> 2010 MS3 - Build Diaries
Like Tree83Likes
 Old 06-11-2015, 02:33 AM   #41
coasttime's Avatar
Posts: 163   (View Stats)
coasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond repute
Groaned at 19 Times in 8 Posts
Keep the build info coming. Your moving right along. She looks pretty. Are you going to upgrade your intake too? That just stood out in the pics to me. What Intercooler are you running, you might of already said just skimmed over your thread. Good luck with the build.
coasttime is offline   Reply With Quote
 Old 06-11-2015, 05:03 AM   #42
865ms3's Avatar
Posts: 2,602   (View Stats)
Why would the intake need need upgraded? Its a 3.5. Won't max that out.
Tr8 intercooler.
Brent
-Built Block-5858-Meth
Dragon Slayer Setup
FreekTuned
 Old 06-11-2015, 09:55 AM   #43
cshunter's Avatar
Posts: 1,312   (View Stats)
but that girth on the 4 inch tho...
2013 CWP That's slow
Previous: MILTUNED E85 K04
The Following 2 Users Say Thank You to cshunter For This Useful Post:
865ms3 (06-11-2015), Easter Bunny (06-17-2015)
 Old 06-12-2015, 01:04 AM   #44
coasttime's Avatar
Tr8 intercooler.
O shit I did not know it was 3.5 inch. LOL nice build.
865ms3 likes this.
The Following User Says Thank You to coasttime For This Useful Post:
 Old 06-17-2015, 10:12 AM   #45
865ms3's Avatar
Swap starts tomorrow evening. will finish up hopefully friday. worst case early saturday. have the beast team coming in from Nator TN/KY.
Meth tank/lines are in....failsafe/gauges done. Having a hard time finding a bov that will work with my failsafe. Tial won't work...but the oem one does. More testing on that and pics tonight..
Brent
Dragon Slayer Setup
FreekTuned
BigBoostMS3 (06-17-2015), Easter Bunny (06-17-2015)
 Old 06-17-2015, 05:15 PM   #46
NCspecV81's Avatar
Posts: 2,867   (View Stats)
@Lakespeed6; how did you wire your relay so that the ewg opens and not the bov?
2013 CWP and Stock
865ms3 (06-17-2015), Lakespeed6 (06-18-2015)
 Old 06-18-2015, 05:47 AM   #47
865ms3's Avatar
d day!
I get off work at 5pm. Plan to start tear down shortly after. Pics and go pro time lapse will be done.
Brent
Dragon Slayer Setup
FreekTuned
ItsNox (06-18-2015)
 Old 06-18-2015, 08:23 AM   #48
Lakespeed6's Avatar
Posts: 2,403   (View Stats)
EBCS is a normally open circuit, so +voltage to the EBCS holds it closed allowing more boost.
I used Bosch 0 332 209 203 because I was not 100% positive on the above so I have a SPDT Relay.
A SPST NC relay would work as well
I cut one of the wires going to the EBCS.
Attach 1 end to 87a and the other to 30.
Leave 87 open.
Attach 86 to a ign +12V.
Attach 85 to the failsafe trigger ground.
24 Volt DC 20 Amp Continuous Duty Relay Bosch Relay 0 332 209 203
Hope that help
1990 Nissan Skyline GTR
1991 White BMW 325ic
The Following 4 Users Say Thank You to Lakespeed6 For This Useful Post:
BigBoostMS3 (06-20-2015), Easter Bunny (06-18-2015), ItsNox (06-18-2015), NCspecV81 (06-18-2015)
 Old 06-18-2015, 09:37 AM   #49
865ms3's Avatar
Leave 87 open.
Hope that help
this is what i did wrong. i added a splice in this line. ran it to 87a...made a seperate ground for the relay.. bet that was my issue. i was getting a low wastegate solenoid code.
i never claimed to be an electrical engineer.....or even NOT an idiot lol.
thanks guys!
@Lakespeed6;
did you cut one of the wires on the car side of the harness? (one 12v 1 ground) or the EBCS side (both have 12v on them)
Brent
Dragon Slayer Setup
FreekTuned
ItsNox (06-18-2015), Lakespeed6 (06-18-2015)
 Old 06-18-2015, 10:17 AM   #50
Lakespeed6's Avatar
thanks guys!
@Lakespeed6;
I cut on the EBCS side but it shouldn't matter it's just completing a circuit.
FYI when the failsafe triggers it will throw a code for low wastegate solenoid since in theory you are creating an open in the circuit.
It should only throw the code though when it triggers.
I was dicking around and wanted to test it a couple weeks ago by hitting the trigger off my laptop.
Cracking wastegates back to spring pressure ~375HP felt like hitting a wall.
Good luck let me know if you have any other questions.
 Old 06-18-2015, 10:21 AM   #51
865ms3's Avatar
yea i had a buddy testing it using a MAC valve the other day. wouldnt work with my tial bc of flow....but the stock BPV works fine. i went to boost and hit cut all of it....was weird.
wastegate control is my solution to keep my tial valve.
thanks for the help man.
Brent
Dragon Slayer Setup
FreekTuned
 Old 06-18-2015, 10:25 AM   #52
Lakespeed6's Avatar
Strange that it didn't work with the tial. Preload on BPV too high?
I like the idea of it opening WG so the turbo isn't trying to spool harder to hit boost with the BPV open if the failsafe hits.
The Following User Says Thank You to Lakespeed6 For This Useful Post:
BigBoostMS3 (06-18-2015)
 Old 06-18-2015, 10:28 AM   #53
865ms3's Avatar
yea. the MAC valve does not flow enough for the valve to work right...even not in failsafe condition.
1/4 line straight from intake manifold...to MAC...to BOV. got flutter. failsafe wouldnt even trigger the valve. threw the stock one on and it worked fine.
i think the WG trigger will be fine. with a 15psi spring and MAYBE a little creep even...the stock fuel system should keep up. with it throwing a code is kinda cool too so you can SEE it worked also.
Brent
Dragon Slayer Setup
FreekTuned
 Old 06-18-2015, 10:33 AM   #54
Lakespeed6's Avatar
1/4 line straight from intake manifold...to MAC...to BOV. got flutter. failsafe wouldnt even trigger the valve. threw the stock on on and it worked fine.
Interesting.
I'm on 14.5psi springs on my EWGs (hitting 18psi) and was just at 104IDC but this turbo flows a ton.
You'll know when it works, trust me haha
865ms3 and smr87 like this.
 Old 06-18-2015, 11:47 AM   #55
NCspecV81's Avatar
well I will be anticipating some good results. I don't want to lose my tial either. @865ms3;
2013 CWP and Stock
865ms3 (06-18-2015), Lakespeed6 (06-18-2015)
 Old 06-18-2015, 12:07 PM   #56
BigBoostMS3's Avatar
Posts: 1,429   (View Stats)
Thank you Lakespeed... We have been trying to wrap our heads around this for a couple weeks. We've come up with plenty of solutions that should work in theory, but finding the best option has proved difficult lol.
I want to keep my HKS valve and doing it with EWG control will allow that to happen!
Scott
www.TorqueSteerStickers.com
The Following User Says Thank You to BigBoostMS3 For This Useful Post:
 Old 06-18-2015, 04:23 PM   #57
865ms3's Avatar
It works when the relay is wired correctly. Wooooooo!
Thanks guys
Lakespeed6 likes this.
Brent
Dragon Slayer Setup
FreekTuned
The Following 3 Users Say Thank You to 865ms3 For This Useful Post:
BigBoostMS3 (06-18-2015), Easter Bunny (06-24-2015), NCspecV81 (06-18-2015)
 Old 06-20-2015, 05:23 PM   #58
865ms3's Avatar
More pictures coming soon...but swap done...and maiden 20 mile voyage in the books.
Brent
Dragon Slayer Setup
FreekTuned
The Following 7 Users Say Thank You to 865ms3 For This Useful Post:
08cosmic3 (06-21-2015), BigBoostMS3 (06-20-2015), Easter Bunny (06-24-2015), NCspecV81 (06-20-2015), phate (06-20-2015), Snyeed (06-20-2015), TRBLSM (06-25-2015)
 Old 06-21-2015, 11:05 AM   #59
865ms3's Avatar
What a weekend.
Got it all swapped in and some miles on it. Down pipe is a little short ....so getting that fixed tomorrow. Had a coolant leak I hopefully fixed this morning. Time for break in miles!
i still have to change my valve cover. ive got one with 2 -10AN bungs welded to it. ill be running them to a vented can. that will be done sometime soon. MAYBE my JMF will be here sometime soon too lol. i was over it for the weekend and ready to relax.
thanks to all my local nator for the help this weekend.
@Travis; @BigBoostMS3; @bcmurphy87; @08cosmic3; @Macedawg;
you guys rock!
08cosmic3 and ItsNox like this.
Brent
Dragon Slayer Setup
FreekTuned
The Following 4 Users Say Thank You to 865ms3 For This Useful Post:
08cosmic3 (06-21-2015), BigBoostMS3 (06-22-2015), cshunter (06-21-2015), ItsNox (06-21-2015)
 Old 06-21-2015, 12:28 PM   #60
08cosmic3's Avatar
Posts: 2,920   (View Stats)
Always a good time at Headquarters in Knoxville. Wating to see the 500+ whp dyno pulls.
The Following 2 Users Say Thank You to 08cosmic3 For This Useful Post:
865ms3 (06-21-2015), BigBoostMS3 (06-22-2015)
 Old 06-21-2015, 02:51 PM   #61
senor blanco ms3's Avatar
Posts: 1,353   (View Stats)
senor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the world
Very nice!!
2008.5 Crystal White Pearl MS3
A lot of mods
Check out my big turbo build!
senor blanco ms3 is offline   Reply With Quote
The Following User Says Thank You to senor blanco ms3 For This Useful Post:
865ms3 (06-21-2015)
 Old 06-21-2015, 03:19 PM   #62
Putin 2.3T's Avatar
Posts: 1,040   (View Stats)
I approve.
Where do you guys get those small little covers teh valve cover? Pretty cool.
2011 Mazdaspeed 3 [Sold]
The Following 2 Users Say Thank You to Putin 2.3T For This Useful Post:
865ms3 (06-21-2015), ItsNox (06-22-2015)
 Old 06-21-2015, 03:31 PM   #63
865ms3's Avatar
I approve.
Rd motorsportz. Fuel pump cover and tuck harness.
Brent
Dragon Slayer Setup
FreekTuned
ItsNox (06-22-2015), Putin 2.3T (06-22-2015)
 Old 06-21-2015, 03:32 PM   #64
865ms3's Avatar
This arrived today as well....
Brent
Dragon Slayer Setup
FreekTuned
 Old 06-22-2015, 07:48 PM   #65
865ms3's Avatar
100 miles in. So far so good. Going to be doing lots of this for break in.......I want to crack the gate so bad!!
Brent
Dragon Slayer Setup
FreekTuned
The Following 5 Users Say Thank You to 865ms3 For This Useful Post:
BigBoostMS3 (06-23-2015), Easter Bunny (06-24-2015), NCspecV81 (06-22-2015), pmartz16 (06-24-2015), s1xstringmayhem (06-23-2015)
 Old 06-22-2015, 07:56 PM   #66
NCspecV81's Avatar
You shold really get on it sooner than later. Help those rings get set. I used the mototune method for my breakin. It really works.
2013 CWP and Stock
ItsNox (06-23-2015)
 Old 06-22-2015, 08:10 PM   #67
865ms3's Avatar
I'm at 100.....I've hit 15psi...on accident...this thing spools. a couple times. Good vacuum already and all seems well. May hammer on it after this oil change if I get the ok from Justin. So many different methods.....but I trust Justin's judgement
Brent
Dragon Slayer Setup
FreekTuned
Easter Bunny (06-24-2015), Justin@Freektune (06-23-2015)
 Old 06-23-2015, 04:21 PM   #68
s1xstringmayhem's Avatar
Posts: 809   (View Stats)
s1xstringmayhem is the leader of the worlds1xstringmayhem is the leader of the worlds1xstringmayhem is the leader of the worlds1xstringmayhem is the leader of the worlds1xstringmayhem is the leader of the worlds1xstringmayhem is the leader of the worlds1xstringmayhem is the leader of the worlds1xstringmayhem is the leader of the worlds1xstringmayhem is the leader of the worlds1xstringmayhem is the leader of the worlds1xstringmayhem is the leader of the world
How does this spool in relation to your 3071? Or is it still too early to tell?
Stock.
s1xstringmayhem is offline   Reply With Quote
 Old 06-23-2015, 04:28 PM   #69
ItsNox's Avatar
Posts: 3,076   (View Stats)
I'm with this guy. When it comes time I'll be doing a 'hard' break in as well.
Sent via Tapafail
'06 Mazdaspeed 6 GT
- Miltuned
Georgia Motherfucking Nator
 Old 06-23-2015, 05:23 PM   #70
865ms3's Avatar
I've stepped it up. Been cracking the wastegate today some. Just changed the oil and it looks mint. 140miles in currently.
Going to do short part gear pulls till 500 Then from 500-1k full gear pulls.
Eric kinda early to tell....but when I touch the gas.....it spools. I think there is going to be little to no difference.
This thing sounds nuts when that wastegate opens. I was afraid the downpipe fell off haha
Brent
Dragon Slayer Setup
FreekTuned
The Following 8 Users Say Thank You to 865ms3 For This Useful Post:
AwAfrican (06-24-2015), BigBoostMS3 (06-23-2015), cshunter (06-23-2015), Easter Bunny (06-24-2015), ItsNox (06-23-2015), JgamB (06-24-2015), Justin@Freektune (06-23-2015), s1xstringmayhem (06-25-2015)
 Old 06-23-2015, 10:48 PM   #71
cshunter's Avatar
Video or lies.
The Following User Says Thank You to cshunter For This Useful Post:
 Old 06-24-2015, 04:33 AM   #72
865ms3's Avatar
Originally Posted by cshunter View Post
Video or lies.
You got it
Brent
Dragon Slayer Setup
FreekTuned
AwAfrican (06-24-2015), cshunter (06-24-2015)
 Old 06-24-2015, 04:45 AM   #73
AwAfrican's Avatar
Posts: 1,038   (View Stats)
In for vids and results! Good luck
2013 Black MS3
 Old 06-24-2015, 11:50 AM   #74
865ms3's Avatar
I know this is probably way off.....but thought I was getting bad boost creep when doing part throttle pulls. 15psi spring and I was seeing 19s part throttle. Decided to do a 3rd gear pull. Just my base map so far. Also downhill a little bit.
cshunter and Justin@Freektune like this.
Brent
Dragon Slayer Setup
FreekTuned
BigBoostMS3 (06-24-2015), Easter Bunny (06-24-2015), ItsNox (06-24-2015), Justin@Freektune (06-24-2015), NCspecV81 (06-24-2015), Putin 2.3T (06-24-2015), s1xstringmayhem (06-25-2015)
 Old 06-24-2015, 12:43 PM   #75
865ms3's Avatar
@cshunter;
Bringing the go pro and selfie stick out tonight. Videos coming of slow wg pulls
cshunter likes this.
Brent
Dragon Slayer Setup
FreekTuned
 Old 06-24-2015, 01:44 PM   #76
King Scumbag's Avatar
Posts: 2,384   (View Stats)
Attachment 204360
I'm assuming you are spraying at this point too?
07 BLACK MICA MS3
PATTY/JEFF BUILT MOTOR
STOCK BLOCK
BOSTON STRONG
 Old 06-24-2015, 01:58 PM   #77
SuckSqueezBangBlow's Avatar
Posts: 266   (View Stats)
865ms3 Nice build looks like a lot of fun
The Following User Says Thank You to SuckSqueezBangBlow For This Useful Post:
865ms3 (06-24-2015)
 Old 06-24-2015, 02:05 PM   #78
865ms3's Avatar
Not a drop. Straight 93. Take that graph with a very large grain of salt. Base map...slightly downhill...etc
Brent
Dragon Slayer Setup
FreekTuned
 Old 06-24-2015, 08:34 PM   #79
Justin@Freektune's Avatar
Posts: 954   (View Stats)
Time to turn it up
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
865ms3 (06-24-2015), BigBoostMS3 (06-25-2015)
 Old 06-24-2015, 08:43 PM   #80
Meanwhile, I still wait for my head.
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
865ms3 (06-24-2015)
865ms3's GT3071R 865ms3 2010 MS3 - Big Turbo Builds 133 06-05-2015 07:48 AM
Pte 5858 build STiKiLLa MazdaSpeed 3/6 - Big Turbo Builds 74 03-13-2015 06:12 AM
Frankie's ghey pte 5858 build ms3driver213 2010 MS3 - Big Turbo Builds 17 04-18-2014 08:11 AM
PTE 5858 BT build!! katoom17 MazdaSpeed 3/6 - Big Turbo Builds 3 02-22-2014 02:48 PM
865ms3 E85 FreekTune 865ms3 2010 MS3 - Dyno Sheets/Discussions 43 06-01-2012 09:35 AM
Page generated in 0.58077 seconds with 35 queries
