> 2010 MS3 - Build Diaries
Like Tree49Likes
 Old 03-19-2015, 05:30 PM   #1
Putin 2.3T's Avatar
Posts: 1,040   (View Stats)
Default Putin's 700+hp build
As you've probably already noticed my previous thread was closed up, shut down, done, gone. Well it's for a good reason! I've dropped the idea of running any sort of power on stock block and went full-force into an engine build. So the story starts at Mazda. I bought a brand new, fresh, 0-mile, long block and had it shipped over to @SPEEDPERF6RMANC3;.
This is where the next chapter begins!
Engine build details:
Fresh Long Block from Mazda
SP63 87.5mm 9.5:1 Pistons
H11 12mm Head-studs w/ OEM headgasket
ARP2000 10mm Main-studs
Manley I-Beam Rods
ARP625+ Rod Bolts
Clevite H Rod Bearings
OEM Main Bearings
Mildly Ported Intake & Exhaust Ports
Crower Springs
Pinned Cams
Key'd Crank & Sprockets
ACT 6-puck Sprung Clutch w/ Prolite Flywheel
- ARP2000 Flywheel Bolts (251-2802)
Balance Shaft Delete
Fueling Setup:
CP-e HPFP
JMF V2 Manifold w/ PI
Split-Second AIC1-V4h (4-channel tach/MAF) with SP63 PnP harness
Bosch 2200cc Injectors
Tokay/Corksport Fuel Injector Seals
FueLab Adjustable Fuel Pressure Regulator (returnless & static @ 43.5)
ATL Well Cell Fuel Cell (12 Gallons)
Radium Engineering FCST w/ 3x AEM 50-1200 E85
Turbo Setup details:
Precision Turbo 6466 DBB .82ar v-band in/out
CP-E LRTmani Turbo Manifold
Kozmic Motorsports Downpipe (Precision v-band)
Kozmic Motorsports Dump Tube
Precision Turbo PTE46 46mm External Wastegate
Kozmic Motorsports Oil Feed
SPEEDPERF6RMANC3 Precision Turbo Drain Line
RamFab 3" under-route intercooler hot-side piping & 3" cold-side piping w/ Treadstone TR1245 Intercooler
RamFab 4.5" Intake
Bosch 4bar MAP sensor w/ PnP Harness
DamondMotorsports Full EGR Delete
TiAL QR Bypass-Valve
MAC 3-port EBCS
PCV Setup:
PERM PCV Plate w/ dual -10an outlets
Blackworks Racing Catch Tank (VTA Breather)
MISC:
SPEEDPERF6RMANC3 Auxiliary Fan Controller
Tuner:
(5/20/15) After much thought and deliberation I've decided to go with Stratified. Both Lex and Nishan are phenomenal tuners, it just came to the fact that a local tuner was a much easier option for me. I thank Nishan for all of his advice, his patience and most importantly his contributions to this build. Thank you!
Current modifications:
2011 Mazdaspeed 3 LSM Tech Package
Stock K04
HTP 3.5" Intake
CP-e HPFP
JBR Silicone Intercooler Piping Kit w/ Treadonstone TR8 & JBR crash-bar
Corksport Race-pipe
Corksport Shifter-Base Bushings
OBX Catback Exhaust
Forge v1 Bypass Valve
CP-e Stage 2 RMM
SPEEDPERF6RMANC3 Valve Cover Breather
DamondMotorsports Front License Plate Relocate
DamondMotorsports PMM
Corksport Recirc. Hose
COBB Accessport V3 (Freektune)
Special Shout Outs too:
This list will grow as the build progresses.
@England15j; one legit motherfucker right here!
@BAT-man; without this guy I wouldn't have the engine.
@SPEEDPERF6RMANC3; Nick and Pablo are awesome people! I'd especially like to thank Nick for all his patience with my questions in regards to the build. Sorry to say broski, but I've got a SHIT TON more questions coming your way. Haha!
*items in red italics are awaiting purchase
2011 Mazdaspeed 3 [Sold]
The Following 21 Users Say Thank You to Putin 2.3T For This Useful Post:
BAT-man (04-02-2015), blakjak0271 (03-19-2015), brandonf (08-14-2015), Cevaes_64 (05-26-2015), chaser27 (04-03-2015), Code Monkey (03-19-2015), CWP_MS3 (03-23-2015), doctavus (03-19-2015), Dralphy (03-19-2015), England15j (03-19-2015), impossible (06-10-2015), ItsNox (06-08-2015), kgb (05-30-2015), lnumbp (03-20-2015), Monotonous ONE (05-10-2015), mxlplx71 (03-23-2015), Scare Dem (03-22-2015), skoski17 (04-11-2016), WA_MS6 (04-15-2015), WetzMS3 (03-22-2015), [R]usty (05-05-2015)
 Old 03-19-2015, 05:32 PM   #2
blakjak0271's Avatar
Posts: 166   (View Stats)
blakjak0271 is the leader of the worldblakjak0271 is the leader of the worldblakjak0271 is the leader of the worldblakjak0271 is the leader of the worldblakjak0271 is the leader of the worldblakjak0271 is the leader of the worldblakjak0271 is the leader of the worldblakjak0271 is the leader of the worldblakjak0271 is the leader of the worldblakjak0271 is the leader of the worldblakjak0271 is the leader of the world
Good luck with the build! What are your power goals?
....Because Canada
blakjak0271 is offline   Reply With Quote
 Old 03-19-2015, 05:35 PM   #3
pirate steve's Avatar
Posts: 248   (View Stats)
pirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the world
Well now things are just going to get ridiculous...
I expect all of your updates will contain pictures of glorious leader.
2011 grey MS3: HTP TIP, COBB SRI, HPFP internals, CS TMIC, Dammond EGR delete, Dammond OCC, M2 full DP all of the cats deleted, freektune OTS+, denso ITV22, Maisonvi turbo bolt, CP-e S2 RMM
pirate steve is offline   Reply With Quote
The Following User Says Thank You to pirate steve For This Useful Post:
Dream20b (05-09-2015)
 Old 03-19-2015, 05:39 PM   #4
Yatta's Avatar
Posts: 1,862   (View Stats)
Can’t wait to see how this is going to turn out.
The Following 10 Users Say Thank You to Yatta For This Useful Post:
Addikted To Boost (05-06-2015), bigspender (03-30-2015), blakjak0271 (03-19-2015), Cevaes_64 (05-26-2015), Cheapspeed (05-06-2015), Code Monkey (03-19-2015), CWP_MS3 (03-23-2015), Dream20b (05-09-2015), Easter Bunny (03-19-2015), ItsNox (06-08-2015)
 Old 03-19-2015, 08:56 PM   #5
Putin 2.3T's Avatar
It really all depends on the turbo and fueling so I'd say 500-700hp. Right now that decision is in limbo as I haven't decided on which turbo to go with. Once that's written in concrete, everything else will start coming together.
 Old 03-19-2015, 11:30 PM   #6
shaneski's Avatar
Posts: 506   (View Stats)
You have 3 bar map sensor in the list, why not 3.5 to wind it up or for the safety to read boost spikes that are out of range of the 3 bar.
The Following User Says Thank You to shaneski For This Useful Post:
England15j (03-20-2015)
 Old 03-22-2015, 04:13 AM   #7
Putin 2.3T's Avatar
Big mysterious things are coming, yes indeed.
 Old 03-23-2015, 10:56 AM   #8
Putin 2.3T's Avatar
Things just got ridiculous. Decided to go Manley I-Beams, 12mm head-studs, Pinned Cams and Crower springs.
 Old 03-23-2015, 11:33 AM   #9
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
curious as to why you didnt get the jmf v1 with port meth bungs?
i know my sht is dirrty
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 03-23-2015, 12:43 PM   #10
HawkeyeGeoff's Avatar
Posts: 3,036   (View Stats)
Agree with this guy. If you're going that big might as well do it the most legit way possible for the extra couple hundred bones.
Silver 2007 Speed3 GT
 Old 03-23-2015, 01:40 PM   #11
Putin 2.3T's Avatar
I understand that having four meth nozzles seems like the right way to go but imagine if one of those nozzles gets clogged. With large enough nozzles most fail-safe boxes may not notice it fast enough. Go WOT and there goes a cylinder. Running a very large single, or dual nozzles is safer then going with 4. Less chances for a fuck up. I'm basically using methanol as supplemental fueling. Two nozzles supplying well over 1,700+cc of methanol and then being distributed evenly by the JMF manifold. I have nothing to worry about. With @mxlplx71; setup, he also has 6th port. So methanol is just for added octane, possibly help a little bit with BATs. I don't plan to go 5/6th port any time soon.
The Following 5 Users Say Thank You to Putin 2.3T For This Useful Post:
865ms3 (03-23-2015), impossible (06-10-2015), mxlplx71 (03-23-2015), rigor (04-25-2015), torquemaniac (05-07-2015)
 Old 03-23-2015, 02:09 PM   #12
Or...you could do it like @SilverDemon; 's / my new setup. 4 50lb injectors in the JMF mani spraying E85 or 104 race gas off a secondary fuel cell.
 Old 03-23-2015, 02:29 PM   #13
Putin 2.3T's Avatar
Dream setup would be a twin-pump SP63 fuel injection setup running a JMF v2 with PI. But at the moment I've had to invest heavily into the strength of the motor. Everything else around it will catch up in time. So for now the JMF v1 is the intake manifold of choice because the OE will cap out at 450-500hp. Methanol over PI.
HawkeyeGeoff likes this.
The Following User Says Thank You to Putin 2.3T For This Useful Post:
WetzMS3 (04-02-2015)
 Old 03-23-2015, 06:55 PM   #14
I think the way you're going to do it will kick ass regardless. When you think 500 whp is slow, you have somewhere to go from there
 Old 03-26-2015, 08:21 AM   #15
SPEEDPERF6RMANC3's Avatar
Posts: 108   (View Stats)
SPEEDPERF6RMANC3 is the leader of the worldSPEEDPERF6RMANC3 is the leader of the worldSPEEDPERF6RMANC3 is the leader of the worldSPEEDPERF6RMANC3 is the leader of the worldSPEEDPERF6RMANC3 is the leader of the worldSPEEDPERF6RMANC3 is the leader of the worldSPEEDPERF6RMANC3 is the leader of the worldSPEEDPERF6RMANC3 is the leader of the worldSPEEDPERF6RMANC3 is the leader of the worldSPEEDPERF6RMANC3 is the leader of the worldSPEEDPERF6RMANC3 is the leader of the world
Groaned at 6 Times in 3 Posts
Just want to say thanks for all the love! We will be sending you pictures to keep this build thread up to date, we are currently waiting on the rest of the parts to come in so we can disassemble the motor and get it sent to the machine shop! If you have any more questions please do not hesitate to ask! Cant wait to see when this monster gets up and running.
Thanks
Nick
Speed Perf6rmanc3
SPEEDPERF6RMANC3 is offline   Reply With Quote
The Following 4 Users Say Thank You to SPEEDPERF6RMANC3 For This Useful Post:
Drive By Fire (06-15-2015), HawkeyeGeoff (03-26-2015), Putin 2.3T (03-26-2015), WetzMS3 (04-02-2015)
 Old 04-02-2015, 09:08 AM   #16
BAT-man's Avatar
Posts: 719   (View Stats)
BAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the world
Groaned at 29 Times in 14 Posts
good planning, kick some built ass, Puta
I drive fast, I turn fast, I do everything fast. I even breakfast. I tend to confuse people with my sudden changes of heart. Sometimes I even confuse myself, which tends to cause problems.
"... if u can't find' em - grind 'em"
- old Chinese proverb
http://www.mazdamotorsports.com/
BAT-man is offline   Reply With Quote
 Old 04-02-2015, 09:50 AM   #17
Putin 2.3T's Avatar
Clutch arrived, thanks @Spec;!
Spec likes this.
The Following 2 Users Say Thank You to Putin 2.3T For This Useful Post:
Spec (04-02-2015), WetzMS3 (04-02-2015)
 Old 04-02-2015, 10:06 AM   #18
Putin 2.3T likes this.
Putin 2.3T (04-02-2015)
 Old 04-02-2015, 10:22 AM   #19
Spec's Avatar
Posts: 4,472   (View Stats)
Awesome. Read up on the ceramic clutches, break in procedure and care.
Mark1992 likes this.
 Old 04-02-2015, 10:24 AM   #20
MSP611's Avatar
Posts: 2,291   (View Stats)
looks like a monster.... man everyone is goin all out now a days
In progress:
The Following User Says Thank You to MSP611 For This Useful Post:
 Old 04-02-2015, 10:28 AM   #21
Putin 2.3T's Avatar
That's the easy part since the first 1k miles on this motor will be mild.
 Old 04-02-2015, 10:29 AM   #22
MSP611's Avatar
whyd u choose this clutch?? jw
In progress:
 Old 04-02-2015, 10:30 AM   #23
First 1K??
I thought you Russians were badasses.
 Old 04-02-2015, 10:44 AM   #24
Putin 2.3T's Avatar
It's proven. It works. Lots of guys have run it from mild to wild.
First 1K??
Badasses, yes. Smart baadasses, even more so.
Last edited by Putin 2.3T; 04-02-2015 at 10:44 AM. Reason: MSF Database - Automerged Doublepost
 Old 04-03-2015, 11:14 AM   #25
Putin 2.3T's Avatar
Special thanks to @MBOIZ-MS3; seriously legit brotha!
MBOIZ-MS3 likes this.
The Following 3 Users Say Thank You to Putin 2.3T For This Useful Post:
MBOIZ-MS3 (04-23-2015), mxlplx71 (04-03-2015), WetzMS3 (04-03-2015)
 Old 04-04-2015, 09:29 AM   #26
Putin 2.3T's Avatar
I've actually had this for a while just forgot to post it up. Thanks @Matt@HTP; be sure to tell Katie that I said thank you for the lollipops.
 Old 04-04-2015, 09:44 AM   #27
MSP611's Avatar
2 dump tubes??? u runnin twin wastegates?
In progress:
 Old 04-04-2015, 09:47 AM   #28
Putin 2.3T's Avatar
Um, no. HTP under-route hotpipe/intercooler pipe.
rigor (04-25-2015)
 Old 04-04-2015, 09:57 AM   #29
MSP611's Avatar
ooo fancy smancy lol
In progress:
 Old 04-11-2015, 09:26 AM   #30
Putin 2.3T's Avatar
I think that's big enough..
Yup..
Thanks @EdgeAutosport.com;!
EdgeAutosport.com (04-13-2015)
 Old 04-11-2015, 12:03 PM   #31
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Not sure about 700, but 600whp is easy with your setup and you should be able to get up to 750 if everything falls right in place. It's just a matter of finding the right balance of the car and torque curve for what you want to do with it. But 500+ or even 600hp on a DD car is definitely possible with all this stuff you have going on there.
Congrats for taking the right decisions
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 04-11-2015, 01:04 PM   #32
kylejenson's Avatar
Posts: 140   (View Stats)
kylejenson has a brilliant futurekylejenson has a brilliant futurekylejenson has a brilliant futurekylejenson has a brilliant futurekylejenson has a brilliant futurekylejenson has a brilliant futurekylejenson has a brilliant futurekylejenson has a brilliant futurekylejenson has a brilliant futurekylejenson has a brilliant futurekylejenson has a brilliant future
I wish I had the balls to put this much into my speed. Can't wait to see the end result!
kylejenson is offline   Reply With Quote
The Following User Says Thank You to kylejenson For This Useful Post:
Putin 2.3T (05-03-2015)
 Old 04-11-2015, 03:31 PM   #33
Spec's Avatar
He doesn't need balls, he's Russian.
The Following 2 Users Say Thank You to Spec For This Useful Post:
England15j (04-11-2015), Putin 2.3T (04-11-2015)
 Old 04-11-2015, 03:42 PM   #34
Putin 2.3T's Avatar
Are you doubting that I'll be able to reach 700hp with this setup? I honestly don't think I'll have a problem with the next few parts that are incoming.
 Old 04-11-2015, 11:50 PM   #35
mituc's Avatar
Groans: 111
No, I do not, your setup is good up to 800 probably and possibly more judging based on how other 700+whp guys managed to get there.
But I guess it depends on the turbo choice how daily drivable you actually want it to be But on the other hand the turbos came a low way these days and even if they push a ton of air past 6500-7000rpm on these engines they can still manage to get these engines from the normally aspirated state even below 3500rpm.
Putin 2.3T (04-12-2015)
 Old 04-15-2015, 12:26 PM   #36
Putin 2.3T's Avatar
Lets play a game of "Spot the Difference." Clue: 2200cc Thanks @Captain KR; for the information! Made my choice much easier.
Thank you @CorkSport; and @Tokay444;
The Following 4 Users Say Thank You to Putin 2.3T For This Useful Post:
Captain KR (04-15-2015), CorkSport (04-15-2015), ItsNox (06-08-2015), Tokay444 (04-15-2015)
 Old 04-15-2015, 01:59 PM   #37
Captain KR's Avatar
Posts: 2,320   (View Stats)
Captain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the world
Groans: 391
Groaned at 75 Times in 49 Posts
so much easier and cheaper that way
moore automitive 4/13/13 515whp 511 tq
Mason Dixon Raceway 11.289 @125 1.845 60'
Killah Built
Powered By Purple Drank
Captain KR is offline   Reply With Quote
 Old 04-16-2015, 04:50 AM   #38
MSP611's Avatar
Damn all sorts of win... I dunno man I'm already shelling out stacks for this rebuild I'm highly contemplating just sayin Fuck it and go with the mani too
In progress:
Putin 2.3T (04-16-2015)
 Old 04-21-2015, 07:13 PM   #39
Putin 2.3T's Avatar
RCI Fuel Cell arrived. Thanks @pmartz16;
And the SP63 PnP Harness for the AIC1 controller I'm using. Thanks @SPEEDPERF6RMANC3;
Alpha (05-05-2015), blakjak0271 (04-21-2015), Captain KR (04-24-2015), impossible (06-10-2015), pmartz16 (04-22-2015)
 Old 04-21-2015, 08:43 PM   #40
BAT-man's Avatar
Is that a surge tank fuel cell? what pump will go in there? whats the capacity?
Dartz Red Russian is a Putin-spec Mercedes G63 AMG 6x6 Haltech Automotive News 0 06-10-2014 08:30 AM
Vladimir Putin's all-Russian limo revealed Haltech Automotive News 0 05-08-2014 11:40 AM
Russian PM Putin reportedly tells Renault to put up or get out Haltech Automotive News 0 10-26-2009 04:00 PM
Putin Power: Even Russian automakers to get a bailout? Haltech Automotive News 0 03-31-2009 04:50 PM
Page generated in 0.59435 seconds with 35 queries
