Like Tree38Likes
 Old 09-22-2014, 09:34 AM   #1
sho
sho's Avatar
Posts: 537   (View Stats)
sho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the world
Default Sho's 2007 MS3 project
Picked up a 2007 Sunlight Silver MS3 GT August 3rd, 2012 after putting 217k miles on my '98 Saturn SL.
I got the MS3 with 25,314 miles on it after spending months searching for the right deal.
I'll be updating this thread as I do things with the car, and hopefully it'll be on the road for a long time!
Also a big shout out to NATOR OH, the guys here have helped me a ton with this car, and I couldn't be more grateful for their help!
Current Mods:
Suspension/Braking/Handling:
-Mazdaspeed Accessory Coilovers
-SPC Camber Arms
-Hotchkis 32mm Front and Rear Sway Bars, rear is on stiffest setting
-OEM Mazda Brake Rotors
-Hawk HP+ Front and Rear Brake Pads
-Stock MS6 wheels with 215/45/18 Michelin X-Ice tires
Engine/exhaust goodies:
-Manley Platinum Series 88mm Pistons
-Manley H-Beam Rods
-Autotech HPFP Internals
-HTP 3.5" Intake
-COBB Front Mount Intercooler (red piping and black core)
-Custom 2-piece 3" Catless Vband Downpipe with Top Portion Ceramic Coated
-Secondary O2 Sensor Delete
-Forge V1 Bypass Valve
-Mazdaspeed Accessory Catback Exhaust
-COBB AccessPort v3
-Cp-e Stage 1 75 duro Rear Motor Mount
-PnP Intake Manifold with VTCS Delete
-Sikky Manufacturing Thermal Insulating Intake Manifold Gasket
-James Barone Racing EGR Blockoff
-Kozmic Primary EGR Delete with Coolant Line Plug
-Kozmic Screamer Pipe
-Precision 5858CEA Journal Bearing Turbo with 4" Ported S Compressor and 2.5" Vband Outlet
-Precision 46mm External Wastegate
-Cp-e Vband Exhaust Manifold (Ceramic Coated)
-Cp-e Safe Seal Injector Seals
-James Barone Racing Stage 2 Oil Catch Can
-James Barone Racing 80d Passenger Motor Mount
-DIY Throttle Body Coolant Bypass
-James Barone Racing Thermal Insulating Throttle Body Gasket
-Bosch 3bar MAP sensor
-Grimmspeed 3 Port EBCS
-Perm PCV Plate
-Vented 2nd OCC
-PTP 1950psi Relief Valve
-Tune by Realgib3
Here's some pics i've collected along the way:
Compression test at 109.5k miles
FMIC install
Everything connected and TMIC ducting removed from hood
Jakey and V trimming my bumper as the piping was hitting some portions and not allowing the bumper to go back on the car
It fits!
Crazy routing for the piping
Hot and cold pipes so close, we took a silicone coupler and cut it and taped it to the hot pipe to keep it from rubbing on the cold pip/bpv flange
Bumper back on...stealth black core
My Rice
DVM17 and Mazdaspeed3_1993 like this.
2007 ms3 GT, sunlight silver
Manley platinum series 88mm pistons, Manley h beam rods, L19 head studs, custom cometic mlx head gasket, massive speed balance shaft delete, massive speed oil pan baffle, OEM Rod and Main bearings, vband pte 5862 .82AR journal bearing turbo, Cp-e exhaust manifold, custom 3" vband downpipe, 3" cnt Catback, pw46 ewg, tr1235 fmic, tial Q BOV on hotside pipe, 3" cold side piping, JMF V2 w/ PI, CS big TB, PERM pcv plate with jbr sealed can and ebay VTA can, custom VC vent with VTA can, SP63 gen 1 vc breather cap, Cp-e injector seals, mazdaspeed accessory coilovers, Hotchkis 32mm fsb and rsb, Damond Motorsports RMM, TMM & PMM.
FD wheels
E48 mix
Tuned by Realgib3
Purchased 8/3/12 - 25,314 miles on chassis and motor
6/21/18- 234,700 miles on chassis, 73,200 on built motor
sho is offline   Reply With Quote
The Following 6 Users Say Thank You to sho For This Useful Post:
chemmedic (06-28-2015), DVM17 (10-20-2014), J'sSpeed3 (09-22-2014), Micha (12-03-2014), pmartz16 (10-20-2014), warjunkies (11-28-2014)
 Old 10-19-2014, 09:46 AM   #2
sho
sho's Avatar
Some small updates:
Sourced a new crank from my buddy @robry; so I don't have to mess with getting the one I have with a spun bearing machined.
Need to get a head as well, then the short block will be off to the machine shop for honing and getting the top of the block and bottom of the head resurfaced. Once that's done, I'll be ordering Manley H-Beams, cp-e stage 2 pistons, and all the new gaskets and bolts and whatnot.
Picked up some cp-e safeseals as well
Also picked up a wrinkle black timing cover and valve cover from my good friend @Lewis7789; which will be going on the built motor. He did a fantastic job on these!
Now to decide...what turbo and manifold I want/can afford....
FD wheels
E48 mix
Tuned by Realgib3
The Following 3 Users Say Thank You to sho For This Useful Post:
DVM17 (11-10-2014), Lewis7789 (10-19-2014), robry (10-20-2014)
 Old 10-19-2014, 10:33 PM   #3
EvoFire's Avatar
Posts: 389   (View Stats)
How are your gauges holding up?
My Prosport oil pressure gauge just took a dump this week, and there are many stories of issues with the sender units.
 Old 10-20-2014, 09:01 AM   #4
sho
sho's Avatar
None of them are working right now. I had to disconnect the oil temp and pressure senders and remove the sammich plate, as my sammich plate needs replaced. And the sender for the boost gauge took a shit. I've had the senders go out on all 3 gauges multiple time though.
FD wheels
E48 mix
Tuned by Realgib3
 Old 10-20-2014, 10:43 AM   #5
pmartz16's Avatar
Posts: 1,140   (View Stats)
pmartz16 is the leader of the worldpmartz16 is the leader of the worldpmartz16 is the leader of the worldpmartz16 is the leader of the worldpmartz16 is the leader of the worldpmartz16 is the leader of the worldpmartz16 is the leader of the worldpmartz16 is the leader of the worldpmartz16 is the leader of the worldpmartz16 is the leader of the worldpmartz16 is the leader of the world
5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858! 5858!
That is all
sho likes this.
2008.5 Mazdaspeed 3 BM - Built BT Realgib3 Tuned
2014 Mz3 MG
pmartz16 is offline   Reply With Quote
The Following 5 Users Say Thank You to pmartz16 For This Useful Post:
cshunter (10-20-2014), DVM17 (11-10-2014), Micha (12-03-2014), robry (10-21-2014), sho (10-20-2014)
 Old 10-21-2014, 12:22 PM   #6
robry's Avatar
Posts: 862   (View Stats)
Groans: 27
Groaned at 9 Times in 7 Posts
dooooooooooo it
The Following 2 Users Say Thank You to robry For This Useful Post:
DVM17 (11-10-2014), pmartz16 (10-21-2014)
 Old 10-21-2014, 04:14 PM   #7
dan7225's Avatar
Posts: 511   (View Stats)
gen2 valve cover better?
 Old 10-21-2014, 04:16 PM   #8
pmartz16's Avatar
Yes the gen2 valve cover is better but that one above is a gen1
2014 Mz3 MG
 Old 11-09-2014, 07:38 PM   #9
sho
sho's Avatar
Updates:
Was going to send the block off to the machine shop and order rods and gaskets and all that shit next week....buuuutt, I hit a Fucking deer today on my way over to @Realgib3; place to pick up some race car parts.
So that $ will be going to pay my deductible. Here's some pics (I got really lucky. Big ass buck, jumped out from my left, and landed its feet on my hood and headlight and not through my windshield)
And the go fast parts I got from Mark
FD wheels
E48 mix
Tuned by Realgib3
The Following 2 Users Say Thank You to sho For This Useful Post:
DVM17 (11-10-2014), Realgib3 (11-09-2014)
 Old 11-09-2014, 08:27 PM   #10
Realgib3's Avatar
Posts: 2,443   (View Stats)
How did I not know you had a build thread???
sho (11-09-2014)
 Old 11-09-2014, 08:51 PM   #11
sho
sho's Avatar
I'm sneaky like that lol.
FD wheels
E48 mix
Tuned by Realgib3
 Old 11-10-2014, 08:38 AM   #12
MOCO MS3's Avatar
Posts: 644   (View Stats)
Rican Stealth Mode, Mark! Get some damn deer repellant!!!!!
 Old 11-28-2014, 11:11 AM   #13
sho
sho's Avatar
Update time:
- Got the lower DP and oil lines from @Realgib3;
-Got an EBCS from @HawkeyeGeoff;
-5858 journal bearing came in today.
-need to pick up 3bar map and pnp harness from @pmartz16;
-waiting on a 2.5"-2.5" coupler for the turbo to hot pipe on the FMIC, and then it's ready to install on the stock block til I get the built motor done. Just need to find a free weekend to install everything.
Power will be kept down while still on the stock block, but I'm sure it'll be enough to have some fun with til the built motor is together!
Realgib3 likes this.
FD wheels
E48 mix
Tuned by Realgib3
pmartz16 (11-28-2014), Scare Dem (11-28-2014)
 Old 11-28-2014, 03:47 PM   #14
Scare Dem's Avatar
Posts: 1,505   (View Stats)
Nice build. Can't wait to see it all together.
2008 Mazdaspeed3 GT
GTX2867r
sho (11-28-2014)
 Old 11-28-2014, 07:14 PM   #15
sho
sho's Avatar
Likewise, man. I've been itching for a bit more power lately and a conservative tune in a 3/9 mix of corn should hold me over til the built motor is done.
In other news, grabbed an OCC today as well from Patrick. So the only other thing left to acquire are the oil fittings for the turbo so I can connect the lines and I'm ready to go. Just need to find a free weekend between school and work.
FD wheels
E48 mix
Tuned by Realgib3
pmartz16 (11-28-2014), Realgib3 (11-28-2014)
 Old 12-14-2014, 05:32 PM   #16
sho
sho's Avatar
Valves cleaned, cp-e safe seals,OCC , New Valve cover , freshly painted IM, PTE 5858, cp-e exhaust mani, precision 46mm ewg, Kozmic screamer pipe, Kozmic primary egr delete, secondary o2 sensor delete, 3 bar map sensor, and hawkeyegeoff 3port EBCS all installed this weekend.
Thanks to @pmartz16; , @Etipp98; , and @DVM17; for everything!
FD wheels
E48 mix
Tuned by Realgib3
The Following 5 Users Say Thank You to sho For This Useful Post:
Chef_A2 (12-15-2014), DVM17 (12-16-2014), Etipp98 (12-14-2014), pmartz16 (12-14-2014), Scare Dem (12-14-2014)
 Old 12-14-2014, 06:27 PM   #17
djones128's Avatar
Posts: 122   (View Stats)
djones128 has a reputation beyond reputedjones128 has a reputation beyond reputedjones128 has a reputation beyond reputedjones128 has a reputation beyond reputedjones128 has a reputation beyond reputedjones128 has a reputation beyond reputedjones128 has a reputation beyond reputedjones128 has a reputation beyond reputedjones128 has a reputation beyond reputedjones128 has a reputation beyond reputedjones128 has a reputation beyond repute
Groaned at 3 Times in 1 Post
Nice man!
djones128 is offline   Reply With Quote
The Following User Says Thank You to djones128 For This Useful Post:
sho (02-17-2015)
 Old 12-16-2014, 04:33 PM   #18
keychain12's Avatar
Posts: 239   (View Stats)
keychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the world
Side note: How's your car ride with the H&R coilovers? I also have them, but with 18x8.5 on 225/40.
Just seeing how your set up feels for you?
ATP GTX2867r | CP-e 3" catted TBE | HTP 3.0" Full inlet & intake | CX Racing piping w/ Treadstone TR8 FMI | HPFP | EGR Delete | Grimmspeed EBC | Forge V2 BPV | Thermal Intake Gasket | NGK Plugs | 3.0 bar Map | Devils Own WMI w/ d07 Nozzle | Cobb AP
Dynojet Dyno:
92 pump gas tune: 326whp & 320tq
24psi tune w/ WMI: 349whp & 351tq
26psi tune w/ WMI: 360whp & 364tq
XXR 531 18x8.5 [+35mm] | Dunlop Sport 225/40 | Cobb Springs | JBR Rear camber arms | JBR 80 RMM | Hotchkis front & rear SB| SS brake lines | Corksport CC | MSD Dashhawk |Custom Stealth Sub Box by user: JTMS3
keychain12 is offline   Reply With Quote
 Old 12-17-2014, 10:39 AM   #19
sho
sho's Avatar
With the hotchkis sway bars, the ride can be a bit harsh...otherwise good. I wish i wouldve got coilovers with adjustable damping though.
FD wheels
E48 mix
Tuned by Realgib3
 Old 12-22-2014, 09:07 PM   #20
sho
sho's Avatar
Absolutely LOVE the way the engine bay turned out! Thanks again to Evan #1 for hooking me up with the wrinkle black valve cover, and to Patrick for doing the previously ugly white intake manifold in wrinkle black as well.
Don't mind the dirty battery/tray, intake, and random walnut media all over. It shall be cleaned and detailed after winter ends.
pmartz16 and DVM17 like this.
FD wheels
E48 mix
Tuned by Realgib3
Boostman07 (12-23-2014), DVM17 (12-22-2014), keychain12 (12-22-2014), pmartz16 (12-22-2014), Realgib3 (12-23-2014)
 Old 12-30-2014, 12:09 PM   #21
sho
sho's Avatar
Update time:
This setup flows incredibly well. So well in fact; that on a 9psi wastegate spring, and 0% Wastegate Duty Cycle, I am hitting 24psi. So standard hybrid tuning is out the window, and @Realgib3; is going to have to control boost with the throttle plate and load tuning. I feel bad that it's gonna be a pain in the ass the tune, so I'll be supplying Mark with substantial quantities of craft beer to keep him sane!
FD wheels
E48 mix
Tuned by Realgib3
ItsNox (01-01-2015), Micha (01-21-2015)
 Old 01-09-2015, 06:36 PM   #22
sho
sho's Avatar
90% sure the issue is the wastegate at this point. Should be able confirm soon, as I'm picking up my friends pw46 from him tomorrow to test on my car; which should do the trick now that I have a working EBCS.
In anticipation of the WG being the culprit, I've ordered a new diaphragm/piston assembly from PTE for my Pw46 tonight.
I'll be rebuilding that sucker as soon as it comes in and the issue is confirmed. Then it's time to make a lil powa!
FD wheels
E48 mix
Tuned by Realgib3
Micha (01-21-2015), Realgib3 (01-11-2015)
 Old 01-15-2015, 02:06 PM   #23
sho
sho's Avatar
Moar Update:
Borrowed Jake's EWG and that solved the crazy overboost issue. Got my replacement Diaphragm and Valve assembly from PTE yesterday, and will be rebuilding it tonight after class.
Also now that the EWG thats on the car is working, got a new map from @Realgib3; yesterday and took a log on the way to class today. the car is doing what he's telling to do for once, so that's a relief.
Here's a vdyno to show what the car is making on very conservative timing and low boost until higher RPM. Can't wait til she's dialed in!
FD wheels
E48 mix
Tuned by Realgib3
Micha (01-21-2015), pmartz16 (01-15-2015), Realgib3 (01-16-2015)
 Old 01-20-2015, 09:33 PM   #24
sho
sho's Avatar
Some sexy curves for a motor that turned 130k miles this evening
FD wheels
E48 mix
Tuned by Realgib3
Micha (01-21-2015), pmartz16 (01-20-2015), TJM216 (01-21-2015)
 Old 01-21-2015, 05:27 AM   #25
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
Looking like a healthy motor for such low boost and timing! Turn it up!
The Following 3 Users Say Thank You to Etipp98 For This Useful Post:
Micha (01-21-2015), pmartz16 (01-21-2015), sho (01-21-2015)
 Old 01-21-2015, 06:42 AM   #26
My decals add horsepower
TJM216's Avatar
Posts: 72   (View Stats)
TJM216 has much to be proud ofTJM216 has much to be proud ofTJM216 has much to be proud ofTJM216 has much to be proud ofTJM216 has much to be proud ofTJM216 has much to be proud ofTJM216 has much to be proud ofTJM216 has much to be proud of
Looks good Sho!
2008.5 Mazdaspeed 3 Built Block
Power
Cobb APv3, CPE HPFP, Cobb Intake, JBR FMIC with TR8, JBR Shifter, JBR Passenger & Transmission Mounts, CPE Stage2 RMM, Turboxs Downpipe, CNT Exhaust, EGR Delete, JBR TIGS/Coolant Bypass, JBR OCC
BT build coming soon!
Mark Gibson Tune (in progress)
TJM216 is offline   Reply With Quote
The Following User Says Thank You to TJM216 For This Useful Post:
sho (01-21-2015)
 Old 01-21-2015, 07:41 AM   #27
sho
sho's Avatar
I'll leave that up to Mark, lol. Although I don't have the fuel for more boost up top
FD wheels
E48 mix
Tuned by Realgib3
 Old 01-25-2015, 12:51 PM   #28
sho
sho's Avatar
Same stretch of road as last time, although I was in the other lane and have a slightly bent wheel that may contribute to the bumpiness
FD wheels
E48 mix
Tuned by Realgib3
pmartz16 (01-26-2015), Realgib3 (01-26-2015)
 Old 02-14-2015, 02:33 PM   #29
sho
sho's Avatar
For Valentine's day and my birthday, I got myself moar parts. 1950psi Rail relief valve, mazdaspeed coilovers, and whiteline adjustable front & rear endlinks are on their way!
FD wheels
E48 mix
Tuned by Realgib3
The Following User Says Thank You to sho For This Useful Post:
pmartz16 (02-16-2015)
 Old 02-19-2015, 07:07 PM   #30
sho
sho's Avatar
Wooo!
FD wheels
E48 mix
Tuned by Realgib3
pmartz16 (02-19-2015)
 Old 02-23-2015, 08:57 AM   #31
sho
sho's Avatar
New Coilovers and Endlinks went in on Friday, thanks to @pmartz16; for the help. Car rides awesome, just need to lower the front a little bit more.
Next up is the 1950RV and a little touching up of the tune with @Realgib3;
Then... I'm done for a while til I can get another motor to build
Realgib3 and pmartz16 like this.
FD wheels
E48 mix
Tuned by Realgib3
pmartz16 (02-23-2015)
 Old 02-25-2015, 09:30 PM   #32
sho
sho's Avatar
That EWG
http://www.youtube.com/watch?feature...so&app=desktop
FD wheels
E48 mix
Tuned by Realgib3
pmartz16 (02-26-2015)
 Old 03-16-2015, 08:16 AM   #33
sho
sho's Avatar
A lil 3rd thru 5th WOT
FD wheels
E48 mix
Tuned by Realgib3
The Following 9 Users Say Thank You to sho For This Useful Post:
CMajor (07-21-2015), ItsNox (03-20-2015), Jeremy M (03-16-2015), Last_Loser (04-06-2015), pmartz16 (03-16-2015), Realgib3 (03-16-2015), Scare Dem (03-16-2015), SpeedRebirth (03-16-2015), sxman (06-03-2015)
 Old 03-19-2015, 09:22 AM   #34
sho
sho's Avatar
RPF1's, new tires, new passenger rear camber arm, extended wheel studs, open end lugnuts, and a few other goodies ordered!
FD wheels
E48 mix
Tuned by Realgib3
Realgib3 (03-20-2015)
 Old 03-23-2015, 09:32 AM   #35
sho
sho's Avatar
New wheels and stuff!
FD wheels
E48 mix
Tuned by Realgib3
The Following 4 Users Say Thank You to sho For This Useful Post:
Last_Loser (04-06-2015), MOCO MS3 (03-23-2015), pmartz16 (03-23-2015), TJM216 (03-23-2015)
 Old 03-23-2015, 02:56 PM   #36
MOCO MS3's Avatar
Nice, clean look.....
The Following User Says Thank You to MOCO MS3 For This Useful Post:
sho (03-23-2015)
 Old 04-06-2015, 01:50 PM   #37
sho
sho's Avatar
Soooo, the car was supposed to be on the dyno at 8am this morning. Last night while finishing up the tune with @Realgib3; on the street, I got this (had to let off early because of traffic)
Then as I came back to take a log in the same spot, the 6 puck decided that the 48k rough miles I put on it was enough and this happened
Now it just slips any time I go WOT.
So tomorrow, I'll be putting another clutch in with some help from Mark. overnighted a new throw out bearing and picked up some MT90 from summit racing.
All I can say, is thank goodness it didn't happen on the way down to or at ENM
FD wheels
E48 mix
Tuned by Realgib3
The Following User Says NO Thank You to sho For This Un-useful Post:
Realgib3 (04-06-2015)
 Old 04-13-2015, 11:37 PM   #38
sho
sho's Avatar
Pulled the 6 puck on Sunday. The clutch itself still had life on it after 50k or so miles, which surprised me. The throw out bearing and the pressure plate were toast however. Back to a stock clutch setup as this motor will never see enough tq to warrant another 6 puck (or similar), and I have no plans to run slicks or anything.
FD wheels
E48 mix
Tuned by Realgib3
pmartz16 (04-13-2015), Realgib3 (04-14-2015)
 Old 04-29-2015, 11:59 AM   #39
sho
sho's Avatar
Some pics from epic nator meet at the tail of the Dragon
Creepin om Patrick through a curve
Lookout point on the skyway
FD wheels
E48 mix
Tuned by Realgib3
CWP_MS3 (01-25-2017), pmartz16 (04-29-2015), Realgib3 (04-29-2015)
 Old 04-29-2015, 01:45 PM   #40
davebigenz1's Avatar
Posts: 17   (View Stats)
davebigenz1 is a jewel in the roughdavebigenz1 is a jewel in the roughdavebigenz1 is a jewel in the rough
Sweet ride man! This is an inspirational thread to say the least.
I do have a question: did you ever get your gauges working again? I know that in the earlier post you stated that you removed the sammich plate. Only reason why I ask is because I am looking to get a plate and I don't know if I should buy glowshift or prosport?
davebigenz1 is offline   Reply With Quote
The Following User Says Thank You to davebigenz1 For This Useful Post:
sho (04-29-2015)
Why would I not want a K04 for my project? sac02 Mazdaspeed3/6 General Discussion 52 09-09-2014 02:28 PM
Project 11s 2XS (From OZ) MazdaSpeed 3 - Engine, Transmission & Driveline 33 07-27-2010 04:05 AM
Page generated in 0.67875 seconds with 32 queries
