![]() Join Date: Feb 2012 Location: King of Prussia, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 126
(Thread Starter) | Not Ranked : 0 score So I've been researching some gauges recently and saw a set up that @deadlandxtreme had that I really liked, but my research yielded some questions. I like the SRTI boost gauge, might go Defi instead, doesn't seem to matter as they are both solid, but the price is what gets me. Likewise with the aeroforces. I'm going to do the 3-gauge a-pillar pod in my gen2 was leaning towards dual aeroforce + boost gauge. The aeroforces tap into the obd2 though, so you can't run the AP at the same time? And doesn't the AP log all that shit anyway. So the dual aeroforce set up + all the sensors is going to run me like $700 that is just wasteful spending, right? I was leaning towards some glowshift gauages since they seem consistent and reliable if nothing else and that'd be the cheapest way to go, and the gauges come with the sensors, and I can run the AP full time still. Possible still a Defi or STRI boost gauge. Am I on the right track? Any thing I'm missing here when it comes to installing/running gauges properly?
__________________ 2011 VMR Mazdaspeed 3 Cp-e | Cobb | JBR | Freektune |
![]() Join Date: Feb 2012 Location: Quantico, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,434
| Not Ranked : 0 score 3-gauge a-pillar pod will kill you if you blow your air bags!
__________________ [SIGPIC][/SIGPIC] 2013 Scion FR-S (Whiteout) GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_Nameless Race Pipe_RBF600_Ferodo DS2500_PTUNING Tuned Less parking more racing |
| The Following User Says Thank You to leon78 For This Useful Post: | m249saw (04-11-2012) |
| The Following 5 Users Say NO Thank You to leon78 For This Un-useful Post: | bertrand_CX_7 (04-14-2012), drknyte (04-13-2012), p057 (04-10-2012), rghispanic88 (04-10-2012), SofaKingAwesome (04-10-2012) |
![]() Join Date: Nov 2009 Location: Dallas, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31,116
Groans: 549
| Not Ranked : 0 score I don't know about the genpu, but gen 1 was fine with pillar pods Sent from my LG-MS690 using Tapatalk
__________________ it's fun to do bad things |
![]() Join Date: Apr 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 427
Groaned at 27 Times in 21 Posts
| Not Ranked : 0 score What are you monitoring other than boost? You are correct you can only run 1 OBD device at a time. |
![]() Join Date: Jul 2011 Location: Plantation, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,748
Groans: 97
| Not Ranked : 0 score You can run the aeroforce and ap at the same time using an obd-ii splitter. They draw info from different pins. I am actualy waiting on my defrost vent pod to arrive tomorrow to do the install this weekend. Honestly im adding a switch to the power of the af gauge just to make sure it doesn't interfere with logging and flashing maps. Btw @rfinkle2 is running the same setup. Im also installing a glowshift boost gauge.
__________________ TEAM LUXURY |
| The Following 2 Users Say Thank You to Sid3wayS For This Useful Post: | deadlandxtreme (04-10-2012), rfinkle2 (04-11-2012) |
![]() Join Date: Apr 2010 Location: Miami FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,836
Groans: 263
| Not Ranked : 0 score NO, theres a video of the mazda 3 crash test and the pillars pop out toward the windshield instead of your face. it's on here look for it
__________________ 2010 Black Mica 2004 EVO 8 Green Monster The "7up" |
| The Following 4 Users Say Thank You to rghispanic88 For This Useful Post: |
![]() Join Date: Aug 2009 Location: Trevose, PA
Rep Power: 7488 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,940
Groans: 224
| Not Ranked : 0 score This sounds like complete overkill to me. Your AP can monitor and log pretty much everything. Watching multiple parameters is nice but for the $700 I'd spend that elsewhere.
__________________ MS3 has been retired to daily duty Project 1G; 1991 Eagle Talon TSi. 63MM Borg Warner Powered, Corn-Fed, 2.4L Long Rod Monster Under Construction Stock Turbo-Stock Engine Grand Champion of the World! 501WHP & 569WTQ (PERM Tuned, 93 OCTANE PUMP GAS K04 W/N2O!!) NATOR PA |
| Not Ranked : 0 score Do you guys even watch those pods when driving? When I track my car I just look ahead, if I had to peek from time to time at gauges I would be slow as shit.
![]() Join Date: Nov 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 849
Groans: 82
| Not Ranked : 0 score You're safe with the pod. But I will say, 3 is overkill for sure. It's nice to be able to see everything at a glance. Not needed really , but if you have the means at the time of the want, go for it. An AP would get the job done if you were budget minded. I just wanted to be able to see exact boost and fuel pressure. The fact that I can see my BATs and Knock warning is a plus.
__________________ 2010 Mazdaspeed3- Installed Mods:- GT 3071 (Ported,polished, and coated by Grimmspeed) Polished and coated throttle body (Grimmspeed)TWM Performance Full Replacement Short Shifter Kit, Corksport FMIC (Upgraded size and coated by Calico Coatings), HTP 4" SRI, Forge V2 BPV, Corksport coolant hoses, NGK Iridum, COBB AP, Full Race DP (ceramic coated), Corksport hangers,JBR EGR block off, Autotech HPFP internals. Glowshift triple gauge pod, Aeroforce Interceptor dual gauges, STRI Imperial boost gauge.Stratified EBCS.RSB and Rear Camber Arms ( JBR ). Tein EDFC kit - Tein Super Street Coilovers . Enkei Racing RPF1 .GTSPEC bracing (front to rear)Corksport FSB..StopTech SS Brake Lines-SportStop Cross Drilled and Slotted Rotors-StopTech Street Performance Brake Pads.. Stratified Boost dial and Guardian Angel. JMF Intake manifold. Full Race Exhaust Manifold (ceramic coated). Damond Motorsports CC. SSP CC. PERM PCV Plate. 3bar MAP. , CP-E Triton full exhaust(Tuning provided by Stratified Tuning) |
| COCKSTRONG ![]() ![]() ![]() Join Date: Jul 2011 Location: Your Mom's House
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,809
Groans: 890
| Not Ranked : 0 score I run dual aeroforces and monitor KR, FP, Boost, and AFR. Only ever hook up my AP to flash a map, which gets less frequent the closer you get to being dialed in.
__________________ Searching for something? Try MS3Shadow's Custom Search EVERY "I DON'T USE MSF" FACEBOOK RETARD EVER |
| The Following 4 Users Say Thank You to SofaKingAwesome For This Useful Post: | bertrand_CX_7 (04-14-2012), deadlandxtreme (04-10-2012), jack_hammer (04-10-2012), rfinkle2 (04-11-2012) |
![]() Join Date: Jun 2011 Location: sufu
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 58
Groaned at 41 Times in 24 Posts
| Not Ranked : 0 score Ultragauge in a windshield mount? Cheap and has alarms for low fp!
__________________ HT programmer, Mazdaspeed CAI, Turbosmart Dual port Bpv, Corksport Test pipe back exhaust, HTP TIP, Autotech CDFP internals, CP-E TMIC, Cobb Springs, Koni yellow struts, SU RMM, Ts shift plate, prosport bg, 10k headlights, 3k fogs, OZ Ultraleggera HLTs, Pioneer nav/dcs......On the way; Devils Own Stage 2 |
![]() Join Date: Nov 2010 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,489
| Not Ranked : 0 score i have had an ultra gauge for a bout a year now. you can monitor 6 parameters at once so i have my home screen set to: Engine Temp - IAT - STFT - LTFT - cat bank 1 temp - Timing advance. Its a sick little device, however it too uses the OBD so you cant run that with your AP. my question is do you actually have an ultra gauge and are monitoring fuel pressure because mine only has an option for diesel fuel pressure, which reads like 1200 at WOT which i know is no where near right haha (before someone asks the stupid question, mods in sig).
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. |
The plan being the AP, which will only show me one or two things at a time, can stay on and show me one or two other things/do data logs/flash new tunes.
Just looking for easy ways to keep an eye on the important stuff once I start tuning, just trying to get everything in place before tuning so I'm not behind the 8-ball on monitoring. And it'd be nice to not have to log/upload logs every so often just to see if my FP or AFR's were off.
__________________ 2011 VMR Mazdaspeed 3 Cp-e | Cobb | JBR | Freektune | ||
Groans: 549
| Not Ranked : 0 score Monitoring with an ap is no good for me. I have the aerforce for live monitoring and it's great. I also have three gauges in my center dash. Sent from my LG-MS690 using Tapatalk
| Not Ranked : 0 score Yeah it stays in the windshield, yes its under d rail pres, mine goes up to 1900 psi.
I'm taking a step back and thinking buying one of these guys is waaay easier/cheaper. I suppose if the boost gauge on it isn't great I can always do a single boost gauge/pod at that point. Thanks for the info man.
![]() Join Date: Nov 2010 Location: St. Louis missouri
Rep Power: 1310 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,310
Groans: 134
I love it cuz I love to monitor ltfts when I'm cruising around town. It's a great heads up if something is acting up. And genpu does not have the dash hawk option. | |
| The Following User Says Thank You to Ckmazdaspeed3 For This Useful Post: | rfinkle2 (04-11-2012) |
__________________ HT programmer, Mazdaspeed CAI, Turbosmart Dual port Bpv, Corksport Test pipe back exhaust, HTP TIP, Autotech CDFP internals, CP-E TMIC, Cobb Springs, Koni yellow struts, SU RMM, Ts shift plate, prosport bg, 10k headlights, 3k fogs, OZ Ultraleggera HLTs, Pioneer nav/dcs......On the way; Devils Own Stage 2 | |
Groans: 134
I found one on Amazon and am hoping it will work. Ideally, if the UG and the AP can run at the same time...I'm done. Worst case scenario is I keep the UG hooked up all the time and only use the AP for logging/flashing...keep the cheaper piece in the car so if it's stolen I'm not out big $$
![]() Join Date: Mar 2011 Location: Hampton, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28,760
__________________ 2011 MAZDASPEED 3 BNR: 352 hp / 342 ft-lbs K04: 296 hp / 343 ft-lbs BNR Supercars Stage 3 Turbo Aquamist HFS-4 Alcohol Injection Cobb Tuning AccesPORT • AccessTUNER Race KMD Tuning HPFP Internals v2.2 NGK 6510 Spark Plugs Bosch 3-Bar MAP Sensor Saikou Michi Oil Catch Can Grimmspeed 3-Port EBCS JBR TIGs • EGR Delete • Rear Sway Bar • RMM • PSMM • TMM HTP 3" TIP • Battery Tray SURE Motorsports 3" MAF • Shortcut • CounterShift • Anchors • AGS 621g Shift Knob Ultimate Racing Catted Downpipe • Test Pipe • Cat-Back Exhaust CP-e FMIC • SAFEseals Turbosmart Dual Port BOV PTP Injector Seal Studs EBC RedStuff Brake Pads • UPR Rotors Swift Spec R Springs Bilstein B8 Shocks SPC Performance Rear Camber Arms Tanabe Sustec Strut Tower Brace TWM Performance Full Replacement Shifter 5zïgen ZR+ 18x7.5 (Ceramic Bronze) Nitto NeoGen Tires Rally Armor Mud Flaps Morimoto 6000K HID Replacement Bulbs DDM Tuning 3000K HID Fog Lights Headlight Armor Yellow Fog Overlays Qualir QL-MZD723 Headunit Glowshift Mechanical Boost Gauge • A-Pillar Gauge Pod Aeroforce Dual Interceptor Gauges | |
| The Following 4 Users Say Thank You to skeurton For This Useful Post: |
![]() Join Date: May 2011 Location: Valdosta GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,861
Groans: 126
| Not Ranked : 0 score Glowshift gives a warning, but I am sure it's just to cover their ass.
__________________ '09 Red MS3 - AP self tuned, CS HPFP, JBR 3.5 WP, CP-e S2 RMM, M2 Catless DP, CX FMIC, CNT CBE |
Groans: 97
| Not Ranked : 0 score I know finkle was running this set up and he assured me on his 2010 ms3 (same as mine) he was able to use both at the same time. He hadn't tried flashing or logging thou. Ive got my guage in today and according to ups should have my obdii splitter tomorrow along with my pod. This weekend I will install everything and report back. I'll also be installing a 12v switch to turn power on and off to the AF just to make sure it does not mess with the ap when Im logging.
| The Following 2 Users Say Thank You to Sid3wayS For This Useful Post: | Ckmazdaspeed3 (04-10-2012), rfinkle2 (04-14-2012) |
![]() | | #24 | ![]() |
Groans: 126
| Not Ranked : 0 score Referring back to when most of us were kids....knowledge is power. Aeroforce gauges are knowledge, therefore power. EDIT: CHEAP RUM HAS SPOKEN!!!
![]() | | #25 | ![]() |
Groans: 224
| Not Ranked : 0 score Lol he said he wanted two Keith
| The Following User Says Thank You to MS3-a(sore)ASS-rex For This Useful Post: | Ckmazdaspeed3 (04-10-2012) |
![]() | | #26 | ![]() |
Groans: 134
| Not Ranked : 0 score I guess $700 means dual aeroforce, boost gauge and extra aeroforce shit, like oil or egt or something, cuz dual aeroforce is $400. And IF u really can run it and the AP at the same time, with the egt and oil pressure additions, that would fucking rock! I was about to sell mine because I hated hooking and unhooking it for the ap. but if I can install a switch and just turn it off to log, than I am really happy w it. I mean to have oil pressure and egts on one gauge would be a great space saver. |
| The Following User Says Thank You to Ckmazdaspeed3 For This Useful Post: | MS3-a(sore)ASS-rex (04-11-2012) |
![]() | | #27 | ![]() |
| Not Ranked : 0 score The splitter will work with the AP and at least one Aeroforce gauge, and I would assume that it would work with the dual set-up as well. The Aerforce dual set up links the 2 together as 1 gauge, so I believe it will function the same as with 1 gauge. The guages are cool because you can set alerts for them as well in the case that a certain pid reaches a threshold of your choice. I agree it isn't necessary to have a million gauges, but it is nice to have the Aeroforce gauges if you want to set a few warnings / monitor simultaneously. As far as the airbags go, Skeurton posted the vid that makes me comfortable saying that although bruises are inevitable if your side airbags deploy, I don't think there will be any significant injury due to gauges being mounted there. |
| The Following 3 Users Say Thank You to rfinkle2 For This Useful Post: |
![]() | | #28 | ![]() |
Groans: 82
| Not Ranked : 0 score ^ Agreed. Thanks for chiming in.
![]() | | #29 | ![]() |
That said, have you tried use the UG with an OBDII splitter? I'd like to run the AP and UG together If I could.
![]() | | #30 | ![]() |
![]() Join Date: May 2011 Location: Lexington, KY / Troy, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 311
| Not Ranked : 0 score same. I find it annoying to use and cumbersome to hold and has limited mounting solutions.
__________________ 08.5 CWP MS3 GT AP Stage 2 S-OTS+ | Cobb Catted DP | Magnaflow CBE | JBR SRI | Cobb TIP | JBR 70 Duro RMM |NGK Iridiums | Autotech Internals | Lamin-X Yellow Fog Overlays |
| The Following User Says Thank You to cabrone For This Useful Post: | SofaKingAwesome (04-12-2012) |
![]() | | #31 | ![]() |
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. | |
![]() | | #32 | ![]() |
UltraGauge EM upgrade [UltraGauge_EM_Upgrade] - $10.00 : UltraGauge, OBD II Scan Tool & Information Center
![]() | | #33 | ![]() |
![]() | | #34 | ![]() |
| The Following User Says Thank You to Voltwings For This Useful Post: | skeurton (04-11-2012) |
![]() | | #35 | ![]() |
Groans: 134
![]() | | #36 | ![]() |
![]() Join Date: Jun 2011 Location: Cumberland, Rhode Island
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,309
__________________ 2007 MS3 Black Mica. Stock. 235whp/244wtq DynojetFREEKtuned 277/316 Dynojet Corksport SRI/TIP/FMIC/GFB BPV/AT Internals/EBCS/Gutted 2nd Cat Bilstein B8/Swift Spec-R/ST120s/Nitto 555 JBR 70dur. RMM-TMM-PMM/SSP+Bushings/TIGs/OCC | |
![]() | | #37 | ![]() |
Groans: 134
| Not Ranked : 0 score |
![]() | | #38 | ![]() |
Groans: 97
| Not Ranked : 0 score @Ckmazdaspeed3 In the back of the af there is a tiny fuse, pull it out and it will not draw power through the obdii port. Try it like that. What year do you have?
| The Following User Says Thank You to Sid3wayS For This Useful Post: | Ckmazdaspeed3 (04-13-2012) |
![]() | | #39 | ![]() |
![]() Join Date: Mar 2010 Location: Italiano
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 22
Hey boss. Since your dreams of using the OBD splitter doesn't work, willing to sell your guage to me? I'm finally ready to buy an aeroforce. I was so close to hit "check out" at the aerofoce website. | |
![]() | | #40 | ![]() |
(Thread Starter) | Not Ranked : 0 score Does this mean it won't work with the UltraGauge/AP combo as well? I'm tempted to try anyway but wasting $25 on a cable I can't use would be annoying.
| CPE Triple Gauge Pod with Prosport gauges finished | asall667 | Appearance - COSMIC BLUE | 23 | 05-31-2015 09:52 AM |
| Gauge Pods. Which Gauges? | Reap3rVIRUS | MazdaSpeed 3/6 - Appearance | 13 | 05-01-2009 08:35 AM |
