> 2010 MS3 - Build Diaries
Like Tree26Likes
 Old 04-25-2016, 12:12 PM   #121
voodoo2crue's Avatar
Posts: 371   (View Stats)
voodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the world
@Ziggyboy; Any progress on the E85 tune?
ItsNox and Ziggyboy like this.
2012 MS3 VRM/w Tech
Self Tuned BNR S4/SP63 4032 88mm pistons/Manley Rods/Power XS Manifold/JBR BSD with Baffle Plate/Cobb APv3/Cobb XLE BPV/CMGS Stg2 w/DO14/CPE TMIC/Autotech HPFP internals/JBR Tru-3 Intake/JBR Boost tubes/JBR EGR delete/Custom
1liter OCC/CPE xflex RMM/CPE Injector Seals/Eibach Pro Springs/Ebay Downpipe/Custom 3" TBE with Vibrant Resonator/Magnaflow Muffler/TB Coolant Bypass/Bosch 3 bar map/ACT 6 puck/GS EBCS 3port interrupt/SP63 VC breather
Plugs-NGK LTR7IX-11(6510)
Oil-RP 10/30
Tires-235 40 18 Federal 595 rsrr
Brakes-EBC Yellow pads with ATE 200 fluid
Check out my wheelwell page here. If your a member hit me up.
https://www.wheelwell.com/profile/558b073762d1852928f23712/garage/
voodoo2crue is offline   Reply With Quote
 Old 04-25-2016, 12:48 PM   #122
ItsNox's Avatar
Posts: 3,076   (View Stats)
I'm also interested. Gearing up to start buying parts for my S4 motor build
Sent from my LG-H830 using Tapatalk
Ziggyboy likes this.
'06 Mazdaspeed 6 GT
- Miltuned
Georgia Motherfucking Nator
 Old 04-27-2016, 08:03 PM   #123
Ziggyboy's Avatar
Posts: 239   (View Stats)
Ziggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the world
E85 is in progress, ran into a few issues along the way. Reduced the plug gap to .025 and replaced the coil springs with solid copper wire to help with plug blow out. I also needed to add 4 turns to the waste gate arm to get some more boost up top. Should finish things up at the end of this week or beginning of next. I will post up some logs within the next week or two.
2013 MS3 // Purple Drank Tune // BNR S4 // All the other shit to go along with it
Ziggyboy is offline   Reply With Quote
The Following 2 Users Say Thank You to Ziggyboy For This Useful Post:
ItsNox (04-28-2016), voodoo2crue (04-28-2016)
 Old 04-28-2016, 06:42 AM   #124
Thanks for the update. What was the spring pressure differences before and after the WG arm adjustment? I'll be installing my s4 this weekend and will be attempting a self tune and trying to find out as much as I can so I'll know what to look out for. How much boost is being targeted up top?
2012 MS3 VRM/w Tech
Oil-RP 10/30
 Old 05-09-2016, 08:04 PM   #125
Ziggyboy's Avatar
Sorry for the delay, the stock setting is 17 psi and to be honest I'm not sure what 4 turns put it at. I'm targeting 25 PSI.
 Old 07-26-2016, 08:18 PM   #126
BuddySpeed3's Avatar
Posts: 479   (View Stats)
Groaned at 7 Times in 4 Posts
Any updates?
Are you using the stock intake manifold with vtcs still in place?
Edit: Never mind, I saw that you are in your earlier pictures.
 Old 07-26-2016, 09:18 PM   #127
blackms3_71's Avatar
Posts: 2,250   (View Stats)
Originally Posted by BuddySpeed3 View Post
Any updates?
Not trying to thread jack, just thought i throw out there that i do have vtcs and stock mani. No issues to report.
BuddySpeed3 (07-27-2016)
 Old 07-27-2016, 03:07 PM   #128
I will eventually be purchasing an IM from relentless customs for more flow capacity, as well as a more even flow balance between ports. But good to know big turbo guys aren't having problems with the stock manifold with vtcs.
 Old 07-27-2016, 03:52 PM   #129
Ziggyboy's Avatar
Things have changed, but I'm finally finished with tuning. I ended up getting rid of the throttle body spacer where I was spraying meth and moved pre-throttle body on a D07 nozzle. Will from PD tuning took care of business and made quick work of the tunes. So as of now I'm on shit 91 Octane, spraying 100% meth on a D07 nozzle, at 5000 Ft of elevation. Could push things further, but I'm going to stay put do to stock block.
impossible (01-02-2017), voodoo2crue (07-27-2016)
 Old 07-27-2016, 05:41 PM   #130
though rob tuned you? and that's not bad for the elevation or using a d07 nozzle. do u have ex mani?
dynojet #'s really? lol
Last edited by blackms3_71; 07-27-2016 at 05:41 PM. Reason: MSF Database - Automerged Doublepost
 Old 07-27-2016, 06:49 PM   #131
Ziggyboy's Avatar
Shit, good eye! Downloaded Vdyno at work and forgot to change the setting. Updated the Vdyno.
 Old 07-27-2016, 08:00 PM   #132
that power makes more sense based on what you said. I cant wait to finish my tune
 Old 07-27-2016, 08:13 PM   #133
Ziggyboy's Avatar
For right now I'm happy with how the car feels. I might get some shit from others for not going further with the tune, but its good for my needs. I will start saving my pennies for a motor build, then see where things take me.
 Old 07-27-2016, 08:18 PM   #134
ill pic up the slack for ya :p
 Old 01-01-2017, 09:05 PM   #135
Ziggyboy's Avatar
Like others, we say we are content and finished with things, but then we start shopping around again. Found a good deal on a Full-Race exhaust manifold and decided to pull the trigger. I also decided to pick a DM RMM to finish off the trifecta. JMF intake mani to come, along with a few other goodies.
Code Monkey (01-02-2017), WetzMS3 (01-06-2017)
 Old 01-02-2017, 01:33 AM   #136
impossible's Avatar
Posts: 733   (View Stats)
Groans: 30
You bought that FR EL mani from a guy in TX huh?
ps. stop wasting money on more flow mods on a stock block setup
 Old 01-02-2017, 09:46 AM   #137
Ziggyboy's Avatar
I picked it up from an online vendor for about 350 off of MSRP. My current game plan is to continue acquiring many of these additional mods, so when I go built block I will have most of the higher flowing parts to support the build.
 Old 01-03-2017, 06:21 PM   #138
impossible's Avatar
Groans: 30
Shouldn't have invested so much in a .55-65 a/r MZR flange, but if you're fine with dropping $5-6k to tap out at 450whp go for it man
 Old 01-05-2017, 08:42 AM   #139
iamareios's Avatar
Posts: 79   (View Stats)
iamareios is a splendid one to beholdiamareios is a splendid one to beholdiamareios is a splendid one to beholdiamareios is a splendid one to beholdiamareios is a splendid one to beholdiamareios is a splendid one to behold
I'm in the same boat here. I'm debating on adjusting my waste gate arm on my S4 build. My WGDC is maxed out on my tune. We're hitting boost targets, but I have more fuel head room (in the mid 75%) to push the S4 a little more. We also raised the rev limiter to 7000rpm. This is on 100% meth D10 nozzle, stock block keeping under 400tq of course. You said 4 turns? I've read about the bnr s3's needing 1 to 1.5 turns.
(PD tuned) 397hp/358tq 91/100% meth
BNR S4, XS v3 manifold, CNT dp, OBX cbe, JBR ebcs, AUTOTECH hpfp, PnP/vtcs del. manifold, SU TMIC, HTP 3.5" intake, Synapse DV, D10 100% meth kit, Damond OCC VTA, AFR failsafe, Bilstein b8's/Cobb springs, stuff
iamareios is offline   Reply With Quote
Build me a BIG Turbo Build for MS3 NCspecV81 2010 MS3 - Big Turbo Builds 14 04-15-2013 02:16 PM
Page generated in 0.39660 seconds with 27 queries
