| 2010 MS3 - Build Diaries Genpu - General Build Threads/Diaries. |
![]() | | #81 | ![]() |
![]() | | #82 | ![]() |
![]() Join Date: Jun 2015 Location: Salt Lake City, Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 59
(Thread Starter) | Not Ranked : 0 score Sorry for the lack of updates over the last couple weeks, I've been busy with a new addition to the family. I was able to get the DP installed, along everything under the car buttoned back up. COBB BPV and valve cover breather are on, and now I'm looking into a vented OCC from Damond Motorsports along with a set of his mounts.
__________________ 2013 MS3 // Purple Drank Tune // BNR S4 // All the other shit to go along with it Last edited by Ziggyboy; 11-14-2015 at 09:39 PM. |
| The Following 3 Users Say Thank You to Ziggyboy For This Useful Post: |
![]() | | #83 | ![]() |
(Thread Starter) | Not Ranked : 0 score I got the idea stuck in my head that I needed a second OCC. Thought about getting a Damond OCC, but decided I wanted to tinker around and make something. I wanted to give a shout out to Damond Motorsports. Matt was cool enough to take some of his Mario Cart time at home, and talk with me about mounts and OCC's. I had a Mishimoto OCC sitting around from another project that is long gone, and decided to make it work. A small strip of aluminum, couple of brass fittings, and a drain valve were all that was needed to get the project finished. Getting to the drain valve is easy, even with the battery box in. I also put a new drain valve on my JBR OCC due to the other valve being stuck. Let me know if you guys see any issues with the set up.
__________________ 2013 MS3 // Purple Drank Tune // BNR S4 // All the other shit to go along with it |
| The Following User Says Thank You to Ziggyboy For This Useful Post: | Fonsi (12-02-2015) |
![]() | | #84 | ![]() |
(Thread Starter) | Not Ranked : 0 score I finished up a couple of things this week. Damond mounts went in, along with a 51r battery. Fabricated a aluminum battery strap, due to the factory strap sitting across the harness wires. I'm still waiting on getting my crash bar back, then I can finish up installing the intercooler.
| The Following User Says Thank You to Ziggyboy For This Useful Post: | neganox (12-07-2015) |
![]() | | #85 | ![]() |
![]() Join Date: Dec 2013 Location: Plainfield, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,712
| Not Ranked : 0 score I'm envious of your mounts sir.
__________________ 2010 black mica speed3 The go: Depo racing: downpipe (100 cell count), custom: FMIC. HTP: 3.5" intake, under route piping. JBR: shortshifter, RSB. Autotech: HPFP internals. Go fast bits: hybrid BPV, VMR: 18x8.5 V710s, Bridgestone: potenza re760 245/40/18, KW: v3 coilovers,SPC: camber arms, freektuned, Damond Motorsports: dual OCC, PMM, PCV plate, RMM, TMM, EGR delete, FoSt mani, Corksport: battery box(fuck this thing), injector seals, Cobb: EBCS, AP v3. AEM: methanol. Seibon: carbon fiber hood. UR: catback. Bosch: 3bar. BNR: s4, DNP: EWG manifold, Tial: 38mm mvs EWG. The show: 5% tint all around, 50% tint windshield, rally armor mudflaps, Sony XAV64BT touchscreen headunit, katskin leather interior, CPE relocation plate, Maisonvi weighted shift knob, Corksport hoodscoop, black housing headlights. Soon:built motor |
![]() | | #86 | ![]() |
(Thread Starter) | Not Ranked : 0 score I'm excited to try them out, everybody seems to swear by them. I didn't get the RMM, ended up staying the COBB RMM for now.
![]() | | #87 | ![]() |
| Not Ranked : 0 score Yea ill be switching out my JBR mounts for Damond. First one to go is passenger.
![]() | | #88 | ![]() |
(Thread Starter) | Not Ranked : 0 score So I figured I've made it this far in the build and might as well get a catback exhaust. Purchased the CPE Triton through @EdgeAutosport.com tonight. I should have waited and purchased my CPE DP now instead of at the beginning of this month, could have saved 15%.
![]() | | #89 | ![]() |
![]() Join Date: May 2012 Location: Ontario
![]() You could "technically" exchange the downpipe for an on sale downpipe
__________________ My car thread: http://www.mazdaspeedforum.org/forum/forum/f542/pwdunmore-s-2012-a-150456/ | |
![]() | | #90 | ![]() |
| Not Ranked : 0 score Or he can just switch to geico and save 15%. Just throwin out options
![]() | | #91 | ![]() |
![]() Join Date: Jan 2013 Location: Pocatello, ID
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29
__________________ Power: Powered by Purple Drank, BNRS3, JBR 3.5, Grimspeed EBCS, 3-bar map, CP-e FMIC, Autotech HPFP, Forge V2 BPV, VTCS delete, DM OCC, Empire water pump pulley, BSD, JBR pan baffle, ebay downpipe, CP-e CBE, NGK step colder plugs, TIGs, CP-E Safe seals, DM EGR delete, etc. Handling: Eibach prokit, SPC camber arms, RX8 wheels, 235/40/18, Goodridge Stainless brake lines, EBC redstuff, mazda 5 rear brakes, Custom mid chasis brace, WR front strut brace, TB traction bar, TB trunk brace, JBR rear sway bar, Moog links, DM RMM, OEM poly filled PMM, CS TMM insert, JBR solid shifter bushings, AP shift hammer, Other: Android Stereo running torque pro, MZ style lip, Corksport LED lights, HIDs, lots of other random stuff | |
![]() | | #92 | ![]() |
(Thread Starter) | Not Ranked : 0 score No on the extra muffler and it is the titan finish.
![]() | | #93 | ![]() |
(Thread Starter) | Not Ranked : 0 score Crash bar is back and mounted up. Added a little paint to make things look nice.
![]() | | #94 | ![]() |
![]() Join Date: Sep 2015 Location: OKC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score how did you fabricate the battery tie down? im going to do that too, i dont have the battery cover though lol. And Im new here, i cant find the forsale section anywhere.
__________________ 08 MS Tres Cobb SF- CS TIH- CS hpfp internal-DM rmm- Down tunnel to straight 3 inch-Cobb XLE- CS OCC Changed oil 12+ times within 2 weeks FoMoCocoCocoCo |
![]() | | #95 | ![]() |
| Not Ranked : 0 score Need to donate to access the for sale section
![]() | | #96 | ![]() |
![]() Join Date: Mar 2013 Location: Accokeek MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 81
Groaned at 7 Times in 5 Posts
__________________ 2013 LSM w/tech Cobb AP V3, CBE CS Turbo tuned by PD Corksport Catted DP/HPFP Internals JBR FMIC Pipe Kit w/TR8 CP-E TIP/3.5" Intake DM OCC/TMM Forge V2 BPV Bilstein B8 w/Swift springs Wilwood 6 pot BBK EBC RedStuff rear pads Konig Hypergram 18x8.5" | |
![]() | | #97 | ![]() |
Aluminum Flat Bar Link
__________________ 2013 MS3 // Purple Drank Tune // BNR S4 // All the other shit to go along with it Last edited by Ziggyboy; 12-07-2015 at 09:17 PM. | |
![]() | | #98 | ![]() |
(Thread Starter) | Not Ranked : 0 score Update time. Car is moving under its own power with no major issues, leaks, or hardware problems. The CPE exhaust was a little loud for my liking, so I ended up having a MF Performance muffler welded in. Hypnotic Tune is in progress, currently on the second revision. Shout out to @rfinkle2 for answering all of my questions and responding extremely fast. Decided to run 100% Meth and will be upgrading to AN lines on my Devils Own setup. Just need everybody to keep calm for a little bit longer while I compile logs, video, pictures, and data.
![]() | | #99 | ![]() |
![]() Join Date: Apr 2013 Location: Atlanta, Georgia
Rep Power: 1578 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,584
__________________ '06 Mazdaspeed 6 GT Power & Drivetrain BNR S3v2 / AP V3 + 100% Meth / Autotechs / JBR Tru 3.5" SRI w/ 51R Battery / ETS TMIC / DO Meth D07 @ 100% / ACT6 Puck w/ Streetlight FW / 80mm CorkSport Exhaust / SLS Test Pipe / Turbosmart BPV / Techna-Fit SS CL / AP Shift Hammer / Bosch 3Bar / Grimspeed EBCS / NGK 1 Step Colder / JBR Boost Tubes / ProSport Sammich Plate / Rotella Suspension & Mounts KWv2 Fronts & Bilstein Rears / AIDS Rear Diff Mounts / Whiteline RSB / Prothane Lowpro Bushings / Steeda Endlinks / JBR 88RMM / JBR Solid Bushings Brakes & Wheels StopTech Slotted Rotors & Pads / Technafit SS Brake Lines / Evo X Wheels / 245/40/18 Potenza RE760s Misc Redline & Unicorn Jizz (XTM5QS) / Sharkfin Antenna / Kuda Mount of Sweetness / Full TRS Mini-H1 Retrofit w/ Demon Eyes / TRS Xb LED Fogs / Hardwired Valentine 1 w/ Bluetooth / AuxMod w/Bluetooth - Miltuned On order/To be installed: E-btec Built Motor , BNR S4, CPe EWG Exhaust Mani, Precision 46mm WG, Kozmic 6th Port, CS FSB, RDMotorsportz Crash Bar, CS Injector Seals.![]() | |
![]() | | #100 | ![]() |
![]() Join Date: Apr 2012 Location: port orchard, w.a
Rep Power: 501 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 655
An lines are the only way man. No issues since i upgraded.
__________________ COBB ACCESSPORT//TURBOXS CATLESS DP+RACEPIPE//3 BAR MAP//3.5" HTP INTAKE//NGK 1 STEP COLDER PLUGS//HKS CATBACK//AUTOTECH INTERNALS//COBB FMIC V2.0//HKS BOV BLACK EDITION IN VTA//RPF1 17x9//pilot super sport 245/45/17//ACT 6 PUCK//M.D OCC VTA//TOKAY SEALS//BNR S4//Hypnotic tuned | |
| The Following User Says Thank You to blackms3_71 For This Useful Post: | Ziggyboy (04-08-2016) |
![]() | | #101 | ![]() |
![]() | | #102 | ![]() |
(Thread Starter) | Not Ranked : 0 score During cold starts its loud as shit, much louder than stock. During idle its about the same, just a little deeper in tone. While driving around I find it to be just right, its louder but you can still enjoy a conversation in the car without yelling. Highway drone is very minimal, and of course when you go WOT it will make other drivers know you are next to them. If I had to do it again, I would get the muffler added from CPE. It is loud as fuck without one. Hope this helps.
![]() | | #103 | ![]() |
| Not Ranked : 0 score Updates?
| The Following User Says Thank You to Djohns For This Useful Post: | blackms3_71 (01-03-2016) |
![]() | | #104 | ![]() |
![]() Join Date: Aug 2014 Location: Lehigh Valley, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 108
| Not Ranked : 0 score Dyno #'s and what not...
__________________ MS6 GT...REBUILD IN PROGRESS BOLTED AND BOOST PROVIDED BY... SPEED1/CORKSPORT... |
![]() | | #105 | ![]() |
(Thread Starter) | Not Ranked : 0 score Still tuning with Mr. Finkle. I have had horrible weather and logs have been few and far between. We are still working on a 91 oct tune and soon will be starting meth. Sorry for the delay on numbers.
![]() | | #106 | ![]() |
![]() Join Date: Jun 2014 Location: Chatsworth, CA
Rep Power: 122 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 33
| Not Ranked : 0 score Any updates on this? |
![]() | | #107 | ![]() |
(Thread Starter) | Not Ranked : 0 score Getting close to being finished. I have been chasing boost leaks, upgrading to SS meth lines, and waiting for weather to allow for logs. 91 Octane tune is done and we are currently working on the meth tune.
![]() | | #108 | ![]() |
![]() Join Date: Jan 2015 Location: Fort Worth, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 289
Groaned at 44 Times in 12 Posts
| Not Ranked : 0 score What were your numbers on 91?
__________________ 2013 VRM MS3 Freektuned--BNRS3--HTP 3" Sri--COBB apv3 & springs--CPE catted dp & safe seals--TS dual bov--AT hpfp internals--CFM rmm--JBR pmm, tmm, ssb, ebcs, TIGs, full egr delete, rsb & fmic piping/tr6--DM occ--CS cbe & ssp--SPC camber arms--Bosch 3Bar map--RA mudflaps Ambit RE82 18x9.5 +38 255/35 -v8 swap in progress- 1994 Miata DGR coilovers-Hard Dog Rollbar-STR 506 15x7.5 +15 -Sold- 2003 Protegé5 w/Hiboost turbo kit ihi vf22 turbo 5 speed -Sold- 89' FC Rx7 vert S5 13B turbo swapped |
![]() | | #109 | ![]() |
![]() Join Date: May 2012 Location: Virginia Beach, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 101
| Not Ranked : 0 score Ziggy I just want to let you know that I am out to sea and I am waiting for these numbers so that I can make a decision on buying this turbo or not lol. let me know how its going. your input is much appreciated!
__________________ 2012 Crystal White Pearl MazdaSpeed 3 Mods: BNR S4 V2 // XS Power Manifold V3 // JBR Tru-3.0" Aluminum Intake // Devils Own WMI D10 NOZZLE// JBR DISI Bypass Valve Hose // JBR 70duro RMM // JBR SSB // JBR SSP // JBR Coolant Bypass Kit // DM EGR Full Delete Kit // DM TMM // DM PMM // COBB AP V2 // CNT Racing Catless Downpipe // CP-E TMIC // CP-E Injector Seals // SP63 Valve Cover Breather // Custom 3" Magnaflow exhaust //One Step Colder NGK Plugs // Bosch 3bar Map sensor // Grimmspeed EBCS // MD OCC // MD PCV Plate // Stop Tech Braided Lines // Autotech Internals // Forge BPV V1 // Corksport V2 RSB // Eibach PRO-kit Stratified Tuned Stage 2 OTS+ 273whp/330wtq SnailD Tuned on Meth 316whp/359wtq Purple Drank Tuned BNR S4 V2 and 100%Meth 412whp/373wtq |
![]() | | #110 | ![]() |
![]() Join Date: May 2013 Location: Mejico, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,088
Groans: 30
| Not Ranked : 0 score Month later.. any updates?
__________________ 2009 Mazdaspeed 3 w/ Manley bottom end, keyed and lightened crank, CNC ported head, 2018 JMF v2 port injection fueled, CM twin disk clutch and Precision 6466 turbo, Kozmic built gen2 transmission with final drive swap. Tuning by PD Tuning |
![]() | | #111 | ![]() |
I would love to post logs but I want to provide accurate information. Remember that I'm at high altitude (5500 FT) with 91 octane gas. Straight 91 will put me in area of 320 safely. With meth we should dial things in right around 400 HP. As soon as these bugs are straightened out I will post up some accurate logs. These are the last numbers before running out of octane on a D07 nozzle. The car is hitting 20 PSI by 3300 RPM and 25 PSI by 4200 RPM.
__________________ 2013 MS3 // Purple Drank Tune // BNR S4 // All the other shit to go along with it Last edited by Ziggyboy; 04-11-2016 at 05:09 PM. | |
| The Following 2 Users Say Thank You to Ziggyboy For This Useful Post: | ItsNox (03-21-2016), speedfreak44 (03-21-2016) |
![]() | | #112 | ![]() |
(Thread Starter) | Not Ranked : 0 score So I guess when you have shit 91 gas and high altitude, its takes e85 and meth to take advantage of my S4. I will give this a shot and see what happens.
![]() | | #113 | ![]() |
![]() | | #114 | ![]() |
(Thread Starter) | Not Ranked : 0 score I have to travel 45 miles round trip to get my e85. We shall see what happens on a two gallon mix of e85 and a d12 nozzle of 100% meth.
![]() | | #115 | ![]() |
![]() | | #116 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yes. Not trying to do anything too crazy just end up in the high 300 HP range.
![]() | | #117 | ![]() |
(Thread Starter) | Not Ranked : 0 score Attached is two runs from my final 91 octane map.
![]() | | #118 | ![]() |
| Not Ranked : 0 score Damn thats pretty weak. I male more with my ko4 with a d10 nozzle.
![]() | | #119 | ![]() |
| Neutral : +1 score The difference from 5000' elevation to sea level for me is almost 40 HP. @Ziggyboy; I don't think that's weak for Utah 91 at your elevation. Sent from my Nexus 6P using Tapatalk
| The Following User Says Thank You to superman For This Useful Post: | Ziggyboy (04-11-2016) |
![]() | | #120 | ![]() |
| Not Ranked : 0 score Oh, i didnt relize you where so high up
| Build me a BIG Turbo Build for MS3 | NCspecV81 | 2010 MS3 - Big Turbo Builds | 14 | 04-15-2013 02:16 PM |
| Report: Fiat to build Alfa Romeo SUV alongside Jeeps in America, build small car in Italy | Haltech | Automotive News | 0 | 09-02-2011 07:20 AM |
| Chrysler to build plug-in Ram test fleet, won't build Two Mode hybrid pickup | Haltech | Automotive News | 0 | 03-22-2010 10:10 PM |
| Theory: Build before Build | demonspeed | MazdaSpeed 6 - Engine, Transmission & Driveline | 5 | 02-10-2009 06:52 PM |
| Build-a-Bull: Automobile mag helps build the first production Lambo LP560-4 | Haltech | Automotive News | 0 | 04-01-2008 05:20 PM |
