| MazdaSpeed 3/6 - Build Diaries MazdaSpeed 3/6 - General Build Threads/Diaries |
(Thread Starter) | Not Ranked : 0 score So far, mostly stock as I've just recently started my build. I don't have a lot of cash flow right now, so mods are few and far between. The pace should pick up some when my divorce is final. Ha. Mods so far in the order of purchase: CS LED fog lights CS LED light kit JBR boost tubes and recirc hose (black) JBR EGR block off & valve - not installed yet CS RMM - ordered a month ago and should have it soon. - cancelled CS mount. Ordered DM RMM CS MZR bypass valve JBR PMM 70 duro - coming back off. Might try AWR 70 for less vibes Is Versatuner a mod? Sure, why not. Planned mods: in somewhat of an order Possibly AWR TMM if I try and like the PMM HPFP - Autotech probably Injector seals when I swap in a clean set of injectors Intake TIG and TB coolant bypass or TB TIG OCC kit of some kind Diff mount & RSB JBR Tru-3.0 Wide Path silicone intake. Maybe 3.5 - kinda depends on if my end goal changes L2A intercooler EBCS if needed Possibly CS turbo upgrade WMI if my end goal changes Better clutch if the OE takes a crap Still up in the air if I want to do exhaust or not. Possibly catted DP 4 piston calipers or larger (really just for looks) w/ braided lines Slotted rotors maybe SPC ball joints Maybe a set of coilovers w/ adjustable dampers if one day I decide to hit the track. I may have missed a few things but you get the gist.
__________________ '06 MS6 GT-167k Miles(Forged@157,116) Manley Pistons & Rods, King Bearings Stock Head/Cams, Stock Int/Exh Manifolds Versatuner, 3-bar MAP, ITV22, CP-e TMIC CS Turbo/DP/RP/HPFP/BPV/R-DiffMount White Widow F-DiffMount, Whiteline RSB Rear Russian Bushings, Poly FSB Bushings Magnaflow CBE, ACT 6-puck/Streetlite JBR Tru-3.5/3-port EBCS/EGR-D Damond RMM/PMM/OCC/PCV Plate Other rides: 2014 F-150 XLT SuperCrew Ecoboost 2002 Tacoma ExtCab 2.4L 5spd 2WD 2004 Olds Alero ECOtec 2.2 - Broken History: 2008 GSX-R 1000 - Stolen 1988 RX-7 TII - Sold (13.467 @ 105.44) 1985 Camaro - Sold (est. 265bhp 5.7 swap, Edelbrock intake & Hooker headers) Last edited by Fstrnyou; 10-10-2016 at 08:18 PM. |
(Thread Starter) | Not Ranked : 0 score Short log of what I consider to be high BAT's for a 77 degree day. Continuation of the other thread, I stand corrected about 140+ BATs. That log was when I didn't have the OE TMIC shroud. Locating a shroud and getting it on dropped the BATs by about 10 degrees by end of log.
__________________ '06 MS6 GT-167k Miles(Forged@157,116) Manley Pistons & Rods, King Bearings Stock Head/Cams, Stock Int/Exh Manifolds Versatuner, 3-bar MAP, ITV22, CP-e TMIC CS Turbo/DP/RP/HPFP/BPV/R-DiffMount White Widow F-DiffMount, Whiteline RSB Rear Russian Bushings, Poly FSB Bushings Magnaflow CBE, ACT 6-puck/Streetlite JBR Tru-3.5/3-port EBCS/EGR-D Damond RMM/PMM/OCC/PCV Plate Other rides: 2014 F-150 XLT SuperCrew Ecoboost 2002 Tacoma ExtCab 2.4L 5spd 2WD 2004 Olds Alero ECOtec 2.2 - Broken History: 2008 GSX-R 1000 - Stolen 1988 RX-7 TII - Sold (13.467 @ 105.44) 1985 Camaro - Sold (est. 265bhp 5.7 swap, Edelbrock intake & Hooker headers) Last edited by Fstrnyou; 10-03-2016 at 06:44 PM. |
| The Following User Says Thank You to Fstrnyou For This Useful Post: | Voltwings (10-04-2016) |
![]() Join Date: Nov 2010 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,489
Try including: Time Accel pedal position AFR / lambda boost boost air temp load coolant temp HPFP pressure (actual, not desired) injector duty cycle intake temp (ambient) VVT advance knock Short term and long term fuel trims MAF voltage G/s MAF airflow RPM Spark advance Vehicle speed Wastegate duty cycle. This will just help give a more complete idea of what is going on in the car. For example, when i pulled my copy of speed6 ATR and reference the BAT vs ECT table we can see that at 130+ BAT it will be trying to pull timing depending on what your ECTs are, but since coolant temp is not in that log we dont know if that was the case or not. There are a lot of smart people on this forum, so when posting logs you want to try to give them as much information as possible. Props for actually doing a log though haha, that's usually a tough first step to get some folks to do.
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. | |
| The Following User Says Thank You to Voltwings For This Useful Post: | WetzMS3 (10-04-2016) |
![]() ![]() Join Date: Jun 2010 Location: Morton Grove, il
Rep Power: 1485 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,886
Groans: 78
| Not Ranked : 0 score Your list is an almost perfectly upside down "go fast" shopping list. I've seen that shroud difference, too. Couldn't believe it, but data don't lie. Sent from my Nexus 5 using Tapatalk
__________________ "Well, Racecar=Broke. Other kinds of awesome may not, but racecar does. But racecar=best kind of awesome." -Wetz QFT |
(Thread Starter) | Not Ranked : 0 score I don't want to go fast first. I want to set the foundation to go fast. This is my DD, so I can't afford to turn the power up then break something that is known to be weak. So I'm replacing the weak links first.
Groans: 78
__________________ "Well, Racecar=Broke. Other kinds of awesome may not, but racecar does. But racecar=best kind of awesome." -Wetz QFT | |
| The Following 5 Users Say Thank You to xfeejayx For This Useful Post: | g00s3y (10-04-2016), KiwiFlavor (10-04-2016), MS3Shadow (10-04-2016), Thor Hammer (10-04-2016), WetzMS3 (10-04-2016) |
Groans: 438
| Not Ranked : 0 score So you're taking the engine out and replacing the rods?
__________________ All good things must come to an end... |
| The Following User Says Thank You to g00s3y For This Useful Post: | WetzMS3 (10-04-2016) |
(Thread Starter) | Not Ranked : 0 score Currently, I don't plan on going past 350whp as a DD. However, once I acquire a spare vehicle, I have plans to start building a spare motor in the garage I don't yet have.
![]() Join Date: Feb 2012 Location: Li ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,290
Groans: 74
You will either blow up your daily and cry while selling everything and buy a Genesis. Or you will build the motor with the parts you were going to spend on all that crap above. Stock mazdaspeeds average 100k to 150k miles. As soon as you modd them the sooner you need to build. Inbeforeihave200kmilesandididntblowresponses.
__________________ MECP 2012 BM PTE 5858 Vband .82ar // Tial EWG // CPE Mani // 3" Turboback // JBR Under route hot pipe // MD ST mani+spacer with PI // Siemens 60lb Injectors // Splitsecond inj controller // JBR 88 duro RMM/TMM // MD PMM // TWM Full replacement shifter // JBR CC // Autotech FP Internals // SP63 SB/Manley rods SP63 pro pistons // Treadstone FMIC TR824 // FoMoCo Tranny Jizz // South Bend Clutch Stage 3 enduro// GFB Respons // FJ 4" intake // WMI 100% VPM1 // Air Lift 1000 in rear // N2MB WOT BOX Rfinkle tune in progress The Brooklyn beater: 2005 1.8 Auto Sentra | ||
The insignicant items, that I listed once but everyone keeps harping about, are insignificant enough that I didn't feel a need to put them in my sig. Unlike you. For some reason you think AWR endlinks are important enough you want everyone to know anywhere you post. Who the fuck cares. I listed every non-stock item for full disclosure of what I've done. I didn't list it to spark meaningless arguments about how important you think it is...or isn't.
__________________ '06 MS6 GT-167k Miles(Forged@157,116) Manley Pistons & Rods, King Bearings Stock Head/Cams, Stock Int/Exh Manifolds Versatuner, 3-bar MAP, ITV22, CP-e TMIC CS Turbo/DP/RP/HPFP/BPV/R-DiffMount White Widow F-DiffMount, Whiteline RSB Rear Russian Bushings, Poly FSB Bushings Magnaflow CBE, ACT 6-puck/Streetlite JBR Tru-3.5/3-port EBCS/EGR-D Damond RMM/PMM/OCC/PCV Plate Other rides: 2014 F-150 XLT SuperCrew Ecoboost 2002 Tacoma ExtCab 2.4L 5spd 2WD 2004 Olds Alero ECOtec 2.2 - Broken History: 2008 GSX-R 1000 - Stolen 1988 RX-7 TII - Sold (13.467 @ 105.44) 1985 Camaro - Sold (est. 265bhp 5.7 swap, Edelbrock intake & Hooker headers) | |||
(Thread Starter) | Not Ranked : 0 score I have several logs that include almost all of that data but not all in the same log. With only 50 PID/s, I was wanting to limit it to 10 items for good resolution. The nearly 20 items you list would result in data points about 0.4s apart. If I recall correctly: MS6 has 50 pid/s Genjuan has 100 Genpu has 200 I always log rail pressure if I make a change that would increase fuel requirements. I haven't logged inj DC because I'm too close to stock to worry about it. I don't log APP anymore because it's always 100% I don't log fuel trims anymore because I'm all stock. I don't log vehicle speed because I'm always in 4th gear. I didn't think to log ECT, I'll try that out. I stopped logging WGDC because my boost is pretty steady. Tapering, but following the tables. Don't read that wrong. I'm not refusing to log what you ask for, I'm just saying I would prefer to only log what is required for a specific diagnosis so resolution is as high as possible.
(Thread Starter) | Not Ranked : 0 score Touche' I couldn't stand having yellowish fog lights with white HIDs. Unfortunately I didn't anticipate that the fogs would be blue. So they still don't match.
Groans: 78
| Not Ranked : 0 score I can't tell if you can't read, if you read too much, or you have selective comprehension. That seems to be going around. If you have any intention of going "fast" in an MS6 you NEED internals, rear diff mount (the wide one towards the rear), RMM, and a tune(r) first. That makes you ready for 350whp by whatever means you choose to get there. At that power level, stop screwing around with various side mounts (then commenting on reduced cash flow). Just put a spare stock PMM on the shelf, and enjoy the lack of vibes.
| Not Ranked : 0 score Word on the street is DM is making a FMM
| The Following User Says Thank You to Mazdazilla6 For This Useful Post: | MS3Shadow (10-05-2016) |
(Thread Starter) | Not Ranked : 0 score I use the term "fast" in a relative sense. Initially, I'll be getting a new PMM from rock auto to hold me over for a while. I already mentioned my intent to upgrade the diff mount. Although I failed to specify the "wide one towards the rear" because I thought it was obvious. I already ordered a RMM a month ago from CS but they were out of stock and were just starting their next production run. So I've patiently been waiting. By NEEDING internals, I'm assuming you're referencing HPFP. Yes. That has also already been laid out in my plans listed above. Also, I thought I made it plainly obvious that I won't be making power mods until I have internals installed by way of putting it at the top of list.
![]() Join Date: Nov 2011 Location: Houston Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 117
| Not Ranked : 0 score There seems to be a disconnect on most car forums as to what constitutes a "build" and "build thread". Installing HID fog lights and silicone plumbing isnt 'building' anything. Replacing engine internals, swapping to a larger turbo, etc. is a 'build'. What your doing is modding you car, which is great and a lot of fun, but calling it a build is inaccurate. /grumpy rant.
__________________ 2012 MazdaSpeed3 - HTP 3" intake, ETS TIMC, Autotech internals, Corksport racepipe, Accessport V3, custom Freektune, CP-E RMM, Koni sports, Progress Technology RSB, AWR endlinks 2003 A4 1.8TQ APR stg2+, MTM 420cc injectors, EuroCode FMIC, PSi testpipe, Techtonics Tuning downpipe, Forge TIP, Hyperboost DV, 240mm clutch, LWFW flywheel, B5S4 calipers, Goodridge SS lines, Stern snub, motor and transmission mounts, Powerflex rear diff bushing, 034MotorSports rear diff. carrier bushing inserts, JHM SS shifter, solid linkage, stabilizer bushing and weighted knob, Vogtland Jr. Cup Kit, B7 RS4 front and rear sway bars. |
This sub forum is called Build Diaries, a bit feminine but w/e. No diary starts off with "look what I made over the last 2 years." It starts at the beginning. Where I am. With piddly little shit like lights that annoyed me, a TMIC shroud that was missing, an OE shift knob that was tore up, a rearview mirror that was fucked up, etc etc. I'm not one to drive around in a hacked up POS. I've spent more money fixing broken shit than I have "mods". Right up until I bought Versatune, which turned that argument upside down. "Replacing engine internals, swapping to a larger turbo, etc. is" modding. Get over yourself.
Groans: 78
The parts I told you that you NEED were an effort to save you time, and money since you mentioned you're hurting for cash flow. Skip the side mounts, and the other shit that is "performance oriented", because you don't need it. All that other stuff is unnecessary until you decide what path you're taking for power, which you haven't, yet. I absolutely understand having nice things in the car. I have 2-3 times as much audio and 'nice' things in my daily MS6 as I do performance. That doesn't change that you're doing some things stupid. This section also gives no shits about your mirror or leds.
(Thread Starter) | Not Ranked : 0 score Apparently discussing the disconnect on what constitutes a build vs modding when they are synonyms in this context. Almost everyone has a limit to their cashflow. Mine being somewhat small by comparison to what I've assumed others have in various threads here. I'm not necessarily hurting for cash like a college student. I have money I could spend, but I'm hoarding most of it until I get that final bill from my lawyer when my divorce is over. I'm not set in my ways. I'm open to suggestions. The items you said I need, I agree with you! They are either already on order or at the top of my to-do list. I listed internals and diff mount before a simple intake for Christ's sake. I'm not trying to make 350whp tomorrow. As the sub-title says, Canadian molasses slow style. 1 step at a time as funds become available. And each step doesn't necessarily have to be HP related. I don't have a shop. My driveway is broken up asphalt, gravel, and a strangely placed small but smooth patch if concrete that I utilize as much as possible. I listed RSB along with the diff mount, because why not? I don't want to pull that shit out twice. I want to put in a set of clean injectors, so while I'm in there..new injector seals and a TIG. Do I NEED a RSB or TIG? Fuck no, but I'll be dammed if I don't go ahead and do those things while it's already apart. That is saving time. A good amount of my wishlist doesn't specify a vendor. I'm open to suggestions on what to avoid. I'm certainly open to suggestions on proven components. I apparently didn't read or ask enough regarding JBR mounts. I saw many many posts saying the vibes weren't that bad and it gets better after break-in, yadda yadda. So I buy it. Then I post that it's too harsh and everyone's like, "ya, JBR is the worst." WTF? Where we're you guys when I was researching what mount to get? Getting the right part first saves money. Skipping aftermarket engine mounts other than the RMM, saves money. Thank you. Getting internals before an oil catch can, for example, DOESN'T save money. Those upgrades are unrelated and I will be having both in the end anyways. Suggesting internals before a turbo upgrade, THAT will save money. Flame away.
| Not Ranked : 0 score They arent semantics though. Poke through the 'build diaries' section. Its all about engine internals, bit turbo setups, complete engine overhauls, etc. Not fog lights, boost tubes, and the like. Like I said, there is noting wrong with modding a car, but calling it a build to a bunch of 'real enthusiast' shows you're wet behind the ears.
| Not Ranked : 0 score In for future boost leak caused by failed JBR boost tubes.
| The Following 3 Users Say Thank You to WetzMS3 For This Useful Post: |
![]() Join Date: May 2013 Location: CO
Rep Power: 2406 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,487
| Not Ranked : 0 score |
| The Following User Says Thank You to monkey.bones.007 For This Useful Post: | WetzMS3 (10-05-2016) |
Groans: 438
| Not Ranked : 0 score 125k miles on a MS6, before you even do anything else, you should be checking compression.
| The Following User Says Thank You to g00s3y For This Useful Post: | WetzMS3 (10-05-2016) |
![]() | | #24 | ![]() |
| The Following User Says Thank You to WetzMS3 For This Useful Post: | monkey.bones.007 (10-05-2016) |
![]() | | #25 | ![]() |
![]() | | #26 | ![]() |
Groans: 78
That's as nice as I get. I'm outtie.
| The Following User Says Thank You to xfeejayx For This Useful Post: | Fstrnyou (10-05-2016) |
![]() | | #27 | ![]() |
My OE recirc tube had a crack in it, which is understandable considering it was probably the original 10 year old piece. If it weren't for that, I'd still have that OE tube and boost tubes. I still have the OE BPV. If the CS version gives me fits, I'll swap it back over. I already ordered the OE PMM from Rock Auto. Fingers crossed it fits. I read a little blurb in another thread that my injectors are probably all caked up with gunk with this many miles. So I figured there wouldn't be any harm installing a set of cleaned ones. Although now that I think about it, LTFT's weren't off by more than 5% I think. Eh, worst case, I'll have a set of clean injectors/seals on stand-by. Right now as a daily driver, the suspension is stiff enough for the roads around here. The calipers/rotors/coilovers are really only if I decide to track my car one day. I grew up in racing, so it's probably inevitable the 6 will see some turns. Really like that HID kit too. I will certainly consider that if/when the stock HIDs go out. I can see quite well at night right now. I AM into the car remaining "nice". No gauge pods. No color changing interior accent lighting. No loud exhaust.
![]() | | #28 | ![]() |
(Thread Starter) | Not Ranked : 0 score Latest log from this evening. Added several parameters per the above suggestions. Versatuner will only allow me to log 16 parameters at a time right now. Not sure if there is a setting to allow more. Also, I overlaid 2 prior runs over tonight's run in VD for shits and giggles. Same stretch of road. Looks pretty dead on consistent.
![]() | | #29 | ![]() |
(Thread Starter) | Not Ranked : 0 score Due to unforseen delays shipping the CS RMM, I cancelled the order and should be receiving a DM RMM shortly.
| The Following 2 Users Say Thank You to Fstrnyou For This Useful Post: | Mazdazilla6 (10-10-2016), WetzMS3 (10-10-2016) |
![]() | | #30 | ![]() |
(Thread Starter) | Not Ranked : 0 score Never thought I'd be so excited to receive an OEM part. PMM going in tomorrow. Upon visual inspection, the Rock Auto mount appears exact to OEM with exception of the bolt. I'll reuse the original bolt.
![]() | | #31 | ![]() |
(Thread Starter) | Not Ranked : 0 score Picture upload issues. All the more reason to strengthen my hatred for Apple products. Not being able to rename images on a device from a supposedly superior company is mind boggling.
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score JBR PMM out, OEM in. OEM RMM out, DM in. Noise is much better. Still plenty of vibes, but it's a different type of vibration due to the different location. Idle is smooth and quiet. Cruising is smooth and quiet. Accel and decel is what transfers the vibes now. The JBR PMM would vibrate worse and with more noise as the revs increased. All in all, it's better than before. http://youtube.com/watch?v=yqyLS6xyEog
__________________ '06 MS6 GT-167k Miles(Forged@157,116) Manley Pistons & Rods, King Bearings Stock Head/Cams, Stock Int/Exh Manifolds Versatuner, 3-bar MAP, ITV22, CP-e TMIC CS Turbo/DP/RP/HPFP/BPV/R-DiffMount White Widow F-DiffMount, Whiteline RSB Rear Russian Bushings, Poly FSB Bushings Magnaflow CBE, ACT 6-puck/Streetlite JBR Tru-3.5/3-port EBCS/EGR-D Damond RMM/PMM/OCC/PCV Plate Other rides: 2014 F-150 XLT SuperCrew Ecoboost 2002 Tacoma ExtCab 2.4L 5spd 2WD 2004 Olds Alero ECOtec 2.2 - Broken History: 2008 GSX-R 1000 - Stolen 1988 RX-7 TII - Sold (13.467 @ 105.44) 1985 Camaro - Sold (est. 265bhp 5.7 swap, Edelbrock intake & Hooker headers) Last edited by MS3Shadow; 10-13-2016 at 08:12 PM. |
![]() | | #33 | ![]() |
(Thread Starter) | Not Ranked : 0 score This past weekend, replaced the TMM with OEM, deleted the EGR valve, and blocked off the EGR tube. More importantly, had a present on my front porch this evening. And lastly, the gift within the package. Ah the little things. Thanks @CorkSport; for the laugh, and touche. Backstory, because I was ordering the internals, I put "Got gas?" in the comments section on the order page.
![]() | | #34 | ![]() |
(Thread Starter) | Not Ranked : 0 score Nearly a month after getting them...intrenals going in today.
![]() | | #35 | ![]() |
(Thread Starter) | Not Ranked : 0 score Done and done. Easy peasy. Had to buy a vise though, but no biggie. Car's been idling for about 30min now. Holding steady at 430psi. After about 5 minutes of idle, a blip of the go pedal bumped it to 1649. So it looks like all is good. The clickety clack of the CS internals are BARELY louder than stock. Almost negligible.
![]() | | #36 | ![]() |
(Thread Starter) | Not Ranked : 0 score About 30 miles in, I gave it some low RPM WOT and it barely broke into the 1800's. I'll put more miles on it tomorrow and then get a log to make sure everything is kosher. If there are any out there still wondering if it's true, minimal removal of parts was needed. 1: Pull CIRCUIT fuse. Run engine until it stalls out. (Still had pressure in the hard line, but w/e. Prob because there was a decent amount of time between running it and loosening the hard line, IDK) 2: TMIC shroud off. 3: Unclip PCV line from intake pipe and rotate up and back to rest on the firewall. 4: Unclip brake booster line I think and pull it over out of the way. 5: Start removing fuel lines, electrical connector and the 3 bolts. Skipped the hassle of trying to zip tie the hard line. Just shove a rag down there. 6: Remove pump. This proved to be the hardest part. Took quite a bit of tugging, wiggling, and prying to get it out. (insert standard instructions for swapping internals here) Going back in was easier, but still took some wiggling and playing with it. I was fortunate that the engine stopped where the pump wasn't on a lobe. It was nearly fully seated without pushing on it. Light pressure allowed me to seat it and thread the crews in all the way by hand. A little more turning with a clicker and done. Took all of 2 minutes to attach the hard line, 2 soft lines, electrics, brake booster, PCV, TMIC shroud, and reinstall the fuse. Wash up. Cycled the key a few times to prime the fuel. Then, with gas to the floor, cranked for about 10 seconds. Let sit for about 10 seconds. Repeat with gas to the floor. After 5 seconds, while still cranking, foot off the gas completely to let it start. Checked for leaks. All looks good. Had it idle for quite a long while (long enough for my BAT sensor to soak all the way to 195). Went for an easy 20 min drive which included about 10 miles of 3k rpm on I-77. After all, it was dinner time and since my buddy let me use his shop, he was due a free meal (I reserve pickle tickles for MSF VIP members only) and I needed the opportunity to put some miles on these internals.
![]() | | #37 | ![]() |
(Thread Starter) | Not Ranked : 0 score I've had a CS midpipe sitting around for a short while. Time to put it in. Grabbed a pair of "before" 3rd gear logs. 1 with current tune, 1 with WGDC @ zero (but the WGDC max increase is still set to 20%). Will post comparisons later today.
![]() | | #38 | ![]() |
(Thread Starter) | Not Ranked : 0 score Took slightly under an hour. More work to do as I didn't have the appropriate gasket for the back side. Snugged it up and drove to Advance. I traced the flange before installing, so I handed the guy my trace and he went to the back. Came back with a gasket that is remarkably similar to the CS flange diameter. Will only have to redo the holes and I'm set. Once installed....it was clear this gasket wasn't going to work. The stock flange wasn't designed to do any sealing, so it's not even close to being flat enough to seal with a thin gasket. I'll have to give Corksport a call on Monday to see if they can ship me the gasket they include with a new pipe. Until then, it's time for some data: Don't look at the actual numbers. I just found a repeatable location. Road was not flat. Compared the two 0% WGDC logs from before & after. The issues are: it was 32 degrees this morning with a 1/2 tank. The "after" log, it was 44 degrees with about a 1/3 tank. Same stretch of road...hit the gas as soon as I passed a street sign. Applied SAE correction for temperature. Sorry the starting RPM isn't exactly the same either. Even with all that, there was a measurable HP difference. Strangely though, the CS graph started at an earlier RPM but the boost appears to come on slower. Got my WGDC dialed in now, but there was a patrol car stationed where I was getting logs. So I'll wait until later when the temperature is back down into the low 30's...and hopefully the five-o is somewhere else.
__________________ '06 MS6 GT-167k Miles(Forged@157,116) Manley Pistons & Rods, King Bearings Stock Head/Cams, Stock Int/Exh Manifolds Versatuner, 3-bar MAP, ITV22, CP-e TMIC CS Turbo/DP/RP/HPFP/BPV/R-DiffMount White Widow F-DiffMount, Whiteline RSB Rear Russian Bushings, Poly FSB Bushings Magnaflow CBE, ACT 6-puck/Streetlite JBR Tru-3.5/3-port EBCS/EGR-D Damond RMM/PMM/OCC/PCV Plate Other rides: 2014 F-150 XLT SuperCrew Ecoboost 2002 Tacoma ExtCab 2.4L 5spd 2WD 2004 Olds Alero ECOtec 2.2 - Broken History: 2008 GSX-R 1000 - Stolen 1988 RX-7 TII - Sold (13.467 @ 105.44) 1985 Camaro - Sold (est. 265bhp 5.7 swap, Edelbrock intake & Hooker headers) Last edited by Fstrnyou; 02-04-2017 at 05:03 PM. |
![]() | | #39 | ![]() |
(Thread Starter) | Not Ranked : 0 score And the verdict is....blah
![]() | | #40 | ![]() |
(Thread Starter) | Not Ranked : 0 score Installed JBR Tru-3.5 Silicone intake today. Zero'd out WGDC before trying to MAF cal. First off, what a tight freaking fit. Hindsight says I should have gone with the metal intake. Several places with contact that will most certainly result in problems. I'm fortunate I had a 51r battery laying around. NO WAY the stock size battery would fit. I even had to trim quite a bit from the battery tray to clear the intake. Second, man does that tiny K04 make some noise now! BPV makes plenty of noise too. Not sure why anyone would want to go atmosphere BOV. Third, once the MAF cal was done (less than 1% LTFTs and WOT AFRs within .005 lambda...a little on the rich side), I figured it was time to allow the ECU to put some WGDC back in it. Quickly found that I'm reaching load targets (1.864 @ 3500) at 14psi when it used to take 18psi. With the intake, it was tapering off to 13psi by redline, so I did a few more runs trying to get it to hold 14psi all the way up. Not sure if I want to let this tune ride for a bit or maybe get back to stock boost levels. I have some maintenance things to take care of before I really start to push it. Not sure if I want to mess with installing the CS downpipe. It's been collecting dust, but this K04 spools so fast now, I'm having to pull throttle at low end to keep from overshooting load targets. Granted, my load targets from 2250 to 3000 are less than stock tune values.
| Display Modes | |
| Where are the Gen 1 1/4mi threads? | TurboGhost | Mazdaspeed3/6 General Discussion | 3 | 04-16-2013 11:40 PM |
| Stock Block BT build threads | xcoldricex | MazdaSpeed 3/6 - Big Turbo Builds | 50 | 07-13-2010 08:37 AM |
