| 2010 MS3 - Build Diaries Genpu - General Build Threads/Diaries. |
![]() | | #41 | ![]() |
| Not Ranked : 0 score Also you are up really fucking early. Or still up not sure of the time difference. Its 8:30 am here.
![]() | | #42 | ![]() |
![]() Join Date: Jan 2014 Location: Germany
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 133
.You can have those ramps if you pay the shipping which should be like 500USD .Btw. its 14:40 here in Germany .
__________________ 2012 Mazdaspeed 3 CS SRI, BNR S1, CS TMIC w/ Boost Tubes, GrimmSpeed EBCS, CS RMM, Stratified tuned, Cobb DP, 3" Catback, H&R coilovers, Tanabe strut & other parts | |
![]() | | #43 | ![]() |
| Not Ranked : 0 score Aww fuck i was going the wrong way on the time difference. It is too early here.....
![]() | | #44 | ![]() |
(Thread Starter) | Not Ranked : 0 score Installed the JBR OCC today:
![]() | | #45 | ![]() |
(Thread Starter) | Not Ranked : 0 score Last spring, we forgot to throw out the mount of the oem downpipe when installing the COBB downpipe. Since there is a lift now in our workshop, I immediately uninstalled the mount which makes a lot more room behind the engine from underneath:
![]() | | #46 | ![]() |
(Thread Starter) | Not Ranked : 0 score A new year - new resolutions: more cars, more boost, more tuning ![]() We started with our traditional new year's eve meeting in the workshop and installed the CorkSport Hood Struts. They give you plenty of room when working in the engine bay. ![]() This leads me to an updated spec list: Mazda 3 MPS BL (european Mazdaspeed) black mica, tech package, navi currently 50.500km Engine, Exhaust & Transmission - CorkSport Stage II SRI - CorkSport Airbox - BNR S1 turbo - CorkSport Boost Tubes - CorkSport Top Mount Intercooler - GFB BOV - CorkSport Bypass Valve Hose - insulating mats delete - COBB AccessPort (tuned by Stratified) - HG HPFP Internals - EGR Block Off - JBR Oil Catch Can - GrimmSpeed EBCS - 3" COBB Downpipe - 3" VAST Catback - CorkSport Race RMM - MME Short Shift Plate - CorkSport Shifter Bushings Suspension, Tires & Brakes - H&R Monotube coilovers - Tanabe strut (coated in matt black) - Sparco Assetto Gara 8x18, 225/40 Goodyear Eagle F1 (summer) - OEM Gen2 rims (coated in green) 7.5x18, 225/40 Nokian WR A3 (winter) - black RAYS Lugnuts Exterior - CorkSport Hood Strut Kit - black Mazda emblems - black front grille without MPS emblem - green brake calipers - black exhaust pipes - black/white rear fog light - some green decals Interior - new steering wheel - black interior
![]() | | #47 | ![]() |
![]() Join Date: Nov 2012 Location: North East
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 261
Groaned at 29 Times in 14 Posts
| Not Ranked : 0 score Was ist mit der strutbar passiert? Zu viel understeer?
__________________ I drive fast, I turn fast, I do everything fast. I even breakfast. I tend to confuse people with my sudden changes of heart. Sometimes I even confuse myself, which tends to cause problems. "... if u can't find' em - grind 'em" - old Chinese proverb ![]() ![]() http://www.mazdamotorsports.com/ |
![]() | | #48 | ![]() |
(Thread Starter) | Not Ranked : 0 score Wieder eingebaut. War nur kurz ausgebaut, damit ich besser an den Turbolader rankomme
![]() | | #49 | ![]() |
(Thread Starter) | Not Ranked : 0 score Threw the fog lights out ... didnt see a difference between on and off and I've never used them anyways. So ... because racecar. Took the car on our lift and took them out. Drivers side was easy as there is plenty of space behind. Passenger side sucks because of the washer reservoir which is straight behind the fog light. ![]() At the weekend I'll put a cold air hose behind the driver's side opening which leads some fresh air to the airbox box.
| The Following User Says Thank You to Fonsi For This Useful Post: | Easter Bunny (01-15-2016) |
![]() | | #50 | ![]() |
(Thread Starter) | Not Ranked : 0 score Cold air hose. I will make some logs soon to see if it's worth.
![]() | | #51 | ![]() |
(Thread Starter) | Not Ranked : 0 score Changed the spark plugs today after 51.000km. It wasn't unnecessary . The Denso ITV-22 are now in.![]() But the main reason I took off the TMIC was the throttle body coolant delete. I also cleaned the throttle body. ![]() ![]()
| Mazdaspeed3 Gen2 tune and tuners | Moraitis87 | Gen2 MS3 General Discussion | 2 | 11-25-2013 07:45 AM |
| Mazdaspeed3 Gen2 tune and tuners | Moraitis87 | MazdaSpeed 3 - How-To's | 3 | 11-25-2013 07:33 AM |
| VersaTuner for Gen2 Mazdaspeed3/3MPS now available | Steve@VersaTune | 2010 MS3 - ECU Computer Tuning | 6 | 03-07-2013 05:57 AM |
| How I Refinished my Stock wheels Gen2 mazdaspeed3 | MazSpd3Jase | 2010 MS3 - How-To's | 60 | 05-03-2010 11:56 PM |
| cp-e™ MazdaSPEED3 Gen2 3" SS Cat Back - Released | Adam is so pro | 2010 MS3 - Engine, Transmission & Driveline | 13 | 05-03-2010 07:48 PM |
