| 2010 MS3 - Build Diaries Genpu - General Build Threads/Diaries. |
14Likes ![]() |
![]() Join Date: Feb 2010 Location: Dallas
Rep Power: 1531 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,819
Groans: 145
(Thread Starter) | Not Ranked : 0 score Mods on the car at this time are GT2876 running e85 and 100% meth. All this happened at about 45k miles. Now onto the build that im planning. Firs of all i don't know shit about building engines and i still need to to a lot of research so any knowledge is welcomed here. My plan is to just keep the 2876 and see what it can make. As for the engine i want to have something that can take 500whp without any issues. Parts list Manley H-beam rods Manley platinum series pistons 88mm Edgeautosport stage 3 motor build kit - OEM main bearings - Clevite h series rod bearings - Cometic head gasket - new vvt - OEM main studs Freek's H11 head studs PERM PVC plate Corksport injector seals ACT 6 puck clutch prolite or streetlite flywheel I'll add on parts if i have forgot anything but i think that should do it so far. Still need to take the engine out of the car and find a local machine shop to send it to.
__________________ 2011 MS3"Princess GRU" GT2876r AEM Meth Injection, Cobb AP, HTP 3' Intake, KMD interals, Shitty FMIC, JBR 88d RMM, JBR 88d TMM, JBR TIG's x2, JBR BSD, JBR Short THrow Shifter, JBR shifter bushings, Corksport License Plate Bracket, Forge BPV v1, ATP Downpipe, UR Straightpipe Beast Mod, Progress RSB, Koni Yellows, Eibach Pro Kit, Kosei K1-TS Gold 17x8, E85 FREEKTUNE Last edited by Zdraveca; 01-26-2016 at 11:07 AM. |
| The Following 8 Users Say Thank You to Zdraveca For This Useful Post: | camcon (02-07-2016), Castillo817 (01-24-2016), Cheapspeed (01-25-2016), kevdog (01-25-2016), MS3Shadow (01-25-2016), redneck4Christ (02-04-2016), SofaKingAwesome (01-25-2016), SpeedRebirth (01-25-2016) |
![]() Join Date: Mar 2011 Location: Cambridge, Ontario, Canada
Rep Power: 221 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
| Not Ranked : 0 score You should buy the Corksport/Tokay injector seals instead of the CP-e seals.
__________________ 2011 MAZDASPEED3 Hypnotic Tuned - Rob CPE HPFP - CPE Catted Downpipe - CPE Catback Exhaust - 3" ETS TMIC - Cobb RMM - AEM Boost Gauge & Vent Pod - CANBus Triple - Corksport BPV - Corksport hood strut - Corksport RSB - Corksport Short Shifter - HTP 3.5" Intake - Damond TMM - Damond Vented CC - Vented Oil Cap - Tokay v2 Seals - GTX3067R - Damond PCV Plate - Built Engine (Manley Rods, 88mm Supertech 4032 Piston) - |
| The Following 4 Users Say Thank You to Polish_Eagle For This Useful Post: |
![]() Join Date: Jun 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 242
| Not Ranked : 0 score Use an OEM head gasket, the off the shelf Cometics are a known fail. No reason not to use the OEM rod bearings either as they are a tad softer than Clevites if the car is daily driven.
__________________ Gen 2 2012 - Precision 6062 Turbo - CPE Exhaust Mani - PTE 46mm EWG - 2NV Industries built Forged bottom end - PNP Head - JMF V2 Intake Mani- Custom DP UR Cat Back - HTP 4 inch intake - TR8 FMIC - Custom FREEKTUNE METH Port Injection - Cobb 3 port EBC- Autotech internals - FREEKTUNED. |
![]() Join Date: Jan 2013 Location: McKinney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,778
| Not Ranked : 0 score Just 500? Don't you want to beat @Mikey; ?
__________________ 3rd rebuild on the way...maybe... |
Groans: 145
__________________ 2011 MS3"Princess GRU" GT2876r AEM Meth Injection, Cobb AP, HTP 3' Intake, KMD interals, Shitty FMIC, JBR 88d RMM, JBR 88d TMM, JBR TIG's x2, JBR BSD, JBR Short THrow Shifter, JBR shifter bushings, Corksport License Plate Bracket, Forge BPV v1, ATP Downpipe, UR Straightpipe Beast Mod, Progress RSB, Koni Yellows, Eibach Pro Kit, Kosei K1-TS Gold 17x8, E85 FREEKTUNE |
![]() Join Date: Mar 2011 Location: Dallas, Texas
| Not Ranked : 0 score Is that a 2876 or a 2867? I know I could look it up..... What's the benefit over the 3076? As far as clutch vibes, did you just barely put your foot on the clutch petal? Mine felt like I hit the brakes with full ABS and my rod wasn't bent very much
__________________ Max Bolted and Built Stock K04 |
![]() Join Date: Jun 2008 Location: Bowling Green, Kentucky.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 909
| Not Ranked : 0 score I wouldn't try to build your own motor if you've never done one before. If you have a local group that has the skilz and will help you can go that route but its a lot of work and has to be done right or you'll just be throwing away money. Find a local builder with a good reputation and get them to put together a long block for you. Dropping in a long block isn't hard so you can save money on the install.
__________________ EBTEC Manley Built // GT3071R // FreekTuned // Freek 3.5" Intake // Ported IM // Perm Plate Dual CC // Catless DP // CNT CB // Tokay V 1's // Autotech // AEM Failsafe // TR8 IC// GFB // JBR 88 RMM // DM PMM // JBR 70 TMM // ACT 6 puck prolite fly // Cobb RSB // 6 pc chassis braced // Koni FSD's // Cobb Springs // EGR Full delete // SWAS switch // SS brake lines // 100% Methanol Injection D14 ____________________________________________Dragon Slayer _________________________________________________ |
Groans: 145
I tried the clutch several times before i turned the car off and felt zero vibration. Its weird but really dont lnow whats up with that
And METH!
__________________ 2011 MS3"Princess GRU" GT2876r AEM Meth Injection, Cobb AP, HTP 3' Intake, KMD interals, Shitty FMIC, JBR 88d RMM, JBR 88d TMM, JBR TIG's x2, JBR BSD, JBR Short THrow Shifter, JBR shifter bushings, Corksport License Plate Bracket, Forge BPV v1, ATP Downpipe, UR Straightpipe Beast Mod, Progress RSB, Koni Yellows, Eibach Pro Kit, Kosei K1-TS Gold 17x8, E85 FREEKTUNE Last edited by Zdraveca; 01-25-2016 at 07:56 PM. | ||
![]() Join Date: Feb 2011 Location: Forth Worth TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,715
Groans: 104
Groaned at 45 Times in 36 Posts
well the ones that are not built 550+hp. hopefully you and Kevin will join the built club and joining us in the 400-500 range. .That way we have Jason, me, Z, David and who ever else. The more the better. ![]() I would get the CS seals over the cpe as well.
__________________ [SIGPIC][/SIGPIC] 2007 Cosmic Blue Built HTA 3076 Corn Fed with shot of Meth and Freektuned | |
![]() Join Date: Nov 2009 Location: McKinney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 852
__________________ gtx3076 and shit | |
| The Following User Says NO Thank You to kevdog For This Un-useful Post: | Mikey (01-26-2016) |
__________________ 3rd rebuild on the way...maybe... | |
| The Following User Says Thank You to Cheapspeed For This Useful Post: | Mikey (01-26-2016) |
Groans: 104
| Not Ranked : 0 score I have it too and cannot figure wtf is causing it. It pops up about every other day.. I did boost leak test and cannot find anything. Driving me crazy that and the stupid p0335 which could be as broad as a week battery. errrrrrrrrr
| The Following User Says Thank You to Mikey For This Useful Post: | Cheapspeed (01-26-2016) |
![]() Join Date: Aug 2014 Location: Garland, TX
just to add to the list of things to check
__________________ Black Mica 2008.5 CS SRI+TIP • AT HPFP • TP | |
| The Following User Says Thank You to dinoxor For This Useful Post: | Mikey (01-27-2016) |
| Not Ranked : 0 score @Zdraveca; so have you done anymore research? The more brainstorming I do, the more I add, and remove from my list. I have to remind myself that a new built block would already make waaaaay more power than my car currently capable of, so I things I thought I would need, I could probably nix.
Groans: 145
with a couple questions and im juat waiting on a response from him at the moment And METH!
__________________ 2011 MS3"Princess GRU" GT2876r AEM Meth Injection, Cobb AP, HTP 3' Intake, KMD interals, Shitty FMIC, JBR 88d RMM, JBR 88d TMM, JBR TIG's x2, JBR BSD, JBR Short THrow Shifter, JBR shifter bushings, Corksport License Plate Bracket, Forge BPV v1, ATP Downpipe, UR Straightpipe Beast Mod, Progress RSB, Koni Yellows, Eibach Pro Kit, Kosei K1-TS Gold 17x8, E85 FREEKTUNE | |
Groans: 145
(Thread Starter) | Not Ranked : 0 score Took out the intake mani last night and found some shitty valves. Enjoy
| The Following 2 Users Say Thank You to Zdraveca For This Useful Post: | Castillo817 (02-04-2016), SofaKingAwesome (02-04-2016) |
![]() Join Date: Jan 2015 Location: Fort Worth, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 289
Groaned at 44 Times in 12 Posts
| Not Ranked : 0 score All of mine looked like this. So naaaaaaasty.
__________________ 2013 VRM MS3 Freektuned--BNRS3--HTP 3" Sri--COBB apv3 & springs--CPE catted dp & safe seals--TS dual bov--AT hpfp internals--CFM rmm--JBR pmm, tmm, ssb, ebcs, TIGs, full egr delete, rsb & fmic piping/tr6--DM occ--CS cbe & ssp--SPC camber arms--Bosch 3Bar map--RA mudflaps Ambit RE82 18x9.5 +38 255/35 -v8 swap in progress- 1994 Miata DGR coilovers-Hard Dog Rollbar-STR 506 15x7.5 +15 -Sold- 2003 Protegé5 w/Hiboost turbo kit ihi vf22 turbo 5 speed -Sold- 89' FC Rx7 vert S5 13B turbo swapped |
![]() Join Date: Jun 2014 Location: McKinney, Tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25
| Not Ranked : 0 score I know I'm ridin' derty...lol. No OCC, 105K damn...when are you hosting the valve cleaning Z? I really don't want to take da 6 apart but I am afraid it may be time.
__________________ 2007 Titanium Gray ll Metallic Mazdaspeed6 #10227 Mods // SURE SRI // COBB TIH // CP-E TMIC w/Robert Roark Cork Gasket // COBB AP V3 // AUTOTECH HPFP // MD SSP // JBR RMM // H&R Springs // 3" Str8 Pipe-Beast Mod // Freektune OTS+ // ITV22 // Kevdog Tow Plate |
| Not Ranked : 0 score I have 150k and my car is doing...yeah, might be worth it.
![]() Join Date: Dec 2013 Location: Dallas, Texas
Rep Power: 0 ![]() Thanks: 1
| Not Ranked : 0 score Any updates Z? lol
| Jaguar Land Rover Special Vehicle Operations could build standalone models | Haltech | Automotive News | 0 | 03-08-2015 03:30 PM |
| My Engine Build | ledfootrob | 2010 MS3 - Build Diaries | 6 | 11-09-2014 10:51 PM |
| new engine build | 907speed6 | Mazdaspeed3/6 General Discussion | 2 | 11-15-2013 09:12 PM |
| eBay Find of the Day: 1915 van Blerck Special Speedster is 18' long with 17-liter engine | Haltech | Automotive News | 0 | 12-07-2010 02:50 PM |
| Rolls Royce to build special edition Minis? | Haltech | Automotive News | 0 | 05-26-2009 03:20 PM |
