| 2010 MS3 - Build Diaries Genpu - General Build Threads/Diaries. |
![]() Join Date: Jun 2015 Location: Salt Lake City, Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 59
(Thread Starter) | Not Ranked : 0 score Lots of pictures to come throughout the build. White Genpu Miles 20,5xx Current parts- Purple Drank Tune Speed Perf6rmanc3 Aux Fan Controller Tanabe Front Strut Tower Bar CPE Top Mount Intercooler (Sold) Resonator Delete Corksport Race Pipe (Sold) Corksport Fuel Injector Seals Prosport 52mm Halo Boost Gauge Cobb Shift Knob Cobb Rear Motor Mount Cobb Air Box (Sold) Cobb Short Ram Intake (Sold) Cobb Access Port Devils DVC-30 Water/Meth Injection Vibrant Boost Manifold JBR Rear Sway Bar JBR Oil Restrictor Bolt (Sold) JBR Boost Tubes (Sold) JBR Catch Can JBR Turbo Inlet Pipe (Sold) JBR Turbo Bypass Hose JBR EGR Delete JBR Thermal Intake Insulating Gasket/Throttle Body JBR Solid Shifter Bushings JBR Short Shifter Plate JBR 5mm Wheel Spacers Auto Tech HPFP Internals Dimple Dell Magnetic Drain Plugs Engine/Transmission Parts to come- BNR S4 (Purchased) Cobb 3 Port Boost Controller (Purchased) 3 Bar Map (Purchased) JBR 3.5 Intake (Purchased) TR8 Core / CXRacing Piping (Purchased) CPE Catted DP (Purchased) CPE Cat Back Exhaust (Purchased) SP63 Valve Cover Breather (Purchased) Cobb BPV (Purchased) Damond Mounts (Purchased) 51r Battery (Purchased) AEM AFR Failsafe (Purchased)
__________________ 2013 MS3 // Purple Drank Tune // BNR S4 // All the other shit to go along with it Last edited by Ziggyboy; 06-27-2016 at 10:19 PM. |
| The Following 4 Users Say Thank You to Ziggyboy For This Useful Post: |
![]() Join Date: Aug 2012 Location: Tracy CA
| Not Ranked : 0 score In for results.
__________________ Too much for you |
(Thread Starter) | Not Ranked : 0 score SnailD posted some dyno sheets with a speed3 making around 400 at 23psi. Anything close to 400 and I will be happy.
__________________ 2013 MS3 // Purple Drank Tune // BNR S4 // All the other shit to go along with it |
| The Following User Says Thank You to Ziggyboy For This Useful Post: | knocturnal (10-20-2015) |
| Not Ranked : 0 score Nice! I recently as in a couple months ago was fully bolted on 5 gal of E spraying meth from 17lbs plus on a BNRS3 and was making 390... I wasn't impressed. So what you read in my signature is the results of the last 3 months going back to drawing bored and starting new. I thought the same thing thinking that would be enough but I was not satisfied.
![]() Join Date: Dec 2013 Location: Plainfield, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,712
| Not Ranked : 0 score This is the turbo I plan on running so I'm in for results!
__________________ 2010 black mica speed3 The go: Depo racing: downpipe (100 cell count), custom: FMIC. HTP: 3.5" intake, under route piping. JBR: shortshifter, RSB. Autotech: HPFP internals. Go fast bits: hybrid BPV, VMR: 18x8.5 V710s, Bridgestone: potenza re760 245/40/18, KW: v3 coilovers,SPC: camber arms, freektuned, Damond Motorsports: dual OCC, PMM, PCV plate, RMM, TMM, EGR delete, FoSt mani, Corksport: battery box(fuck this thing), injector seals, Cobb: EBCS, AP v3. AEM: methanol. Seibon: carbon fiber hood. UR: catback. Bosch: 3bar. BNR: s4, DNP: EWG manifold, Tial: 38mm mvs EWG. The show: 5% tint all around, 50% tint windshield, rally armor mudflaps, Sony XAV64BT touchscreen headunit, katskin leather interior, CPE relocation plate, Maisonvi weighted shift knob, Corksport hoodscoop, black housing headlights. Soon:built motor |
(Thread Starter) | Not Ranked : 0 score I chose not to go with the BNR S3 due to it being maxed out around 380 or so running e85 and meth. This way with the S4 if I'm not happy I can build the block and go crazy.
(Thread Starter) | Not Ranked : 0 score Weather sucks so I grabbed a few pics of the car in the garage. Just wanted to show you guys the current setup.
__________________ 2013 MS3 // Purple Drank Tune // BNR S4 // All the other shit to go along with it Last edited by Ziggyboy; 10-05-2015 at 09:27 AM. |
![]() Join Date: Mar 2013 Location: Huntsville, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,402
| Not Ranked : 0 score Which FMIC you planning to run, and are you considering clocking for under-routed piping?
__________________ Manley forged long block, secret snail, manifolds, and 2gal E85 tune running like a champ - about to dial in a lot of meth and see what we've got. 13.10@117.1 full weight DD no prep 1/4 (BNR S3 / E85) |
(Thread Starter) | Not Ranked : 0 score I'm leaning towards the JBR piping kit with a TR8 core. If I can find a good deal I will go with the under-routed setup. I'm a poor State employee so I have to find the best deals I can.
| The Following 2 Users Say Thank You to Ziggyboy For This Useful Post: | 5doorsoffury (10-20-2015), JgamB (10-05-2015) |
| Police ![]() Join Date: Jul 2013 Location: Louisville, KY
Rep Power: 2719 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,545
Groans: 312
| Keep in mind the one Snail tuned is at altitude in Colorado, that set up would be making much more power if it could actually breath. I'm excited to see what you get out of this set up!
__________________ |
(Thread Starter) | Not Ranked : 0 score I'm also at high altitude in Utah 4500-5000 FT. All I know is it has to be better then the K04.
| The Following User Says Thank You to Ziggyboy For This Useful Post: | InkedInspector (10-05-2015) |
| Nishan ![]() Join Date: Apr 2012
Rep Power: 9816 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,290
| Not Ranked : 0 score Very nice setup. I am currently tuning a car with an S4 here now. Haven't turned up the boost yet, but it looks promising.
__________________ www.tunedbynishan.com |
| The Following 3 Users Say Thank You to ms3blackmica For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score Have you noticed any sort of boost creep like some of the larger GT30 sized turbos with IWG?
![]() Join Date: Nov 2010 Location: Reading, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23,158
Groans: 731
| Not Ranked : 0 score any particular reason you're running the jbr oil bolt?
__________________ Mods: stock Eventually I'll pay for how I am....but it won't be by the hand of any of you faggot fucks here. |
(Thread Starter) | Not Ranked : 0 score I was attempting to avoid a smokey K04, even though they are kind of hit or miss with which ones have problems.
(Thread Starter) | Not Ranked : 0 score 10 done over at BNR Supercars, more to ship next week.
Boost control is super smooth and easy to manage.
__________________ www.tunedbynishan.com | |
| The Following 4 Users Say Thank You to ms3blackmica For This Useful Post: |
![]() Join Date: Nov 2014 Location: La Porte, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 56
| Not Ranked : 0 score Definitely sounding like the go to option for me. looking forward to more info. |
(Thread Starter) | Not Ranked : 0 score So I'm still waiting on the turbo to arrive, but I was able to pick up a few parts in the meantime. Thanks to the MSF for sale section, I was able to grab a TR8 Core with a CXRacing piping kit and a JBR 3.5 intake. Piping kit wasn't my first choice, but after doing a little research it should be fine. Will try to grab some more pics of the car this weekend cleaned up and outside of my garage.
![]() Join Date: Mar 2013 Location: Phoenix, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 667
| Not Ranked : 0 score @Ziggyboy; how long do you have to wait to get the BNR S4 turbo? I'm thinking of ordering one or rebuilding my S3. Not sure if upgrading S3 to S4 would make a huge difference.
__________________ '07 MS6: HTP 3 Inch Intake.Cobb AP.CorkSport CBE.ATP DP.FMIC.AutoTech Internals.Bosch 3 Bar map sensor.GRIMMSPEED 3 PORT EBCS. BNR S4.WISECO 9:5 pistons. Manley H-Beam rods. Keyed Crank by APEX. SouthBend Stage 3 clutch kit. Bilstein shocks. H&R Springs. |
![]() Join Date: May 2012 Location: Virginia Beach, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 101
| Not Ranked : 0 score Subbed so i can see the results when i get back. Plan on going S4 with a D010 nozzle tuned by @snailD; My car and right foot loves his tunes
__________________ 2012 Crystal White Pearl MazdaSpeed 3 Mods: BNR S4 V2 // XS Power Manifold V3 // JBR Tru-3.0" Aluminum Intake // Devils Own WMI D10 NOZZLE// JBR DISI Bypass Valve Hose // JBR 70duro RMM // JBR SSB // JBR SSP // JBR Coolant Bypass Kit // DM EGR Full Delete Kit // DM TMM // DM PMM // COBB AP V2 // CNT Racing Catless Downpipe // CP-E TMIC // CP-E Injector Seals // SP63 Valve Cover Breather // Custom 3" Magnaflow exhaust //One Step Colder NGK Plugs // Bosch 3bar Map sensor // Grimmspeed EBCS // MD OCC // MD PCV Plate // Stop Tech Braided Lines // Autotech Internals // Forge BPV V1 // Corksport V2 RSB // Eibach PRO-kit Stratified Tuned Stage 2 OTS+ 273whp/330wtq SnailD Tuned on Meth 316whp/359wtq Purple Drank Tuned BNR S4 V2 and 100%Meth 412whp/373wtq |
| you don't really need a small battery box/51R battery tray. both the ECU and the 51R Battery will fit inside of the stock battery box.
| The Following User Says Thank You to MS3Shadow For This Useful Post: | Ziggyboy (10-20-2015) |
Yeah, I have been looking at a few threads with info on making everything fit. Waiting on getting everything mocked up before I make the decision on what I want to do.
__________________ 2013 MS3 // Purple Drank Tune // BNR S4 // All the other shit to go along with it Last edited by Ziggyboy; 10-20-2015 at 07:23 AM. Reason: MSF Database - Automerged Doublepost | |
| The Following 2 Users Say Thank You to Ziggyboy For This Useful Post: | MS3Shadow (10-20-2015), SamiChicago (10-20-2015) |
![]() | | #24 | ![]() |
| i can take a picture of mine if you want. it's more easier than you think. you make a small cut just so the ECU cables can fit and that's it. the battery and ecu would be covered unlike using battery tray and saves you over $100+
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score Please do.
![]() | | #26 | ![]() |
| The Following 2 Users Say Thank You to MS3Shadow For This Useful Post: | aaronsleeps (05-05-2016), Ziggyboy (10-20-2015) |
![]() | | #27 | ![]() |
| Not Ranked : 0 score The only issue I could see, is if the battery fails or shorts and leaks, pops, etc. |
| The Following User Says Thank You to Raider For This Useful Post: | Ziggyboy (10-20-2015) |
![]() | | #28 | ![]() |
| Not Ranked : 0 score I bought JBRs battery tray off here and I do hate how the ecu isn't covered. Of course I haven't installed it yet but I'm gunna try and make a custom cover to cover both the battery and ECU
![]() | | #29 | ![]() |
| i do have a rubber piece in between them, i might put a bigger piece to cover it from the battery.
![]() | | #30 | ![]() |
Groans: 438
| Not Ranked : 0 score Go with the battery in the trunk. Makes working in the engine bay so much easier all the time.
__________________ All good things must come to an end... |
| The Following 4 Users Say Thank You to g00s3y For This Useful Post: |
![]() | | #31 | ![]() |
(Thread Starter) | Not Ranked : 0 score Over the weekend I began tearing out the parts that are going to be replaced. Everything took about 4 hours including a trip to Harbor Freight to pick up an oxygen sensor socket. A bunch of parts should be rolling in this week so I can start putting things back together.
__________________ 2013 MS3 // Purple Drank Tune // BNR S4 // All the other shit to go along with it Last edited by Ziggyboy; 10-26-2015 at 07:02 PM. |
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score I was able to extend the coolant hose that can cause some issues with larger intakes. This may seem like common sense to most, but there are some that may need a little more info on how its done. Total cost was $7.00 and any local parts store should have everything. Gates 5/8" Hose Connector- Part #28604 3" of 5/8" Heater Hose HoseClamps Find the coolant line that runs directly beneath the EGR valve and connects to the firewall behind the turbo. Use something to clamp the line to prevent a large loss of engine coolant. I used a pair of channel-locks and a rag to soak up the fluid that came out. Find something to plug the line you pull the hose off, so you don't loose a bunch of fluid from that as well. Assemble 3" of hose and the 5/8" Gates connector. Place this between the hose and metal line, then tighten everything back up.
__________________ 2013 MS3 // Purple Drank Tune // BNR S4 // All the other shit to go along with it Last edited by Ziggyboy; 10-20-2015 at 06:20 PM. |
![]() | | #33 | ![]() |
![]() Join Date: Jan 2013 Location: Pocatello, ID
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29
| Not Ranked : 0 score Does your intake push on the battery box and are you still on the stock turbo? Maybe the S3 shifts the intake over more than the ko4 does. I like how you did your box. I thought about positioning the ECU like that, but decided not to to avoid adding any stress to the wires.
__________________ Power: Powered by Purple Drank, BNRS3, JBR 3.5, Grimspeed EBCS, 3-bar map, CP-e FMIC, Autotech HPFP, Forge V2 BPV, VTCS delete, DM OCC, Empire water pump pulley, BSD, JBR pan baffle, ebay downpipe, CP-e CBE, NGK step colder plugs, TIGs, CP-E Safe seals, DM EGR delete, etc. Handling: Eibach prokit, SPC camber arms, RX8 wheels, 235/40/18, Goodridge Stainless brake lines, EBC redstuff, mazda 5 rear brakes, Custom mid chasis brace, WR front strut brace, TB traction bar, TB trunk brace, JBR rear sway bar, Moog links, DM RMM, OEM poly filled PMM, CS TMM insert, JBR solid shifter bushings, AP shift hammer, Other: Android Stereo running torque pro, MZ style lip, Corksport LED lights, HIDs, lots of other random stuff |
![]() | | #34 | ![]() |
| Not Ranked : 0 score @Ziggyboy; I would recommend some additional improvements to your motor mounts. At least a corksport insert for the TMM. I poly filled my stock PMM and it isn't too loud, but definitely helps (and was cheap). If your car is down for a bit it would be a good time to try it. Also, I think I found you on KSL. Since I don't live near any other speeds you are one of the most "local" to me.
| The Following User Says Thank You to superman For This Useful Post: | Ziggyboy (10-20-2015) |
![]() | | #35 | ![]() |
__________________ 2013 MS3 // Purple Drank Tune // BNR S4 // All the other shit to go along with it | |
![]() | | #36 | ![]() |
Since that's how stock was but a bit closer.
Will keep the engine rock solid and with minimal NVH. sent from my Nexus 6P
__________________ 2013 Crystal White Pearl Mazdaspeed 3 w/ Tech Package BNR S4, XSPower v3 Exhaust Manifold w/ Tial 44mm EWG Cobb accessport V3, Dizzy Tune in progress CP-e stage2 rmm, tmic, hpfp JBR boost tubes, Tru-3.5in Intake inside a Corksport Cold Air Box, Catless Downpipe & Racepipe, bypass hose, hood scoop, BPV, hood struts, stubby antenna, Aluminum Skid Plate, EBCS, 3.5BAR MAP Sensor, Magnaflow Catback Exhaust DM Full EGR Delete, Passenger Motor Mount, Transmission Motor Mount., Coolant Bypass, VTCS Delete, NGK ILTR6A-7G ,G-LOC R6 Brake pads and Centric High Carbon brake rotors Looks: 25% tint front, 5% back, Heat-blocking front windshield film Escort Passport Max360, RGBW Halos/Demon Eyes 20'' LED Light bar Use my Updated Custom Google Search to search this forum since the advanced search here is broken | ||
![]() | | #37 | ![]() |
(Thread Starter) | Not Ranked : 0 score JBR 3.5" Intake arrived today along with a few misc parts. Should be able to have the turbo installed this weekend. Wanted to thank everybody for ideas and information so far.
| The Following User Says Thank You to Ziggyboy For This Useful Post: | ItsNox (10-21-2015) |
![]() | | #38 | ![]() |
![]() Join Date: Apr 2013 Location: Atlanta, Georgia
Rep Power: 1578 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,584
| Not Ranked : 0 score If you want race car vibes go with JBR. If you want less vibes with the same mounted benefit, Damond seems to be the way to go. Sent from my big ass Note 4 using shitty Tapatalk.
__________________ '06 Mazdaspeed 6 GT Power & Drivetrain BNR S3v2 / AP V3 + 100% Meth / Autotechs / JBR Tru 3.5" SRI w/ 51R Battery / ETS TMIC / DO Meth D07 @ 100% / ACT6 Puck w/ Streetlight FW / 80mm CorkSport Exhaust / SLS Test Pipe / Turbosmart BPV / Techna-Fit SS CL / AP Shift Hammer / Bosch 3Bar / Grimspeed EBCS / NGK 1 Step Colder / JBR Boost Tubes / ProSport Sammich Plate / Rotella Suspension & Mounts KWv2 Fronts & Bilstein Rears / AIDS Rear Diff Mounts / Whiteline RSB / Prothane Lowpro Bushings / Steeda Endlinks / JBR 88RMM / JBR Solid Bushings Brakes & Wheels StopTech Slotted Rotors & Pads / Technafit SS Brake Lines / Evo X Wheels / 245/40/18 Potenza RE760s Misc Redline & Unicorn Jizz (XTM5QS) / Sharkfin Antenna / Kuda Mount of Sweetness / Full TRS Mini-H1 Retrofit w/ Demon Eyes / TRS Xb LED Fogs / Hardwired Valentine 1 w/ Bluetooth / AuxMod w/Bluetooth - Miltuned On order/To be installed: E-btec Built Motor , BNR S4, CPe EWG Exhaust Mani, Precision 46mm WG, Kozmic 6th Port, CS FSB, RDMotorsportz Crash Bar, CS Injector Seals.![]() |
| The Following User Says Thank You to ItsNox For This Useful Post: | Deldran (10-24-2015) |
![]() | | #39 | ![]() |
(Thread Starter) | Not Ranked : 0 score I will be going with Damond but haven't decided if I should also replace my Cobb RMM.
![]() | | #40 | ![]() |
| Yeah, you should replace it, I'm going to replace my CPE stage 2 RMM with a DM RMM sent from my Nexus 6P
| The Following User Says Thank You to MS3Shadow For This Useful Post: | MD1032 (11-01-2015) |
| Build me a BIG Turbo Build for MS3 | NCspecV81 | 2010 MS3 - Big Turbo Builds | 14 | 04-15-2013 02:16 PM |
| Report: Fiat to build Alfa Romeo SUV alongside Jeeps in America, build small car in Italy | Haltech | Automotive News | 0 | 09-02-2011 07:20 AM |
| Chrysler to build plug-in Ram test fleet, won't build Two Mode hybrid pickup | Haltech | Automotive News | 0 | 03-22-2010 10:10 PM |
| Theory: Build before Build | demonspeed | MazdaSpeed 6 - Engine, Transmission & Driveline | 5 | 02-10-2009 06:52 PM |
| Build-a-Bull: Automobile mag helps build the first production Lambo LP560-4 | Haltech | Automotive News | 0 | 04-01-2008 05:20 PM |
