalk
![]() | | #51 | ![]() |
![]() Join Date: Apr 2011 Location: HOFFMAN ESTATES IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 30
Groaned at 7 Times in 5 Posts
| Not Ranked : 0 score Oh yeah!! Can't wait to do mine. Enjoy! Sent from my SM-G955U using Tapatalk |
![]() | | #52 | ![]() |
(Thread Starter) | Not Ranked : 0 score Ok: aside from some mafcal shenanigans it`s running extremely well. Build seems to be solid and I`ve given it the business a time or two just to wake up the hamsters under the hood. Nothing very dramatic as far as performance but it`s still on spring pressure until the maf gets sorted. The clutch is ridiculous. Grabby as f*** but not unruly.
![]() | | #53 | ![]() |
| Not Ranked : 0 score Was the engine already broken in Sent from my SM-N950U using Tapatalk
![]() | | #54 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yep. A three hour dyno break in procedure that gets the motor ready for full tuning right away. Had I wanted them to tune it I could have gotten it back the same day fully dyno tuned but for several reasons I opted not to have them tune it. I did consider it, though. A local buddy had the same shop do his that way and it ripped from the day he picked it up.
![]() | | #55 | ![]() |
(Thread Starter) | Not Ranked : 0 score First oil change today. I was not ok with leaving the break in oil in there for long but the builder said give it 10 days or so. Not that I expected anything less, but the oil that came out was clean and clear (technically it's the second batch of oil as it was changed immediately after the break in) Took a sample to send to Blackstone just for baseline reference. Installed an oil pressure gauge while I was at it. After a short trip to the store she's getting about 25psi at idle and 60 under a bit of throttle, 80 if I'm leaning on it. So far it's looking solid. 750 miles or so and nary a peep out of it.
![]() | | #56 | ![]() |
| Not Ranked : 0 score Glad to hear it's running well. What oil are you going to run? Sent from my SAMSUNG-SM-G890A using Tapatalk
![]() | | #57 | ![]() |
(Thread Starter) | Not Ranked : 0 score I put Valvoline dino 10w30 in this time. After this I'll run Mobile 1 extended protection and probably stick with 10w30. It's supposed to be a 15k mile oil, but I change it at 8k and have been getting great UOA results. The next oil analysis will tell me more but unless there's still excessive wear particles that's the plan.
![]() | | #58 | ![]() |
![]() | | #59 | ![]() |
(Thread Starter) | Not Ranked : 0 score It really comes down to bearing clearances. Mine is dead on oem spec so I could conceivably even run 5w30 again. The 10w isn't going to affect much of anything other than maybe cold start oil pressure.
![]() | | #60 | ![]() |
High weight makes higher oil pressures, but doesnt that mean the fluid is having issues flowing to where it's needed? The tightest tolerances, and quite frankly the only real restriction IMO, is getting into the bearings.
__________________ '06 MS6 GT-167k Miles(Forged@157,116) Manley Pistons & Rods, King Bearings Stock Head/Cams, Stock Int/Exh Manifolds Versatuner, 3-bar MAP, ITV22, CP-e TMIC CS Turbo/DP/RP/HPFP/BPV/R-DiffMount White Widow F-DiffMount, Whiteline RSB Rear Russian Bushings, Poly FSB Bushings Magnaflow CBE, ACT 6-puck/Streetlite JBR Tru-3.5/3-port EBCS/EGR-D Damond RMM/PMM/OCC/PCV Plate Other rides: 2014 F-150 XLT SuperCrew Ecoboost 2002 Tacoma ExtCab 2.4L 5spd 2WD 2004 Olds Alero ECOtec 2.2 - Broken History: 2008 GSX-R 1000 - Stolen 1988 RX-7 TII - Sold (13.467 @ 105.44) 1985 Camaro - Sold (est. 265bhp 5.7 swap, Edelbrock intake & Hooker headers) | |
![]() | | #61 | ![]() |
![]() | | #62 | ![]() |
https://www.amazon.com/Royal-Purple-...sed+SAE+10W-30
![]() | | #63 | ![]() |
(Thread Starter) | Not Ranked : 0 score We used Motul high zinc break in specific oil on mine. Builder said I could go a month on it and I thought "yeah, I trust that like a fart after mexican buffet". RP does seem to be popular for sure. Given how well the Mob 1 extended has done for me I'm inclined to keep using it until a UOA comes back with a reason not to. Blackstone as well as Bob the Oil Guy have gone on record to say that at the end of the day oil is oil and none of them test any better than another. I'm sure we all have our own favorites but I wonder how different they really are....
| The Following User Says Thank You to VoodooJef For This Useful Post: | voodoo2crue (09-18-2017) |
![]() | | #64 | ![]() |
(Thread Starter) | Not Ranked : 0 score So, the latest... I said I was going to have some help from one of our established tuners. Didn't happen. Rather than sit on my ass, I set out to familiarize myself with the software and started tuning it my damn self. A couple of steps in the learning curve and a cautious approached has me sitting right under 400whp, mafcal is perfect and scaled for methanol, and only at 19psi or so. I'll start upping the load targets and bringing up boost until either (a) I hit my goal or (b) I run out of fuel. I should hit 460whp around 28psi. Load tuning was aggravating and foreign at first, seeming ridiculous and tedious to get anywhere but now that I am familiar with the process I see the value in it. Not to mention the pride in doing it myself. It's pretty quick already, easily handling a feisty M4 earlier (they're not very fast but I'm also hardly turned up the wick, too). I've got about a thousand miles on the motor now and she seems to be holding together like a champ.
![]() | | #65 | ![]() |
(Thread Starter) | Not Ranked : 0 score Vdyno has since given me 440, 444, 471, and 457. Vdyno is by no means gospel but the logs imply 440 is in the ballpark. I've got some minor tweaking to do then I'll get her on the rollers. I'm admittedly proud of myself for the way it's running. Very smooth and mild mannered while part throttle, turns into a fire breathing beast of fury at wot and still what could be considered a moderate tune, even mild considering the forged motor and head work (not ported, just new valve seats, guides, springs, etc).
| The Following 2 Users Say Thank You to VoodooJef For This Useful Post: | andale927 (09-29-2017), Thor Hammer (09-25-2017) |
| BNR S4v2 | NJsean0 | 2010 MS3 - Big Turbo Builds | 23 | 08-16-2017 09:25 PM |
| Voodoo's BNR S4 Tune in progress | voodoo2crue | 2010 MS3 - ECU Computer Tuning | 36 | 06-18-2016 06:37 AM |
| LA 2010: 2011 Scion xB Release Series 8.0 dabbles in Voodoo | Haltech | Automotive News | 0 | 11-18-2010 01:00 PM |
| Photoshop voodoo gives close-up view of Chevy Volt | Haltech | Automotive News | 1 | 08-29-2008 11:09 AM |
