> Gen2 MS3 General Discussion
Like Tree3Likes
 Old 12-07-2018, 09:53 PM   #41
Solarsurge's Avatar
Posts: 577   (View Stats)
Cool man. Now update your avatar.
+1 lol
 Old 12-09-2018, 03:22 PM   #42
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
FYI: you say you're aiming for 700+(whp?). More power to ya, but your rods are only rated to 750bhp.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 01-14-2019, 07:26 AM   #43
qtrmile beast's Avatar
Posts: 2,423   (View Stats)
fyi you can upgrade your rod bolts and this can help with your bhp!!! also to the other person talking about welds that was for the intake manifold not the exhaust manifold..
track weight 3220
street weight 3370
 Old 01-14-2019, 07:27 AM   #44
Fstrnyou's Avatar
I'm just saying, the rods he selected don't have the upgraded bolts.
Other rides:
History:
 Old 01-14-2019, 09:20 AM   #45
5doorsoffury's Avatar
Posts: 1,123   (View Stats)
Groans: 74
I am really surprised after reading this whole thread no one said anything about his tr8 choice rated for 500hp for a 600+ build.
MECP
2012 BM
Rfinkle tune in progress
 Old 01-14-2019, 02:09 PM   #46
Posts: 2,237   (View Stats)
It may be swapped along the turbo to get above 500 later.
 Old 01-14-2019, 02:15 PM   #47
Fstrnyou's Avatar
Agree with Jeff. The TR8 should work "okay" for the 3076. Maybe he got a good deal on it.
That's the same reason I have a CP-e TMIC instead of stock. It was a deal I couldn't pass up to hold me over until my W2A is done.
Other rides:
History:
 Old 01-15-2019, 03:46 AM   #48
Groans: 74
I totally agree i was illuding to the 26 posts prior to him announcing his intentions about going precision turbo. I stuck with my tr8 since 500ish was my goal.
MECP
2012 BM
 Old 10-07-2019, 02:03 PM   #49
SHADY1's Avatar
Posts: 60   (View Stats)
SHADY1 has disabled reputation
Groaned at 7 Times in 5 Posts
I agree, Turbo will be bottle neck at this point. You may push 600hp/540'ish whp depending the A/R but still be maxing out GTR3076!. If you havent already upgrade intake manifold and throttle body. I would of went with 83lb @ 35mm seat and 233lb @ 12mm lift springs. But to each their own and you should be fine.
Once you get it together and tuned I would like to see some of your data. It will be a fast bitch!
strickly a
Shady1Blk Mica / Carbon Fiber MS3GT
[COLOR="White"]AP / CS 3" Turbo Back / Autoteck HPFP / CS BPV /GA V3 / GT3071R / Cobb FMIC / JBR TRU 3.0 SRI / HTP 3" TIH / CP Low End / Massive Auto Keyed Crank / ARP Main & Head studs / DO Meth 1200cc Full SS quad Inj/ AEM Fail Safe / Cobb 3 Port / H & R Lowering Spring / Magan Racing Camber Arms/ Damond MS Catch Can / Sure Shift Linkage / Sure Hard Mounts / SPEC LW Fly Wheel / SPEC ST3+ Clutch / JBR Trans and Motor Mounts / JBR Balancer Delete Kit / Denso 1sg cooler plugs / Freaktune - (24PSI 450whp, 470 ft-lb)
SHADY1 is offline   Reply With Quote
Build me a BIG Turbo Build for MS3 NCspecV81 2010 MS3 - Big Turbo Builds 14 04-15-2013 02:16 PM
Page generated in 0.29403 seconds with 26 queries
