| 2010 MS3 - Build Diaries Genpu - General Build Threads/Diaries. |
![]() | | #121 | ![]() |
| when in doubt.... ![]() Join Date: Nov 2014 Location: Connecticut
Rep Power: 102 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 106
| Not Ranked : 0 score |
![]() | | #122 | ![]() |
![]() Join Date: Mar 2008 Location: Navarre, FL
Rep Power: 4956 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,585
Groans: 370
| The Following 7 Users Say Thank You to aaronc7 For This Useful Post: | Easter Bunny (08-09-2015), Mauro_Penguin (08-10-2015), MS3Shadow (08-10-2015), NCspecV81 (07-04-2015), PUGENE (07-31-2015), Putin 2.3T (07-08-2015), WetzMS3 (08-10-2015) |
![]() | | #123 | ![]() |
![]() Join Date: Sep 2013 Location: Tacoma, WA
Rep Power: 581 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 382
(Thread Starter) | Not Ranked : 0 score Surely he shall and he has! I have an update... the build is getting shut down. I'm moving on with another project that has had my attention for a while now. ![]() I finally finished the fuel setup. I went with an ATL Well Cell in the 12 gallon variety for the rear with a Radium Engineering Fuel Cell Surge Tank system. I will be using three AEM 50-1200 E85 pumps. One for a feed for the surge, and two to feed the PI. Each one of these fuel pumps is good for around 700-750hp. Pictures will be coming up as soon as I have it arrive. For the moment the fuel cell mounts will not be very.. special. Budget cuts and time constraints have forced me to move with using tow-straps, haha! Ghetto as it may be, it WILL hold. I assure you of that. When I get a little more money I will go with something a little more fancy. - Along with this comes the change to the FPR setup. All the components remain, but I've decided to go returnless to keep the system a little simpler. By returnless I mean that the FPR will be mounted at the rear with the fuel cell. A singular -8an line will feed the fuel injectors. No fuel will return from the fuel rail. I will have a gauge in the back with the FPR and a digital gauge up front to ensure that the pressures are good. This also means the FPR will be run static. With the Bosch 2200cc injectors @ 43.5psi, they are MORE then enough to feed not only the PI but also the entire motor safely to 700+hp. I've also decided to go with an Odyssey PC680 battery and relocating the battery into the front fender wheel well. No real specific reason for that other then to allow the 4.5" intake that is being fabricated by (censored due to outside non-vendor) to have some room to breathe. On top of that I'll be using the current battery tray (JBR) to mount my BWR VTA Oil-Catch can. Should look pretty bitching once I get everything set up and ready. Pictures coming soooooon..
__________________ 2011 Mazdaspeed 3 [Sold] 2013 Ford F-150 XLT 3.5 Ecoboost |
| The Following 7 Users Say Thank You to Putin 2.3T For This Useful Post: | aaronc7 (08-09-2015), Easter Bunny (08-09-2015), GARRETHEXTREME (08-09-2015), ItsNox (08-10-2015), Mauro_Penguin (08-10-2015), TRBLSM (08-09-2015), WetzMS3 (08-10-2015) |
![]() | | #124 | ![]() |
| Not Ranked : 0 score You probably know this but you need to look at net fuel pressure. Ie if boost is 30 and fuel pressure is 45 you only have a differential of 15 psi across the injector.
| The Following User Says Thank You to Easter Bunny For This Useful Post: | Mauro_Penguin (08-10-2015) |
![]() | | #125 | ![]() |
(Thread Starter) | Not Ranked : 0 score I did think about it briefly, but must have passed it off for another more pressing issue. Not a hard fix, just means I've either gotta run a 3an line under my car to the manifold, or move the FPR up front and run a 6an line under the car for a return. Both are do'able. I originally decided on static because the system would be turning on only at WOT. Rising-rate is best when the fuel system needs to adjust between vacuum-boost at whatever load. But now that I think about it, even if I were to increase the fuel pressure to overcome the added boost pressure, it would still leave my fuel setup in a level of unpredictability that I want to avoid. Particularly when coming in to boost where it might see 60+psi of fuel but only 5-10psi of boost. At that point it would be rich as high hell up until when the boost builds. Sure that additional fuel could be tuned out via the DI injectors, but why make it harder on my tuner? Right? Haha!
| The Following User Says Thank You to Putin 2.3T For This Useful Post: | Mauro_Penguin (08-10-2015) |
![]() | | #126 | ![]() |
![]() Join Date: May 2011 Location: knoxville, TN
Rep Power: 1703 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,468
| Not Ranked : 0 score But then my issue...all these horsepowers but no traction. What's your plan there? I'm getting tires asap.
__________________ Brent Mazda Dragon Camp - Event Coordinator -Built Block-5858-Meth Dragon Slayer Setup FreekTuned ![]() |
![]() | | #127 | ![]() |
(Thread Starter) | Not Ranked : 0 score Scroll back a ways in the thread, I think I have some M&H's pictured. Those should solve my problems. For D/D I'm planning to run 255-wide R888s.
| The Following 4 Users Say Thank You to Putin 2.3T For This Useful Post: |
![]() | | #128 | ![]() |
| The Following User Says Thank You to Realgib3 For This Useful Post: | Mauro_Penguin (08-10-2015) |
![]() | | #129 | ![]() |
(Thread Starter) | Not Ranked : 0 score That is the end goal. Because of time, it will just be feeding PI for now.
![]() | | #130 | ![]() |
Mount your regulator in the hatch, near the fuel cell. Then, run -8 from cell to one port on the reg, -6 from 2nd port on reg back to the cell as your return line, then run a vac line and one, -8 line to the surge, then from the surge to the passenger side of your secondary rail, then -8 to your HPFP. This will keep it as a return setup, only makes you have to run one line to the front of the car, and allows you to run the proper 1:1 boost ref on the regulator. The only thing you'll have to figure out either way is if you want your pumps to be all fancy and wired in with relays and everything or if you just wanna put them on switches to start. If you decide on the switched option to start, I'd put your primary (to surge tank) and one secondary on a keyed 12v, which will turn on and run under normal driving, then put your other secondary on a hobbs switch to turn on once you're under some boost. Again, shouldn't take any more time or money to do it all this way and it'll be much better than running two very large fuel tanks, a dead head rail, and a static regulator. | |
| The Following 4 Users Say Thank You to Realgib3 For This Useful Post: |
![]() | | #131 | ![]() |
__________________ 2011 Mazdaspeed 3 [Sold] 2013 Ford F-150 XLT 3.5 Ecoboost | |
![]() | | #132 | ![]() |
As for the hpfp, you just get a fuel line to -8 adapter fitting. This is exactly how I've run my systems in the past. | |
| The Following 2 Users Say Thank You to Realgib3 For This Useful Post: | Mauro_Penguin (08-20-2015), Putin 2.3T (08-10-2015) |
![]() | | #133 | ![]() |
(Thread Starter) | Not Ranked : 0 score The only question I have in my mind right now is... why didn't I buy this sooner? Radium Engineering for the freakin' win!
__________________ 2011 Mazdaspeed 3 [Sold] 2013 Ford F-150 XLT 3.5 Ecoboost Last edited by Putin 2.3T; 08-12-2015 at 11:41 AM. |
| The Following 3 Users Say Thank You to Putin 2.3T For This Useful Post: |
![]() | | #134 | ![]() |
| Not Ranked : 0 score Pictar is broken.
![]() | | #135 | ![]() |
(Thread Starter) | Not Ranked : 0 score Fixed, I hope.
![]() | | #136 | ![]() |
![]() Join Date: Jun 2011 Location: Tacoma Wa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20,346
| Not Ranked : 0 score Fancy
__________________ Blacked Out 2010 Black Mica MazdaSpeed 3 Performance: Speed Performance 10.6:1 Built motor, CP-e Exhaust Mani, GTX3071, Tial MVR EWG, JBR 3.5" SRI, Cobb AP V3, Autotech HPFP, Guardian Angel, eBay Downpipe, CP-E Triton CBE, Treadstone TR8L Intercooler, CX Racing FMIC Piping Kit, JBR Crashbar, NGK Plugs, PNP Intake Manifold, CoolingMist WMI system w/failsafe, DM Throttle Body Spacer with Dual D07 Nozzles, |
![]() | | #137 | ![]() |
![]() Join Date: Apr 2013 Location: Atlanta, Georgia
Rep Power: 1578 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,584
| Not Ranked : 0 score Its beautiful!
__________________ '06 Mazdaspeed 6 GT Power & Drivetrain BNR S3v2 / AP V3 + 100% Meth / Autotechs / JBR Tru 3.5" SRI w/ 51R Battery / ETS TMIC / DO Meth D07 @ 100% / ACT6 Puck w/ Streetlight FW / 80mm CorkSport Exhaust / SLS Test Pipe / Turbosmart BPV / Techna-Fit SS CL / AP Shift Hammer / Bosch 3Bar / Grimspeed EBCS / NGK 1 Step Colder / JBR Boost Tubes / ProSport Sammich Plate / Rotella Suspension & Mounts KWv2 Fronts & Bilstein Rears / AIDS Rear Diff Mounts / Whiteline RSB / Prothane Lowpro Bushings / Steeda Endlinks / JBR 88RMM / JBR Solid Bushings Brakes & Wheels StopTech Slotted Rotors & Pads / Technafit SS Brake Lines / Evo X Wheels / 245/40/18 Potenza RE760s Misc Redline & Unicorn Jizz (XTM5QS) / Sharkfin Antenna / Kuda Mount of Sweetness / Full TRS Mini-H1 Retrofit w/ Demon Eyes / TRS Xb LED Fogs / Hardwired Valentine 1 w/ Bluetooth / AuxMod w/Bluetooth - Miltuned On order/To be installed: E-btec Built Motor , BNR S4, CPe EWG Exhaust Mani, Precision 46mm WG, Kozmic 6th Port, CS FSB, RDMotorsportz Crash Bar, CS Injector Seals.![]() |
![]() | | #138 | ![]() |
| Not Ranked : 0 score when is this going to be done??? dammmmnnnnn can we post cats yet?? ![]() i like seeing your progress on this crazy build. keep it up.
| The Following 2 Users Say Thank You to 865ms3 For This Useful Post: | Easter Bunny (08-18-2015), Mauro_Penguin (08-20-2015) |
![]() | | #139 | ![]() |
(Thread Starter) | Not Ranked : 0 score I don't know man. Compared to a lot of the other crazy builds on here, I'd say mine is pretty mild.
| The Following 2 Users Say Thank You to Putin 2.3T For This Useful Post: | 865ms3 (08-17-2015), Mauro_Penguin (08-20-2015) |
![]() | | #140 | ![]() |
| Not Ranked : 0 score Quit playing around and get that dyno queen rolling, Russian!
| The Following 4 Users Say Thank You to WetzMS3 For This Useful Post: | Easter Bunny (08-19-2015), Mauro_Penguin (08-20-2015), monkey.bones.007 (08-19-2015), Putin 2.3T (08-19-2015) |
![]() | | #141 | ![]() |
| Not Ranked : 0 score I demand a update to your madness
![]() | | #142 | ![]() |
![]() | | #143 | ![]() |
![]() Join Date: Jul 2012 Location: Toledo, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,271
| Not Ranked : 0 score So Uh... why the part out...?
__________________ 07 Mazdaspeed 3 Grand Touring Black Mica (The Summer Daily / Toy) Fanboy Brand Mods: A'PEXi Turbo Timer, Autotech Internals, BNR S3 V1, Bosch 3 Bar MAP, CNT 3" CBE, COBB AP V3, STS, FMIC Piping, Corksport Adjustable Shocks/Struts, CP-E Dash Pod, Safe-Seals, Enkei Evo IX (17x8+38), Exide 51RX Battery, FoMoCo XT-M5-QS, Grimmspeed EBCS, Ground Control Bumpstops, Hankook RS-3 (235/45/17), H&R Springs, Hawk HPS Pads, HTP 51R Battery Tray, JBR 88d RMM, 80d PMM, Shifter Bushings, TIG's, Secondary EGR Delete, 3.5" Aluminum WP, Mudflaps, Kozmic Primary EGR Delete, maisonvi Knob Collection, Damond OCC, NGK LTR7IX-11, Progress RSB, Prosport Boost, Oil Temp, Oil Press, Redline Tuning Hood Struts, SPC Camber Arms, Speed Daddy (Ebay) Catless DP, SP63 MAP Harness, Stratified Guardian Angel, Treadstone TR8, TRZ TMM, TurboXS H-RFL VTA BOV, XS Power V1 Manifold Maisonvi's Inherited Motor Build: ARP L19 Head Studs, Crank Bolt, Cam Bolts, Manley H-Beam Rods, SP63 Wiseco Armor Plated Pistons, New Rice, AKA To be Installed: Autoexe Front Bumper Cover, GT Spec Strut Brace, Wedge Engineering Seat Base, Sparco Speed Bucket Seat, 08 Mazda 6i Hatchback (The Daily MPG Commuter) 93 Mazda B2600i 4wd (The Winter Beater / terMINATOR Parts Hauler) |
| The Following User Says Thank You to speed3 britz For This Useful Post: | maisonvi (09-25-2015) |
![]() | | #144 | ![]() |
| The Following 11 Users Say Thank You to WetzMS3 For This Useful Post: | Easter Bunny (09-25-2015), impossible (11-24-2016), InkedInspector (09-25-2015), maisonvi (09-25-2015), Mauro_Penguin (09-25-2015), MS3Shadow (09-25-2015), NCspecV81 (09-25-2015), Pu Manchu (09-25-2015), sh4d0w (09-25-2015), sho (09-25-2015), speed3 britz (09-25-2015) |
![]() | | #145 | ![]() |
| Police ![]() Join Date: Jul 2013 Location: Louisville, KY
Rep Power: 2719 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,545
Groans: 312
| Can't believe this project got aborted. Third trimester style.
__________________ |
| The Following 6 Users Say Thank You to InkedInspector For This Useful Post: | Easter Bunny (09-25-2015), Mauro_Penguin (09-25-2015), MS3Shadow (09-25-2015), NCspecV81 (09-25-2015), speed3 britz (09-25-2015), WetzMS3 (09-25-2015) |
![]() | | #146 | ![]() |
![]() Join Date: Dec 2014 Location: Novi, MI
| Not Ranked : 0 score Putin's got to pay for that military aid he's giving to Syria somehow.
__________________ 2011 grey MS3: HTP TIP, COBB SRI, HPFP internals, CS TMIC, Dammond EGR delete, Dammond OCC, M2 full DP all of the cats deleted, freektune OTS+, denso ITV22, Maisonvi turbo bolt, CP-e S2 RMM |
| The Following 4 Users Say Thank You to pirate steve For This Useful Post: | Easter Bunny (09-25-2015), InkedInspector (09-25-2015), Mauro_Penguin (09-25-2015), MS3Shadow (09-25-2015) |
![]() | | #147 | ![]() |
(Thread Starter) | Not Ranked : 0 score The ruble has tanked. I'm not in a very stable situation financially, so had to think smart. The Syrians are cheap bastards. I gave them top of the line weapons and they pay me with cash and herd animals. What use do I have for herd animals? The goats look very used.
| The Following 5 Users Say Thank You to Putin 2.3T For This Useful Post: | Easter Bunny (09-25-2015), impossible (01-18-2016), InkedInspector (09-25-2015), Mauro_Penguin (09-25-2015), pirate steve (09-25-2015) |
![]() | | #148 | ![]() |
![]() Join Date: Aug 2012 Location: Tracy CA
| Not Ranked : 0 score It's those muslims! Get rid of them and your goats will not be abused anymore
__________________ Too much for you |
![]() | | #149 | ![]() |
![]() Join Date: Dec 2009 Location: layton, UT
__________________ In progress: Engine: Built long block by Keefover. Keyed crank,keyed cams/VVT,Crower 65lb valve springs,Wiseco pistons,Manley H beam rods,AFI t3 stock location mani,Comp turbo CT4x 53-56,Kozmic 6th port PI with 2200cc bosch injectors,N2MB WOT box,Relentless ported intake mani,Kozmic oil feed line,Custom oil return line,Ramfab 3.5" intake,Ramfab alum. crash bar,Ramfab IC piping,TR10 IC,Saiko Michi and JBR dual custom catch can setup, Guardian angel v3 with 4bar map sensor,Dual Deatschwerks in-tank fuel hat with bigger pickup,-6an nylon braided fuel lines,Fuel labs FPR,SP63 3 port EBCS,Mishimoto oil cooler, HKS SSQV1,BSD,Autotech FP internals,CPE injector seals EGR delete,TB coolant bypass delete,M2 Ebay DP Suspenion/Bracing: Sonic tuning CO's revalved by Feal Suspension, QA1 600lb rear springs, 750lb front Swift springs,AWR front and rear sway bar endlinks,Whiteline RSB,SPC front adjustable ball joints,GT spec ladder brace,SU rear interior brace,NRG harness bar. Drivetrain:SS brake lines,SS clutch line,Carbotech ax6 F&R, Southbend STG 3 endurance clutch and flywheel,SU rear diff mount,SU front rear diff mount,SP63 TC caps,DSS rear axles,AWR Trilogy mounts 70A,Hubcentric centering rings,2" brake ducting F&R,TWM STS stg 1 with bushing kit Interior:Redline custom shift boot,Redline custom steering wheel cover,Redline custom ebrake handle cover Bride Stradia V.2 rep seats,Corbeau seat brackets,JBR heavy shift knob,Custom LED gauge cluster,Custom Steering column dual gauge pod,AEM wideband failsafe,AEM oil pressure gauge,Schrothe Rallye 4 harnesses,Escort 9500ix with mirror mount and hard wired with external controller,DIY ipod adapter. Exterior: STI front lip,Enkei PF01SS 17x9 +48 wrapped in Bridgestone Potenza RE-71R's 245/45/17,Full clear bra,Muteki SR48 blue locking lug nuts,RHO side plate mount,Smoked side markers, Shark fin antenna Last edited by MS3Shadow; 09-25-2015 at 01:43 PM. | |
![]() | | #150 | ![]() |
![]() Join Date: May 2013 Location: Mejico, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,088
Groans: 30
| Not Ranked : 0 score Sucks to see things didn't pan out due to financial constraints.. This was gonna be a godly build :/
__________________ 2009 Mazdaspeed 3 w/ Manley bottom end, keyed and lightened crank, CNC ported head, 2018 JMF v2 port injection fueled, CM twin disk clutch and Precision 6466 turbo, Kozmic built gen2 transmission with final drive swap. Tuning by PD Tuning |
![]() | | #151 | ![]() |
![]() Join Date: Mar 2015
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score How did you route your hoses from your fuel cell? I have mine like this but having a hard time figuring it out lol. |
![]() | | #152 | ![]() |
Groans: 211
| Not Ranked : 0 score Quoting these necro posts most likely....99% chance.....will go un-noticed by the OP. Good luck!
![]() | | #153 | ![]() |
Groans: 370
| The Following User Says Thank You to aaronc7 For This Useful Post: | andale927 (03-02-2019) |
| Dartz Red Russian is a Putin-spec Mercedes G63 AMG 6x6 | Haltech | Automotive News | 0 | 06-10-2014 08:30 AM |
| Vladimir Putin's all-Russian limo revealed | Haltech | Automotive News | 0 | 05-08-2014 11:40 AM |
| Russian PM Putin reportedly tells Renault to put up or get out | Haltech | Automotive News | 0 | 10-26-2009 04:00 PM |
| Putin Power: Even Russian automakers to get a bailout? | Haltech | Automotive News | 0 | 03-31-2009 04:50 PM |
