> 2010 MS3 - Build Diaries
  • 1 Post By Dread1292
 Old 11-03-2016, 10:28 PM   #1
Dread1292's Avatar
Posts: 26   (View Stats)
Dread1292 has a little shameless behaviour in the past
Default Engine build help!!
I have a 2010 mazdaspeed 3 and I'm curious to what build/tune I can do to get 500+hp I am getting a new engine in with zero miles. I'll be doing new pistons and rods, bsd, and egr delete, also oil baffle. But as far as a step has anyone achieved this goal without meth or e85. I do not want to go meth or e85. Any advice is much appreciated. Also I have my list planned out I just want to know has anyone do anything similar.
Djohns likes this.
Dread1292 is offline   Reply With Quote
The Following User Says NO Thank You to Dread1292 For This Un-useful Post:
Vansquish (11-03-2016)
 Old 11-03-2016, 11:24 PM   #2
stockms3's Avatar
Posts: 840   (View Stats)
Groans: 74
Um search. You need aux fueling.
 Old 11-04-2016, 12:01 AM   #3
Dread1292's Avatar
I saw a mazdaspeed 3 with 500hp without meth or e85, I think it could be achieved with a6th port injection kit. And if I ever do go e85 I can.
 Old 11-04-2016, 02:13 AM   #4
shaneski's Avatar
Posts: 505   (View Stats)
Good luck with that...FMD do any of these Johnny come lately gronks research at all these days.
Use to be non stop blow off valve questions, now it's i want 500whp with no clue on what it takes to get there other than thinking a set of rods and pistons will do it.
The Following 3 Users Say Thank You to shaneski For This Useful Post:
thems3driver (11-04-2016), Vansquish (11-04-2016), WetzMS3 (11-04-2016)
 Old 11-04-2016, 06:48 AM   #5
thems3driver's Avatar
Posts: 235   (View Stats)
thems3driver is the leader of the worldthems3driver is the leader of the worldthems3driver is the leader of the worldthems3driver is the leader of the worldthems3driver is the leader of the worldthems3driver is the leader of the worldthems3driver is the leader of the worldthems3driver is the leader of the worldthems3driver is the leader of the worldthems3driver is the leader of the worldthems3driver is the leader of the world
Groaned at 4 Times in 1 Post
I'm just glad we are past the stance season, bags and camber that look like Starbucks girls with fucked up Uggs.
Current Installed: Autotech Internals | Cobb AP v3 | JBR SSB | JBR RMM 80A Duro | Pioneer HU - Alpine speakers - Alpine sub (cause fuck BOSE) | Goodyear F1 Asymmetric | CS Intake + TiP | Forge BPV v2.0 | Swift Springs Spec R | Redline MTL 80
Future Installs: CS Race Pipe | CP-E TMIC | WMI
Rice Maker Mods (not power mods): Daily Driven, Mazdaspeed Decals, Cobb x2, JBR Decal, Stratified Tuned Decal, RVinyl yellow fog overlays, Plastidip rear valance, G2 caliper pnt, 35W Kensun slim HID, CS LEDs Fogs | Footwell blue LEDs | Dual ported box | Foglight Covers dipped | Red Vinyl Wrapped Tail Lights
thems3driver is offline   Reply With Quote
The Following User Says Thank You to thems3driver For This Useful Post:
KiwiFlavor (11-04-2016)
 Old 11-04-2016, 09:21 AM   #6
Dread1292's Avatar
Now that the trolls are here, what does it actually take to get there. I have some idea that more fuel, bigger turbo, and just about everything else. But what exactly is needed. What is a setup that doesn't need meth or e85?
 Old 11-04-2016, 12:14 AM   #7
stockms3's Avatar
Groans: 74
I saw a unicorn once, I think I forgot to take my meds that day.
The Following 6 Users Say Thank You to stockms3 For This Useful Post:
CMajor (11-04-2016), frothy (11-04-2016), KiwiFlavor (11-04-2016), thems3driver (11-04-2016), Vansquish (11-04-2016), WetzMS3 (11-04-2016)
 Old 11-04-2016, 10:06 AM   #8
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
6th port fueling would work, the jmf or damon st intake with 4 injectors would be better.
a turbo would have to be gtx3076 or bigger to get 500 hp.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
The Following User Says Thank You to mxlplx71 For This Useful Post:
Dread1292 (11-04-2016)
 Old 11-04-2016, 11:31 AM   #9
Dread1292's Avatar
@mxlplx71 that's what I figured, I just wanted someone else's opinion as well. All the other stuff I have figured out. I plan on going with the PTE 6266 or PTE 6262.
 Old 11-05-2016, 07:11 AM   #10
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Neutral  +1 score
DO NOT delete the balance shaft unless you really need to (damaged crankshaft gear or damaged BS).
The BS is there to eliminate the vibrations which not only that you will feel minimally in the cabin, but the main bearings will suffer most and it's a matter of a few tens of thousandths of miles before you will have to open the engine again.
There is no real benefit to delete the EGR either especially if you have aux fuelling (and for 500HP you cannot get away without meth or PI with ethanol mixes in tank).
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 11-05-2016, 10:38 AM   #11
torquemaniac's Avatar
Posts: 733   (View Stats)
Mituc, do you have hard evidence of this claim...the health of my engine is top priority and I will put the balance shaft back if need be
2011 CX-7 AWD 2.3 turbo
 Old 11-05-2016, 01:25 PM   #12
mituc's Avatar
Groans: 111
I don't have a hard evidence of this, I'm only telling you what my engine builder told me when I brought this into discussion (and as a consequence I bought a new crank and an used balance shaft, and the second engine I'll build will have a BS delete because of the affected crank gear for the balance shaft).
torquemaniac (11-06-2016)
All Out MzR Engine build SPEED6 KILLAH Mazda MZR DISI Engine Builds (2006-2013) 1299 10-30-2018 08:25 PM
My Engine Build ledfootrob 2010 MS3 - Build Diaries 6 11-09-2014 10:51 PM
Engine build josh0408 MazdaSpeed 3/6 - Big Turbo Builds 5 12-28-2010 07:15 PM
DCR Engine build FTW !!!! flyrevs2 MazdaSpeed 3 - Engine, Transmission & Driveline 28 10-11-2009 10:20 AM
Page generated in 0.32206 seconds with 26 queries
