| 2010 MS3 - Build Diaries Genpu - General Build Threads/Diaries. |
![]() Join Date: Oct 2011 Location: Sterling, Virginia
Rep Power: 0 ![]() Thanks: 0
Groaned at 8 Times in 4 Posts
(Thread Starter) | Not Ranked : 0 score My objectives include a moderate increase in power, neutral handling characteristics, reduced weight overall (rotational, unsprung, and chassis) without sacrificing comfort, increased efficiency, and finally, subtle styling. |
(Thread Starter) | Not Ranked : 0 score My first modification was a set of 18x8 black O.Z. Racing Alleggerita's. Weighing around 17 pounds each, it gave me the unsprung weight reduction I was looking for, while also adding a bit of style to the vehicle. My next round of mods include Cobb Accessport, Cobb Intake, Cobb Turbo Inlet Hose, Denso ITV22 Spark Plugs, and finally, a CPE Stage II Rear Motor Mount. (Not installed at this time) |
Groans: 63
| Not Ranked : 0 score Skip they ITV22s, they aren't needed. They'll actually be detrimental to performance at this point. Research before doing those mods....you're missing something. And I won't tell you what, that would ruin the fun. But it's clear you need to do some research.
Also, from the research i've made, the ITV22 Spark Plugs are a good plug for additional boost that will come from the modifications I have so far and what is to come. Thank you for your input. | |
Groans: 63
| Not Ranked : 0 score Your extra 1psi doesn't need step colder plugs. There's guys pushing 400hp with stock range plugs. Spark plugs should be as hot as possible for a more efficient burn. The reason people run colder plugs is to combat detonation from the heat retention in the ceramic. If you are not experiencing detonation you should run hotter plugs. you even stated you wanted better efficiency....
![]() Join Date: Apr 2015 Location: Sterling Heights Michigan
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 47
Groaned at 9 Times in 7 Posts
| Not Ranked : 0 score +1 Unless you're making close to 350 to the wheels you do not need colder plugs. They will bring you more problems than stock range and in your case offer pretty much no benefit. If you plan on getting up to this power level, then replace the plugs then, not now.
__________________ Things that matter: CS "Stage 2" SRI/TIP, CS TMIC, AT HPFP, JBR 70 duro RMM, Stratified OTS +, Koni FSD's, Whiteline endlinks. Things that don't: Gen Pu wheels, CPE center pod with Prosport boost, OP, and OT gauges, Eonon G9151A. |
| The Following User Says Thank You to Bingo For This Useful Post: | Vansquish (09-01-2016) |
![]() Join Date: Mar 2013 Location: North Brunswick, NJ
Rep Power: 1125 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,645
Groans: 143
| Not Ranked : 0 score There are some who prefer colder plugs and some who don't. I am in the latter camp. I use OEM plugs in my car and run them for the full service life (60k). Honestly the most important thing is to make sure your gap is set correctly regardless of which way you go. I have found the colder plugs tend to foul more easily in some cars which can cause misfires and knock. In other cars they will run perfectly.
Also, no offense OP but if you did more research, you'd probably realize that handling and tire upgrades will take you a lot further than power upgrades, as appealing as they might be. Don't get me wrong, the intake is a decent idea but you need tuning to get any advantage from it, which you won't be able to do immediately with the Cobb Accessport thanks to Cobb's new policy regarding Accesstuner Race where you need to complete paid training to get a copy. Also, you could have easily fit an 18x9 wheel instead of that 18x8, which is barely wider than the stock wheel. The 18x9 will accommodate wider tires in the future and allow for more grip.
__________________ 2007 Mazdaspeed3 GT | |
| The Following 3 Users Say Thank You to MD1032 For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score Just ordered a set of Corksport HPFP internals. Figured I'd add a level of safety. Maybe my ITV22's make more sense now, as I'm sure the hpfp will increase boost a bit more. |
Groans: 63
| Not Ranked : 0 score No. Clearly you aren't doing your research.
| The Following User Says Thank You to anavrinIV For This Useful Post: | MD1032 (08-22-2016) |
| Not Ranked : 0 score I honestly can't tell if this is just sarcasm. I hope for your car that it is.
(Thread Starter) | Not Ranked : 0 score I don't understand the negatively. I spoke with cobb about their tunes and they actually recommended these plugs with ap, sfor, tip, and HPFP. Cobb said the itv22'same work very well with their tunes. |
![]() Join Date: Sep 2015 Location: Brick, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,356
Groans: 50
| Not Ranked : 0 score Did cobb tell you hpfp internals increase boost? LOL
__________________ 2011 Mazdaspeed3 w/ tech package Totaled/ R.I.P. |
| The Following User Says Thank You to robbspeed For This Useful Post: | MD1032 (08-22-2016) |
| lol, hpfp internals increase boost. i don't really trust Cobb. the only good thing is their AP and that's about it. i wouldn't let them tune my car.
Groans: 63
| Not Ranked : 0 score It's not negativity it's stating facts. You say you're researching then turn around with lots of misinformation that's easily cleared up with 10 minutes of search results from this site alone.
| The Following User Says Thank You to anavrinIV For This Useful Post: | robbspeed (08-22-2016) |
(Thread Starter) | Not Ranked : 0 score My apologies. I think there's been a misunderstanding l. What I meant is, I can safely run more boost with the hpfp internals. Not that they provide more boost. |
| Not Ranked : 0 score Well you did kinda say... Additionally it's still puzzling why you're so adamant about using step colder plugs when people (definitely at least a couple that have posted to this thread) know exponentially more than yourself and even Cobb on the subject. We know what's best for your car (at least at this stage of modding) even if you don't yet. Not trying to be insulting here, just trying to get you to heed advice that's been tried and tested for a decade now.
| The Following 3 Users Say Thank You to Bingo For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score Okay... update: Ordered stock range plugs, CNT catted downpipe, Street Unit TMIC, and H&R Springs (great deal on the Facebook page). So here's my next question: With full intake, hpfp internals, downpipe, and tmic. Will I need to: A) upgrade/disable my EGR system B) use stock or ITV-22's WI'll these mods allow me to run Stage 2 maps from cobb tuning? And would the addition of a catback exhaust allow me to run stage 3 (even tho I don't have a FMIC, but instead, I have a TMIC?) |
![]() Join Date: Feb 2012 Location: davenport, iowa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,201
Groans: 128
| Not Ranked : 0 score A, you should, slightly cleaner valves and no hot air being pumped into the intake. B, no. not needed until HP is close to or over 100 more than stock levels. you should get an E Tune. off the shelf maps suck
__________________ 09 Speed3 ,sold 2012= k04@18lbs, k&n intake, race pipe, selftune13.00@109.76 2013= BNRs2@20lbs E30 FreekedBuilt & Bolted12.63@113.75 full weight, nitto dr's 2014 06 ms6 gt3076 built bolted 2015 06 ms6 parted 2016 07 cosmic MS3 SOLDforged pistons/rods, bsd baffle, cs turbo, fmic, occ, spin on conv, catless long dp, e30, sri, cpe hpfp, rmm, ported im. |
| The Following User Says Thank You to mxlplx71 For This Useful Post: | WAMBUSHHHH! (09-01-2016) |
![]() Join Date: May 2013 Location: Bryn Mawr, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,449
| Not Ranked : 0 score This. You're adding a good amount onto the car and those OTS maps are just one size fits all and leaves a lot to be desired for. Do yourself, wallet and car a favor and get an E-Tune. OTS is adequate but I won't use it long term.
__________________ 2013 LSM Mazdaspeed3 - stocked out and traded 6/5/2017 2017 LGM Golf R - South Bend stage 3 daily clutch / IE intake / Wagner IC / AWE downpipe / Indvidia catback / EQT Tuned 2004 Yamaha R6 - Micron Ricer Pipe / PC 2005 Honda CBR 600 F4i - R.I.P. 10/29/13 |
![]() Join Date: Jan 2013 Location: McKinney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,778
| Not Ranked : 0 score Leave the EGR alone. It gives you better mpgs and cools the cylinder temps when cruising.
__________________ 3rd rebuild on the way...maybe... |
(Thread Starter) | Not Ranked : 0 score Is there a recommended person who does E-tunes? AmI correct in assuming that this requires me to send a data log to an individual and they provide a tune from this information (no dyno involved)? |
Groans: 438
__________________ All good things must come to an end... |
| 2011 MS3 modest build | the_afterglow | MazdaSpeed 3/6 - Build Diaries | 0 | 09-10-2012 10:58 PM |
| Autobytel turns modest Q3 profit | Haltech | Automotive News | 0 | 11-11-2011 03:50 PM |
| Autobytel turns modest Q3 profit | Haltech | Automotive News | 0 | 11-11-2011 02:00 PM |
| Nissan X-Trail gets modest refresh, new diesel | Haltech | Automotive News | 0 | 07-08-2010 05:10 PM |
