| MazdaSpeed 3/6 - Build Diaries MazdaSpeed 3/6 - General Build Threads/Diaries |
![]() Join Date: Jun 2013 Location: Jackson Tn
Rep Power: 0 ![]() Thanks: 1
Groans: 211
| Not Ranked : 0 score Why wouldn't it be worth rebuilding if it runs fine? Doesn't make sense. An engine is not worth rebuilding when you vent the block or some other catastrophic failure.
![]() Join Date: Sep 2017 Location: Western Mass
Rep Power: 43 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
| Not Ranked : 0 score What @Thor Hammer; said
__________________ 06 Speed6 White/Black interior Sure Diff Mounts, JBR Intake, JBR I/C Hoses, Wiesco pistons .5mm over, Molnar H-Beam Rods, King bearings, New to me Cylinder Block, CS turbo, CS catted turbo back exhaust, CS HPFP, CS EBCS, CS injector seals, AP v3, FREEKTUNE, rebuilt clutch from Falcon Clutch with kevlar lining, DM PCV plate, DM stage 1 OCC, EcoBoost oil pump, vented oil cap with baffle, Speed Solutions PTO bearing caps, All Damond mounts To think... this is suppose to be my winter car... because, '72 AMC Javelin AMX 366 CI, 4speed 13.13 quickest 1/4 mile et so far '12 1/2 Triumph Daytona 675R stock some how '79 AMC Spirit AMX, 4.6L stroker I6 |
| Not Ranked : 0 score If it's not your daily, rebuild the motor you have. If it is your daily, find a motor to build and then swap them out over a weekend. This is what I did. I still have my "old/good" motor...just in case.
| What You Need to Know to Build a Motor | TWOptSL0W | Mazda MZR DISI Engine Builds (2006-2013) | 73 | 07-26-2019 03:57 PM |
| Mazdafreak's High Compression Build! | mazdafreak | Mazda MZR DISI Engine Builds (2006-2013) | 159 | 06-04-2015 06:44 AM |
| BNR S3 motor build | mikey32235 | MazdaSpeed 3/6 - Big Turbo Builds | 74 | 04-19-2014 09:09 AM |
| What You Need to Know to Build a Motor | TWOptSL0W | MSF KB - Mazdaspeed 3/6 - Engine/Turbo Builds | 14 | 09-26-2012 03:33 PM |
| high capacity tranny build!! | 0sixmazda6 | MazdaSpeed 6 - Engine, Transmission & Driveline | 29 | 04-24-2012 06:13 PM |
