 Old 08-02-2018, 06:02 PM   #1
Ds_06_Speed6's Avatar
Posts: 38   (View Stats)
Ds_06_Speed6 will become famous soon enoughDs_06_Speed6 will become famous soon enough
Default Ds 06 Speed6 build.
My 2006 Whitewater Pearl speed 6-
Bought it completely stock. She is no longer stock lol.
First was shifter bushings, short shifter and new knob-
Nex up was a Cobb AP V3-
More to post tomorrow, was too busy at work to get anymore photos uploaded today. Will update more tomorrow....
Ds_06_Speed6 is offline   Reply With Quote
 Old 08-03-2018, 11:46 AM   #2
Next step was getting the fuels system ready for all the future uprades so in went corksport fuel pump internals and stainless fuel line-
And since I was already all up in there, took out the EGR system and put in a CPE block off kit in-
And since I had the TB off to remove the EGR tube, decided to run a coolant bypass-
I was pretty sketch at first doing the fuel pump(never done one before) but it wasnt all that bad. Fuel line wast bad at all either, definately made getting the pump back in easier.
 Old 08-03-2018, 12:11 PM   #3
Police - Grammarhead
Vansquish's Avatar
FYI, you're going to fail emissions with the EGR block-off installed.
 Old 08-03-2018, 12:17 PM   #4
That isnt the only thing on the car that will cause emissions failure.
 Old 08-03-2018, 01:25 PM   #5
Found my oem BCS was broken while I was working so I ordered a Grimmspeed EBCS that I am currently running in 2 port mode-
 Old 08-03-2018, 01:46 PM   #6
After all the above was taken care of, the rest of the new goodies could go in. CPE topmount, JBR boost tubes, Corsport sri/tip, corksport 50/50 BPV-
And on the exhaust side of things, put in a corksport test pipe-
Now it was time for a tune. Went with a custom Freektune.
 Old 08-03-2018, 01:54 PM   #7
Well, it really didnt take long to figure out the stock mounts werent doing a great job, so in went the JBR trilogy mount set-
Now she was feeling solid.
 Old 08-03-2018, 02:12 PM   #8
Next I wanted to put in a boost gauge so I dot need to run the AP all the time, but I didnt want to run Ts and shit, so I ordered up a Damnd vacuum block and some thick silicon vaccum line-
 Old 08-03-2018, 02:13 PM   #9
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
Your pivot shaft seal on the transmission is leaking. There is a how to on here to complete the job.
Nice to see you did all the upgrades in good order. That JBR PMM must cause a lot of NVH along with the TMM. I went with stock PMM and Corksport inserts on the OEM TMM. Was just too much NVH for me personally. YMMV.
You'll hear clicking of the EBCS with it mounted on the firewall. Just so you don't wonder what it is when you start to hear it. Though with that mount set you probably wont! Lol.
Nice zip ties on that front bumper! What happened there?
Whats next? How many miles on it? Did you do a compression test?
 Old 08-03-2018, 02:31 PM   #10
Thanks, Ill check out the how to to fix it.
I onwed a speed3 a while back so I learned how to do shit proper lol.
The NVH is pretty gnarly, but Im used to it now. I do still hear the click from the EBCS though. haha
I bought it like that so not sure what happened, Ill get around to taking care of that eventually.
Its got 87K on the clock now, bought it with 84K. I did not compression check it, the next time I swap plugs i plan too.
As for whats next will be reveiled soon. Hehe.
 Old 08-03-2018, 03:05 PM   #11
Next up was installing the gauge. I didnt want highly visible gauge pods and shit, so I went with the center vent install on this one. I tried plastic first, but didnt like it, so I used 1/4" oak lol-
Pretty simple to do with hand tools, I can throw a quick write up together if anyone is interested.
 Old 08-03-2018, 03:16 PM   #12
And lastly, replaced my busted antennae with a stubby-
And thats how she sits now. I do have some upcomming plans and some parts coming in next week. Will update more once everything has arrived.
 Old 09-27-2018, 09:24 AM   #13
Replaced the pivot seal/bearing/breather assembly that @Thor Hammer pointed out I was leaking from-
Ill be draining and replacing the trans fluid with Redline MT90 after work.
06 Speed6
AP V3| CS TIP/SRI |CS 50/50 BPV |CS Test Pipe |CS FP internals|CS high pressure SS fuel line |CPE EGR delete |CPE TMIC |JBR Boost Tubes |JBR Trilogy race mounts |JBR short shift kit |Grimmspeed EBCS |GA V3|Custom FREEK tune
The Following User Says Thank You to Ds_06_Speed6 For This Useful Post:
Thor Hammer (09-28-2018)
 Old 09-28-2018, 10:58 AM   #14
Groans: 211
Getting shit done son! Nice.
 Old 09-28-2018, 11:04 AM   #15
5doorsoffury's Avatar
Posts: 1,123   (View Stats)
Groans: 74
Yea nice to see someone doing it right without bitching. Nice 6!
If i had to say 1 thing it is that sure is cancer. I cringed to see that name on the bushing.
MECP
2012 BM
Rfinkle tune in progress
 Old 09-28-2018, 01:26 PM   #16
Drained the trans and rear dif and refilled with Redline MT90(trans) and 75W90 gear oil(Dif). Glad I did the bearing with the seal, feels pretty solid now.
Found 2 more leaks, possibly a third.
Oil cooler seal is leaking and one of the coolant hoses to the oil cooler is leaking.
I have a spin on conversion to go in so I guess Ill just have to get a new oil cooler setup to go in with it.
Third possible leak is between transaxle and shaft. Ran short on time so had to throw car back together, but next time I go under Ill check this one out more closely. Hoping its just blow back from the leaking oil cooler, but with my luck it wont be. lol.
06 Speed6
 Old 09-28-2018, 02:22 PM   #17
Posts: 2,237   (View Stats)
There are doing replacement oil cooler for cheap now.
As other said, nice progress in the perfect order.
The powerstering return hose have some weakness there too so wash everything with brake cleaner and check it again to see where it really leaks. I though i had a bad diff seal, i ordered it and when come time to replace it, i found it was just the crush washer on the oil plug...Not that i was mad to save a lot of time but i should have checked before ordering it...anyway it will leak soon or later and i will have the part...
 Old 10-01-2018, 09:54 AM   #18
Got a line on a gen 2 oil cooler and coolant lines for 60 so Ill be grabbing that, then Ill put in my screw on filter setup with the new oil cooler and coolant lines.
My Gaurdian Angel should arrive today. Once I get that in Ill be returning to Justin to retune in 3 port mode.
06 Speed6
 Old 10-22-2018, 10:05 AM   #19
Installed Gaurdian Angel this weekend. Having some issues hitting peak boost now, at least according to my boost gauge. Im tuned to peak at 19.5 and my boost gauge would match this prior to installing the GA, now my boost gauge shows my peak at 18. Idle vacuum is normal before and after install. I wanted to run a log and see what was really going on, but my OBD2 port is being a bitch and the AP would not keep connected. I think I need to tighten up the pins in the port.
06 Speed6
 Old 10-22-2018, 03:09 PM   #20
The GA purpose is to let BOV to open if overboost happen, it may just be set lower than expected.
 Old 10-22-2018, 03:44 PM   #21
I hit 19 on the gauge today at lunch, so for now I think Ill call it fine until I can take care of the OBD2 port and run a log.
06 Speed6
 Old 10-23-2018, 12:35 AM   #22
Turbosuby's Avatar
Posts: 218   (View Stats)
Turbosuby has a reputation beyond reputeTurbosuby has a reputation beyond reputeTurbosuby has a reputation beyond reputeTurbosuby has a reputation beyond reputeTurbosuby has a reputation beyond reputeTurbosuby has a reputation beyond reputeTurbosuby has a reputation beyond reputeTurbosuby has a reputation beyond reputeTurbosuby has a reputation beyond reputeTurbosuby has a reputation beyond reputeTurbosuby has a reputation beyond repute
Groaned at 7 Times in 3 Posts
Nice mods, nice joint lol
Turbosuby is offline   Reply With Quote
 Old 10-23-2018, 10:12 AM   #23
if you run a k04, it could be just the air temperatyure that made a difference.
 Old 10-23-2018, 12:53 PM   #24
Just noticed a bunch of black dust on the passenger side of the engine bay, like rubber dust. Wasnt there when I put in the new motor mount. Almost as if the serp belt is being eaten up, but the belt itself looks ok, no apparent damage.
06 Speed6
My slow Speed6 "Build" BrandonM MazdaSpeed 3/6 - Build Diaries 9 04-15-2017 08:26 AM
brandonf (FLO)'s BT speed6 build brandonf MazdaSpeed 3/6 - Big Turbo Builds 86 05-17-2016 12:11 AM
Speed6 big turbo build etc. speed6speed MazdaSpeed 3/6 - Big Turbo Builds 11 04-18-2016 06:17 PM
Psycho's Speed6 Build (PT6266) psychophyr Mazda MZR DISI Engine Builds (2006-2013) 710 09-18-2014 09:27 AM
07 Speed6 Build ABQ Speed6 MazdaSpeed 3/6 - Build Diaries 57 05-27-2014 01:22 AM
Page generated in 0.47766 seconds with 25 queries
