> 2010 MS3 - Build Diaries
  • 1 Post By thatguy0o0
  • 1 Post By MSMS3
 Old 01-26-2019, 07:17 PM   #1
jrosvaldoavila's Avatar
Posts: 5   (View Stats)
jrosvaldoavila is an unknown quantity at this point
Default Next mods?? Suggestion?
Hi mazdaspeed fans
I have à mazdaspeed 3 2013, i have a cobb stage 1 tune( cold air K&n and of course the accesport)
What would u guys recommend to have a build reliable to touch at least 300hp as a daily car?
Envoyé de mon iPhone en utilisant Tapatalk
jrosvaldoavila is offline   Reply With Quote
 Old 01-27-2019, 08:45 AM   #2
doublegmoto's Avatar
Posts: 23   (View Stats)
doublegmoto will become famous soon enough
Originally Posted by jrosvaldoavila View Post
Hi mazdaspeed fans
High pressure fuel pump first all the bolt ons corksport turbo custom tune
Sent from my LGMS631 using Tapatalk
doublegmoto is offline   Reply With Quote
 Old 01-27-2019, 10:00 AM   #3
Hi doublegmoto!
What are bolt ons is it forged piston,camshaft etc..? Sorry my english is not the best lol
 Old 01-27-2019, 11:11 AM   #4
thatguy0o0's Avatar
Posts: 148   (View Stats)
thatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond repute
Hi doublegmoto!
Bolt ons are parts don't require a ton of engineering. Things that you can basically buy and swap the factory parts with...you remove the factory bolts and "bolt on" the new part. Your air intake is an example of a bolt on. An aftermarket top mount intercooler is another example. Things like forged pistons are not bolt ons because you have to tear the motor apart and do some serious engineering feats to make that stuff work.
Search HPFP internals. This is what you NEED sooner than later. Without it your engine will blow up.
jrosvaldoavila likes this.
2013 Speed3 w/ tech
Autotech HPFP
Cobb APV3
ETS TMIC
JBR 3.5in SRI
UR catless DP
Corksport TP
Corksport Hoodscoop
JBR RMM
Stratified e30 tune
Other Stuff:
1992 Jeep Cherokee 202,000 miles (salt/snow work horse)
2009 Toyota Rav 4 (wife has to drive something practical)
2012 Yamaha R1 Full Two Brothers exhaust & ECU flash
thatguy0o0 is offline   Reply With Quote
 Old 01-27-2019, 01:00 PM   #5
Posts: 2,830   (View Stats)
Hi mazdaspeed fans
High pressure fuel pump internals upgrade. A real custom tun from a reputable e-tuner. Perhaps exhaust side upgrade of 3" downpipe and midpipe with high flow cats or catless and e-tune for those mods. Maybe a larger diameter maf housing to turbo intake, with recalibrated maf.
Your K04 will max out at 300-310 whp on pump gas. You will need a larger turbo and e-tune for it.
 Old 01-27-2019, 02:32 PM   #6
Thank u guys!
need a map suggestion speedms6 MazdaSpeed 3/6 - ECU Computer Tuning 1 03-26-2011 12:51 PM
Cobb Access Port/Maps
4 03-25-2011 01:50 PM
Page generated in 0.28396 seconds with 23 queries
