Like Tree22Likes
 Old 06-27-2012, 07:18 PM   #81
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
that's an interesting opinion...
Tomas (07-28-2012)
 Old 06-27-2012, 08:34 PM   #82
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Originally Posted by crazyp View Post
is the machining going to be local or out of town?
Yeah local.
I dont think I am going to raise the fp past 2000psi, I dont use atr.
2006 Mazdaspeed 6
SpeedSixxx (07-01-2012)
 Old 06-27-2012, 08:51 PM   #83
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
Take this statement into consideration when modifying the "hard line" This is quoted from everyones favorite...John at PTP!!! Whoosh also worked on something like this, and you can search here for "whoosh mod" or something to that effect.
"We modifiy the shuttle valve at the high pressure side of the fuel pump. The OEM passage is 1.2mm We open this up to 2.3 mm to allow for a great flow volume through the shuttle valve. We then modify a new high pressure supply line from 1.3mm to 2.5mm. Some ask, "why do you open them up this much", we did several tests verifying what would work best for the application. We found that 3mm was to much and caused very agressive pressure changes (up to 400 psi). We found that modifying the line but not the shuttle valve had zero effect on fuel delivery. So, this is a two part design that gives an additional 18% flow."
"Pressure bleed by holes… these are very important for lower seal longevity (VW and Audi market really have a problem with this). What we have found in testing is that a single hole is not enough to support the proper feed back into the fuel return side. You are running a higher volume/pressure of fuel and more fuel will need to be sent back. The OEM single hole is not enough, so with our fuel pumps we have two holes feeding the low pressure fuel back into the pump return (internal passages). This is a patent pending design with our fuel pumps, so nobody will be able to reproduce it."
I think the above paragraph is the reason why the 2150 rail valves will NOT work with the majority of our setups.
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
 Old 06-27-2012, 09:08 PM   #84
crazyp's Avatar
Posts: 1,093   (View Stats)
Groans: 68
Yeah local.
cool can't wait to see how it goes
The Following User Says Thank You to crazyp For This Useful Post:
06Speed6 (06-27-2012)
 Old 06-27-2012, 09:35 PM   #85
Speeeeeed
06Speed6's Avatar
The 2150psi valves work fine at stock or near stock pressures, I think 1950ish spiking to 2000 will be fine and if its not ill lower it until it is.
2006 Mazdaspeed 6
 Old 06-27-2012, 09:40 PM   #86
mrmonk7663's Avatar
What internals do you have? Myself and a multitude of others did not get the 2150 valve to work, and John from PTP could not get the valve to work on my autotechs. I was commanding 1500 psi...lower than stock values, and pegging the sensor like it was no mans business.
The Following 2 Users Say Thank You to mrmonk7663 For This Useful Post:
djuosnteisn (07-02-2012), phate (06-27-2012)
 Old 06-27-2012, 10:45 PM   #87
Trail of Fail
Dano's Avatar
FWIW I have sporadic difficulty keeping off the sensor limit of 2073 with my PTP 2150 RV. it typically occurs in the upper RPMs but can happen post shift when getting back on the gas.
I command 1897 up until 6K where I drop to 1808 and I actually run 1950 to 20ish with the above mentioned spikes to 2073 from time to time... I need a lil more tweaking and I'll hopefully get it under control. I think I have the upper RPM spike gone and now just need to get rid of the post shift spikes which will likely require lowering the entire range down to 1808.
its so sporadic it may take awhile. I would like to run right at 2k but that's easier said than done with ATR at least...hopefully Versatuner will be easier for ya.
 Old 06-27-2012, 10:57 PM   #88
Speeeeeed
06Speed6's Avatar
I have a set of autotechs but I might sell them for a cpe. John sent me a stage 3 pump to test but it was just a used stock pump and I sent him a new core for it and paid shipping so I am kinda against owning a ptp pump. He swears its a stage 3 but I tore through it with a micrometer and compaired it to my spare oem and its stock as fuck.
Internals shouldnt make a difference in how the relief valve functions.
2006 Mazdaspeed 6
 Old 06-27-2012, 11:10 PM   #89
mrmonk7663's Avatar
Its not a function of the relief valve that is the issue, it is the ability to bleed off the excess fuel pressure. It seems that not only pressure increases, but volume increases as well, and the relief valve can't bleed it off quick enough. I eventually sent my 2150 back to John, and other locals who had purchased one (with bigger turbos and much more power than I) also had the same issues...they went back to stock valve. I got John to send me a 1950 valve. The 1950 valve initially spiked and cut like the 2150, but it did not stay pegged as long...so I tuned the fuel pressure tables and I have it gotten it to work pretty well.
My biggest complaint is that the 2150 was advertised to work fine...and it flat out did not. The valve itself functions correctly, but not on a stock sensor (which we have no work around yet) and in my opinion, not without drilling out the hard line like you want to do increasing the size of the pump check valve (spill valve?)
Stage 3 should be easy to identify...John uses a totally different set of internals, no where close to stock, on the stage 3.
left to right: S3 fuel pump internals, S1/2 fuel pump internals, stock fuel pump internals. 2nd pic is the larger diameter of the pump check valve or as John calls it in the quote from above, shuttle valve, whatever. I hope some of this info proves to be benefical to you...I'm not trying to crowd up your thread
The Following 7 Users Say Thank You to mrmonk7663 For This Useful Post:
06Speed6 (06-28-2012), atvfreek (07-01-2012), Boosted Beluga (06-28-2012), Dano (06-28-2012), djuosnteisn (07-02-2012), Easter Bunny (07-01-2012), TJ446 (02-20-2014)
 Old 06-30-2012, 11:45 PM   #90
holeinmypocket's Avatar
Posts: 1,129   (View Stats)
holeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the world
Pauter Rods & CP Pistons
holeinmypocket is offline   Reply With Quote
 Old 07-01-2012, 12:18 AM   #91
bobbybennett23's Avatar
Posts: 132   (View Stats)
bobbybennett23 has a reputation beyond reputebobbybennett23 has a reputation beyond reputebobbybennett23 has a reputation beyond reputebobbybennett23 has a reputation beyond reputebobbybennett23 has a reputation beyond reputebobbybennett23 has a reputation beyond reputebobbybennett23 has a reputation beyond reputebobbybennett23 has a reputation beyond reputebobbybennett23 has a reputation beyond reputebobbybennett23 has a reputation beyond reputebobbybennett23 has a reputation beyond repute
Since everyone started cracking open champagne bottles and throwing parties when I bent a couple rods, I figured that I should start a official build thread. I guess people have been praying that ide finally blow and start bolting parts on, well sweet baby Jesus has heard your prayers and answered them.
First lets start with the good stuff, I am going to be running the most built motor on the planet. It will be built once and it will be done right.
I have a prepped block that I am going to install timeserts for oversize main and head studs. All bearing surfaces will be coated along with the pistons and sleeves. I may also install a main girdle plate made of 1" steel that will also tie into the balance shaft bolt holes, I am not positive on that though. I am going to run eagle rods and gen2 ms3 oem pistons that are ceramic coated and dry film coated. King bearings will replace the oem bearings. A Cosworth high flow oil pump will round out the block.
The head is fully ported and flow benched, it flows 265cfm @1psi on the intake side and 200cfm @1psi on the exhaust side. It has 1mm oversize inconel exhaust valves and stock intake valves, new viton seals, new locks, oem retainers, and Cosworth springs.
I will also be running a DCR VVT and upgraded cams.
I have a set of flow benched, matched injectors along with the Toyota seals and a injector stud kit.
A gen2 valve cover and custom crankcase breather should keep the blowby in check, they will be vented to the exhaust.
The egr is completely deleted and welded closed.
I am going to chop up the oem IM and have it ported to match the head and I am going to weld a new plenum on and its going to look something like Erichs IM. It will use the Hemi tb which is a fair bit larger than stock.
I will be slightly reworking my l/a system to make it purdy, cuz it looks like ass now lol.
I will also be converting to a blow through setup and a full vta bov.
My trans has been fucked for about a year so its also going to get a rebuild with upgraded shift forks and new syncros and hopefully upgraded ratios.
The tcase will be getting upgraded bearing caps and new bearings. I think I am also going to coat it inside and out to seal it so it doesnt leak anymore.
The ps pump will be swapped for the newer model gen1 pump and the rack will have its bushings replaced. New hoses will also be used.
The clutch will also be replaced with a 6 puck, but I havent determined which one yet.
I think that is about all ill be doing, a new turbo will go on when I get the money for it. Dustin will be making a sidewinder manifold for it and it will be sitting above the trans. The turbo will be the Holset he351ve with a prototype Fleece controller.
I do have a few questions if anyone knows, what is the part number for the Arp flywheel and crank bolts and who was it that had a torque plate made?
How can you get differnt gear ratios ?
bobbybennett23 is offline   Reply With Quote
 Old 07-01-2012, 10:17 AM   #92
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
Its a mazda 6 diesel trans from europe. They have slightly longer gear ratios.
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
 Old 07-01-2012, 12:38 PM   #93
mrmonk7663's Avatar
Is the trans a direct bolt in?
The Following User Says NO Thank You to mrmonk7663 For This Un-useful Post:
Captain KR (07-01-2012)
 Old 07-01-2012, 01:11 PM   #94
Don06speed6's Avatar
Posts: 2,492   (View Stats)
Don06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the world
Groans: 62
You seriously need to search around more homie. It's not a direct bolt in. The gears are pulled from the donor trans and put into ours.
Captain KR likes this.
Cobb AP(FREEK TUNED)/CS TBE/SURE AEROS/CPE TIH/ ITV 22/SU RMM/KMD INTERNALS/SURE DREADNAUGHT/JUGGERNAUGHT/WHITELINE RSB/SURE ANCHORS/SURE COUNTERWEIGHT/SURE SHORTCUT/JBR HEAVY KNOB/JBR EGR DELETE/SPC BALL JOINTS/CENTRIC BLANKS/HPS PADS/BNOON BOLT/ALTERED CUSTOMS FMIC/TURBO XS RFL
Don06speed6 is offline   Reply With Quote
The Following 3 Users Say Thank You to Don06speed6 For This Useful Post:
Captain KR (07-01-2012), chuckms6 (07-01-2012), phate (07-01-2012)
 Old 07-01-2012, 02:47 PM   #95
Speeeeeed
06Speed6's Avatar
The input shaft also has to be machined
2006 Mazdaspeed 6
The Following 3 Users Say Thank You to 06Speed6 For This Useful Post:
djuosnteisn (07-02-2012), Don06speed6 (07-02-2012), mrmonk7663 (07-01-2012)
 Old 07-01-2012, 05:28 PM   #96
mrmonk7663's Avatar
I don't need to search around more "homie." I simply asked a yes or no question that was on topic.
The Following 2 Users Say NO Thank You to mrmonk7663 For This Un-useful Post:
Captain KR (07-01-2012), Easter Bunny (07-01-2012)
 Old 07-01-2012, 06:22 PM   #97
Groans: 62
Well if you searched at all you have seen that it doesn't. "Homie"
 Old 07-01-2012, 08:35 PM   #98
SpeedSixxx's Avatar
Posts: 4,184   (View Stats)
SpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the world
Groans: 778
excited to see this build finished.
2003 SilverStone Grey Honduh S2000
SpeedSixxx is offline   Reply With Quote
 Old 07-02-2012, 11:05 AM   #99
Speeeeeed
06Speed6's Avatar
That makes two of us
2006 Mazdaspeed 6
 Old 07-02-2012, 03:43 PM   #100
Speeeeeed
06Speed6's Avatar
Corksport front sway bar and pauter rods ordered.
2006 Mazdaspeed 6
Boosted Beluga (07-02-2012)
 Old 07-02-2012, 03:53 PM   #101
redmnsterut's Avatar
Posts: 838   (View Stats)
redmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the world
Damn, this is going to be sick cant wait to see it done!
SURE RMM | SURE Shift Weight | SURE SSP | CP-E CAI | CP-E DP | CP-E TIP | COBB AP |SnailD Tunned| TEIN Springs | SU Turbosmart BPV | Autotech HPFP Internals | Autolite XP step colder plugs | JBR Heavy Shift Knob | CXracing FMIC | Block8 Single Gauge Pod | MSD DashHawk
Waiting to be installed: SURE Dreadnaught | JBR Shifter Bushings | SU Boost Tubes | P&P Intake Manifold
Soon to come:SURE Intake/TB TIG | SURE Juggernaught | RSB |
286awhp / 346lbs tq @4500 ft ASL
redmnsterut is offline   Reply With Quote
The Following 2 Users Say Thank You to redmnsterut For This Useful Post:
06Speed6 (07-02-2012), Boosted Beluga (07-02-2012)
 Old 07-02-2012, 06:22 PM   #102
SpeedSixxx's Avatar
Groans: 778
you mean rear sway bar right?
just checking..
 Old 07-02-2012, 06:33 PM   #103
laxplayermjd's Avatar
Posts: 779   (View Stats)
just checking..
he means front they are on pre order theresa thread in corksport area
laxplayermjd is offline   Reply With Quote
The Following 2 Users Say Thank You to laxplayermjd For This Useful Post:
06Speed6 (07-02-2012), SpeedSixxx (07-02-2012)
 Old 07-02-2012, 07:41 PM   #104
SpeedSixxx's Avatar
Groans: 778
ty...
could you link thread please?
 Old 07-03-2012, 02:09 AM   #105
Speeeeeed
06Speed6's Avatar
Just mounted the pauter rods and wisecos up and compaired them to the stockers and holy fuck there has to be at least twice the metal in the pauter rods
2006 Mazdaspeed 6
The Following 4 Users Say Thank You to 06Speed6 For This Useful Post:
Boosted Beluga (07-03-2012), laxplayermjd (07-03-2012), SilverDemon (07-03-2012), SpeedSixxx (07-04-2012)
 Old 07-03-2012, 06:15 AM   #106
Groans: 50
Yep got to love pauter rods. Idk why more ppl don't use them.
08 Mazdaspeed 3
The Following User Says Thank You to Boosted Beluga For This Useful Post:
06Speed6 (07-03-2012)
 Old 07-03-2012, 04:19 PM   #107
Speeeeeed
06Speed6's Avatar
Dropped the parts off at the machine shop, they said they would try to work it inbetween other peoples engines.
2006 Mazdaspeed 6
 Old 07-03-2012, 05:37 PM   #108
Trail of Fail
Dano's Avatar
insert "post" for thread
I wanna see a big thick rod....conrod that is.
 Old 07-03-2012, 08:21 PM   #109
Empurfektion's Avatar
Posts: 30   (View Stats)
Empurfektion is a jewel in the roughEmpurfektion is a jewel in the roughEmpurfektion is a jewel in the roughEmpurfektion is a jewel in the rough
Groaned at 6 Times in 2 Posts
When mine popped I went with k1's. After doing a lot of research I figured they were pretty good for the price and they still help up really well for all that I need. They still had twice the metal as the stockers too. It was crazy to me to see how thin the stock ones really are.
Empurfektion is offline   Reply With Quote
 Old 07-03-2012, 08:54 PM   #110
Trail of Fail
Dano's Avatar
Is is cold in here or is it just me?
 Old 07-03-2012, 09:03 PM   #111
Speeeeeed
06Speed6's Avatar
Ours are beefy compared to some rods but yeah they are really small.
2006 Mazdaspeed 6
 Old 07-03-2012, 09:17 PM   #112
Trail of Fail
Dano's Avatar
Must just be me....
Tappin
 Old 07-04-2012, 12:11 PM   #113
Groans: 50
Yeah it's just you D.
08 Mazdaspeed 3
 Old 07-04-2012, 12:39 PM   #114
Trail of Fail
Dano's Avatar
I thought so....
 Old 07-04-2012, 01:15 PM   #115
Groans: 50
Want to cuddle to warm you up?
08 Mazdaspeed 3
 Old 07-04-2012, 01:32 PM   #116
Trail of Fail
Dano's Avatar
nah...but thanks for the offer...i have thick skin.
Boosted Beluga (07-04-2012)
 Old 07-09-2012, 06:35 PM   #117
Speeeeeed
06Speed6's Avatar
Bought a torque plate, nother part down.
2006 Mazdaspeed 6
 Old 07-12-2012, 09:51 PM   #118
Speeeeeed
06Speed6's Avatar
So I have a 88mm 5 layer Cometic HG and a 88mm 3 layer Cometic HG, How much compression do you guys think that I would lose with the 5 layer?
2006 Mazdaspeed 6
 Old 07-13-2012, 03:35 PM   #119
SpeedSixxx's Avatar
Groans: 778
ask john at ptp
honestly DCR and PTP both sell a 5 layer HG..
PT-Performance.com
read what he says on his site about compression drop.
Last edited by SpeedSixxx; 07-13-2012 at 03:35 PM. Reason: MSF Database - Automerged Doublepost
 Old 07-13-2012, 09:59 PM   #120
Speeeeeed
06Speed6's Avatar
I think with head and block surface prep the compression drop is very low. Ive been trying to find a good write up on why 5 layer gaskets are better.
2006 Mazdaspeed 6
long awaited turbo manifold is out!!! Grumpyjap Custom Performance Engineering (cp-e.com) 146 05-13-2012 06:05 AM
Page generated in 0.63019 seconds with 32 queries
