> Gen2 MS3 General Discussion
  • 1 Post By MSMS3
 Old 08-20-2019, 07:30 PM   #1
Mini Franki's Avatar
Posts: 37   (View Stats)
Mini Franki will become famous soon enough
Default Gtx2867r leaking, need new turbo
Hi,
My gtx2867r leaking so i need new turbo. I dont want to spend too much on the new one so im trying to find the best price/perf bet. Im actually pretty happy of this turbo so i want something similar! Im on stock block(140 000km and BT since the 50 000km). Im running it at 21psi and 500cc WMI. I have a 3.5" intake
I think to go with bnr s3 or s4 after a good research but i dont know which one to choose. Gtx2867r seem to be between these 2 turbos. According to circumstances, which one is the best?
Thx
Mini Franki is offline   Reply With Quote
 Old 08-20-2019, 09:08 PM   #2
monkey.bones.007's Avatar
Posts: 3,853   (View Stats)
Originally Posted by Mini Franki View Post
Hi,
My gtx2867r leaking so i need new turbo. I dont want to spend too much on the new one so im trying to find the best price/perf bet. Im actually pretty happy of this turbo so i want something similar! Im on stock block(140 000km and BT since 50 000km). Im running it at 21psi and 500cc WMI. I have a 3.5" intake
Thx
Why don't you just rebuild it if you can afford a small amount of downtime?
 Old 08-20-2019, 10:08 PM   #3
Its my daily driver, i cant remove the turbo and to send it to garrett. I already bought a rebuild kit but i returned it because my exhaust housing is completly jammed, impossible to remove the bearing. Oil leaking dont really bothered me but at my last oil change(5000km), i had no oil on my stick! So now i probably lose too much oil, i need to fix that
 Old 08-20-2019, 10:16 PM   #4
Db09ms3's Avatar
Posts: 536   (View Stats)
Groans: 105
Modding the daily! Risky business indeed.
Stockish
The Following User Says Thank You to Db09ms3 For This Useful Post:
monkey.bones.007 (08-20-2019)
 Old 08-21-2019, 05:06 AM   #5
I agree but its my 2nd speed, 300 000km total and 160 000km total BT and i dont want any another car for my daily. This car is too much fun to drive. Recently did a 120-220kmh against a audi r8 v10, that was equal! This is my motivation to keep a 30k car in live lol
 Old 08-21-2019, 10:01 AM   #6
Db09ms3's Avatar
Groans: 105
I'd deal with the down time and get it rebuilt. That's a nice turbo. Catch the bus!
Stockish
 Old 08-21-2019, 12:30 PM   #7
Im from canada/quebec, do you guys know a good place for rebuild? how many time that will take for it? If its really a small amount of time, i can try to get a car for this time
 Old 08-21-2019, 12:35 PM   #8
Db09ms3's Avatar
Groans: 105
You should be able to find a local competent turbo shop to complete the rebuild and balance. In AZ there a few local diesel shops capable of doing our baby turbos. The same could be said for you. Prices always vary.
Stockish
 Old 08-21-2019, 01:25 PM   #9
I find blaast performance turbo shop. But i think i need to do a good check up for see if the motor is good and if.my PCV is good too before to do a turbo rebuild. Maybe my turbo is okay but all the rest make it leak
Thx for the info guys
 Old 08-21-2019, 01:45 PM   #10
Db09ms3's Avatar
Groans: 105
Yeah man, check all that shit. Should be doing that to begin with
Stockish
 Old 08-21-2019, 09:45 PM   #11
Polish_Eagle's Avatar
Posts: 408   (View Stats)
Not local, but I used Cherry Turbos in St. Thomas, Ontario to rebuild my GTX3067R.
The Following User Says Thank You to Polish_Eagle For This Useful Post:
monkey.bones.007 (08-27-2019)
 Old 08-27-2019, 10:29 AM   #12
For people near to montreal, dont go at blaast performance. Review are not very good
For the best job, turbo expert at Quebec
I dont have a lot of shaftplay, ill try a banjo bolt restrictor to see if that stop leaking. That seem to leak only on boost because i dont see any smoke when i drive it normally. I already have a sp63 filter on the oil cap for help the pressure in the return line
The Following User Says Thank You to Mini Franki For This Useful Post:
Db09ms3 (08-27-2019)
 Old 09-04-2019, 10:28 AM   #13
That maybe can a pcv valve failure? On idle, vaccum is supposed to suck air from my oil breather cap? That actually did the opposite. I feel a little pressure and that throw oil everywhere when i remove the oil breather cap. I have a gen 2 so im not supposed to receive oil from the chain
Im now at 145k and i think the pcv never get changed
 Old 09-08-2019, 05:15 PM   #14
Posts: 2,826   (View Stats)
Hi,
Thx
BNR can probably rebuild your GTX2867R. They do rebuilds of many turbos in addition to selling their own custom turbos. Check with them.
Db09ms3 likes this.
Oil leaking from turbo Djohns 2010 MS3 - Troubleshoot/Diagnostics 42 03-22-2019 07:39 AM
Theoretical pressure,Temp, Airflow and HP output applied to GTX2867R turbo charger wake2011 2010 MS3 - Turbo Induction 16 04-17-2012 06:19 PM
Page generated in 0.34932 seconds with 24 queries
