> Gen2 MS3 General Discussion
  • 1 Post By GreyGhost
 Old 03-10-2013, 02:26 PM   #1
GreyGhost's Avatar
Posts: 315   (View Stats)
GreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the world
Default Installed HTP Battery Tray w/ Affordable Smaller Battery
Just thought I'd share pics of my HTP Battery Tray I installed this weekend with a Autocraft 51R Battery. Great battery, smaller, just as efficient as a regular sized one without breaking the bank. Didn't wanna spend the coin on a Kinetik, Odessey, or Optima since there are mixed reviews on all. My battery was $116.99 at the local Advanced Auto Parts - my 10% military discount. Needless to say I'm very pleased and my ride is running strong. You can see I have the HTP 3" with plenty of room for a 4"
deadlandxtreme likes this.
2013 Mazdaspeed 3:
Performance: Autotech Internals // COBB AP // COBB TIP // Cobb Intake & Air Box // COBB FMIC // UR Catted DP V1 // UR CBE // UR Testpipe // Go Fast Bits BPV // Stratified ECBS 2-Port Mode // NGK One Step Colder Plugs // JBR Coolant Bypass Kit // Rotella T6 5w-40 // CP-e Stage RMM // Cp-e PMM // CS Shifrer Plate // Sure Shift Anchors // Redline Plus Hood Struts
VD: 304hp / 333tq Stage 2 91 Octane Freek Tune
GreyGhost is offline   Reply With Quote
The Following 8 Users Say Thank You to GreyGhost For This Useful Post:
cymen (03-10-2013), deadlandxtreme (03-11-2013), Hush (03-10-2013), impossible (12-05-2013), Koke382 (03-10-2013), Menace1 (03-10-2013), smoogs12 (03-10-2013), TiGraySpeed6 (03-11-2013)
 Old 03-10-2013, 02:37 PM   #2
Menace1's Avatar
Posts: 946   (View Stats)
Menace1 is the leader of the worldMenace1 is the leader of the worldMenace1 is the leader of the worldMenace1 is the leader of the worldMenace1 is the leader of the worldMenace1 is the leader of the worldMenace1 is the leader of the worldMenace1 is the leader of the worldMenace1 is the leader of the worldMenace1 is the leader of the worldMenace1 is the leader of the world
Groaned at 40 Times in 21 Posts
Nice setup. Sometimes the cheaper way is the best or better way In this category. I like it sir.
2012 MS3 / Cobb AP/ JBR / STRATIFIED Stage 1 Tuned / Stock K04 / CPE HPFP / Maisonvi Heavy Shift Knob / JBR Powerpath Intake / JBR TIP / JBR BT / JBR BVH / JBR 88D RMM /
FOR NOW...
Menace1 is offline   Reply With Quote
 Old 03-10-2013, 03:05 PM   #3
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
I really need to start giving HTP my money.
"Exclusivity" - CP-enis
Demodded.
The Seals
cymen (03-10-2013), MSFer87 (03-10-2013), rfinkle2 (03-10-2013), TiGraySpeed6 (03-11-2013)
 Old 03-10-2013, 03:08 PM   #4
08cosmic3's Avatar
Posts: 2,920   (View Stats)
I'm going to get their intake and tray when I upgrade to the BNR.
The Following 2 Users Say Thank You to 08cosmic3 For This Useful Post:
rfinkle2 (03-10-2013), Tokay444 (03-10-2013)
 Old 03-10-2013, 03:13 PM   #5
That battery is made by Johnson Controls. I have the same battery and it has been very good to me.
I don't drive my car much and unfortunately forget to leave my trickle charger plugged in, and have had it go totally dead 3-4 times and it still takes a full charge and starts the car with ease.
Oh.. and of course, the HTP tray is a great way to free up some much needed space in the intake / tip area.
 Old 03-10-2013, 03:33 PM   #6
GreyGhost's Avatar
Thanks fellas! I did it to make more room for when I install a BNR S3 soon. So tired of destroying my hands, gloves are like condoms you lose sensation so I don't bother!
2013 Mazdaspeed 3:
The Following 3 Users Say Thank You to GreyGhost For This Useful Post:
DSIT995 (03-10-2013), Menace1 (03-10-2013), rfinkle2 (03-10-2013)
 Old 03-11-2013, 10:11 PM   #7
MZRSPEED's Avatar
Posts: 550   (View Stats)
Was there a noticeable weight difference between the two batteries?
 Old 03-10-2013, 07:30 PM   #8
Tokay444's Avatar
Groans: 793
What are condoms?
Demodded.
The Seals
rfinkle2 (03-11-2013)
 Old 03-10-2013, 09:01 PM   #9
blackms3_71's Avatar
Posts: 2,250   (View Stats)
makes the 3" look small in there lol
 Old 03-11-2013, 09:28 AM   #10
Zbrit00x's Avatar
Posts: 541   (View Stats)
If some of you guys running a smaller battery can do me a favor.. After not driving the car for a day or so plug the ap in and put in the key on position. Go to the screen that displays bat volt and then start the car. If you could take note of the voltage before starting and the lowest observed voltage once you crank and car starts that would be real helpful. I'm trying to check a few things out with my smaller battery now that I have a sub and amp in here.
2010 ms3-sold
ww evo x -385/360
Zbrit00x is offline   Reply With Quote
 Old 03-11-2013, 11:00 AM   #11
I think it will be in the 12.2v area and after immediately shutting down around 12.5v.
 Old 03-11-2013, 11:20 AM   #12
i also have a nice system in my car and was worried about using the smaller battery
 Old 03-11-2013, 03:24 PM   #13
Zbrit00x's Avatar
Mine was 12.1 overnight and 9.7 crank
I had an issue where my battery discharged last week. I found a tiny copper strand stuck between the remote line and power on the amp. Pretty sure that's what discharged it but I also wanted to compare various loads on startup. So far someone else who has a stock sized battery has had similar numbers as me
2010 ms3-sold
ww evo x -385/360
 Old 03-11-2013, 10:44 PM   #14
This is for the MS6:
Stock battery + tray is 38.4 lbs.
Braille 2015 + HTP tray is 16 lbs.
MZRSPEED (03-12-2013)
JBR 3.5 WidePath + HTP tray + 51r battery Dano MazdaSpeed 3 - How-To's 48 08-10-2017 06:16 PM
Battery Tray HTP HTP (Hi-Tuned Performance) 196 05-26-2013 03:43 PM
MS6 Small Battery Tray HTP HTP (Hi-Tuned Performance) 21 01-16-2013 07:15 PM
MS6 Battery Tray Release HTP HTP (Hi-Tuned Performance) 28 09-30-2012 02:54 AM
Battery Tray DJBY 2010 MS3 - Engine, Transmission & Driveline 4 08-23-2011 06:10 PM
Page generated in 0.35027 seconds with 29 queries
