> 2010 MS3 - Build Diaries
Like Tree28Likes
 Old 10-03-2014, 02:25 PM   #1
England15j's Avatar
Posts: 1,910   (View Stats)
Default England15j's SP63 10.6:1 CR GTX3071 Build
Back story.
September 5th while on my back for logging I noticed a pulse in the clutch pedal and knew the motor was done for.
The following day I did a compression test and pulled the oil pan to verify the bent rod I suspected and to see if any other damage had occurred and found #2 had in fact bent.
Compression test results 1-4
175-160-145-170
September 20-21 pulled the motor and packaged it up for shipment to Speed Performance.
September 22 motor was shipped out.
October 6 upon tear down rods 1/2 were found to be bent and ringland on #3 are broken explaining the low compression results.
Bent rod from #2
Vdyno from night of the failure
Motor removed
Stock Clutch
The new motor specs
10.6:1 88mm SP Pistons
Manley H-beams
L19 head studs
Keyed Crank
Port and Polished Head
New parts for the build
Southbend stage 3 endurance
CP-e exhaust mani (pending)
Aem 30-3020 wmi fail safe
Pics of car
More will follow as the build continues
The Following 7 Users Say Thank You to England15j For This Useful Post:
Easter Bunny (10-18-2014), Lex (10-03-2014), mxlplx71 (10-05-2014), SPEED6 KILLAH (11-17-2014), Swinger13 (11-11-2014), Wilksy (10-07-2014), [R]usty (10-03-2014)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f542/england15j-s-sp63-10-6-1-cr-178180/
Will the paranoia ever end it it a TO bearing or is it a bent Rod? - Page 2 This thread Pingback 10-07-2014 01:29 AM
NJSPEED3's SP63 build..To infinity and beyond.. NJSPEED3 Mazda MZR DISI Engine Builds (2006-2013) 335 07-04-2014 07:08 PM
GTX3071 EWG build Seatime3 2010 MS3 - Big Turbo Builds 171 01-11-2014 07:50 PM
A GTX3071 Build from SE MO krispyskustoms 2010 MS3 - Big Turbo Builds 14 01-11-2014 05:56 PM
GTX3071 build JacksonMS30 MazdaSpeed 3/6 - Big Turbo Builds 767 05-18-2013 12:49 AM
Cld12pk2go's ATP GTX3071 Build cld12pk2go MazdaSpeed 3/6 - Big Turbo Builds 210 12-31-2012 08:03 PM
Page generated in 0.74594 seconds with 34 queries
