| 2010 MS3 - Build Diaries Genpu - General Build Threads/Diaries. |
![]() Join Date: May 2011 Location: knoxville, TN
Rep Power: 1703 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,468
(Thread Starter) | Not Ranked : 0 score for starters. ive been on a 3071 for about a year and a half. no issues...just want more. that thread can be viewed here. Currently 56k on the clock and 190psi across the board. car has been a trooper on my 3071. 865ms3's GT3071R Ive been sitting on a block for a couple years and picked up some molnar rods a year or two ago for a good price.after talking with @phate; about these...i finally felt comfortable to throw them in. follow up that by a good deal on an exhaust manifold and a local doing a build...pushed me over the edge. want to go ahead and thank the people that have helped me with all my dumb and repetitive questions along the way. my NATOR guys. @bcmurphy87; @BigBoostMS3; @Macedawg; . Also, @Justin@Freektune; . dude is always there for me and ALL of nator tn/ky anytime we need anything. Waiting on a shipment of parts from @EdgeAutosport.com; and @Justin@Freektune; and ill have everything i need. block needs assembled and im shooting for a install the weekend of june 20th. car is "fully bolted" already so some mods are already taken care of. tr8 intercooler, ACT 6 puck, etc etc. Engine: Manley pistons molnar rods L19 Head studs balanced rotating assembly clevite main and rod bearings oem main studs stock valvetrain some minor bowl work, 5 angle valve job pretty basic stuff valves have already been set and all buckets spec out thanks to help from @BigBoostMS3; Parts: John russell t3 stock location tubular exhaust manifold PTE JB 5858 T3/Vband .82 A/R PTE 46mm EWG FJ Performance Vband downpipe Kozmic dump tube (hope it fits) Kozmic oil feed line HTP under route intercooler piping JMF V1 Intake Manifold Corksport injector seals Freektune Wideband Failsafe Aem oil pressure gauge Damond oil pressure switch kit JBR BSD plug and oil pan baffle (im sure im missing a lot will update) Fuel: devils own progressive meth (pre throttle body) cm14 nozzle. more if needed edit: running a cm14+d07 nozzle now again, using Freektune AFR failsafe Goals: Hope to have a car thats still fun to drive and does not loose too much spool to the 3071. i do a lot of trips to the dragon and dont want to kill that setup. i want to do a standard 93 tune, 93+Meth street tune to what i feel is "street-able", then go all out on the dyno tune. of course using @Justin@Freektune; again. will also be buying a daily driver lol. looking for a 4 runner currently. once again. ill be update this post. just wanted to get going on it. Added pics of a weak mock up attempt before a local's swap. didnt have a vband clamp for the DP so it was really a lost cause. pic of wall of parts (better soon)
__________________ Brent Mazda Dragon Camp - Event Coordinator -Built Block-5858-Meth Dragon Slayer Setup FreekTuned ![]() Last edited by 865ms3; 08-10-2015 at 10:43 AM. Reason: meth nozzle addition |
| The Following 15 Users Say Thank You to 865ms3 For This Useful Post: | BigBoostMS3 (05-25-2015), cshunter (05-25-2015), Easter Bunny (05-26-2015), h.h.sk1nny (05-25-2015), Hush (05-25-2015), ItsNox (05-28-2015), JgamB (05-25-2015), Justin@Freektune (05-27-2015), Macedawg (05-25-2015), NCspecV81 (05-26-2015), phate (05-26-2015), s1xstringmayhem (05-25-2015), SpeedRebirth (05-26-2015), Vader (05-26-2015), WetzMS3 (06-08-2015) |
![]() Join Date: Jul 2011 Location: Knoxville TN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 642
| Not Ranked : 0 score Is it June yet. Geez
__________________ Ferg: ive been inside so many deep dark loose holes even ron jeremy would be impressed. |
| The Following User Says Thank You to Macedawg For This Useful Post: | 865ms3 (05-25-2015) |
![]() Join Date: Dec 2011 Location: Brooks, KY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,568
| Not Ranked : 0 score In as always I would also like to take claim to the local build that pushed you over the edge!
__________________ Scott Mazda Dragon Camp - Event Coordinator // PTE 5858 // FREEKbuilt & tuned \\ M-1 Meth\\ www.TorqueSteerStickers.com Last edited by BigBoostMS3; 05-25-2015 at 07:26 PM. Reason: MSF Database - Automerged Doublepost |
| The Following 2 Users Say Thank You to BigBoostMS3 For This Useful Post: | 865ms3 (05-25-2015), s1xstringmayhem (05-25-2015) |
![]() Join Date: Jan 2013 Location: South Boston, MA
Rep Power: 1402 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,475
| Not Ranked : 0 score I need to update my thread...maybe when the new 5858 comes in and I give a fuck again..lol Subbed for the gheys doe
__________________ 07 BLACK MICA MS3 PATTY/JEFF BUILT MOTOR BNRS3V2 349/344 VD 93 FREEKTUNE E25 382/375 GSD DynoJet 141020 STOCK BLOCK FREEK KORN TUNE 335whp/356wtq ENM 14 K04 ~ Ordnance, Droppn' Warheads of Foreheads Since 1922 ~ BOSTON STRONG |
| The Following User Says Thank You to King Scumbag For This Useful Post: | 865ms3 (05-25-2015) |
![]() Join Date: Apr 2011 Location: Oviedo, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 499
| Not Ranked : 0 score I just came! Build looks fuckin awesome Brent.
__________________ Stock. |
| The Following User Says Thank You to s1xstringmayhem For This Useful Post: | 865ms3 (05-25-2015) |
![]() Join Date: Nov 2011 Location: Caldwell, ID
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,042
| Not Ranked : 0 score @865ms3; great turbo choice man. Think rips and spools fast. Looks like you have a solid setup.
__________________ Old stuff: Stock k04 12.301 @ 113.20 New Stuff: PTE 5858 and Built, not bought, by ME ![]() |
| The Following User Says Thank You to h.h.sk1nny For This Useful Post: | 865ms3 (05-26-2015) |
![]() Join Date: Jun 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 242
| Not Ranked : 0 score Nice set up, nothing over exotic as Freek has proven, it isn't needed to go fast and stay together.
__________________ Gen 2 2012 - Precision 6062 Turbo - CPE Exhaust Mani - PTE 46mm EWG - 2NV Industries built Forged bottom end - PNP Head - JMF V2 Intake Mani- Custom DP UR Cat Back - HTP 4 inch intake - TR8 FMIC - Custom FREEKTUNE METH Port Injection - Cobb 3 port EBC- Autotech internals - FREEKTUNED. |
| The Following User Says Thank You to shaneski For This Useful Post: | 865ms3 (05-26-2015) |
(Thread Starter) | Not Ranked : 0 score not out to break records. id like to hit 500ish easily. i know this setup can do ~6....so we will see what happens. honestly im fine with my car right now making 400/388 so anything above that is a plus.
__________________ Brent Mazda Dragon Camp - Event Coordinator -Built Block-5858-Meth Dragon Slayer Setup FreekTuned ![]() |
| Not Ranked : 0 score All that work and it'll still be slow around corners ![]() Good luck with it. It's a fun project, for sure.
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. |
| The Following 4 Users Say Thank You to phate For This Useful Post: |
![]() Join Date: Feb 2010 Location: NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,089
| Not Ranked : 0 score JB turbos blow up in NC when pushed hard ask @King Scumbag; personally invest in the BB. |
| The Following User Says Thank You to dagrimey1 For This Useful Post: | 865ms3 (05-26-2015) |
__________________ 07 BLACK MICA MS3 PATTY/JEFF BUILT MOTOR BNRS3V2 349/344 VD 93 FREEKTUNE E25 382/375 GSD DynoJet 141020 STOCK BLOCK FREEK KORN TUNE 335whp/356wtq ENM 14 K04 ~ Ordnance, Droppn' Warheads of Foreheads Since 1922 ~ BOSTON STRONG | |
| The Following User Says Thank You to King Scumbag For This Useful Post: | 865ms3 (05-26-2015) |
(Thread Starter) | Not Ranked : 0 score @bcmurphy87; has been beating on his jb 5862 @40 psi for months. Still going strong. If there is an issue I'll upgrade. Pat's could have been a fluke...or common occurrence. Hopefully just a fluke.
__________________ Brent Mazda Dragon Camp - Event Coordinator -Built Block-5858-Meth Dragon Slayer Setup FreekTuned ![]() Last edited by 865ms3; 05-26-2015 at 08:28 PM. |
| The Following User Says Thank You to 865ms3 For This Useful Post: | King Scumbag (05-26-2015) |
![]() Join Date: Mar 2014 Location: Manhattan
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8
| Not Ranked : 0 score Just out of curiosity, what made you go with a JB over a BB? Obviously the BB costs more but I think I'd appreciate the reliability of ball bearings.
__________________ Still waiting on the mods to start putting themselves on ![]() ![]() 2010 Mazdaspeed 3 Stock IG: nicbledsoe62 |
(Thread Starter) | Not Ranked : 0 score Failures can happen with anything. I've seen a jb precision at 40 psi for about 6 months with no issues. Decided to save some money.
| The Following User Says Thank You to 865ms3 For This Useful Post: | nicb (05-27-2015) |
(Thread Starter) | Not Ranked : 0 score got this from the wife yesterday afternoon. pretty cool to have someone that is supportive.
(Thread Starter) | Not Ranked : 0 score Moving my meth tank from the trunk to the fender well.I don't want 100% in the car. Received this today. ForumRunner_20150528_204310.png Trying to make a remote fill setup. May mess with it tomorrow after work.
| The Following User Says Thank You to 865ms3 For This Useful Post: | dan7225 (05-29-2015) |
| The Following 2 Users Say Thank You to 865ms3 For This Useful Post: | NCspecV81 (05-28-2015), s1xstringmayhem (06-06-2015) |
![]() Join Date: Apr 2013 Location: Wilkesboro, North Carolina
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,221
| Not Ranked : 0 score Be sure to put a small hole in your lid. It helps pump reliablity.
__________________ 2013 CWP and Stock |
| The Following User Says Thank You to NCspecV81 For This Useful Post: | 865ms3 (05-28-2015) |
(Thread Starter) | Not Ranked : 0 score Cap is vented and the cap on the tank is vented as well. I hope that's enough. Thanks though! Using -10 braided line from fill to the tank. I'm going to tap the top of the tank with a 5/8 barb fitting. Going to make a bracket for pump and tank...as well as two occs. I MAY have enough room lol.
| The Following 3 Users Say Thank You to King Scumbag For This Useful Post: |
Sealed can between Pcv plate and intake manifold(how I run it now).I'm adding two -10 bungs welded on valve cover. They will go to a vented can. If no room for the can.....the ground.
__________________ Brent Mazda Dragon Camp - Event Coordinator -Built Block-5858-Meth Dragon Slayer Setup FreekTuned ![]() | |
| The Following 4 Users Say Thank You to 865ms3 For This Useful Post: | cshunter (05-29-2015), Justin@Freektune (05-29-2015), Putin 2.3T (05-28-2015), s1xstringmayhem (06-06-2015) |
![]() Join Date: Sep 2013 Location: Tacoma, WA
Rep Power: 581 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 382
| Not Ranked : 0 score Good plan. What I would do instead of using the intake manifold is use the intake for the PCV plate. -12an, catch-can, intake. No worries.
__________________ 2011 Mazdaspeed 3 [Sold] 2013 Ford F-150 XLT 3.5 Ecoboost |
| The Following User Says Thank You to Putin 2.3T For This Useful Post: | 865ms3 (05-29-2015) |
| Not Ranked : 0 score I'm a venturi guy. Feed it to the exhaust. No use having that nasty blowby going back into the intake anywhere. Best to have it go out the exhaust where no fucks are given how nasty it is.
| The Following 4 Users Say Thank You to NCspecV81 For This Useful Post: |
![]() | | #24 | ![]() |
| Not Ranked : 0 score A good oil catch can will catch the blow-by.
| The Following User Says Thank You to Putin 2.3T For This Useful Post: | King Scumbag (05-29-2015) |
![]() | | #25 | ![]() |
| Not Ranked : 0 score A catch can is actually just a bandaid to a design OEM's had to improvise due to emissions. Venturi is the far superior and cheaper setup. If it were not for the EPA and emissions OEM's would also do venturi systems for PCV excavation. If you aren't running any cats venturi is going to be the better route. I plan on doing the same. Did I also mention a venturi design is cheaper?
![]() | | #26 | ![]() |
(Thread Starter) | Not Ranked : 0 score Fender mount remote fill setup...done. Local nator Friday night project. I need to clean up the brackets for the remote fill...but it's in. ForumRunner_20150529_231529.png ForumRunner_20150529_231540.png ForumRunner_20150529_231551.png ForumRunner_20150529_231603.png ForumRunner_20150529_231613.png
| The Following 5 Users Say Thank You to 865ms3 For This Useful Post: | cshunter (05-30-2015), JgamB (06-03-2015), Micha (06-02-2015), NCspecV81 (05-29-2015), s1xstringmayhem (06-06-2015) |
![]() | | #27 | ![]() |
(Thread Starter) | Not Ranked : 0 score ^ solves the catch can debate btw. there is no room for another can now. the valve cover breathers are going VTA below the splash shield. also after giving this some thought today. i may go back to trunk mount, but use a fuel cell. a plastic jug in the front fender will bust in a fender bender. right now im just running 49/51 meth (was already tuned on E just wanted to test meth setup) so not a big deal. but when going 100% may not be the brightest idea. thinking about picking this up. i like how the pump mounts, etc. im open to suggestions. id like to run an external vent out of the car and the lines will go out of the hatch and under the car. http://www.alcoholinjectionsystems.c...duct_info.html to this point EVERYTHING has been purchased for the build and is in route. except finalizing the meth setup. shooting for a install of june 20th...but looking like it may be sooner
__________________ Brent Mazda Dragon Camp - Event Coordinator -Built Block-5858-Meth Dragon Slayer Setup FreekTuned ![]() Last edited by 865ms3; 05-30-2015 at 04:12 PM. |
![]() | | #28 | ![]() |
(Thread Starter) | Not Ranked : 0 score The eagle has landed. Everything to assemble the engine showed up today. Thanks to @EdgeAutosport.com; and @Justin@Freektune; ForumRunner_20150601_183907.png
| The Following 2 Users Say Thank You to 865ms3 For This Useful Post: | King Scumbag (06-01-2015), Micha (06-02-2015) |
![]() | | #29 | ![]() |
| The Following User Says Thank You to King Scumbag For This Useful Post: | Micha (06-02-2015) |
![]() | | #30 | ![]() |
(Thread Starter) | Not Ranked : 0 score Got bored tonight. Got the head on and l19s torqued. Oil pump in, jbr oil pan baffle,oil pump,water pump,thermostat housing. Went to do the cams and realized I left my good in lb tq wrench at work. Will finish up tomorrow ForumRunner_20150602_202558.png ForumRunner_20150602_202628.png
![]() | | #31 | ![]() |
(Thread Starter) | Not Ranked : 0 score Hope I know what I'm doing! Engine assembled. ForumRunner_20150603_203739.png ForumRunner_20150603_203615.png ForumRunner_20150603_203625.png
| The Following 5 Users Say Thank You to 865ms3 For This Useful Post: | BigBoostMS3 (06-03-2015), Easter Bunny (06-09-2015), Hammology (06-26-2015), JgamB (06-03-2015), phate (06-04-2015) |
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score Test fitting. Waiting on my dump tube and oil feed. Have to remove one of the manifold studs or cut it down. Its hitting my compressor housing. ForumRunner_20150604_174459.png ForumRunner_20150604_174508.png ForumRunner_20150604_174518.png
__________________ Brent Mazda Dragon Camp - Event Coordinator -Built Block-5858-Meth Dragon Slayer Setup FreekTuned ![]() Last edited by 865ms3; 06-04-2015 at 04:31 PM. |
![]() | | #33 | ![]() |
![]() Join Date: Jul 2013 Location: Canberra, AUSTRALIA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 187
| Not Ranked : 0 score Subbed! Gonna be a weapon...ill be running a similar setup. just ordered my JRD mani...will also be going 5858, tr8 and htp piping, jmf v1 but on stock block for now. Keen for results....good luck with the rest of the build! Tapatorque steering
__________________ 2006 True Red 3 MPS - Top Mounted 5858 in progress |
| The Following User Says Thank You to TRBLSM For This Useful Post: | 865ms3 (06-07-2015) |
![]() | | #34 | ![]() |
(Thread Starter) | Not Ranked : 0 score off work friday 6/19. got the nator tn/ky A team coming in for reinforcement thrusday night/friday morning. starting to get excited. still to do.... waiting on my JMF (this wont delay me) finish mock up when i get dump and oil feed weld a bung to my downpipe figure out if i want to cap coolant line to turbo...or replace the hole line to remove the hard pipe im installing all my gauge's/failsafe setup this weekend along with my new meth setup with the help of @SpeedyTater; id say @BigBoostMS3; will be there too. im going to order some 90* fittings for the two EBCS setups and the boost switch. plan to mount them on the firewall behind the battery tray...hopefully making it clean.
| The Following User Says Thank You to 865ms3 For This Useful Post: | BigBoostMS3 (06-08-2015) |
![]() | | #35 | ![]() |
| Not Ranked : 0 score Engine hoist will be delivered to your house Saturday... Then we just need one good circle jerk and we'll get this stuff in there! Remember to throw the axle half shaft on the block to test clearance on that as well! I had to adjust my dump tube once I had it on mine. Thankfully it was on a stand at that point lol.
__________________ Scott Mazda Dragon Camp - Event Coordinator // PTE 5858 // FREEKbuilt & tuned \\ M-1 Meth\\ www.TorqueSteerStickers.com Last edited by BigBoostMS3; 06-08-2015 at 02:47 PM. Reason: MSF Database - Automerged Doublepost |
| The Following 2 Users Say Thank You to BigBoostMS3 For This Useful Post: | 865ms3 (06-08-2015), Easter Bunny (06-09-2015) |
![]() | | #36 | ![]() |
Then the weekend of your swap all the wimminz are going on a nator girls weekend, so we should all be set! But again, I'll have to keep any eye on the dogs lol.
__________________ Scott Mazda Dragon Camp - Event Coordinator // PTE 5858 // FREEKbuilt & tuned \\ M-1 Meth\\ www.TorqueSteerStickers.com | |
| The Following User Says Thank You to BigBoostMS3 For This Useful Post: | 865ms3 (06-08-2015) |
![]() | | #37 | ![]() |
(Thread Starter) | Not Ranked : 0 score Meth tank here...along with dump tube and oil feed ForumRunner_20150609_180953.png ForumRunner_20150609_181005.png
| The Following 2 Users Say Thank You to 865ms3 For This Useful Post: | BigBoostMS3 (06-09-2015), Hammology (06-26-2015) |
![]() | | #38 | ![]() |
| The Following 2 Users Say Thank You to 865ms3 For This Useful Post: | BigBoostMS3 (06-09-2015), TRBLSM (06-09-2015) |
![]() | | #39 | ![]() |
![]() Join Date: Nov 2008 Location: Irving, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,506
| Not Ranked : 0 score looking great. which cold pipe are you using?
__________________ 2008.5 Crystal White Pearl MS3 A lot of mods Check out my big turbo build! |
![]() | | #40 | ![]() |
(Thread Starter) | Not Ranked : 0 score Htp Edit....cold pipe...durrrr Keeping the pipes I have off my cx racing kit. They work and won't cost more $.
| 865ms3's GT3071R | 865ms3 | 2010 MS3 - Big Turbo Builds | 133 | 06-05-2015 07:48 AM |
| Pte 5858 build | STiKiLLa | MazdaSpeed 3/6 - Big Turbo Builds | 74 | 03-13-2015 06:12 AM |
| Frankie's ghey pte 5858 build | ms3driver213 | 2010 MS3 - Big Turbo Builds | 17 | 04-18-2014 08:11 AM |
| PTE 5858 BT build!! | katoom17 | MazdaSpeed 3/6 - Big Turbo Builds | 3 | 02-22-2014 02:48 PM |
| 865ms3 E85 FreekTune | 865ms3 | 2010 MS3 - Dyno Sheets/Discussions | 43 | 06-01-2012 09:35 AM |
