| MazdaSpeed 3/6 - Build Diaries MazdaSpeed 3/6 - General Build Threads/Diaries |
![]() Join Date: Nov 2011 Location: Greece-Athens
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 470
(Thread Starter) | Neutral : +3 score So lets start with the engine parts Sp63 87.5 stok cr pistons Manley I-beam with arp 625+ L.A. sleeves Oem brand new head gasket 12mm Head bolts 11mm main bolts New oil pump I also make some upgrades to crank girdle (i will attach photos) For the cylinder Head Supertech intake valves +1 Supertech exhaust valves +1 Supertech valve guides Supertech single 55lbs spring kit(i will soon upgrade it to dual spring) Big Head port with handjob(because there is no cnc for heads in my country)it is made by one of my country`s best(attached flow bench results) Dcr vv-t Sp63 stage 2 cams Other parts Pte 6466 V-band 0.82 cp-e maniford Jmf V2 Intake Htp 4~ inch maf 4X 1250cc bosh style Deutshwerks injectors Oil cooler with relocation & spin on filter Corksport seals (great desighn) Custom 3.5inch Dp Custom 3.5inch aluminium exhaust 7.25 Twin disk Clutch (quarter master with sintered discs) and custom made billet flywheel As for the AWD conversion I buy a rear subframe from a cx-7, and gearbox and transfercase from speed6.The 2 rear axles are custom made from driveshaft and the front rear right(passenger side) is from totalmps . I also make a custom fuel tank witch seats in the oem location and it is feed from the oem fuel tap .It need some modification at rear subframe to fit all these into the speed3 but nothing serius the lower arms ,camper arms & toe arms need to be machined. I have also put a switch for the awd .When it is on, the car is 50-50 and when it is off is 100-0 .In future I will put a switch with 3 options and I will put a 3rd option for 70-30 . My goal is to make a nice 9sec pass(with 4 slicks) and make 750whp,i just hope that all will handle good. Lets see how it works . I have already made some miles about 100 everything looks great I will change oil at 250 miles then at 450miles and then i will start to give her some boost. P.S. Soory for my poor english -I`m open to all coments
__________________ 2008 speed3 True red. Pte 6466 & AWD Mode on !!!! 11.114@131.04 .........GTX3071.....FWD 10.62@136.64............PTE6466.....AWD [SIGPIC][/SIGPIC] |
| The Following 152 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post: | 09TrueRedGTX (03-12-2015), 2eatV8everyday (06-24-2015), 37371118 (05-02-2015), 3starmagnum (04-01-2015), 5doorsoffury (03-12-2015), 802MS3 (03-12-2015), acidplant (11-11-2016), acousticdefbot (06-24-2015), Addikted To Boost (06-24-2015), Agent_Orange (03-13-2015), Alpha (03-27-2015), Amnesiac (03-12-2015), andrewz17 (11-15-2015), ArmanRus (03-12-2015), ASHMS3 (03-12-2015), AveryPlaysBass (10-29-2016), B4RK3R (03-12-2015), BigjohnB20 (03-12-2015), BlackFlag (11-09-2015), blackmicamps6 (03-12-2015), blakjak0271 (03-12-2015), BLKSTIG (03-13-2015), Boost_creep (01-27-2016), brandon3212 (03-12-2015), brandonf (12-28-2015), brandonnicholson (03-12-2015), BrandonRKD (03-12-2015), btstarcher (09-06-2015), ButtholeRedMS3 (01-06-2016), Cevaes_64 (10-05-2015), chaser27 (03-12-2015), chris323 (03-16-2015), cld12pk2go (03-15-2015), Code Monkey (03-12-2015), Cpt_Rum-bo (03-12-2015), cshunter (03-12-2015), CWP_MS3 (03-12-2015), Cyclops (03-12-2015), daafisch (06-24-2015), dagrimey1 (12-02-2015), dale_gribble (03-12-2015), dan7225 (03-12-2015), Dano (06-19-2015), DaUberSchwebel (12-10-2015), dereeek (03-12-2015), derek13p (03-12-2015), derp_ms6 (03-16-2015), DevinS (12-28-2015), Dimenus (03-12-2015), DingoDave (12-25-2015), donjohnk (03-12-2015), Easter Bunny (03-12-2015), Erick13Speed3 (03-12-2015), Etipp98 (03-15-2015), Frnchplayr15 (03-12-2015), g00s3y (03-12-2015), gsrtype1 (09-01-2015), Hargarbl (03-15-2015), harryclay (03-21-2015), HawkeyeGeoff (03-12-2015), Hush (03-12-2015), IamJamen (03-12-2015), impossible (03-15-2015), ink28 (04-09-2015), ItsNox (03-15-2015), Jackis (05-09-2015), jack_hammer (03-12-2015), Jester2552 (07-10-2015), JgamB (03-12-2015), JSmith (03-12-2015), Jtaylor (03-13-2015), Justin@Freektune (03-12-2015), jweller (12-31-2015), kolosok17 (11-02-2015), k_kid (03-15-2015), Lex (03-12-2015), littleloogy (07-15-2015), lnumbp (03-12-2015), lolwrx (03-12-2015), magicka (04-01-2015), maisonvi (03-12-2015), manu (12-15-2016), Matt H. (03-12-2015), Mattyhawk1 (03-16-2015), MattyP617 (04-09-2015), Mauro_Penguin (03-12-2015), mazdakaps (03-14-2015), Mazdazilla6 (03-12-2015), MBalik (03-13-2015), MD1032 (07-02-2015), meelo88 (03-12-2015), meicalnissyen (09-04-2016), mituc (04-09-2015), Mr Wilson (03-12-2015), Mr. T (04-09-2015), ms3blackmica (03-13-2015), ms6mil (03-12-2015), mxlplx71 (03-12-2015), mzr0818 (12-06-2015), nekret (03-14-2015), Neverlift (03-12-2015), NoRegrets (04-09-2015), nybe0010 (03-12-2015), PapaSmurf (03-13-2015), PhillyCheese (09-13-2015), predapio (04-09-2015), Pu Manchu (03-12-2015), Qwik6 (03-11-2016), Raider (03-13-2015), redneck4Christ (07-10-2015), Rich990 (08-13-2015), rigor (06-08-2019), robbspeed (09-27-2016), roguemazda (10-31-2015), ryguy 3 (03-27-2015), SamiChicago (12-24-2015), Scare Dem (03-12-2015), shaneski (03-13-2015), Shwaykid (03-12-2015), smoogs12 (03-27-2015), Snyeed (03-28-2015), SofaKingAwesome (05-03-2016), some call me...Tim (03-27-2015), SparkySparks (09-01-2015), speed23 (03-12-2015), Speed3Pedro (11-13-2016), SpeedRebirth (03-12-2015), speed_freak91 (03-12-2015), SpencerC (03-13-2015), squats (03-12-2015), stanley0910 (03-15-2015), Swinger13 (03-12-2015), Tacheny (04-09-2015), taf0422 (03-12-2015), tegxsi (03-12-2015), thems3driver (03-28-2015), TiGraySpeed6 (03-12-2015), Tokay444 (04-01-2015), Tomas (09-01-2015), torquemaniac (04-11-2015), twincitySPEED6 (03-12-2015), UnknownSuperhero (03-13-2015), Vader (03-12-2015), Vadim aka ScooteR (03-12-2015), Varomnia (11-14-2016), WA_MS6 (04-01-2015), WetzMS3 (03-12-2015), Z32_MS3 (03-14-2015), Zachms3 (11-14-2015), Zdraveca (06-19-2015), zooomMPS3 (12-28-2015), [R]usty (09-14-2015) |
![]() Join Date: Nov 2010 Location: South Haven, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,824
Groans: 75
| Not Ranked : 0 score Wow, you are going big, I like it. Keep up the good work.
__________________ Franken Turbo, built motor, meth. DIY parts: Shift Knob, Shift Plate, Shift Bushings, Battery Tray, EBCS, RSB, probably more. "Your signature should just say, I'm the shit." -LynzeC |
| The Following User Says Thank You to maisonvi For This Useful Post: | HawkeyeGeoff (03-12-2015) |
Groans: 438
| Not Ranked : 0 score That... is... BEAUTIFUL
__________________ All good things must come to an end... |
![]() Join Date: Jan 2011 Location: East Lansing, MI - America's High Five
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 403
| Not Ranked : 0 score Tasty
__________________ '06 LPM MS6 GT - GTX3071R and stuff and stuff ![]() ![]() |
| The Following User Says Thank You to IamJamen For This Useful Post: | maisonvi (03-12-2015) |
![]() Join Date: May 2011 Location: Valdosta GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,861
Groans: 126
| Not Ranked : 0 score I came....
__________________ '09 Red MS3 - AP self tuned, CS HPFP, JBR 3.5 WP, CP-e S2 RMM, M2 Catless DP, CX FMIC, CNT CBE |
Rep Power: 6573 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,956
Groans: 122
| Awesome! Glad to see someone is doing it, and doing it BIG. In for huge HP AWD MS3. Can't wait to see it run.
__________________ CP-e S2 RMM // TurbineTech FMM // Ghetto SRI // 3" ATP MAF housing // Ultimate Racing CBE // Ebay Downpipe // Cobb AP // Autotechs // PG TIP // HKS V4 BOV // NGK Iridiums // ACT Street Disc // JBR Trans Mount Rich Tuned 330WHP and 363TQ 10-19-13 Moore Automotive ![]() |
| The Following 3 Users Say Thank You to CWP_MS3 For This Useful Post: |
![]() Join Date: Oct 2013 Location: Raleigh, NC
Rep Power: 186 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 193
| Not Ranked : 0 score Wow...
__________________ Stock as Fuck |
Groans: 75
| Not Ranked : 0 score Plus he has driver mod. Thing is going to move (if it stays together, always seems the awd mzrs like to not stay running)
| The Following User Says Thank You to maisonvi For This Useful Post: | impossible (03-15-2015) |
Groans: 122
| Aww, why you got to shit on his parade already...?
| The Following 2 Users Say Thank You to CWP_MS3 For This Useful Post: | cshunter (03-12-2015), RalliartRsX (03-12-2015) |
![]() Join Date: Dec 2008 Location: FLORIDA
Rep Power: 1419 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,235
| Not Ranked : 0 score Subbed for results. A lot of hard work went into this.
__________________ 2008 Mazdaspeed3 GT GTX2867r ![]() |
| The Following User Says Thank You to Scare Dem For This Useful Post: | Mauro_Penguin (03-12-2015) |
Groans: 75
| Not Ranked : 0 score Haha dont get me wrong, Im hoping for the best. But Ive been around long enough to know how it goes. Hell, Im jealous of his fab skills. I would love to do an AWD swap.
![]() Join Date: Mar 2011 Location: St. Boni, MN
Rep Power: 485 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 355
Groans: 34
| Not Ranked : 0 score This is awesome... Shit, I would be happy with just adding AWD to the MS3. |
Thanks everyone for the good words...
__________________ 2008 speed3 True red. Pte 6466 & AWD Mode on !!!! 11.114@131.04 .........GTX3071.....FWD 10.62@136.64............PTE6466.....AWD [SIGPIC][/SIGPIC] | |
| The Following 13 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post: | chaser27 (03-12-2015), CWP_MS3 (03-12-2015), daafisch (06-24-2015), Easter Bunny (03-12-2015), harryclay (03-21-2015), Hush (03-12-2015), impossible (03-15-2015), JgamB (03-12-2015), maisonvi (03-12-2015), Mauro_Penguin (03-12-2015), Scare Dem (03-12-2015), WA_MS6 (04-01-2015), WetzMS3 (03-12-2015) |
![]() Join Date: Dec 2013 Location: East Bridgewater, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 124
| Not Ranked : 0 score Looks like a beast. 2015 has to show a 10 sec pass
__________________ BNR s3, Freek 3.5", Autotech internals, depo racing catless dp, TR6, JBR FMIC piping, 80a rmm, OCC, TIGs, EGR delete and Coolant bypass FREEKTUNED |
![]() Join Date: Mar 2012 Location: Waterford, MI - America's High Five
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,451
| Not Ranked : 0 score Here I am sweating in a dark corner pretending like im not fapping furiously to this thread. Greece is going big
__________________ Silver 2007 Speed3 GT Xona Rotor 6156, Port Injection w/ E85...Bunch of other stuff. I make some power. Titanium Grey Mazdaspeed6 GTX3071, DD |
| Not Ranked : 0 score Very very cool! Custom prop shaft? (drive shaft)
![]() Join Date: May 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
| Not Ranked : 0 score I want to hear this thing! Video? |
(Thread Starter) | Not Ranked : 0 score The front half is from speed6 the rest custom I attached a video at the first post...
__________________ 2008 speed3 True red. Pte 6466 & AWD Mode on !!!! 11.114@131.04 .........GTX3071.....FWD 10.62@136.64............PTE6466.....AWD [SIGPIC][/SIGPIC] Last edited by RE-ACTIONENGSPEED3; 03-12-2015 at 08:15 AM. Reason: MSF Database - Automerged Doublepost |
| The Following 3 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post: |
![]() Join Date: Jan 2009 Location: ATHENS-GREECE
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score Greek State of Art after Parthenon...
__________________ http://www.linkedin.com/in/dgiannitakis |
![]() Join Date: Jul 2008 Location: Imperial MO
Rep Power: 582 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 127
| Not Ranked : 0 score why did you go with the custom fuel tank vs using an S40 fuel tank?
__________________ 2008 MazdaSpeed 3 AWD big turbo...blah blah blah |
| Approved MSF Vendor ![]() Join Date: Mar 2014
Rep Power: 2489 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,022
| Not Ranked : 0 score Love it man! Can't wait to see what you can lay down at the track. Keep us updated with the progress too!
__________________ Custom Tuning for Mazdaspeed, Ford, and Subaru ![]() Website- http://www.freektune.com/ PTE 6062 633HP/523TQ First gen2 in 10's- 10.93@137 Atco NJ 11/14/15 ![]() Quickest/Fastest Mazdaspeed First Gen 1 in the 9's 9.94@149.5 4/22/2017 New England Dragway |
![]() Join Date: Apr 2012 Location: Charlotte, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 646
Groaned at 6 Times in 4 Posts
| Not Ranked : 0 score That...is...awesome! Are the rear axles a custom length? Not sure if the rear track width is the same on the 3 and the cx7. Ill be interested to see how the driveline holds up with the locked front/rear ratios.
__________________ 1999 Cosmos M3 turning bits and more better suck, squish, bang, and blow FREEK'D 2012 Liquid Silver Genpu-sold We were young, and we were fearless and, after all, nobody had ever told us young engineers that we couldn't successfully land humans on another planet. So we did it. |
(Thread Starter) | Not Ranked : 0 score Because it is difficult to find it in my country and i also want to reduce weight. Yes it is custom length
__________________ 2008 speed3 True red. Pte 6466 & AWD Mode on !!!! 11.114@131.04 .........GTX3071.....FWD 10.62@136.64............PTE6466.....AWD [SIGPIC][/SIGPIC] Last edited by RE-ACTIONENGSPEED3; 03-12-2015 at 10:25 AM. Reason: MSF Database - Automerged Doublepost |
![]() | | #24 | ![]() |
Speed 6 axles work in this set up...so custom axles aren't required. I hope youre talking about fuel weight lol.
__________________ 2008 MazdaSpeed 3 AWD big turbo...blah blah blah Last edited by Jarods7920; 03-12-2015 at 10:27 AM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #25 | ![]() |
![]() Join Date: Mar 2013 Location: Huntsville, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,402
| Not Ranked : 0 score All of this engine porn and awesome fab work.. and I can still only chuckle about "Big Head port with handjob" I wish you the best with this amazing build.
__________________ Manley forged long block, secret snail, manifolds, and 2gal E85 tune running like a champ - about to dial in a lot of meth and see what we've got. 13.10@117.1 full weight DD no prep 1/4 (BNR S3 / E85) |
| The Following 9 Users Say Thank You to JgamB For This Useful Post: | Agent_Orange (03-13-2015), daafisch (06-24-2015), Easter Bunny (03-12-2015), impossible (03-15-2015), jack_hammer (03-12-2015), lolwrx (03-12-2015), Mauro_Penguin (03-12-2015), Putin 2.3T (03-12-2015), RE-ACTIONENGSPEED3 (03-12-2015) |
![]() | | #26 | ![]() |
![]() Join Date: Mar 2014 Location: Canada
Rep Power: 0 ![]() Thanks: 3
| Not Ranked : 0 score This is amazing. Glad to see others putting in hard work for the love of this Mazda. Cannot wait to see this thing run a quarter. I'd be doing this in a second if I had the cash to do so freely with time. Awesome work man |
![]() | | #27 | ![]() |
| Daily Driver ![]() ![]() Join Date: Dec 2008 Location: Tampa, Fl
Rep Power: 880 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 576
| Not Ranked : 0 score Yeah and the MS6 axles have been proven to be dog shit and bust on many cars so he made much stronger ones from drive shafts., Which I think he was smart in looking ahead to see that as an issue. |
| The Following 4 Users Say Thank You to Nitr0EngiE For This Useful Post: | Downmented (03-13-2015), Easter Bunny (03-12-2015), RE-ACTIONENGSPEED3 (03-12-2015), redneck4Christ (07-10-2015) |
![]() | | #28 | ![]() |
(Thread Starter) | Not Ranked : 0 score A litle update I just went to the alighment today..everything is perfect and i setup it as i wanted... Furthermore, i forgot to write about the re-inforcments i have done to the transfercase. I put the upgraded bearings caps from 06speed6 , i have replace all the bolts with arp`s and i have made an extra re-inforce like a handcuff (photos below)
__________________ 2008 speed3 True red. Pte 6466 & AWD Mode on !!!! 11.114@131.04 .........GTX3071.....FWD 10.62@136.64............PTE6466.....AWD [SIGPIC][/SIGPIC] Last edited by RE-ACTIONENGSPEED3; 03-12-2015 at 03:16 PM. |
| The Following 32 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post: | 802MS3 (03-12-2015), ASHMS3 (03-12-2015), aviator79 (04-09-2015), blackmicamps6 (03-12-2015), brandon3212 (03-12-2015), ButtholeRedMS3 (01-06-2016), Code Monkey (03-12-2015), Cpt_Rum-bo (03-13-2015), daafisch (06-24-2015), Dano (06-19-2015), Downmented (03-13-2015), Easter Bunny (03-12-2015), Hargarbl (03-15-2015), Hush (03-12-2015), impossible (03-15-2015), ItsNox (03-15-2015), JgamB (03-13-2015), Jtaylor (03-13-2015), Lex (03-12-2015), magicka (04-01-2015), Mauro_Penguin (03-13-2015), Mazdazilla6 (03-12-2015), mxlplx71 (03-12-2015), Pu Manchu (03-13-2015), Reactorpwr (04-19-2019), redneck4Christ (07-10-2015), robry (02-04-2016), smr87 (03-12-2015), Swinger13 (03-12-2015), Tokay444 (04-01-2015), torquemaniac (04-11-2015), WA_MS6 (04-01-2015) |
![]() | | #29 | ![]() |
| Not Ranked : 0 score Nicely done! How does the car handle in the turns? Understeer, oversteer or neutral?
| The Following User Says Thank You to Lex For This Useful Post: | Mauro_Penguin (03-13-2015) |
![]() | | #30 | ![]() |
![]() Join Date: Sep 2012 Location: London Ontario Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 338
| Not Ranked : 0 score Best of luck with this crazy build, I will be following closely.
__________________ 07 Speed 3 Handling: H&R Springs, Koni yellow shocks, JBR .250 Competition RSB, Whiteline poly control arm bushings, Custom 1/2" rod end RSB links, JBR 88D Trilogy, steel RMM bushings, Sparco Pro 2000 race seat (driver), Kirkey race seat (passenger), shift plate, 18X10.5 +15 RPF1, 275/35 18" Nitto NT01 Brakes: Wilwood 6 piston calipers, Cobalt Friction XR1 race pads Power: Custom 3.5" intake, Synapse Diverter valve, dual 3" Hood Exit, BNR S3, Treadstone 3126 core, 3 port EBCS, 3" custom cold pipe, 2.5" custom underroute hot pipe, Aquamist HSF4 |
![]() | | #31 | ![]() |
| Not Ranked : 0 score Very awesome! I have three questions: 1. Why did you go to 11mm main studs? I've seen no one having issues with 10mm. 2. What caused you to put on crank girdle straps? 3. How much was it for the LA sleeves and where did you get them?
| The Following User Says Thank You to Mazdazilla6 For This Useful Post: | Mauro_Penguin (03-13-2015) |
![]() | | #32 | ![]() |
| Not Ranked : 0 score Holy shIt. Go big or go home. I assume this means that The 3 is not available in Greece as awD?
![]() | | #33 | ![]() |
| Not Ranked : 0 score Ya and you can buy upgraded ms6 axles just like he did and just like I did....in case you have forgot, I did this too.
![]() | | #34 | ![]() |
| MSF's Punishing Member ![]() Join Date: Apr 2011
Rep Power: 2794 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,165
Groans: 546
| Not Ranked : 0 score in case you have forgot, you have a build thread that's laid dormant for 3 years.
__________________ 94 M MS6 IS350 |
| The Following 3 Users Say Thank You to Pu Manchu For This Useful Post: |
![]() | | #35 | ![]() |
![]() Join Date: Jan 2012 Location: Edmonton, Alberta, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,581
Groans: 53
| Not Ranked : 0 score what 12mm head studs do you have?
__________________ 06 Speed 6 rock chipped n' shit Performance: Stratified Tune in progress Old Set-up: CS Ram air intake with 3" HTP inlet + "sig" Vdyno 323 awhp 349 awtq uncorrected Current Set up: JBR 3.5" WP, Perm PCV w/dual catch cans, trunk battery Vdyno 343 awhp 374 awtq uncorrected Corksport CBE ~ Ebay DP ~ Autotech Internals ~ COBB AP ~ BC Racing Coilovers ~ SURE shortcut ~ SURE countershift ~ SURE anchors ~ heavy sphere shift knob by maisonvi (MSF member) ~ CP-E seals ~ BSD ~ baffle pan ~ Dual Corksport OCC ~ CP-E Rear Diff Mount ~ SURE Juggernaught ~ Dashhawk ~ AWR 88 duro trilogy ~ EGR delete ~ 3 bar ~ JBR TIG's ~ Grimmspeed 3 port ~ GT2871R w/ported hotside ~ JBR 3.5 inch intake ~ Perm Tuning PCV Plate ~ Forge V1 BPV ~ ITV22's @ .026" ~ CP-E Helihose |
![]() | | #36 | ![]() |
![]() Join Date: Jul 2014 Location: North Carolina
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 127
| Not Ranked : 0 score Truly amazing!
__________________ 2013 CWP W/Tech Package: Cobb Tuning Accessport //Cobb Tuning SF Intake //Cobb Tuning Turbo Inlet Pipe //Corksport TMIC //M2 Test pipe //Autotech HPFP Internals //JBRacing 1.25'' Rear Sway Bar //JBRacing 88A RMM //JBRacing Short Shifter Plate //Swift Spec R springs// Bilstein B8's //Resonator delete //35% window tint// Rally Armor Mudflaps// Go Fast Bits BOV// NGK Step Colder Plugs |
![]() | | #37 | ![]() |
![]() Join Date: Nov 2011 Location: hollywood Fl
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,448
Groans: 42
| Not Ranked : 0 score Threads like this makes me wanna go balls deep in my speed But then i remember im a college student on a budget Keep it up sir. Truly amazing job
__________________ i got a useless big fucking turbo Fuck mazdaspeeds Fuck shayne |
![]() | | #38 | ![]() |
![]() Join Date: Jun 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 242
| Not Ranked : 0 score Great work, this is pure dedication to achieve his goals with a MZR powered car.
__________________ Gen 2 2012 - Precision 6062 Turbo - CPE Exhaust Mani - PTE 46mm EWG - 2NV Industries built Forged bottom end - PNP Head - JMF V2 Intake Mani- Custom DP UR Cat Back - HTP 4 inch intake - TR8 FMIC - Custom FREEKTUNE METH Port Injection - Cobb 3 port EBC- Autotech internals - FREEKTUNED. |
![]() | | #39 | ![]() |
The L.A. sleeves i bought them direct from them (500$ if i remeber correct) i get them on a local engine builder Nice question they are from Nissan Gtr R35 (they are almost identical) No Awd speed 3 in my country...
__________________ 2008 speed3 True red. Pte 6466 & AWD Mode on !!!! 11.114@131.04 .........GTX3071.....FWD 10.62@136.64............PTE6466.....AWD [SIGPIC][/SIGPIC] Last edited by RE-ACTIONENGSPEED3; 03-13-2015 at 01:22 AM. Reason: MSF Database - Automerged Doublepost | ||
| The Following 8 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post: | Agent_Orange (03-13-2015), impossible (03-15-2015), maisonvi (03-13-2015), Mauro_Penguin (03-13-2015), Mazdazilla6 (03-15-2015), redneck4Christ (07-10-2015), SamiChicago (12-24-2015), Swinger13 (03-13-2015) |
![]() | | #40 | ![]() |
![]() Join Date: Sep 2012 Location: Elizabeth, NJ
Rep Power: 3180 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,265
Groans: 665
| Not Ranked : 0 score That is all I have to say. |
| The Following 18 Users Say Thank You to Agent_Orange For This Useful Post: | ArmanRus (03-13-2015), ASHMS3 (03-13-2015), BigjohnB20 (03-13-2015), blackmicamps6 (03-13-2015), ButtholeRedMS3 (01-06-2016), Cpt_Rum-bo (03-13-2015), cshunter (03-13-2015), Easter Bunny (03-13-2015), Erick13Speed3 (04-06-2015), harryclay (03-21-2015), impossible (03-15-2015), ItsNox (03-15-2015), JgamB (03-13-2015), lolwrx (03-13-2015), MattyP617 (04-09-2015), Mauro_Penguin (03-13-2015), SamiChicago (12-24-2015), WA_MS6 (04-01-2015) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f541/pte-6466-awd-conversion-185595/ | ||||
| ClubC4 ? Vezi subiect - Fun | This thread | Refback | 12-19-2015 01:37 AM | |
| Articole interesante despre masini - Pagina 46 - Cafenea - Club Mazda | This thread | Refback | 12-18-2015 10:34 PM | |
| Pte 6466 & AWD conversion - Page 3 - Mazdaspeed Forums | This thread | Refback | 06-24-2015 04:14 AM | |
| ?????? ?????? ?? Mazda 3 mps AWD | This thread | Refback | 05-07-2015 04:11 AM | |
| Articole interesante despre masini - Pagina 36 - Cafenea - Club Mazda | This thread | Refback | 04-09-2015 12:46 PM | |
| ? View topic - Trying for a 9 !! 1/4 Mile in a MPS3 | This thread | Refback | 03-15-2015 05:11 AM | |
| Çàåçäû (÷àñòü 2 - íîâûé ñåçîí!) (Ñòð.314) / ×åëÿáèíñê — FFClub | This thread | Refback | 03-12-2015 08:30 AM | |
| di to pi conversion | cbspeed3 | MazdaSpeed 3 - Engine, Transmission & Driveline | 7 | 04-05-2009 09:48 PM |
| HID Conversion Kit | SpdFreak | MazdaSpeed 3/6 - Car Audio & Electronics | 62 | 01-27-2009 05:18 AM |
