> Gen2 MS3 General Discussion
 Old 04-09-2012, 10:42 AM   #1
SRHTX's Avatar
Posts: 437   (View Stats)
SRHTX has a reputation beyond reputeSRHTX has a reputation beyond reputeSRHTX has a reputation beyond reputeSRHTX has a reputation beyond reputeSRHTX has a reputation beyond reputeSRHTX has a reputation beyond reputeSRHTX has a reputation beyond reputeSRHTX has a reputation beyond reputeSRHTX has a reputation beyond reputeSRHTX has a reputation beyond reputeSRHTX has a reputation beyond repute
Question Adjustable Wastegate
I'm sure I'm putting this in the wrong area but, I've never done anything with this.
Where is one able to get an Adjustable Wastegate on the '11 Speed3s at? Here is what mine has:
K&N Typhoon
Borla Catback Exhaust
ATP 3" Stainless Catless High Flow Downpipe
A little over a week ago, my friend had a dyno day at his shop and my car did 271hp at the wheel. People have advised me if I were to get an Adjustable Wastegate, it will increase the HP.
Please assist if possible.
Thanks
Stephen
'11 Speed3 / Liquid Silver Metallic / COBB AccessPORT / NGK LTR7IX-11 Spark Plugs / K&N Typhoon / Borla Catback Exhaust / ATP 3" Stainless Catless High Flow Downpipe / Autotech High Pressure Fuel Pump Internals / TRZ Rear Motor Mount / AWR Passenger Motor Mount / Goodyear Eagle F1 Tires / CorkSport Front Swaybar / CorkSport Adjustable Rear Swaybar / CorkSport Rear Camber Arms / CorkSport MZR Bypass Valve / CorkSport FMIC kit for Short Ram Intake / Kozmic Tuned
Facebook - Mazdas of RGV
Facebook - Mazdas of San Antonio
SRHTX is offline   Reply With Quote
The Following User Says NO Thank You to SRHTX For This Un-useful Post:
trf5000 (04-09-2012)
 Old 04-09-2012, 10:43 AM   #2
trf5000's Avatar
Posts: 2,290   (View Stats)
Get a manual boost controller and set it to 25psi. You will dyno around 350hp.
2010 MS3 - Sold
2015 CX-5 GT AWD - Current
The Following User Says Thank You to trf5000 For This Useful Post:
Don06speed6 (04-09-2012)
 Old 04-09-2012, 10:50 AM   #3
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
In before boom.
Our wastegate is controled by an ebcs this aint your boys honda. Get some cdfp internals and a cobb ap so you can run a tune. Stop listening to your friends and actualy do some searching on this site before you explode. Good luck and flame on.
TEAM LUXURY
Manny3 (04-09-2012)
 Old 04-09-2012, 10:57 AM   #4
rghispanic88's Avatar
Posts: 3,131   (View Stats)
Groans: 263
Troll
2010 Black Mica
rghispanic88 is offline   Reply With Quote
 Old 04-09-2012, 11:46 AM   #5
m4tic's Avatar
Posts: 4,928   (View Stats)
Super secret! Just take the vac hose off the top of the wastegate and hold on!
*im not responsible for anything you do to your car, you do it of your own free will and take full responsibility for your actions.
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
Easter Bunny (04-09-2012)
 Old 04-09-2012, 12:18 PM   #6
RIP: November 21, 2012
fortressofcomfort's Avatar
Posts: 862   (View Stats)
fortressofcomfort is the leader of the worldfortressofcomfort is the leader of the worldfortressofcomfort is the leader of the worldfortressofcomfort is the leader of the worldfortressofcomfort is the leader of the worldfortressofcomfort is the leader of the worldfortressofcomfort is the leader of the worldfortressofcomfort is the leader of the worldfortressofcomfort is the leader of the worldfortressofcomfort is the leader of the worldfortressofcomfort is the leader of the world
Groaned at 20 Times in 12 Posts
I'd help this guy but there seems to be so many trolls around here lately.
I'm giving in.
OK, boost is controlled by the wastegate which is PRECISELY controlled by the ECU. You change the ECU to change the behavior of the wastegate to change boost. DO NOT try to circumvent the ECU to alter boost on THESE cars. THESE cars (MZR 2.3 DISI) are NOTHING like a Honda or Subaru so whatever you read there just erase from your mind.
2012 Black Mica MazdaSpeed3
Mods (in order of significance): Cobb AccessPort, Autotech CDFP upgrade (thanks Captain KR for your assisstance), Cobb SF SRI Intake, Ultimate Racing cat and resonator-less test pipe, Cobb Turbo Inlet Hose, Cobb Knob, Cobb 300g shifter weight
Tune: My own (based on the v210 and v231 Cobb OTS maps but ramped way up)
Street creds:
- Fastest known K04/93 MS3/driver with only an AP, CDFP upgrade, intake, and tune | 13.37@106.83mph on stock Dunlops (2.04 sec 60' time, full curb weight, 75*F ambient temp)
- Has gone an indicated 146mph on three occasions now.
Yes I will help you tune your K04/pump gas car; I have much less experience than the major players but I also charge you $0 and can turn you around quickly. 4 satisfied customers and counting...
fortressofcomfort is offline   Reply With Quote
 Old 04-09-2012, 12:18 PM   #7
spiffy9999's Avatar
Posts: 143   (View Stats)
spiffy9999 is the leader of the worldspiffy9999 is the leader of the worldspiffy9999 is the leader of the worldspiffy9999 is the leader of the worldspiffy9999 is the leader of the worldspiffy9999 is the leader of the worldspiffy9999 is the leader of the worldspiffy9999 is the leader of the worldspiffy9999 is the leader of the worldspiffy9999 is the leader of the worldspiffy9999 is the leader of the world
Neutral  -1 score
No need for an adjustable wastegate....all you needz is a "type r" badge and you'll make moar hp than you can handle...
spiffy9999 is offline   Reply With Quote
How to connect the stock wastegate solenoid to an external wastegate cageyvet MazdaSpeed 3/6 - Turbo Induction 0 03-17-2010 05:02 PM
Are the stock MS3 shocks adjustable? lengbros MazdaSpeed 3/6 - Suspension & Brakes 3 03-29-2009 08:09 PM
Page generated in 0.27984 seconds with 26 queries
