  • 1 Post By sms1701
 Old 02-05-2018, 12:19 AM   #1
Mazduhspeed6's Avatar
Posts: 157   (View Stats)
Mazduhspeed6 is a name known to allMazduhspeed6 is a name known to allMazduhspeed6 is a name known to allMazduhspeed6 is a name known to allMazduhspeed6 is a name known to allMazduhspeed6 is a name known to all
Default 2.3 Ecoboost crate motor
Ok, I know there are a few talks about interchangeable parts and stuff like that. But because I just recently blew my trans in my speed 6 and have low comp in my motor I was looking at options. One of the things that happened to pop up when I googled 2.3 mazda turbo motor for shits and giggles was a link to Fords racing 2.3 Ecoboost mustang crate motor and you can buy the full control kit to make it plug and play in a swap. My question isnt about taking parts from the motor.
My question is as a whole with the plug and play control kit would the motor sit in the factory location of the speed6 motor and more importantly would a speed6 transmission mount up to the 2.3 Ecoboost motor. I know the price and all that, I'm just curious if it would work or not, trying to figure out my options, I also have a thread asking about the JDM speed6 motor and trans asking if it's a direct drop in, I believe it should be because obviously our cars were made in Japan so I would think it would. Thanks Raz the shit outta me, I'm just curious about the whole Ecoboost thing.
2007 Mazda Speed6 GT
Power: rebuilt stock motor*
JBR full power path stage II intake w/JBR TIP*
ATP catted downpipe w/ second cat delete*
Corksport HPFP internals*
Corksport BeCuse injector seals*
Corksport Turbo*
Corksport 3.5 Bar MAP sensor*
Corksport EBCS*
Treadstone Tr8 w/ RPM CX racing piping kit*
Suspension: Corksport Lowering Springs
Brakes: Still stock
Driveline: Sure Motorsports R6*
Sure Motorsports Juggernaut*
Sure Motorsports Dreadnaught*
Sure Motorsports shifter bushings*
Corksport weighted Black shift knob
Electronics: Cobb Accessport V3 w/ tune by Will at PD tuning*Purple Drank Tuning*
Mazduhspeed6 is offline   Reply With Quote
 Old 02-05-2018, 06:14 AM   #2
flapjack's Avatar
Posts: 121   (View Stats)
flapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to behold
Well starting off I'll just say this; If money is no object to you, you can make it happen.
It would be difficult though and take a lot of time and work. Just by looking at the Mustang block, I can tell that the motor mount locations are not the same as the speeds. You have to make custom motor/trans mounts. Also it doesn't look like the trans would mount straight to the block, so you'd need an adapter plate custom made to make it work and thats just assuming everything fits right with an adapter plate.
After you get all that to fit right, you'll then have to hook up and route the plug&play setup which I doubt would be compatible with the stock gauge cluster or instrument panel anyway.
After its all said and done, you'd have spent more money than just getting a 2.3 DISI shortblock built for 700HP, P&P'd head, and big turbo setup.
As far as interchangeable parts go, I think the only confirmed one is the the oil pump.
2007 Sunlight Silver Mazdaspeed3
Engine:
\\ JBR Solid RMM \\ AWR PMM \\ TRZ TMM \\ JBR PCV OCC \\ HTP 4" Intake \\ BNR S3 \\ CPE 3.25" TMIC \\ eBay 3" Catless DP \\ Autotech HPFP Internals \\ Ford Transit Van Spin-on Oil Filter Adapter \\ Full EGR Delete \\ Throttle Body Coolant Bypass \\ Corksport Injector Seals \\ Greddy Type FV BPV \\
Tuning:
\\Cobb AP V3\\ Freektune Custom Tune \\
Suspension/Brakes:
\\ BC Racing BR Type Coilovers \\ StopTech Street Pads F&R \\ Centric Drilled & Slotted Rotors \\ OZ Alleggerita Wheels 18x8 et48 \\
flapjack is offline   Reply With Quote
 Old 02-05-2018, 06:16 AM   #3
zenit's Avatar
Posts: 1,364   (View Stats)
Groans: 57
link?
-feejay
-wetzel
flapjack (02-05-2018)
 Old 02-05-2018, 06:26 AM   #4
Ok I figured it'd be an in-depth swap, but was a long shot. It'd would just be really nice to buy a fully assembled longblock from well if it was still possible mazda, but I can only find short block and head, no assembled long blocks anymore. I mean I know they have different intake manifolds and exhaust manifold...ok so throw that out the window,, I was already started on a forge build it was just something that crossed my mind when I saw the motor. Curious though as we can use the fost intake manifold because it bolts up and is better fooling, I kinda like the exhaust manifold on the fost as it looks like it would free up some room because of the way it's cast, does the IT mount to the Mzr block
Corksport Turbo*
Corksport EBCS*
Brakes: Still stock
 Old 02-05-2018, 06:45 AM   #5
flapjack's Avatar
So what is your overall goal here? You just want something that's different or you want an easy drop in longblock? If thats the case, edgeautosport has a reman with stock internals for $4140 MZR DISI Remanufactured Long Block Mazdaspeed 3 Mazdaspeed 6 2006-2013
Engine:
Tuning:
Suspension/Brakes:
 Old 02-05-2018, 07:13 AM   #6
Those motors are garbage, I had one, actually 2 they replaced the first one after 5k miles because compression dropped to 120 and lower across all 4 and then the second motor last about 13k then dropped compression to 120 across all 4. They weren't done right to begin with, I compression tested them every 500 miles and the first motor was 150x4 when it showed up then the second motor was 160x4 and each time I got a motor like that and I called and told them about it, they said because they machine the tolerances alil looser...hahahaha, horseshit, more like none existent. Their machining standards are horse shit, and their warranty people they send are fucking idiots, I had the gold no questions warranty but they fucked me on the second motor because the guy opened the hood up and looked at the GFB Dual port BPV and said that's going to be a problem, and I qoute, see that set screw on top, people like to turn that all the way in and get lots and lots of boost." End qoute so anyways point being, I will stay away from remans from now on, it'll either be a used motor with low miles that I know at least was assembled and built using mazda ford fomoco parts instead of a motor that was put together using Chinese this and that and oversized and undersized bearings. Other then that I'll do a built block with forged internals or a Mazda short block with a Mazda head and just assemble it myself. That's where I'm at, I guess really I just need to figure out my trans sitcheation
Corksport Turbo*
Corksport EBCS*
Brakes: Still stock
 Old 02-05-2018, 07:38 AM   #7
Just so it's said, I broke in those 2 motors following their stupid break in or the warranty would be null and void. Required conventional oil for the first 5k miles, and a change within the first 500. I religiously followed there procedure paper that came with the motor.
Corksport Turbo*
Corksport EBCS*
Brakes: Still stock
 Old 02-05-2018, 07:42 AM   #8
flapjack's Avatar
That really sucks man, sorry that happened to you. Yeah I've heard they are turning to shit lately with quality. A few guys around here have used them and had good luck so far but I'm not sure I'd trust a long block from them.
Engine:
Tuning:
Suspension/Brakes:
 Old 02-27-2018, 08:46 PM   #9
sms1701's Avatar
Posts: 5   (View Stats)
sms1701 is a jewel in the roughsms1701 is a jewel in the roughsms1701 is a jewel in the rough
I will give a fair warning here-
Do not... do NOT.... DO NOT... use the Ford Ecoboost 2.3 engine in a Mazdaspeed 6... or really in any car. It is indeed the same 2.3L block coming from the same engine factory in Spain with some MAJOR differences/defects.
Since Ford likes to cheat to get HP and torque numbers, they jam all kinds of overboost into the engine. The cylinders/rods/pistons can take overboost for a short period of time. So can the cylinders/rods/pistons in my grandpa’s Buick Century, or a POS 80’s clapped out Civic. Then the Ecoboost ECU reduces the boost.
Why?
Because the problem with doing this repeatedly is you create so much additional heat as a result of the extra produced torque. So to compensate for this, the fine Ford “engineers” decided to make an “open-deck” cooling system. The cylinders aren’t surrounded by metal, they have a moat of coolant flowing around them. This creates a litany of problems in boosted engines, such as:
1. Head gasket failure. Which leads to catastrophic engine failure because the coolant, found in great abundance RIGHT OUTSIDE OF THE CYLINDER, flows into the cylinder after the engine cools. Next time you go to start the car you immediately bend rods. This is happening to so many of the 2.3 Ecoboost motors (ESPECIALLY in the Focus RS) that Ford already sent TSB guidance to dealerships.
2. Cracked engine blocks. Since there is so little metal between the cylinders and the outside of the engine, these motors are cracking like eggs because there is literally less than 1/8” of aluminum between this magical moat of coolant and the outside of the block. This is fine in say, a normal Honda Civic, because Honda doesn’t fake engineer more horsepower out of a block that can’t take it. Normal Civics have less than 170ish HP for a reason.
The Mazdaspeed MZR DISI motor has a closed-deck cooling system in the block, where the coolant channels are machined through the block, and there is plenty of metal around the cylinders.
3. If some other component fails, like the High-Pressure Fuel Pump (which is killing a TON of Mustang Ecoboost motors), this will cause detonation. Since most cars can handle occasional pinging/detonation, this usually doesn’t matter. But when you are cheat-ass Ford overboosting an engine with so much air... and you don’t have the fuel to mix with it because of a pump failure.... EcoBOOM lol. You create nice holes in your block for the rats to sleep.
Want proof? https://youtu.be/CuGodKdRLpE
So what’s the moral of the story here? Just buy a long-block from Mazda. The part number is:
L3M6-02-300M
This is a stem-to-stern BRAND new, final-generation MZR 2.3 DISI motor used in the 2013 Speed 3. It includes the cylinder head, spark plugs, valve cover, oil pan, PVC assembly all pre-assembled. It is already timed and ready to drop in. Most places/dealerships will sell it for a little less than 4 grand, and it comes with a 12-month, 12,000 mile warranty.
I know this because I put this motor in my Speed 6 last year, and it runs beautifully.
So a word of wisdom again- DO NOT USE THE FORD ECOBOOST 2.3 garbage motor in a Mazda.
thrisnospork likes this.
sms1701 is offline   Reply With Quote
The Following 4 Users Say Thank You to sms1701 For This Useful Post:
impossible (10-16-2018), SoyBean (05-18-2019), Spectrix (02-28-2018), thrisnospork (02-28-2018)
 Old 02-27-2018, 09:01 PM   #10
pwdunmore's Avatar
Posts: 368   (View Stats)
Why?
L3M6-02-300M
lol good first post... but why would the OP do the simple thing?!?!
My car thread:
 Old 02-27-2018, 09:10 PM   #11
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
he waited 2 years to drop that on us, that's a wild first post.
94 M
MS6
IS350
 Old 02-27-2018, 09:14 PM   #12
sms1701's Avatar
Haha I know, and I decided to finally speak up because I’ve seen so many people get dicked by Ford with this motor.
 Old 02-28-2018, 09:34 AM   #13
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
Glad you are out of the closet.
 Old 02-28-2018, 09:39 AM   #14
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
We should all be so thankful to this random nobody for giving us this information.
I can only imagine how many people, who needed a new MZR motor, went out and purchased this instead. Finally, the nightmare is over.
The Following 4 Users Say Thank You to g00s3y For This Useful Post:
kTaLgsTo (02-28-2018), Pu Manchu (02-28-2018), Tomas (03-02-2018), Vansquish (02-28-2018)
 Old 02-28-2018, 10:53 AM   #15
JakeMS3's Avatar
Posts: 1,164   (View Stats)
Groaned at 7 Times in 5 Posts
Lol, Goosey, you never cease to amaze. I too am glad this mysterious lurker bestowed this wealth of knowledge amongst the community as I was lining up an EcoBoost engine after reading OP’s thread. (Sarcasm)
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
 Old 02-28-2018, 08:58 PM   #16
sms1701's Avatar
Haha I love this. Yeah, I've taken quite a lot from these forums... especially when I had to get the new motor in the Speed 6 last year.
Lately I've seen/read so much about how the Focus RS and Mustang Ecoboost owners are whining, crying, and disappointed because Ford destroyed this engine. Some of the shit on youtube is both laughable and sad at the same time.
After digging and really finding out how BAD Ford messed it up, I thought it's time to steer anybody in a Mazda away from making a massive mistake.
Now I'll go back into my cave until I receive another grand revelation.
The Following User Says Thank You to sms1701 For This Useful Post:
Tomas (03-02-2018)
 Old 03-24-2018, 10:27 AM   #17
Inzane81's Avatar
Posts: 8   (View Stats)
Inzane81 is an unknown quantity at this point
Why?
L3M6-02-300M
Would this engine work in a 2008 Gen 1?
Inzane81 is offline   Reply With Quote
 Old 03-24-2018, 06:48 PM   #18
JakeMS3's Avatar
If this is sarcasm in relation to OP’s post, you’re about a month too late. That, or this has to be troll...
2013 LSM w/tech
Cobb AP V3, CBE
DM OCC/TMM
Forge V2 BPV
Wilwood 6 pot BBK
crate motor? frivolous_rob MazdaSpeed 3 - Engine, Transmission & Driveline 42 09-20-2017 03:56 PM
Production starts on Mopar 426 'Elephant' Hemi V8 crate motor Haltech Automotive News 1 12-14-2010 06:25 PM
GM E-Rod crate motor no longer just for the shiftless Haltech Automotive News 0 04-27-2010 04:10 PM
SEMA Preview: Ford stuffs 400-hp EcoBoost motor in '34 Hot Rod Haltech Automotive News 0 10-28-2009 04:10 PM
LS9 crate motor costs more than most cars Haltech Automotive News 1 02-19-2009 03:42 PM
Page generated in 0.41812 seconds with 29 queries
